Visitor Agreement.
When an engine goes on the highway, the rpms are just over idle, and the engine runs cool. There is not accelerating to build extra heat.
When driving in the city, on average, the rpm is much higher, as you acceerate and change gears, plus, the engine needs to work harder accerate the weight of the car. Also, since you are generally moving slower at a higher rpm, the engine will build up more heat.
The two elements that wears out oil and filters is heat and dirt. As stated above, city driving generates more heat. If you drive for 1 hour with a 2 liter engine in the Hwy, you will pass 180,000 liters of air and dirt through your motor. If you drive in the city you will pass 360,000 liters of air and dirt through your engine:
City: (60min/1hr) x 1500rpm x 2.0l = 180,000l/hr
Hwy: (60min/1hr) x 3000rpm x 2.0l = 360,000l/hr
That means for that same hour of driving, you are passing twice as much air and dirt through your motor.
I drive a lot of highway and the intervals are like 4800 for my light.
Hell yes highway is less work on the engine and oil.
- Tim
Short answer is I don't know why the schedule should be accelerated. Obviously it makes sense to change air filters more frequently - maybe manufacturers are just after easy money on more regular servicing (surely not). I have never seen a manual that differentiates between frequency of air filters in certain climates - always the frequency of the complete service.
Would you elaborate more on the "new engine" bit and your usual driving habits? What you're saying is very interesting! What are the symptoms that led you down the path to "new engine"? Did you burn much oil? Do you do a lot of short runs? (2-3 miles) Was there another failure that precipitated the need for the new engine? It seems that anything above a Yugo should go 190K w/o needing to be replaced.
Rich
BTW
I just heard that the Yugo factory in Kosovo was bombed during the hostilities. I guess that we'll never see another new Yugo. Sob, sob :-)
Let us all know "when" your truck starts throwing parts through the hood.
"You read it!!??....Must be True!!"
- Tim
Waste of money.
I put Slick 50 in an 88 GrandAm back in '90. Car never ran right after that. Think about it. #1, if it was that good a product, it would be treated with it from the start. #2 Since when is a good thing to have even micron sized particles of a solid like teflon to be floating around in your oil? All that crap about how the teflon "bonds" to engine parts. Get real. It is not possible for teflon to "bond" with engine parts...period!
#3 Again, if it is all that great, why do you have to treat your engine with it after so many miles of use? If the teflon bonded with the engine parts, it would be permanent.
Waste your money if you want. Any benefit you see in the product is placebo. Ever wondered why you never see ANY snake oil products at the race track? If any car could benenfit from such a product with its so called protective properties, it would be at the race track. Race car mechanics know that this stuff is a hoax and if anything will do more harm than good. I have never seen any reputable mechanic, race car driver, or reputable mechanical manufacturer promote these snake oil products other than their own people. With all the money that could be had from sponsorship, if they believed in the product, they would promote it. They don't, plain and simple.
You are correct to a point about why snake oils are not at the track. 1. They rebuild so often 2. They don't want all the crud that builds up from oil additives. 3. it doesn't add any benefit.
If slick 50 reduced friction like they say, every Nascar racing today would be buying it by the 50 gal drum.
Slick 50 is a decent product, one of the few additives I will use. It is not a cure for a bad engine, but if used every 50-60k miles, it will help an engine last longer, which is all it needs to do.
You may think I am sipping too much suds, but you are the sucker. I can at least get a good laugh out of all you snake oil users' stories!
A friend of mine does oil and fuel analysis for GM. Verifiably you are wasting your money. If you ever have a warranty repair and oil is questioned, he will tell you first hand that your oil "IS" sampled. If any trace of snake oil is found in your oil (and it is easy to tell), you AND your warranty will be sent packing. Seen it many many times. Good luck on that high dollar bottle of placebo.
LOL!
I don't think it was "the mistake of a life-time" but I can't say that it really changed performance, etc.
I never found teflon in any motor oil I have ever seen. Any oil that contains anything a cheesy additive has in it, isn't worth the container it is distributed in.
You can't "teach" me anything about oil. I happen to be an Amsoil Rep and know a thing or two about oil. All the parafins and other waxes, etc that most oil companies use in their oil is crap! If you want better protection for your vehicle, you would educate yourself on the harm that "additives" produce in your engine. It is obvious you know nothing about the lubrication business.
Your comments tell me that you heard from a friend of a friend that Slick 50 was a great product.
Do yourself a favor and educate yourself on lubrication products and its properties. For instance, Amsoil's fluidity rating (it's ability to remain fluid)is guaranteed to -40 degrees. Stick a bottle of Slick 50 in a chiller down to even +10 degrees and it starts to gel up and thicken to the point it would cause damage to an engine.
No thanks. The laugh is still on you and your buddies that "know it all". Let me know how long it takes you to clean all the sludge out of your engine block when your engine prematurely smokes from excessive blow by and starts to run sluggish.
