Mercedes-Benz E-Class Maintenance and Repair
1235723
  • microrepairmicrorepair Member Posts: 508
    It hasn't happened on my E320 yet, but on at least two other cars I've owned there were similar situations that turned out to be leaves or pine needles that got into the air intake cowling and got trapped in the passageways and vents. In one case it caused ice particles to spit out of the vents when running the AC because it was clogging up the condenser unit. If you park under or near trees, you may want to check it out.
  • roadrunningroadrunning Member Posts: 7
    Diesel noise means you need new updated engine mounts. For Audio/Teleaid problems ask for a copy of the software versions of your audio, instrument cluster, and communications modules, and a bulletin stating the most up-to-date software versions! If they can't deliver these then find a new dealership for service!
  • rockymtnhigh1rockymtnhigh1 Member Posts: 2
    Reading this message board really hits home! I was one of the people who bought a E500, paid full price,waited 4 months for delivery (early October)and now have had nothing but problems with the car. I have had the car in the shop 7 times and will be taking it in tomorrow for a total of 8. All the same electrical problems I have been reading about in these posts. Mercedes is telling me there is nothing they can do, ("that's what a warranty is for!!!"). I expected so much more. My next car will be a Lexus.
  • benzdriverbenzdriver Member Posts: 1
    Is there anyone out there who owns a 2003 E320, and the car steers to the right, and also gets poor gas mileage? I would appreciate any info sent to me at sn654321@aol.com
  • sfvassfvas Member Posts: 10
    I'm actually taking it back to dealer to get it checked out in a few days. I think the intake on the E320 vents have a filter, so the leaves should not be the problem. The service guy said it could be a fan regulator control unit or a million other things.
  • 2002camry12002camry1 Member Posts: 2
    Please see web site www/Mercedesshop.com for information regarding premature crankshaft balancer failure and cost big money.
    Refer to SHOP FORUM heading and go to Tech Help-crankshaft balancer failure must read.
    Please report to NHTSA for complains.
  • cbgb1975cbgb1975 Member Posts: 51
    radio on e320 sometimes starts to scan at random while listening to radio. Any ideas on problem and cure? Thanks
  • ncvolncvol Member Posts: 196
    I read a post on another site from an E320 owner who said that he drove through a deep puddle, and it shut down the engine. According to him, the dealer told him that there is some kind of air intake at the front of the vehicle (paraphrasing here, I'm not great with automotive lingo) that is known to suck water up into the engine even when you're not fording a stream or something like that.
    Has anyone ever heard of this?
  • jg69jg69 Member Posts: 2
    After 4 visits to the shop spanning at least a week overall, they seem to have fixed my keyless go system. They had to replace all the various antennas and sychronize the remotes. They also replaced the "gateway" whatever that is. They did have to replace my rear brake pads after a mere 17k miles. Has anyone else had problems with excessive rear brake wear?
  • tipster42tipster42 Member Posts: 3
    Just got my e320 back from the dealership after 6 days in the shop. My complaints were:
    1. Loud vibration from the brake pump. First I was told this sound was normal. After my insistence that this noise (incessant every time I released the brake pedal)was obviously not even remotely within the range of normal even for a new type of brake system, I got results. A new pump, several new lines and some kind of dampening were installed and the brakes now sound fine. A minimal rumble is all I hear. I can be more specific on what was done if there is interest.
    2. My wife, whose hearing on the high frequencies is better than mine, complained of a high pitched whistle when the brakes were applied. On a test drive the shop foreman also heard the noise, said there was a service bulletin about that and applied the fix.
    So far 2 for 2
    3. After the first 500 miles, my engine began to sound like a cross between diesel and a sowing machine at idle and low revs. After listening to several other e320's at the dealership, we are convinced that our car is louder than the others we've heard. The dealership says the car sounds normal, but has agreed to bring the matter up with a MB rep next week.
    My experience with MB factory reps has been positive in the past. My 2000 e320 was running rough, and after several weeks of diagnosis, they replaced my engine and reimbursed me for the equivalent of month's lease payment. So we'll see.
    After this long winded intro, My question is this:
    Has anyone else experienced this loud ticking noise from the e320 engine, and what fix if any is out there.
