Visitor Agreement.
The issue that is interesting with me is that the article I read said a couple of owners of the 06 Limited model had lower back aches from driving in this car for any specfic period of time....one mentioned a 45-60 minute commute to work......once he arrived at work.....his lower back was always hurting.....no matter how he adjusted the seat he could never get it right.....the article finished by him saying that the problem is so bad he is thinking about getting rid of his Avalon.....he loves the car but the back issue seems very big to him....I understand his position....
I've had chronic problems with lower back pain in OTHER vehicles because I'm tall and the "average" lumbar placement is wrong for me. With my new Avalon that problem is GONE. This is the first time I've had a car with seats that could be adjusted to fit ME.
To each his own. The car must fit YOU. I confirmed the comfort of the Avalon by renting one for a weeklong 1700 mile trip. If you're uncertain, I recommend you do the same. This is a big investment and what's comfortable for one may not be for others.
As far as low back pain goes, though, I doubt there's any difference between the Limited and other trims. A difference between the Avalon and other cars, yes, but not between the Avalon trims.
Doug
I got a "monster" one, the package says it is for Ipod.
My player is not an Ipod, but the sales person told me it will work with any mp3 player.
Well, it works, but the volume is very low...almost inaudible. Player has to be cranked, as well as the volume on the car stereo.
My guess, I need to get one with a power supply to amplify the sound. I don't want to "re-wire" anything to make the JBL see it, the cassette solution would be fine if it worked!
Anyone had any success with this?
Thanks, and I have over 10,000 miles on my 05 LTD with not a single problem!
It sounds great through my JBL system and just blast out its tunes. I don't know if it will work for your MP3 player but you may check into it. I mounted the display in the sunglass compartment in the overhead console, so it folds up out of sight. The control tuggle I mounted in the center console in the box with the pop up lid behind the shifter. I then rounted the ipod cable from the radio to the glove box.
Once the ipod is plugged in and the glovebox closed its out of sight as well. Works as good as I expected. It would be nice to have a direct connect plug built into the radio in the first place.
I asked my parts guy to print out the instructions and he did without a problem, in fact the one parts box even say on it that instruction need to be obtained from the Toyota Instruction Computer or something to that effect. I have them if you want me to fax them to you. The link for the xm install does appear to be dead in message 10743.
When i push the audio button on my NAV the screen pops up with the station and song info, but only ten characters. It does not scroll. You don't have to keep switching screens the station info will appear above the NAV screen when your rotating the dial or scanning. The xm/sirius screen will display info as you drive unlike the FM and CD info.
Don't buy the panel tool they want to sell you for installation. Any one from a auto parts store will do, just take your time.
I'm finding that while the factory NAV may not have the whiz-bang factor of the latest aftermarket unit it DOES have a nice large screen that I can read in ALL conditions and solid basic functionality that I really use.
If you're a gadget freak (I used to be) then get an aftermarket with all the bells & whistles and upgrade it every 2 years to stay on the bleeding edge. If you just want solid, basic NAV that works day in and day out without a lot of fussing, then spring for the one built into the dash.
Looking in the manual for this, the manuals seem to be divided into sections, and page numbers restarting within each section so I am having trouble finding a page 1591.
Did I misunderstand? or can you give a section #
Henry
Hope this helps you.
USAID42
Oh yeah, did I mention gas mileage and HID headlight?
Doug
TexasRed
Before anyone jumps me for mentioning a topic once discussed, hear me out.
I had the Roady 2 radio placed inside the drop-down glasses holder forward of the overhead light. It's the perfect size. I can drop it down to change stations, briefly losing use of the rear view mirror -- which doesn't seem a problem since the side mirrors work just fine -- and either change stations manually, or with the remote.
The unit is powered from near the ignition, the wire run up the side post (clear of the air bag, and alongside the antenna wire) and then beneath the ceiling liner to the radio. That unit now has Velcro on the back, as does the back of the glasses case in which it now lives.
I have about five inches of extra wire on the unit so when desired I call pull it out, unplug it, and use it in my house, which has its own antenna.
There are no wires exposed, and unless a windshield leak develops, I don't see a down-side. The antenna is directly above the windshield with little wire exposed. It is not damaged or pulled lose by automatic car washes.
This frees up the accessory plug between the seats, which I was using before.
Anyone else do this?
zekeman1
It's an 06 Limited. I didn't get the XM option because of the expense. For a while I put the antenna on the dash or behind the back window, but tired of the wire and unit hassle.
This way -- assuming I don't have any problems with it -- I have a radio I paid $69 for (including the home unit). That plus the installation came to well under $200...a $300 savings over factory install, and I can remove the radio unit and use it in my house. Not perfect, perhaps, but a lot less expensive, and more flexible. I put one drop of silicone sealant where the tiny antenna wire slips under the windshield molding.
Now if I can just figure where to put my glasses...
Bass -1
Mid +3
Treble +3
I use this as my baseline now and fiddle with it from there if what I'm listening to happens to need it.
He said Toyota is trying to save some money. This is a safty issue.
TexasRed
I'm about to. I'll report the results.
Bass 2
Mid 5
Treble 6
Fader -5
On a totally unrelated note, I test drove the new Lexus GS300 today. Aside from the absolutely amazing Mark Levinson audio and the wonderful (gasp) TOUCH SCREEN nav, I think I made the right choice going with the Avalon. I know I will feel bitter when Camry comes out with the six-speed gearbox though. Also, the sales drove me around in the new IS 350 (Avalon's 3.5L engine tweaked to 306hp), and the raw power is just incredible, but I don't think I'd ever dare to push my Avalon as hard.
That is a good looking wood trim.
Is it an option on order or an after market? If so, would appreciate the source.
I'm a great believer in 'original', but that is a definite improvement.
My dealer hooked me up with a "take off" tire. Same tire with about 20 miles of use on it. He had to have it Fed-ex to his place from a Toyota center in Ohio. He said it is one of the hubs where they install some of the factory options and customer upgrades.
Out the door price $123.00. Just in case any of you folks ever need a tire you may want to ask your dealers about this option.
That said, the Roady is an inexpensive way to add XM to a car and to add it to a home stereo also. When I replace the car with the Roady, I intend to get factory XM but keep the Roady for home and portable use.
wouldn't feel bad about the upcoming 6 speed, either. Although overall economy may improve just a little, the penalty may be in even more transmission programming that may just aggravate our oft discussed 'hesitation'.
I bought the extra wood trim, when I ordered the car from Champion Toyota in Austin, Texas. I could have ordered it in dark or light wood. It is not after market as in... bought from a company. Alot of things can be added to the car in Houston, at Gulf States Toyota. This is who is over our sales of the Toyota in the Gulf states section. I think that Toyota sends cars out to 5 different sections of the United States. If this can be bought after market, it would definitely have to be the molded design, not the flat design. For my husbands Ford Crew Cab Diesel truck, we bought after market MOLDED DESIGN for his dash in the dark wood design and it really is pretty. We put it on ourselves. With the Avalon, we wanted to go with the light oak look. We Love it! But I am GLAD that we were able to order it that way. Hope that this info will help.
TexasRed
TexasRed
Thanks, we love the extra wood, too! If you go to message #11329, that I wrote in answer to another message, I think you will find the answers that you are looking for. If not, let me know, and I will try again.
Sheila (Texasred1)
Final note: I noticed that the big Toyota dealerships have a better handle on the full range of options available for the Avalon. Two other (smaller volume) dealerships I went to had limited or flat-out wrong information on what options can be added to the Avy.
Also, anything ré the cost?
