A reporter would like to speak with you about your experience; please reach out to PR@Edmunds.com by 7/25 for details.
Slick 50 and Synthetics
For years I've used Slick 50. Back before it was
$15 a bottle..I got it from mail order in the back
of car mags for about $60 a quart? Has it
helped?..I don't know. I can say I've had no major
engine problems in any of the cars I've driven
hard..(which is all of them)
I have a 2000 3/4 6.0 Silverado and it's got about
700 miles and ready for the first Oil change.
I've never used Synthetic..and will be using Mobil
1 5-30. Should I still use the slick 50? I
suppose i could look up slick 50's web site or
somewhere else....but I have had fun getting
answers here.
Lemme here what you have to say.
Any conflicts with synthetic and this product?
Any input would be great.
- Tim
answers here.
- Tim
I think you have been successful in spite of your use of Slick 50.
And the way I make my living is as a PTFE process engineer for implantable medical products.....
I'd run 10W-30 Mobil 1 if you live where it is warm......
I'd also wait until another oil change, and run conventional until then.
Wait for what?....Slick 50 or synthetic?...and what's your theory?
I know we have duked it out in past topics...perhaps we can get along here?..LOL!
- Tim
I was told initially not to switch to Mobil 1 until after rings set completely. I believe in it and will use it in my 2000 Sierra after the second oil change. I read an article shortly after it first became available in which Mobil 1 was compared to conventional oils. The oil remained cleaner longer and wear was less.
If anything, teflon additives kill your oil filter life and in turn causes real damage to your engine. Being a motorcycle enthuist as well as a slack-jawed roofer, ANY cycle mag will bash any additive. The teflon clogs the filter and in turn allows the debris to continue to flow in the engine. Notice how Slick 50 has backed off it's guarantees? Most manufactuers recommend against that type of additive. I'll trust Ford,GM,Honda and Harley before the snake charmers in CA selling sLICK 50.
I've heard to wait for the rings to seat...but wouldn't ya think at 750 they be seated by now?
So I should hold off on the Mobil 1 until about 4000?.....doesn't seem right. Vette's come with it from day one?
Anybody else have 2 cents?....I'll even take your 1 cents.
Thanks for all so far.
- Tim
Most new vehicles come with a high chrome content rings. These can take as much as 25,000 to seat in. I would wait until your oil consumption is drastically reduced between changes before using the Mobil 1.
Rich
It's not using any now?
Almost 800 and still no first oil change yet...we shall see what I decide. Probably skip first change with it...but perhaps after.
- Tim
When I was dreaming of the corvette the choice was easy, redline oil through out the car. On a truck I'm thinking Mobel 1 is good enough. What do you think?
Automatic transmission, did anyone change out the fluid after breakin. I was thinking about having them pump it out, but I don't know if I want to drop the pan on a new truck.
What are people using in the rear dif?
Mike
P.S. SLick 50, I used it in my second car and the engine oil pump went out at 100,000 miles. From what I have read Dupont tried to NOT sale it's teflon to Slick 50, but Slick 50 took them to court. Dupont still says that teflon should not be used inside engines. I also read a report about Prolong which said it worked great, BUT if your engine parts were exposed to air (i.e., when you stop your engine and let all the oil drain into the pan) they would start rusting at a lot faster rate. Conclusions, what may be good for racers may not be good for Joe Public.
Anybody else got a theory?
- Tim
BS on the break it in the way you intend to drive it. Spend the first 1000 miles doing low power city driving.
While I make my living understanding how to make PTFE (teflon and other brands) into salable products, I can't imagine the value of using it in an internal combustion engine except maybe as a piston skirt coating.
I try to baby my new race bikes (come with teflon coated piston skirts) for the first tank or two, then gradually hammer on it more and more until it is fully broken in.
mfreeman - I wouldn't worry about changing fluid, the new DexIII/Mercon stuff is almost as good as Mobil 1's old synthetic ATF. If I were to change, I would certainly drop the pan and change the filter. In fact, would rather change the filter and reuse the ATF give the choice. I have dropped many tranny pans and never had leak problems......
I stayed under 55 for the first 500...then hit the highway for about 120 miles at about 70-75. I've been driving highway/city..going about 55 in city..70-75 on highway. Had it up much higher to see what it feels like...but no serious ragging. About 800 or so and ready for the first oil change. Going to skip Slick 50 and go with Conventional oil for first change. May change it at 3000 still?....We will see.
- Tim
Good memory on the DuPont battle with Slick50. All must wonder about Slick50's claim if the actual maker doubts its use in engines.
Isn't the T-Plus product made by DuPont? It's a Slick competitor.
When i go past 3000 by a thousand or 2...that's why i don't worry.
Oh well
- Tim
- Tim
Rich
Use the weight & type of oil that is recommended in your owners manual.
I have never seen an owners manual recommend 15W50 oil. This should only be used if you have a high mileage car the uses oil(rings are shot). It is not true that heavy oil does a better job of lubricating. In fact the opposite is true for todays engines.