    I posted this messagee on another board, but it might be more appropriate here.
    So far 2 for 2
    CROSSCW--The wiper chatter is probably happening because the wiper blade in not aligned properly in the perpendicular to the windshield...in other words, the "angle of attack" of the rubber blade tip is wrong. So the problem is in the steel arm that holds the blade, not the blade itself.
    NCVOL---this is called "hydro-lock" and any car that is driven too rapidly through a pile of water, even a puddle that isn't all that deep, can suffer this. Cars are not submarines and when you see those TV commercials with SUVS crashing through creeks or luxury cars thrashing through rainstorms and pushing up waves of water, you should protest to the ad agency, because they are inviting disaster. This is why the ads always say, in microscopic letters "professional driver on closed course. Do not attempt these maneuvers".
    The only sure preventative for this would be a snorkel that sucks in air for the engine from the very top of the car's roof---not a pretty sight on a Benz!
    A few cars are somewhat notorious for hydro-lock, such as the pretty little 280SLs of the early 1970s. The air intake is way too low on those cars.
  • tkingsleytkingsley Member Posts: 1
    The issue for me is how to even get close to the 16 city mpg that is advertised?! I drive like "an ol' lady" not using/enjoying the V8 and I still best 10 to 12 mpg on city? Anyone else had this experience - the dealer tells me to keep on running in the motor...?
    I have had my car since May 2003 and wish I had known of this site before I (foolishly) purchased this car based on the bad reliability reports I see from you fellow owners. Although I have only got 2500 miles on the car I have not had any bad luck of note other than less then excellent workmanship on fit & finish.
    I have not had any problems with mileage. In fact around the city the car is consistently above 16 mpg and on the highway is runs around 25 mpg. Of course I have an E500. I would think that the e320 would get even better mileage? Maybe the V8 is more efficient.
  • sassycarsassycar Member Posts: 2
    We're contemplating shipping our '95 E320 cabriolet to London to may parents' house. Can anyone recommend a shipping service for overseas? Car will be shipped from Los Angeles. The last time we shipped a car the radio and other items were stolen, and the E320 is in immaculate condition (only 25K miles) with all the accessories. Any suggestions?
  • mynextcarmynextcar Member Posts: 30
    I am experiecing the same loud sound from my 2002 E320 started a couple weeks ago. It happens after I drive a while and when the car is in the first gear (less than 10 mph) and the moment I release accel padel. Does any other 2002 E owner experience the same problem?
    Thanks Mr. Shiftright. I knew that you can't get engines wet, but from the tone of the post I had read, it made it sound like the E-Class had something peculiar about it that made it extra-susceptible.
  • cduongcduong Member Posts: 70
    What is the required interval for trans. fluid change? every 30K or 60K? Your input please.Thanks
  • richgeorichgeo Member Posts: 2
    Just recently I have been hearing a moaning/droning/rumbling sound when I brake at very low speeds, 5 to 10 mph. It stops soon before I come to a full stop. No squeaking. Took it to the dealer today and they said it is nominal and normal. Right... It is very annoying. HELP!
  • allygallyg Member Posts: 18
    I have had my 2003 E320 for over a month now and with only 500 miles on it. I have already experienced some problems. First the headlights were not angled right. I couldn't see anything when driving at night. The car was in the shop for two days for that. Today I noticed that my passenger site doesn't have warm air. It only blows cold air no matter how low the temperature is in the car! The driver side is fine. Now it has to go back to the dealer again. Also I have noticed the louder than expected rumbling of brakes, especially when I am backing my car out of my garage. I am going to have that checked out while the car is in the shop. I will let everybody know how it goes. Now I am seriously considering the extended warranty.
  • mbbuyer123mbbuyer123 Member Posts: 5
    I am thinking of buying a '04 E320; does anyone know if MB has corrected the electrical and other problems that I read about in the '03 model? I emailed MBUSA but have not heard from them. Any information would be greatly appreciated
  • q45manq45man Member Posts: 416
    Required interval to maintain warranty and OPTIMUM interval to maximize life into the 200,000 mile range is quite different!
    Most ATF has color sensitive organic dyes, which fade under excessive temperatures [when they exceed the 176F optimum operating temperature.
