Nissan Quest 2004+: Problems & Solutions
1303133353642
  • garandmangarandman Member Posts: 524
    You would want to use 215/70 instead of 215/65. There are more selections in these sizes.
    Tire Rack lists four sizes of 215/70x16 All Season Tires. And 30 215/65x16.
    Based on the tire size calculator on 1010tires.com, it looks like you can use 215/65 without having too much variance in the speed and tire diameter. The issue is to find one tha has the same load rating as the OEM. Thanks garandman
    I didn't find any that don't have higher load ratings.
  • sopecreeksopecreek Member Posts: 203
    I'm interested in replacing with size 215/65x16. Has anyone actually done it yet? Feel the difference?
  • mpg2mpg2 Member Posts: 2
    has anyone found their 04 quest 4 spd tranny overheating? not easy to find except to smell the fluid for a burnt smell. mine seems to overheat on a hill or slow going on a hot day. i have also lost power 4 times [must use mucho gas pedal for almost no forward gain]. this has happened on flat ground.
  • vger105vger105 Member Posts: 57
    Regarding the tires for the Quest; I just ordered four Yokohama Avid TRZ 225/60/17 tires, $128 each, mounted, balanced, and with valves.
    Our '04 Quest has 40,000 miles and the original tires are shot.
    Consumer Reports rated the Yokohama Avid TRZ tires very highly.
    visited local nissan dealer today. they said that this tranny is used in lighter vehicles & might account for some of the heat. also going up to 215 or 225 degrees [40 degrees over max operating temp] for a while is ok. do i believe that? does anyone know? the torque conv generates the most heat & if temp goes up there is a 5th gear when the conv locks up. you can see if it works by noting about a 500 rpm drop as it goes from overdrive to lock up. still wondering...
  • jipsterjipster Member Posts: 6,302
    What kind of tire is that vger? A touring or performance tire? For the price I would say a high performance tire. I thought the Yokohama Avid line was more of a discount line... as their Avid Touring 15" tire is around $58(tire only)??
  • mercymemercyme Member Posts: 1
    Bought A 2004 Quest in September because we needed the extra room for four kids. It was a real good deal with just a little over 20,000 miles. We have although had a few problems so far.
    #1. Began to have the 3rd row rattle from day three (didn't hear it on the test drive). After about a month finally took it in to dealer to get it fixed, they fixed it with no problem. At the same time I told them about a squealing noise that comes from the hood when I accelerate. They were not able to find that problem.
    #2. It is just now turning cold here and I have noticed that as the temperature has dropped the tire pressure has also. The light has come on in the morning when I take the kids to school saying low pressure. By the evening (without adding air) the light is off. Go figure! I have had one instance when the tire pressure light was on saying the tire was flat, although it was just low. I had a service guy to put air in it and light went off after driving for a couple of minutes. When we took a long trip the next weekend, tire pressure light came on half way through saying low pressure. The next day no problem. :confuse:
    #3. The air vents are constantly falling out of the vents. I haven't taken it in for that yet, I just stick them back in. Also the lights sometimes pop out when you click them on. :surprise:
    #4. The seat skirts in the 2nd row keep coming off. I've tried to fix this, but they keep coming undone anyway. What to do! What to do!
    #5. Within the last three or four days I have noticed a vibration, not really when driving, but when the van is just idling. Has anyone else had this problem?
    Before this I drove a 1992 Toyota (I still have) and was well pleased with it. I bought it used and have had very few problems.
    #6. I have noticed that the reception in my Toyota was nine times better than what I get with the Nissan. The radio keeps cutting in and out. I can't stand it so I have been listening to cds a lot lately. Not just the AM stations, but the FM stations also. These stations should come in clearly.
    #7. Last night my husband came in and ask me to go tomorrow and get the transmission checked. He said that as he was trying to take off from the store into traffic, the van would only move very slowly even though the RPM's were revved up high. He said that that shouldn't happen and asked if I had ever experienced that problem. I had not. This seems like a problem that could cause an accident. :(
    I have had Nissan's in the past and choose this one based on prior experience. The problems I have had so far have been minor, but I hope that will be the extent of what problems this Quest has.