My owners manual (99 silverado 5.3) says use 5w30 as the 1st choice, 10w30 ok if temperature above??. (It also holds 6 quarts)
The only difference between 5w30 and 10w30 will be the viscosity of the oil at cold start up. After the oil is warm they are both the same 30weight. The 5w30 does a better job at start up because it is thiner and flows easier, getting to the moving parts faster. I live in Houston and it is hotter than hell - but I still use 5w30. Most dealers in the area are 20 years behind the times - they say use 10w30 unless it is below 0 degrees. The are full of [non-permissible content removed]. The real reason they want you to use 10w30 is that is all they have in bulk and it saves them $.10 per quart.
The lower the first number on the oil weight indicates the flow when cold. I have had no problems with the van and as soon as my 99 Silverado requires an oil change in it will go.
5-quart jugs, but if they did, I would have gotten that. The winters here in northern New Mexico seldom get down below the 20's, but still the lower the viscosity at start-up the better (well, there's a limit to that, of course. It would still have to have enough viscosity to lubricate properly). Good luck!
-powerisfun
I've been using it since 1975. My first new car, a 75 Chevy Monza 262 V8 4-Speed. It flew, matter of fact it still does. I have 110K miles on it now. It's now in storage. I changed the filter every 5,000 dumping the old Mobil 1 from the old filter to the new...screw it back in. Changed the oil every 25,000 miles! Yes I have changed it four times. The motor still purrs not even a lifter tic.
This is great stuff, don't be afraid of going beyond 3,000 miles guys. Extended changes are no problem for this oil.
I use it in everything from the lawnmower to the kitchen fan.
I was sold long ago when one cold (-25F) morning I thought my car would never start. Well it cranked like it was in southern Calif.
Its really amazing stuff.
-Jim
After that many miles the oil had to be black, black black. It is not the oil that goes bad, it collects dirt & acid from normal engine operation.
Are you concerned about voiding your warranty?
Why spend $20,000 or more on a car/truck and then not spend $20 on normal maintenance?
your reasoning applies to conventional motor oils; however, synthetics require fewer viscosity improvers than conventional oils to achieve the wider viscosity profile. It's the viscosity improvers (VI) that screw things up since they do not provide any significant lubrication qualities. The synthetics remain free flowing at lower temperatures than conventional oils and can thus start out with a higher base viscosity than conventionals. This allows them to achieve a wider effective viscosity profile while actually having fewer VIs than the organic stuff.
Just my $.02
www.EliteOne.com
I'm gonna go 150 to 200K running Walmart tech2000 synth blend at $1.25 per quart. If synthetic was so superior, I would bet that the OTR diesels would be running it.
I do run synthetics in my race bikes for the reasons your list, but just don't see the value for my 10yr around town vehicles.
- Tim
I can not understand why anyone would go to the trouble of changing the oil filter and not changing the oil. I saw one post where a guy actually said he dumped the oil from the old filter into the new filter. If you really "treat your engine the best regardless of what I may get by with" as you say why not change the oil when you change your filter? Sound to me like you need to take your own advise.
The reason behind the synthetic oils is the Purity of oil molecules. Few or no additives to breakdown. If there isn't a breakdown of the oil, then why change it? Even GM says the recommended period between changes is 7500 miles, without regard to it being conventional or otherwise.
One would still want to change the filter more often than the oil. Why? While the synthetic oil will last much longer, the engine is still wearing away and creating it's own contaminants of metal, combustion byproducts, etc.. These Should get trapped in the filter. Too many particals in the filter and it will stop doing it's job.
How many miles do you get between oil and/or filter changes? It depends on what you believe and who you listen to.
Conventional Oil / Filter companies say : 3000
Why do you think they say that? Hmmm. You don't have to be a brain surgen to figure this one out.
GM says : 7500 miles
It's their warranty on your 5.3. You think they would put unneccessary risks on their bottom line.
Synthetic Oil companies will claim whatever they have to, to win your business.
Again, it depends on what you believe, and who you listen to. In my car I use conventional oil every 3K. I never planed on having it this long. In my 93 Honda VFR crouch rocket I have used slick 50. Soon after, I noticed a slight tap from the heads, and no other positive or negative results. No change in performance or oil cleanliness. I'll never use it again.
When I get MY new LT I'll be using a synthetic at the first oil change. Most likely mobil1. A friend has been using it for years on his Mustang, changes his oil and filter every 5K, and I've seen the inside of his valve covers(he's a performance freak). Spotless. He swears by it, and that is the best recommendation I can make.
Word of mouth is by far the best way to go.
The color of the oil (that is caused by blow by gasses) does not directly correlate with its ability to lubericate and dissapate heat.
