I bought a 04 V8 SRS 4Runner early 2004 and have been stuck with a problem since then -- annoying humming noise from transmission at or above 72 mph. Brought back to dealers many times but got no fix; some said the noise is normal, some even claimed the noise cannot be heard. If you do decide on a 4Runner, here is my (hard-learned) advice: test drive at least 3 different 4runners on both local and highway and then choose the best one. Do not be fooled by the sales: "the 4Runner is a quality product (many of them are!) and Toyota is fully backing its product". The truth is that not all 4Runners have been created equal and, when it unfortunately has a problem, it is hard to get the problem fixed from the dealer -- they usually deny the existence of the problem or claim the problem is normal. Good luck on your purchase!
I purchased this 2001 2WD SR5 4runner new. At aprox 20k miles I had the differential gear oil changed. I now have about 24k miles and noticed what I thought was a very slow leak at the diff. drain plug. Turns out the seal where the bellhousing meets the differential had a leak and was dripping down to the drain plug...very hard to notice. The work / repair is covered under the drivetrain warranty fortunately.
When I first discovered the leak a few days ago I checked the fluid level and had to add aprox. 1/3 quart to bring it up to full. The diff. holds about 3 quarts total. Does anyone know if driving mostly in town for 1-2 thousand miles with the gear oil aprox 11% low could do any long term damage to the pinion gear or other components ?
Response to Onesone: I am over 6' and have the limited WITH sunroof. The power seat has so many adjustments that you can find a comfortable position.
I did learn, however from a Toyota Dealer that the computer on the car learns your driving habits and adjusts itself as you drive the car when new. I don't know if he was blowing smoke, but thought I would mention it anyway.
Also is it just me or anybody else experienced this. Whenever I stepped on the brake while at a standstill the break pedal would feel like it would vibrate as if the abs is activated.
This thing only has 200 miles in it, still under break in.
Get LIVE feedback on your maintenance or repair problems. Join our guest experts alcan, 0patience and mr_shiftright as they tackle your fix-it questions!
kirstie_h
MODERATOR /ADMINISTRATOR
Share your vehicle reviews
I plan to take it to the dealer to get this checked out, but I'd like to have some info to go in with to make this a one trip fix.
Whenever I am making a u-turn, I hear a clunk coming from underneath my 2003 4-Runner Sport 2-wheel drive V-8, has anybody else experience this??
2. Which other fluid can be used instead ot T-IV ? If possible I am looking for fully synthetic type from any major oil company. At $ 35/quart from Toyota dealer there must be someone else producing it for less. I change fluid often since I do lot of towing.
Thanks in advance.
Brian
Or something could be left running without your knowledge. My guess is the alternator.
Anyone fitted one yet?