    I read somewhere that Nissan had extended their warranty for the 2004 Quest vans because of all the problems associated with them. Is this true? Has anyone heard the same story? If so please let me know. I talked to a Nissan dealer and a sales man there told me that all Nissans are covered with a 50,000 mile bumper to bumper warranty and a 100,000 mile powertrain warranty. He did not say whether this was for the '04, '05, or '06. Has anyone heard of this?
  • plashenickplashenick Member Posts: 165
    Some of your problems are non-unique and have recourse: Third row rattle is correctable from dealer. When your tire pressure falls below 28 the light will come on. Cold weather will cause tire pressure to drop, driving for a while causes it to go up (air gets warmer), you may have a slow leak if drops after driving. The "Stuck in third problem" is non-uncommon, look through earlier messages for the exact remedy to have Nissan perform.
    I do not recall anyone complaining about the skirt on chairs, or the vent pieces falling out, or standing vibration; have the dealer check the car out; may just be a rough idle.
    In case you were not told the 04's have a 5yr/60K mile Factory warranty (extension of the original 3yr/36K) due to first year issues, so most of your problems should be covered.
    Did you have the selling dealer (if you used a dealer) give you a repair history? Check to see if the recalls / Customer service inititiaves were all done. You can bring your van to any Nissan dealer to confirm this work / schedule it to be done.
    We have an '04 with 26K miles, have had multiple issues but all were solved and we love the van :)
    I'll echo wht plashenick said. With the tire pressure, Make sure your cold tire pressure is around 34-35. With the cold nights, you'll lose a few pounds overnight.
    Air vents: Mention it to the service manager on your next visit. I'll also check my vents. The vents may be designed to be removed and yours may be missing a clip or something.
    Seat skirts: Never heard that one before. Sounds like the previous owner had some good times in those seats. This
    Vibration when idle: have them look at that. It could be as simple as changing the air filter (the owner's manual shows how to change it) or could be the idle control valve. I would check the air filter. There is a chance the previous owner never changed it. At 20k miles, it is way overdue.
    Radio: Known issue with early models of the Quest. Should be any easy fix.
    Transmission: Had this happen to me 3 or 4 times during my first year. Haven't had it happen in over a year. Also own a 2004 S. There is a fix for this problem. Talk to your service manager about this. The problem is some service departments have said they need to duplicate the problem befor e fixing it. The problem with this approach is it goes away as soon as turn the key off and restart it. The good thing is you do have 5 yr/60k bumper to bumper warranty.
    The majority of the problems are known and shouldn't be too bad in fixing. Good luck and keep us up to date on what happens.
    Consumer Reports refers to the Yokohama Avid TRZ as an all season tire.
    Tire Rack refers to it, I believe, as a touring tire. You can check their site: tirerack.com
    The tire article is in the latest issue of Consumer Reports, and it's on their website as well: consumerreports.org
    As for the price, Tire Rack sells it for $88, plus shipping, plus mounting and balancing, plus valves, so I thought $128 per tire, installed, was in the ballpark.
    o.k, didn't take into account shipping, mounting as well as you having 17" tires.
    I did read a lot of positive reviews on Yokohamas Avid line of tires. Would be interested in a report when you get them installed. Thanks.
  • calvin1962calvin1962 Member Posts: 34
    I just put General Tire "Exclaim" (not the UHP) on my 04 Quest. I opted for 235/60 16". It is only 1.5% smaller circumference. That calculates to a speedo reading 61 when I am doing 60 mph. I can lve with that compared to paying 50 a piece more to put the OEM junk Goodyears LS's back on.
    My issue right now is that the tire pressures won't register. The shop did not replace the valves, but I just get a *. Any suggestions?
    We bought a 2004 Quest SE? (middle of the road package) and have mixed emotions. We get tons of compliments on the styling but have experienced man similar "minor" quality problems.
    - Rear windows rattle like crazy when opened. One is finally cured...we hope.
    - Our seat skirts keep coming off too. Kids kick them off walking through the middle two seat.
    - We have had the arm rest & seat cover material pull loose.
    - Power door has malfunctioned a couple of times.
    - A lot of little rattles and noises in general
    - Way worse mileage than advertised...but most cars do :(
    -Oh yeah...really junky OEM Tires that can't be replaced by anything in the same size except the same junky tires. A thread in this forum discusses this one.
    On the wish list..split rear seats would be nice as well as back lighted steering column control buttons.