    When the color changes the product is degrading. Simple to see!
  • buster6buster6 Member Posts: 134
    I am having the same concerns as you. In looking at the other boards, it seems that a lot of MB models are having the same problems as the E. I have a friend who bought a ML (traded in a 4 year old Grand Am), he has had the MB in the shop more in 6 months than the Grand Am was in 4 years. I am looking on the 5 series boards, and finding that some new 04 owners are experiencing electrical problems as well. Let me know what you decide, and if you do pull the trigger how things go in your new E.
  • merrelmerrel Member Posts: 45
    I have a 2003 E320 and 3 things all stopped at once, controlled by one chip. Auto headight on & off, LED radio screen not changing from backround white to backround black and rain sensor wipers. R/R at 15k miles. Everything is fine now. Still average
    33 mpg hwy w/ac on.
  • 1alex1alex Member Posts: 1
    Four thousand miles.
    1 Car vibrates and moans when depressing brake pedal-Been in for service five times-cause the SBC pump on the brake system-replaced pump,bracket , bushings , somewhat better still not what to expect from a luxury car
    2 Metallic chunk going over rough road surface- fixed by replacing front arm struts
    Mercedes aware of both problems -bad engineering
    ..just want to give everyone a heads up about some changes taking place in an effort to organize and make it easier for members to find the most appropriate discussion for their question/comment.
    This discussion will soon be combined with the "Mercedes-Benz E-Class Owners: Problems & Solutions", which resides in the Mercedes-Benz E-Class Owners Club. However, the combined topics will also appear here in M&R. If you are subscribed to this discussion, you will need to re-subscribe when the change takes place.
    If you have any questions/concerns, please address them to me in email, karen@edmunds.com.
  • carnaughtcarnaught Member Posts: 3,605
    After a trip to my friendly MB service dept.,I now have a fix for the 2003 E brake squeak. This problem is worse when the car is cold and best heard inside the car as a "poik". Let me know if you need the info.
  • zster1zster1 Member Posts: 6
    Any news on when the diesel will be offered, perhaps next summer ? What about mileage estimates, pricing, performance etc /
  • letdownbymbletdownbymb Member Posts: 8
    Ever since I drove out of the showroom, my 2003 E Class pulls to the right. After two visits to the dealer (who kept saying the car was "within factory specs" and that the pulling was "acceptable"), a factory technician looked at it and agreed it wasn't. They won't give details, but apparently it has to do with the suspension. The shop manager says they could fine-tune suspensions in older models, but that the new Es come with fixed suspensions. At this point I'm waiting for them to get a special tool from the factory to fix the problem.
    My E also makes the same squealing noise when I apply the brakes, but I've noticed it won't make it for the first 15-20 minutes after I start the car. I'm saving this complaint for my FOURTH visit to the dealer to the get the car aligned.
    Finally, the dashboard keeps flashing a message that one of my parking lights is out, when it isn't. I'm terrified this is the beginning of the electrical problems mentioned by other owners.
    I hadn't seen car quality this poor since the 1987 Hyundai I owned in my college days. Wish I could turn the clock back and have my Honda Legend back. This car is all looks -- lesson learned... stick with Japanese cars.
    Carnaught, what was causing the noise? my 2003 E makes it too and I'm about to take it to the dealer to have it fixed. Thanks!
    was fixed by "replacing the BOU" and "bleeding the hydaulic brake system"...work order also says "erased DTC,S"...Service codes are 421640, 421641, 421354, and 420653.
    At any rate, seems to have taken care of the annoying but not serious problem, at least for now :o).
    Thanks. I'll have them look up those service codes. Does your E also pull to the right like mine does?
    Your welcome, no problem. No, my E doesn't pull to the right (or left for that matter).
  • nelsonr1nelsonr1 Member Posts: 2
  • wesbarneswesbarnes Member Posts: 13
    My 2003 E320 has approximately 500 miles on it but it has a thumping noise near the gas cap when the engine is running and I am at a stop. Dealer has replaced the charcoal cannister and the relay and says it is operating as designed. They now are going to attempt to put sound proofing around the cannister. The noise can be heard over the air conditioner blower and is irritating. Any one else have this problem? If so, what was done to fix it?
