Slick 50 and Synthetics
However, you should not visually see any blowby if the crankcase ventilation system is working properly (the intake sucks the gases through the PCV). While the gases are in the engine, they will intermingle the oil and cause some degradation.
Again, a cold engine has more blowby. This is why the engine manufactures frequently recommend shorter oil change intervals for vehicles that see frequent short trips.
Use the best filters you can buy to clean the oil,(regular oil or syn).
Synthetic at cold temps will turn over like summer, saving on the battery and starter.
Regular oil, as it is used, will evaporate the 'thinner' molecules, and in cold weather it thickens, causing hard starting and poor lubricating.
One of the best points is, it is a super lubricating oil, staying on the bearings, thus cutting wear when starting cold.
Out of 10 engines I used it in, never lost one to mechanical breakage. Use it only after around 5k miles to allow for breakin, I changed oil at 8K or 150 hours of use.
I realize some of the above is for cold weather, but seems to me it should improve warm weather considerations also.
Catapillar synthetic
Mobil 1 Delvac
Where do you factor in the disallowed waranty claims when the manufacturer says, "You didn't follow the required maintenance schedule. Tough do-do, you're paying for the repairs."?
I doubt either of us will have anything to worry about using Mobil 1 with 5000 mi intervals, though. The motors in our Z71's will be like new
for probably 200,000 miles (maybe longer). I don't know about you, but I hope to keep mine for a long time, so we'll see...
Do you use 5W-30 or 10W-30? I use the 5W-30 because the climate in northern NM at high altitude is never hot (85 in summer is usual) and it gets down in the 20's regularly in the winter.
-powerisfun
Before After
126 h.p. (rear wheels) 210 h.p. and the rear tires were spinning on the rims!
Mobile1 is a very good filter, but wix and purolator are about as good for about $4 less.
Still a very good and still very highly rated filter for less than $3 is the AC Delco filter. It has a very strong casing, good filter paper and surface area, a good check valve. If you change your oil every 3k miles with petroleum based oils or every 5k miles with synthetic, you should be just fine with an AC Delco. I just use the wix for added comfort feeling of protection and also to support my local autoparts store. Personally, I don't shop at WalMart for reasons I won't disclose here.
With whatever filter you choose, I would highly recommend using Mobile1 or other good synthetic oil.
Rich
In short, I'm in total disagreement with the "Save the little man" philosophy. That's perpetuated by store owners that want to continue living high on the hog at the expense of the public. In my opinion, no one is owed a living.
I'll shut up now.
-powerisfun
One thought is switching to synthetic oil. If I decide the cost is too high or I don't see a gain, is it a piece of cake to switch back to conv? For that matter, is it a piece of cake to switch to synth in the first place?
Synthetic oil is petroleum based just like normal
motor oil..The synthetic just refers to the molecular weight,, the molecular weight average would equal a certain value for a normal oil but the average can be a large spread, for example 10 and 2 average out to 6 right? Well normal oil may have 10 and 2 both and over time the more volatile componants will vaporize leaving the heavier componants.... the synthetics have a better (SYNTHETICALLY )engineered mix, for example 7 and 5 also average out to 6.....
the synthetics over time will retain more of the original character than the normal oil would...
the point here is 'over time'...
ever notice how your pcv valve will stay clean if you change oil frequently????if you leave oil in forever it will start vaporizing the heavier stuff and there goes the pcv,,,glug,glug,glug,clog,clog,clog,,etc,etc,etc
The point is, the synthetics retain the original oil characteristics longer (not forever though)
and the normal oils will thicken up quicker... so change it regularly and your in good shape ,,, and as far as $$$$$$$....
I use castrol GTX 10w-30 (5$ for a 5 quart jug) and ac filters (<$3 at most parts houses) (used to
use fram but they apparrantly used to be rated number 1 but now are just about rated number last)
so for $8 a oil change (at home, $20 at a oil change shop) its the cheapest,best, most effective maintenance that can be done on any vehicle , old or new...........
so there , now go change that oil, now you have a great reason to NOT go shopping with your wife..
enjoy
Pure synthetic oil is made from chemicals, not crude oil of any type.
-powerisfun
(ONE OF THESE DAYS WE WILL AGAIN HAVE A NUMBER #1
FOOTBALL TEAM AND I HOPE ITS WHILE I'M YOUNG ENOUGH TO HANDLE THE TEQUILA WHILE I WATCH THE GAME...)
1. ORGANIC MEANS CARBON BASED.....
2. HYDROCARBONS MEAN HYDROGEN AND CARBON...
3. THERE ARE ALKANES (SINGLE CARBON BONDS) AND
ALKENES (CONTAIN DOUBLE CARBON BONDS)..