    Overall I give the 04 Quest a C grade. I probably would buy an Odessy or Sienna if I had $30K to try again.
  • werner339werner339 Member Posts: 5
    There is a technical service bulletin for the transmission problem. The fix is to replace the A/T Control Module. This problem happened to me for the first time today, with 15K on my '04. The TSB says customer reports"engine has low power and/or the tranny doesn't shift in 3rd," AND the incident occurs just after engine is started, AND when the engine is turned off then restarted, the engine and transmission regain normal operation. Anyway, I believe that's the same problem. It felt like I was dragging an anchor. Turned off, then back on, and worked as advertised. see Nissanhelp.com
    Regarding your comment about the tires; I previous posted about the tires I ordered, Yokohama AVID TRZ 225/60/17. Tire Rack lists several tires in this size for our Quests.
    When we got our '04 Quest we had a horrible rattle coming from the back. The dealer tried several times to correct it but couldn't. It was my wife who finally found the problem; the dealer installed a license plate frame, with the dealership's name on it, in the back. That frame was lose and rattling. I tightened the screws and POOF! the rattle was gone.
    I had the lic. plate rattle several times on other cars. They are ussually so quick to advertise, they forget to do it right! As a rule I don;t do free ads so I always remove this, the rattle is just an incentive.
    A lot of your problem have been answered in previous postings (mostly recently). Rattles were a common problem but can all be remedied.
  • gg2k2segg2k2se Member Posts: 109
    I thought I had a horrible rear window rattle also. I experimented and figured out that it rattles if partially open. You must open it all the way to lock it into place. And it takes a few seconds to get it open all the way. So next time it rattles, just press the open button for a few seconds and see if that fixes it.
    There is a TSB for the rear window rattle. Take a look on Nissanhelp.com. It's pretty recent.
  • rdufresnerdufresne Member Posts: 2
    Hi, I was hoping to find information or any other '04 Quest owners with the same/similar issue.
    We have had our Quest since Nov. 03, first new model release. Lately, it has been in for service more often than I would think should be necessary, for seemingly minor issues, but it also seems that these issues continue to re-occur after service.
    My biggest concern is the recent issue with the brakes. we had the van in on July 20, 2005 reporting that the steering wheel 'shook' alot whenever braking, amongst other concerns: Automatic Sliding door would/would not close properly with sensors, Rear Sensor not working, etc. The dealer told us that the 'shaking' was a designed warning, indicating that the brakes needed to be replaced. They replaced the front brake pads, resurfaced front brake rotors, & lubricated the slide pins.
    Afterwards, the car did not shake at all & rode smoothly. They also recommended replacing the rear brakes in approx. 3000 miles. We had the rear brakes replaced on September 20, 2005, in the same fashion--pads, rotors, lubrication.
    Within a few weeks, however, the van started 'shaking' again whenever braking, & the dealer indicates we should bring it back in, saying the rotors may need to be replaced.
    After hearing this, I wondered what the normal time frame should be to replace the rotors, since it's only been 4 months since they resurfaced the front brakes & 1 month since the rear brakes were done. When I found this forum, it seems like this question may have been addressed previously, but I could use some advice before I shell out more $$$ to have them replace anything. :confuse:
    Thanks for any feedback!
  • famof3kidsfamof3kids Member Posts: 160
    Here is the e-mail text I recieved back from them: (Hope Ok to post here) ;)
    Dear Mr. ,
    Thank you for contacting Nissan North America, Inc. /Infiniti and allowing us the opportunity to be of assistance.
    In regards to issue that was stated in your email. At this time we have no documentation that can be provided because there is an automated distribution to our customers and you should be receiving your documentation shortly.
    WARRANTY DESCRIPTION EXP. DATE EXP. MILES
    BASIC WARRANTY 04/08/09 60,000
    OUTER TRIM CORROSION 04/08/05 12,500
    ADJUSTMENTS 04/08/05 12,500
    SEATBELTS 04/08/14 UNLIMITED
    POWERTRAIN 04/08/09 60,000
    PERFORATION 04/08/09 UNLIMITED
    EMISSION DEFECTS 04/08/07 36,000
    EMISSION DEFECTS (CALIF 1ST LIST) 04/08/07 50,000
    EMISSIONS PERFORMANCE 04/08/06 24,000
    If you have any further questions or comments, please feel free to e-mail me.