  • 320jeff320jeff Member Posts: 1
    I recently had an overnight test drive for a 2004 E-320 sport. I loved everything about the car and was looking forward to purchasing it. On the way back to the dealership the next day I had a total brake failure. Cruising down the highway at 60 MPH all of a sudden alarms started to go off "Stop vehicle, Brake Malfunction" was displayed in the speedometer dial. When I pushed on the brakes, the pedal did not move. There was no braking power. Slowly I coasted to a stop on the shoulder of the highway. After turning the car off and waiting 5 minutes the alarms went off. The speedometer dial now displayed "2 malfunctions". After another 5 Min, I scrolled through the computer menu on the steering wheel and it displayed "ABS Malfunction and ESP Malfunction". As I continued to scroll, the display returned to normal. It seemed the computer had reset itself. I started the car and the brakes were working again. I tested it on the shoulder and it seemed okay. I decided to cautiously continue to drive the car back to the dealership, since I was stuck in the middle of nowhere on the shoulder. Not a safe place to be. But 20 mins later while on the freeway the same malfunction happened again, NO Brakes once more. I took the exit off the freeway and coasted to a stop. Luckily the exit was an incline and so I was able to stop safely. The car had to be towed to the dealership.
    The service manager at the dealership said it was a bad sensor. But I can not find out why this would cause a total brake failure. Apparently, the car is designed to have a back-up brake system, but they don't know how the system works or is designed and why the back-up system did not work. I'm wondering if this problem is a design flaw or just a fluke? If anyone has any ideas, I would be extremely thankful. So far I have not been successful getting any information from Mercedes on why the back-up brake system failed, or why in the first place a bad sensor shut down the brakes. It is a serious safety issue to not have any brakes, and to be told that it is not supposed to happen or it has not been designed that way just does not cut it. Thanks for any help.
  • w210w210 Member Posts: 188
    And the service manager you talked to?
  • tedsmith2tedsmith2 Member Posts: 1
    I've had my '01 E for about a month now;I bought it out of state and did a rather cursory test drive, also have an '01 Ml, and have driven E class cars before; with that said. The 250m drive back home was a nightmare!
    The problem was not evident until I got up to 65-70mph. The car can be sent from side to side with the littlest bump or gust of wind and the steering does not seem to give warning or movement. I have had the car thoroughly tested by independent shop they say it is fine, but I think the car is dangerous. I have owned a lot of cars in a lot of price ranges and NONE have been this unstable at speed.
    Love the ride around town, as this was pretty much the test drive with quick highway ride.
    I can not believe that this is normal I have driven too many cars to accept that. Any suggestions of what to look for or tell the shop to look for?
  • pissed1pissed1 Member Posts: 3
    I HAVE A LOUD TICKING IN MY ENGINE BETWEEN 1000&2500 RPM IT SOUNDS LIKE A DIESEL. THE DEALER SAID IT COULD BE AN EGR VALVE,THEN A MOTOR MOUNT. NOW THEY TELL ME IT IS NORMAL. NO ONE CAN TELL ME WHAT IT IS MAKING THE NOISE.IF YOU HAVE HAD OR HAVE THIS NOISE PLEASE POST WHAT SUCCESS YOU HAV HAD SOLVING THIS PROBLEM
  • eclass28eclass28 Member Posts: 1
    Hopefully somebody can help me shed some light on this problem. I have a 1993 E300 2.8, I have had the car at the dealer, had 2 Mercedes mechanics look at it outside of the dealer and no one knows what the problem is.
    The car runs extremely rich and cannot find the idle. To try to remedy this, we have tried a new mass air flow sensor, throttle body, new coils, new spark plugs, a brand new wiring harness for the computer. The cars runs fine when it is cold, but when it warms up the engine cannot find the idle, and when you push the accelerator the car seems like it is going to stall. Once the cars gets past 2000rpm it runs fine.
    Does anybody have any suggestions on what the problem(s) might be? Thank you.