Some people just won't learn the easy way!
Good luck. This is the last response to you I care to make. If you had any valid points to make, I would continue to debate, but it is obvious you don't have any facts to provide. Throw me some facts. I would love to prove you wrong.
Why would that have been I wonder!
So long bud_lite_dude, budlitedude, bud@lite@dude, bud*lite*dude, bud__lite__dude !!
Older engines that are starting to get a lot of blow by or seepage past the rings can benefit from a thicker oil like 20w50. The thicker oil helps compensate for the looser tolerances.
BTW: I am not going anywhere.
Brand new sports cars and high end vehicles come straight from the factory with Synthetic oil. The only reason they all don't is $$. Saves the manuf. tons if they can put the vehicle out the door with the regular conventional oil.
You will have much better heat resistance and dissipation, better vescosity indexes, and more stable volitity (weight loss). The API rating is much higher. The API rating is what is used to rate the efficiency and wear protection of ANY oil. Higher API ratings (Amsoil was the first to have an API rated synthetic oil) also mean saving fuel due to the higher efficiency.
As far as the differential lube, this is more crucial than even the motor oil. Transmissions and gearboxes have way more heat built up in them than engine motor oil, especially when towing or downshifting often, or in 4X4 operation.
Lubricants like Mobil1 are excellent products in the lines of lubricants readily available in most Discount store chains, and for most people and driving conditions, will be more than sufficient.
However, with those lubes, they don't have near the longevity of protective properties as Amsoil and you must change them much more frequently to get the same protective benefits from them.
As with any lube though, the lube collects carbon blow by and dirt from use. If you use the Amsoil products with their extended drain intervals, you will still need to change the filter with a quality filter at the same intervals you would with any comparable lube (engine and transmission).
With the Amsoil 2000 0W30 engine oil, drain intervals are 1 year or 35,000 miles with a filter only change 1/2 way in between.
Amsoil and Mobil1 are very close in price so the extended drain interval Amsoil provides, even with a filter change in between, will save you money and provide the best lubrication money can buy.
I have used Redline and other oils similar to Amsoil. I stay with Amsoil simply because if you look at all the properties (oil sample analysis proves), Amsoil is just plain better. I could just as easily become a Redline distributor or not at all. I really do not make much money off of selling Amsoil. I remain a dealer primarily because I believe in the product and can get it for my personal use much cheaper if I am a dealer.
Try it for yourself. Only you can determine if it is right for you. I strongly suggest though that you do not buy into the snake oil crap. There has never been an oil additive made that was ever worth the container it is distributed in.
Any reputable and informed person will agree with that.
You may see an increase, but I wouln't count on a huge one. If you are already using Mobil1 and changing every 7.500 miles or less, you will probably not see much of a gain in mpg. I switched from Mobil1 to Amsoil in my wifes GrandAm and saw a slight increase in mpg (may have been placebo affect thought). What I really noticed was a much smoother idle and acceleration.
Made a world of difference in the driveability of the car. Another thing I noticed is that my oil stays golden looking much longer than it did with Mobil1. Nothing scientific as to why, just my perception.
You won't go wrong with Amsoil. It may be overkill for a lot of people, but if you are as hard on your truck as I am mine, it pays for itself very quickly. You would be absolutely amazed at how many over-the-road trucking companies use Amsoil in their tractor trailer rigs. Diesels are the worst on oil of any truck and Amsoil is proven to last up to 12 times longer than other synthetics for diesel applications.
Glad to see we can converse about something civilly. I don't know everything as you implied in previous posts, but I have been around the block a few times and I do have vast experience in a lot of diverse areas. I am not an oil expert, but I have done a lot of researching and now through Amsoil, I am certified to sell Amsoil lubricants. If there is something particular that I don't know, I have contacts to many Chemical Engineers that do.
I guess its just that neither of us take sh**t from others and I dont know when to shut up.
I would say that for all around use, 5W30 is a very good weight to use. If I were up in the Northern states, I would not use anything but 0W30 during the Winter months.
Your truck will probably come with synthetic oil. look in the owners manual. for your climate, I would suggest 10W30, as long as it says its OK to in the owners manual.
The reason oil turns from golden to black color is carbon. has nothing to do with the quality of the oil. different brands of oil darken quicker than others because they are naturally darker. Kendall is naturally much lighter in color than Delo. Delo darkens faster but that doesn't mean anything. Carbon in oil doesn't mean anything. its the break down of polymers that mean something.
the reason big rigs are hard on their oils is because of the high temps and heat flow in the diesels. they also carbon up worse than gas, so the oil will get blacker. but, like i said, not related to quality.
this topic is being "frozen." It will be archived or deleted in the next 10 days or so.
Front Porch Philosopher