    Sincerely,
    Coleman Stephens
    Consumer Affairs Specialist
    nnaconsumeraffairs@nissan-usa.com
    Reply:
    #2, Yes, we too have noticed that the tire pressure sensors are very sensitive to temperature changes. Seems that the tires loose about 5lbs of pressure between 50 and 30 degrees. That's enough to set off the alarm. However, I do like the fact that the tire pressure sensors are relatively 'real time'. If you leave the van running while putting air in the tires, you can fill them to the exact recommendation. I just left the wife in the van and she told me how much to put in, etc. Interesting note, a lot of manufacturers do not use actual pressure sensors, but, instead rely on the ABS modules to determine pressure based on the revolutions, etc. That's why some vehicles with tire pressure indicators have to be driven before it will work.
    Can't comment on your other issues, as we haven't experienced them.
    I just posted a message about the extended warranty issue, for only the 2004 models, I understand.
    In regards to the vibrations, etc., interesting that the Toyota Sienna forum is discussion the same issue.
  • eyeblindeyeblind Member Posts: 156
    For those discussing different tires to put on their Quest I noticed something when I was at the dealer today. I stopped by the dealership to buy some touch-up paint. As I walked by the 04 Quest that the dealership uses to shuttle customers around I glanced at the tires. They weren't the OEM Goodyear LS2's. They put on a brand called Remington? I looked at the size. They were 225/60/R16's.
    I don't where to start. BAsed on what you described, I don't think your dealer was completely honest with you. The shaking you were experiencing was not the warning sign that you need new pads. It was the brake rotors warping. This is a common problem with the Quest (and many other vehicles). Many of us have been to the dealer to have the rotors re-surfaced within the first 15k-20k miles. It sounds to me that they should have just resurfaced the rotors but instead "convinced" you to buy a pair of brake pads. The shaking started again because the rotors warped again. Since this happened so soon after the original brake repair, my guess is the rotors should have just been replaced the first time. And were probably too thin to resurface.
    I can't say for sure if you needed new brake pads but the reason they gave you does not fit the symptoms of bad brake pads. I do think you need to change your rotors now. Personally I would be hesistant to go back to this dealer. Again this is just based on what you described in your post. I don't believe he/she is being honest with you and may be using your naivete against you. Unfortunately, there is no way now to tell if you needed new brake pads or not. If you have another dealer in town (probalby not likely), I would go to them.
    HOw many miles do you have on your vehicle?
    Thanks eyeblind!!! Time to do some research on Remington tires.
    I Just passed 30,000 miles--30,510 to be exact. I actually went back to the dealer today to question this, & explained what I had been told previously. They took a look at the front brakes & determined that I did, indeed, need the rotors to be replaced. They did it for me at no charge, explaining that this has become an issue they are more aware of lately, & that this was covered under warranty.
    At the time, I was a little confused about the brake pads myself, wondering why a vehicle with only about 25k miles on it needed new pads, but they assured me that the pads were worn down & needed replacing, both front & back, within 3 months of each other. Since I was unclear of how often brake pads would need replacing, I didn't want to take a chance of having my wife & kids riding in a vehicle with worn out brakes, so I agreed to have them done. (Also, when the rear brakes were done, it was when I brough the vehicle in for NYS inspection; I was told that the vehicle would NOT PASS inspection with the brakes as they were.)
    Going forward, how often should I expect to need changing the pads or replacing the rotors? Since they replaced the rotors on the front brakes today, but not the rear brakes, should I have had the rear brake rotors done also?
    That was great gesture by your dealership. They did not have to replace the rotors for free at 30k miles. If your rotors are warped esp. at that mileage, the wear of the pads may be uneven and many places recommend replacing the brakes pads. You don't have to but it is recommended.
    The pads they use for the Quest seem to be top quality. At my inspection in JUne at 26k miles, I had well over half the pad life left. It depends on your driving. Up until July, we were driving many more miles on the highway. Now it is more in town driving. I think the pads will wear more. These pads should last you at least 30k miles, most likely longer.
    The rear rotors are probably fine. I highly doubt you will have to replce those rotors for quite while.
    I had new tires installed on our '04 Quest; Yokohama AVID TRZ. I previously posted how Consumer Reports rated the tires very highly, so I won't go into all of that again.