Oil that comes out of a race car after it has been driven 300 miles comes out almost black. The oil from a car that drives under 55mph every Sunday to the market, after 1000 miles, and 8 months, has very light oil. The oil from the regular car is much more along in its lifecycle than the 300 mile race car. Break down of oil has a lot to do with the oil being heated and cooled over and over again. The more heat cycles you put on a oil the more it aborbs moisture and starts to break down.
If the color of the oil were dirt, then the person who changes the filter all the time would have the right idea, and the oil would always be amber colored and never go bad.
I changed at 980 with regular Mobil and a GM filter
Going to change at 3000 with Mobil 1 5-30
After that every 5000...and have not yet decided on GM filter or Mobil 1. perhaps GM to keep a warranty record..kinda..
- Tim
The way engines are today - all the computer stuff- I will admit it is above my capabilities..and I really don't have the time or the right tools. I guess the good news is engines are more reliable and don't have as many internal problems.
You may be taking this oil stuff to personal. I had no intention upsetting you or anyone. I have not seen anyone get so upset since I told someone in a Toyota topic that I thought the Tunda back seat was to small. Change your filter if it makes you happy - it still seems like a waste to me. Hell maybe we should start a topic about tire rotation - that would really get everyone excited.
Pcheng- I understand you race car VS 1,000 miles in 8 month example. It is not just miles but time.
I run synthetics in my street and dirt motorcycles. Run relatively cheap oil in my tow vehicles, pressure washers, lawnmowers, ....
My tow vehicles never overheat, and I don't think it's possible to measure the difference in engine temps related to oil type (my opinion)
ZBad71, feel free to keep offering your opinion, but please allow the other readers to draw their own conclusions.
My Silverado has 5,000 miles - is it time for a differential oil change??
Anyone also know what GM charges for a quart of synthetic gear oil. (I say quart but the regular gear oil they sell comes in 22 ounce bottles) The Mobile 1 75W90 synthetic gear oil I saw at AutoZone said " not approved for limited slip differentials" Whats up with this - if mobile 1 is so good why is it not approved for limited slip differentials.
The strange thing is the Silverado has a drain plug in the rear differential but no change recommended in owners manual. The Tahoe has no drain plug, you have to take the cover off and replace the gasket when you change the fluid. To me this seems [non-permissible content removed] backwards.
I would like some information on this before next weekend. The Tahoe is due for a change and as long as I plan on getting dirty and oily I might as well do both of them.
Dunno
- Tim
My Dad, although he for some reason felt the need to buy his wife a Ford V10, has always been a loyal Chevy owner. He is still the original owner of a 78 K10 Reg Cab 4X4. I think it was the first year for the manual locking hubs.
He is on the second engine. The first had over 200k miles on it before replacing. The one in it now has a little more than that. SAME TRANSMISSION and going strong!
He has always used synthetics in his trucks and continues to do so today. He swears its the only thing that kept oil blow by past the rings. The truck lost some compression upon reaching the high mileage and eventually leaked oil, but never burned a drop and to my knowledge doesn't on the second engine either.
I will always use a good synthetic, no matter what the cost. I feel it pays for itself in the long run
By the way my post said that my 96 Saab had 95,000 now and I wanted to drive it for 300,000. Sometimes it does 200 miles a day sometimes its just around town. My wife is a contractor (no pizza's) and her assignments vary, I still do my 5K/10K thing. But it might be every month or every three, it depends. If it was six+ months I'd probably change it then regardless of miles. For many years we have averaged 25K-35K on each of 2 vehicles and 10K-15K on the third (usually a truck or van). We spend alot of time in vehicles communiting to work and shuttling our seven kids around.
One last quick story, in 67 my dad gave me his 62 Impala, little 283 V8. I ran that car through high school and college and put another 100K on top of my dads 90K (no doubt the second 100K was a lot rougher on that car, the 5 trannies I put in it prove that). I changed the oil every 3K (no synthetic then). That was the recommended interval back then. When I took it off the road the motor was using oil and it was noisy (lifters) and it had sludge built up real thick. I was comfortable with that and really thought I accomplished something putting that many miles on it.
Then I started using synthetics and it is a night and day difference. If you live in a cold climate you will hear the difference. If you don't you will have to measure the difference over time. But like I said every situation is different, some guys lease and just use a good oil and its done.
Good luck, I'm sure everyone is doing what they think is right. As I said before I just wanted to let people know what has happened to me using synthetics.
-Jim
regarding manufacturer 7500 mi. interval recommendation:
I asked my mechanic, who is a friend I trust. He says, they want the engines to last for 100k (well past the powertrain warranty), then want you to buy a new vehicle. There is also a statistic called "maintenance cost" for every vehicle. Obviously a 7500 interval will have lower "maint. cost", thus creating a lower "total cost of ownership". Looks good on paper and to the JD Power people.
To support the theory, there are some fluids that should obviously be changed, such as power steering fluid and brake fluid. some owners manuals ignore changing these fluids completely.
FYI: Saw a study which proved the most popular brand of oil filter, was complete junk. Can't remember the WEB site to back it up. The brand was Fram.