4. ALKANES (METHANE,ETHANE,PROPANE,BUTANE,ETC...
ALKENES (ETHENE,PROPENE,BUTENE(SEVERAL ISOMERS OF THIS.., AND SO ON)
5. ALKANES ARE CONTINUOUS CHAIN MOLECULES AND
ALKENES INTRODUCE THE DOUBLE CARBON BONDS AND THEN START FORMING AROMATICS (CYCLICAL MOLECULAR SHAPES..)(BENZENE,TOLUENE
ZYLENE..WHICH ARE DRY CLEANING SOLVENTS BY THE WAY(WHICH ALSO SMELL GOOD AND ALSO CAUSE CANCER
WHICH IS A MAJOR BUMMER.....)
6. ALKENES ARE ALSO CALLED 'OLEFINS' .....
7. THE POINT IS THEY ARE ALL HYDROCARBONS...
THEY ARE DIFFERENT ARRANGEMENTS OF THE SAME ELEMENTS WHICH DEFINITELY RESULT IN DIFFERENT
CHEMICAL PROPERTIES....PROBABLY THE COOLEST
PART OF THE ENTIRE ORGANIC CHEMISTRY CLASS!
8. THE MOLECULAR WT OF THESE MOLECULES CAN BE
ENGINEERED TO BE A CERTAIN VALUE COMPOSED OF
A CERTAIN PERCENTAGE OF THESE 'AROMATIC' MOLECULES, RATHER THAN THE OTHER STRAIGHT
CHAIN MOLECULES AND THEREFORE GIVE THE CHEMICAL
PROPERTIES THAT ARE DESIRED (BETTER LUBRICATION,LONGER LIFE DUE TO MOLECULAR STABILITY,BETTER CONTROLLED VOLATILITY,ETC..)
9. SO, SYNTHETIC IS STILL PETROLEUM.. JUST PUT
TOGETHER A LITTLE BETTER ..(LIKE A WOMAN THAT
IS SERIOUS ABOUT HER WORKOUT AND GETS POSITIVE RESULTS..STILL A GIRL, BUT PUT TOGETHER BETTER....)
10. AND, BY THE WAY, WAR EAGLE!, BEAT BAMA!
AND PLEASE, WIN A GAME!!!
SEE Y'ALL
In general, I have found that under the same conditions a full synthetic will break down less and last longer than a similar natural feedstock oil.
This is why I keep all of my air cooled equipment on synthetic and change once a season.
Great posts, keep it up.
BTW I intend on switching my F250 to synthetic at 5K and keep it on the sythetic. I haven't decided how long to go yet, but as usual, this mainly depends on personal preference and how much you drive in a time period.
how long to go yet..."
I did the same exact thing with my '98 GMC switched to synthetic at 5000 miles (after changing oil at 1000 and 3000). Now I change every 5000 with mostly highway miles. I love my truck! Good luck with your F250 (great looking trucks!).
-powerisfun
It all boils down to this:
Synthetics are better AND more expensive.
Whether or not you decide to use them is entirely up to you and a variety af variables. If you feel comfortable with conventional motor oil, use it! If you want the additional protection (and cost) of synthetics, use synthetics.
P. S. I cant remember, when exactly WAS the last time Bama or Auburn beat the VOLS?
I understand what you're saying. The only yardstick that I have for oil is the API ratings. Unfortunately, the testing is done by the oil producer. How honorable are they???? The filter is a different matter. I always buy the heaviest one. Usually it will have more filtration material inside. Dumb on my part? Maybe, but if anybody has a better idea, I'm all ears.
Rich
Some things are definitely "you get what you pay for, and thats true with these oils ...
Synthetic is better , conventional is cheaper,
if your good about maintenance the conventional is
probably fine. If you're wanting to stretch out the maintenance schedule at least you have synthetics available to help you out.
Personally, I think shorter maintenance intervals
help people check other things that may not really
be on the schedule but could use checking anyway..
Actually, I think even the added cost of using
synthetic oil and higher cost filters (don't assume the expensive filters are always better though) is still the cheapest,best maintenance any
backyard mechanic can do to take care of a motor.
AND as far as bama/burn/vols are concerned....
I was at Auburn when Bo Jackson was beginning and it was
great watching them, It's still great watching all
of them actually, (seems like Tenn is more consistent though)
Let's just say 'hey' for SEC football , and remember.......practice this line......
'you go ahead dear, I've got to work on the car/truck and it's probably gonna take alllll
day.....