    Someone posted a request that I comment on the tires once they were on so here goes; I really don't notice much of a difference. They seem to be quieter than the OEM tires, but I can't say "Wow, they handle so well!!" or anything like that.
    Consumer Reports gave the tires high marks for, among other things, snow traction, and that was an important consideration for us (we live in a suburb of New York City).
    If I can be of further help to anyone regarding these tires, I'd be happy to help.
    Personally I've found ice performance to be a lot more critical than snow traction.
    One problem with any tire tests is that diffeent sizes of the same tires seem to perform differently on different vehicles. Hopefully that will prove a good combo for you.
    They were rated highly on ice as well, but my experience has been traction on ice is severely limited regardless of make of tires or 4 wheel drive. I've seen many SUVs in the winters, whose drivers thought they were immune from the laws of physics, nosed into a snow bank.
    You're quite right about tire tests, but I wanted to maximize our chances of having safe tires on snow and ice, so I followed the ratings.
  • pwsworldpwsworld Member Posts: 1
    vger105,
    can you tell me the size of those tires you had put on?
    were they 225/60/16 or 225/65/16/
    Is there any info. on the site about the propsed "Super Warranties"?
    Thanks, so maybe I do have that rear window problem. I'll check it out. I forget how useful the nissanhelp.com web site can be. Everyone should check it out regularly.
    I do have a new intermittent problem with my right hand slider closing to within 4 inches, then reversing like there is an obstruction. Almost seems like the auto-reverse safety feature is too sensitive. I have a dealer appointment next week.
    The power-sliding door is a know issue. They do have a remedy for this
  • mwokesmwokes Member Posts: 10
    Has anyone tried to add satellite radio to the existing in-dash radio? I know that the Quest is prewired from the factory if your VIN is after 32000 and something(sorry I don't know the exact number)and I was wondering how difficult it was to do. I found on the Nissanhelp page that the receiver used is a Clarion brand(by the part reoder number from the TSB) and was curious as to if anyone has done it. Would prefer to not have the dash mounted receiver for the sat radio, would rather it look factory. :shades:
  • fmunoz1069fmunoz1069 Member Posts: 35
    Hi all, I just wanted to write an update about a problem that I have been having on my 2004 Quest. I have had alot of problems with a vibration in my steering wheel when driving 20mph and up. I had taken it to the dealer about 4 times and all they kept doing was balancing the tires, I was told that maybe the tires were bad. So I went to goodyear and they balanced them also and then replace 2 tires. Vibration still present. So I decided to take it to another dealer who I asked to please help me. They checked my van out, check road force, and balance and they did a tension adjustment on the rack. I picked up the van a day later and on the way home there was no vibration anymore. The steering is a little more tighter but the vibration is gone. What a pleasure it is to drive my Quest now. I don't think there were any memos out there, but this dealer knew what to do. WOW..
  • carzzzcarzzz Member Posts: 282
    in floor panel behind left second row seat, occurs when stepping on floor board on 2005 Quest, is this normal? The Dealer claimed that is from fuel pump cover, and this noise is normal! ????
  • emmittobieemmittobie Member Posts: 13
    I have the exact same sound on my car as well when I step there. This is in a 2004 Quest. Hope this helps.
  • cirrusscirruss Member Posts: 87
    fmunoz - that is a very interesting find as many people on this board have had many problems with this. Can you provide any additional detail that may have been documented on your work order. Maybe if you will visit that dealer again, can you ask if they can explain what was the actual problem and solution for this. I would be so happy if I can fix this annoying problem. Thanks.
  • nolemonadenolemonade Member Posts: 3
    How often do you experience the transmission sliping?
    What did the mechanic say he did to "fix" it?
    Did the mechanic experience the transmission problem?
    Have you had a response from the manufacturer? Did they want to help?
    Aloha from Hawaii!
    C
    Thanks for the info... I want to return our Nissan 04 quest, because I just don't know when the transmission will act up....of course m=our mechanics can't find a problem... and so I am looking into a lemon law suit... and I can;t even sell it in good conscience...
    Is your car currently still "fixed" after the (IPDM CONTROL UNIT fix?
    thanks,
    So dtownfb, how did the work on your transmission go? Can they tell you exactly what was changed/fixed?
    Are you satisfied?