  • cloto1cloto1 Member Posts: 1
    I have the same problem with a '97 E320. Bought out of town and on the way home wound it up a bit. Very little tracking control. Brought back to dealer and they said all was okay. I am sure they did not test drive it. I took car up to 100 and then released gas - all over the place when the power came off. Shocks are good, alignment is good, tire pressure is good. Anyone else have any ideas?
  • glennd1glennd1 Member Posts: 1
    Own a '97 E with 118K miles. The front spring perches have just collapsed due to excessive rust. There is also excessive rust to the frame rails which are also being replace. We are lucky the car did not collapse while underway or in an accident. MB is going to repair the car at their cost ($7,500 retailk - I'm told) - I guess that is preferable to the lawsuit that would come from the survivor of the inevitable total suspension collapse . I sincerely doubt my E is the only one afflicated with this problem - so BEWARE. So much for MBZ. It's my last one. That's a pitty, cuz the car was wonderful to drive. I would have expected more from a YUGO!
  • chensel2chensel2 Member Posts: 1
    I also own a 1997 E320 and have experienced similar steering and stability problems. The car's drive line was easily put off course by lumps and bumps in the road. Changing lanes quickly caused the car to oscillate back and forth a bit. However, after replacing my Michelin Energy MXV4 Plus tires with a set of Michelin Pilot Alpin tires the problems disappeared. The Pilot Alpin tires probably have more rigid sidewalls. Tire pressure is set to the "heavy load" pressure. Sitting too far back from the steering wheel with arms completely stretched did not work well for me either. Sitting a little closer gives better control.
  • mzakmzak Member Posts: 1
    Pissed1, I too have noticed the "diesel sound" of my wife's new E320. However, the sound lessens considerably once the car has run about 20 minutes. My dealer says it sounds like a normal V-6 to them. Not buying it. This car should not be making this much engine noise. Does anyone else think their engine is noisey?
  • rashidirashidi Member Posts: 18
    we have a e500 and i find a similar anoyance with the "diesel sound" coming from the engine. the capable mechanic fixed all 8 of my service problems listed, however, said that the car runs "lean" and the noise and idle was normal.
    I THINK I HAVE HAD MY PROBLEM SOLVED M.B. REPLACED MY MOTOR MOUNTS YESTERDAY. A SERVICE BULLITEN CAME OUT IN JULY STATING IF A CUSTOMER COMPLAINS ABOUT DIESELING AT 1000RPM TO 25OORPM REPLACE MOTOR MOUNTS. M.B. LIED TO ME SAYING IT WAS NORMAL B.S. HAVE ONLY DRIVEN MY E320 A COUPLE OF TIMES SINCE THE REPAIR BUT SO FAR NO DIESELING NOISE. THIS IS THE NEW PART #211-240-05-17. I HOPE THIS IS A PERMANENT FIX DONT TAKE NO FOR AN ANGER M.B. JUST WANTS YOU TO GO AWAY, IT TOOK ME 12MONTHS TO GET THEM TO ADMIT A PROBLEM. GOOD LUCK TO ALL.
  • ahmadmahmadm Member Posts: 15
    Dear MB Owners:
    I have been having problems with the windshield defogger. I live in Maryland and in low outside temperatures if I turn the climate control ON, all of the windows, windshield and rear included, get badly fogged up. The moisture sometimes is so heavy that I have to stop and hand wipe it. This only happens in low temperatures outside. Keeping the system ON removes very little moisture. I took the car to the dealer and they traced the problem to faulty wiring on the AC compressor. Guess what, it is hitting freezing temperatures again and the problem is back. Any insights into what may be the issue here? Thanks a bunch.
  • gumigumi Member Posts: 1
    Just bought 04 E320. The valet parking key does not work as the way it supposes to be. You suppose can use the valet key to lock the trunk and remote can't open it. But this does not work. The technichan at dealer said he tried on all other 04 models, and all act the same way. Is this true? I can't believe this.
  • ong2000ong2000 Member Posts: 19
    I just got the 04/E320 a couple days ago.
    We got 2 keys, but no valet parking key, the sales man said that Mercedes Benz doesn't make the valet parking key anymore. Is it true?? Did he lie ?
    But then later on, he said that he is going to order for us another extra key, the same keys as the other 2 keys. For free. But not the valet parking key.