By the way there is a good page that shows oil
filter comparisons...
http://minimopar.simplenet.com/oilfilterstudy.html
I checked out the page that you mentioned. The guy has examined maybe 20 oil filters. At 5 bucks a filter that's over a hundred bucks in filters alone, plus all the labor. I don't understand his motivation. Maybe I'm just too skeptical.
Rich
riding on 'E' just to get to a favorite too...
We all have our quirks huh?
He does do a pretty even comparison though, more
power to him, It did show me some things I didn't
know, thought it was kinda cool.
The article made me to try an AC filter on my NISSAN at the nextoil change and I did notice the motor was noticibly quieter while warming up (was using fram
but not any more)......
I guess It's good to keep up with how things change, sometimes for the good and sometimes not.
Just saw a commercial for jello that fizzes....
HEY, just use good oil, people don't usually complain about problems with too much maintenance,
just too little.
Later
DRANDO
Maybe after the initial purchase it takes 6000 miles to catch one's financial breath so that the synthetic oil becomes a reasonable alternative.
Rich
Like slos, I waited till my third oil change to switch to synthetic because of myths, but I could have used synthetic from day one and not had problems.
perhaps the myth got me too?
hell....last truck I had for 156K....nothing but conventional oil...
it's not like it's going to die if you don't use synthetic!
- Tim
Where I have seen a huge difference between the two is when two engines of like mileage are torn down and looked at on the inside. The engine that ran synthetic oil is much much cleaner and much easier to rebuild and bring back to specs than the one that ran conventional oil.
Most people won't even keep their truck long enough for this benefit to prove out. I just do it because I am very particular about my truck and want to take the best of care of it. That includes going a little overboard by using synthetic oil.
My whole family has had many GM trucks that they put over 200k miles on using conventional oil.
They all use their trucks on the farm and to do heavier work than I use my 1/2 ton for. I have a 1 Ton Chevy with the 454 that has almost 263k miles. I use it for my heavy work so I don't have to use my new 1/2 ton for. I use conventional oil in it. It has been rebuilt, but still ran great before the rebuild.
cars/trucks? What happens to oil when a car is not used regularly on weekends or is only used on
weekends? What effect does moisture and acids play on oil life? At what point does the oil/filter combination lose the ability to protect the engine? Is it 3k or is it closer to the factory recommended changes approaching 6k or 7.5k (some are even longer)? Posts on other topics have said that oil life, measured by contaminate suspension, is around 5k. I'm not sure this is definitive and is certainly effected by driving conditions. If suspended contaminates are the real evil causing oil changes then logically air quality conditions would effect this - then why is stop/go city driving touted as a major reason for oil change - seems to me it would be harder on transmissions (hince ATF) than engine oil, but I don't see or hear about 3k ATF changes. I use to change air filters with oil changes, but factory schedules are showing 15k or a year between changes. My understanding of combustion engines would lead one to say that a dirty/inefficient air filter allows more dirt into the engine than anything else (the only other avenue is internal wear of components). There is suppose to be less wear with synthetics
so therefore there should be less contaminates in
the oil with synthetic. Should air filters be
changed more often? I ask these questions because
of my experience with the Army's oil analysis
program. The two major reasons for the program
were to get an early identification of engine
failure either through component wear or dirty air
filters. You did not want an analysis returned
indicating dirty air filters (trust me). Component wear ID allowed better logistics planning, service schedules and ultimately better readiness. What I am trying to think through on this post is a 3k oil change with conventional oil better than 7.5k oil change with synthetic oil. If I believe the 3k oil change story then logically I should look at more frequent changes for other fluids that also get contaminated and more frequent air filter changes. If I believe the factory recommended schedules, but just want to use IMHO a better quality lubricant then I should also get a satisfactory service life. I'm not sure there is an absolute answer to this question, but I love my truck and want to keep it that way.
what makes them different is that they use a different base stock. they use a stock that is very similar in chemical make up to the type of synthetic used on commercial jet turbines . this stock (polyol ester) is the only one that will take the heat and stress produced in these turbines. you can imagine the performance in internal combustion engines. it is however about twice the price of the cheaper synthetics. but the protection offered is far superior. users are getting upwards of 500k miles from run of the mill gm v8's. unheard of with any other mode of lubrication. it is true that you will never exceed the parameters of this synthetic compound in street vehicles (100 % synthetic)it is primarily used in race cars dragsters and road racers. i'm crazy about my truck and wish to keep it as long as possible and will do whatever to that end. check out red line or neo oil they to my knowledge are the only manufacturers of polyol ester based oils. check it out.
maybe premium synthetics aren't for everyone but i for one want to keep my truck for as long as possible. i don't relish the idea of supporting the auto manufacturers if i don't have to. i guess
some people care more than others which is fine because that is what makes the world go round.
- Tim