    Nov 15, 2005
  • rach98nrach98n Member Posts: 3
    This is just a follow up to my previous post about my Quest '04 having a slow turn over when starting. The service tech was nice enough to take the information I found here about the fuel pump and go ahead and replace it even though he didn't see any problem with it. I haven't had any trouble with it since. Hopefully that fixed the problem.
    nolemonade: I haven't had anything done to my tranny. The only problem I experienced was no-power when you put it into Drive. I haven't experienced that in about 14 months. I do know there is a fix for it if it were to happen again.
    No it did not solve the problem. This was, however, a technician guessing at what he thought the problem might be. To update you since then, On december 22nd, 2004 Nissan released a technical service bulliten to correct this problem.( Technical Service Bulliten #04144) If you go to www.nissanhelp.com and search the Quest service bullitens you can read and print it out.
    It is the A/T Control Module(TCM) that needs to be replaced. I took My Quest in and had it replaced in June. I have not had the problem since.
  • 04questtweaked04questtweaked Member Posts: 1
    (04 Quest SE, all options, 42k miles)
    With regard to tires/rims: Vibration was also a problem with mine, along with tracking- will look into getting my rack tightened up like yours- think that is a good idea.
    I am currently midway going Plus-1 on the tires/rims to improve the situation with tire choices (I could not see being cubbyholed buying a third set of Goodyear Eagle LS2s again at 41k miles for $700-800 total, only to have them wobble and wear out so quick.):
    I found 2 '03-'04 Nissan Murano five-spoke 18"x7.5" take-off rims sofar, just ordered two more of these rims through a Discount Tire retailer. The centerbore is 66.1mm on both, I realize the offset is less on the Murano rims- I believe that it puts me 8mm closer to the strut on the inside and 18mm on the outer flange, compared to Quest SE 17" rims, and one can tranfer the TPMS sensors to the Murano rims. I didn't go with FX35 base take-off rims, since they are 18"x8" width, and I have heard in that application, the FX35 has extended snouts to mount the wider Infiniti 18" and 20" rims onto.
    Currently, I have 235/50-18 Michelin Pilot A/S Y-rated All Season M+S C3M Process 400AA tires mounted on the fronts (set to 41-42 psi cold- TPMS reads 47psi at over 80+ on freeway- max rating on them is 51psi.) on the Murano rims and awaiting the final two rims to arrive for mounting the other Michelins on the rear. Even with the current mismatch, it is very pleasing how Vehicle Dynamic Control and ABS actuation is pushed WAY far out with *only two of these tires on the front*- the brakes *shut right down* with shorter stopping distances and reduced pedal pressure, MUCH more so than it did before stock. I am also getting better gas mileage from this tire rim combo with higher pressure capabilies, possible lower rolling resistance of the Michelins over the Goodyear LS2s, believe the Murano rims are lighter too, with would help.
    The reason I went with the Michelin A/Ss: I kept reading over and over on the Infiniti and Nissan groups about how well posters were doing with both wet/dry performance and treadwear with these tires- keeping in mind the Quest shares the Nissan Skyline/Infiniti G35 rear suspension, albeit with the rear wheel drive features of the rear knuckles unused (I would quickly buy another Quest SE if they move over to a 4WD option with the drifting capability retained in the Nissan VDC- ala Altezza System) I found that I was able to drift the Quest SE with VDC a few times on hairpin turns- a handy feature to not just hotdog, but to get out of trouble by swinging around the rear to keep that nose pointed through that unexpected curve that came up too fast in unfamiliar territory- I've been there...:-D
  • nishonbarunishonbaru Member Posts: 39
    Where do I start. At 10,000 miles Nissan had to replace my transmission. It started when while driving the car it was stuck in 2nd or 3rd gear. My paperwork from the service at the dealership says. "1/4 to 1/3 inch of metal shavings and part of the clutch assembly in the bottom of the pan". They replaced the transmission - 19 days out of service. Two weeks later the car would not shift again. - 8 days out of service. Could not recreate problem. Few months later, smoke coming from under car. Seal on transmission leaking - 5 days out of service. Transmission would not shift again, this time I drove it to the dealership and the service manager had the same experience. Replaced to computer in the transmission - 2 days out of service. few weeks later the transmission is smoking again. Seal is leaking - 7 days out of service. Other problems include door rattles. All together this van has beenin the shop 43 days. I have also filed a lemon law claim. :lemon:
