A reporter would like to speak with you about your experience; please reach out to PR@Edmunds.com by 7/25 for details.
2000 Dodge Ram - II
Be careful bumping up the HP and Torque on the Cummins. The diesels have been de-tuned to keep the transmition alive. The ETH is reportedly going to come out first only on the manual because the current Auto can't handle the additional power and torque. The rumors are that Dodge will get the new Allison automatic (sharing it with GM), which is an excellent automatic that will allow much more power/torque output from the Cummins. So if you change the computer chip to increase output, you might be jeopardizing your tranny.
Thanks ..........
And there are no orders being taken because DC has exceeded their build capacity for model year 2000 due to CAFE regulations,which run from 1/1/99 to 12/31/2000, and not by the typical build of model years,Aug-July. DC will probably start allowing orders sometime around the 2nd-3rd week in December.At that time you will be ordering "Model year 2001 Trucks" this is the only way they can build trucks and not pay a stiff fine to "Uncle Sam".
And the best part is the first tank got me 18 mpg's(my calculations), 17.2 by the computer.
Keep on truckin!
Your case seems to be the same as a few others, what did you order on your truck ?? Has the dealer stepped in to try and help ??
Cheers.
Rich: Good luck in finding a replacement, wish I could help out.
How do you like the transmission?
Wait til Jan.-Feb.-Mar so-on-so-on... (ETH)will be out then. (245hp/505tq) Sorry couldn't wait ...
The 6-spd is awesome tighter than I expected for this beast.It shifts positive,no poping out of gear,no blow-ups(teamviper). My first tank 29.1 gal got me 490 mi. a 16.88 MPG avg. the fuel gauge warning light/ chimes go off at 1/4 tank, I drove it another 70+ miles down to just below 1/8 and filled up.
Great build quality (Fenton Plant) No squeaks or rattles and the paint is just about flawless, exception is last 1" of the lower bedside panels, paint's a little thin there next to the down bend.
I'd hook up and tug any dodge on down the road!
Not real sure why DC told you your ram would be made at Dodge City (Warren, Michigan), since that plant makes regular cab Rams only. Quads come from Fenton or one of the 2 Mexico plants.
kcram
Community Leader/Smart Shopper Conference
I currently have (2) Chevy 3500 4x4 4 door SRW,
LWB, 6.5 Diesels Turbos at work, I have had them for about 1.5 years now. They both have been in the shop countless times, one is on its third tranny (automatic) and the other ones lastest is the A/C compressor went out. we use both of them daily and pull a trailer approx. 6000 lbs. and haul minimal loads. after dealing with these (2)
Chevys and and mutiple Navistar Diesels, my choice was to buy the Dodge Cummins Turbo and I have been pleased ever since, you cannot go wrong when you look at the track of the over the road rigs, and the % of trucks that have them. So hook a chevy to my bumper and I will pull it to a reputable mechanic. Happy Thanksgiving!
If you're like me, you will find yourself passing on the air conditioning just to have the windows open so you can hear the engine
kcram
I have come to the understanding that there is a delay in shipment of trucks from the railyard to railcars. Is this true? I ordered my truck October 1, when do think it will arrive at Riegler Dodge in Summit?
Thanks, Bob
Unfortunately, railcar shortages are not uncommon. The time frame is based on several factors:
- when railcars will free up
- railroad schedules
- the holidays
Depending on where your Ram was built, once it's on a railcar, it can take anywhere from a week to 4 weeks to get from factory to dealer. My Ram took 3 1/2 weeks to get from Lago Alberto, just outside Mexico City, to my dealer in Ramsey, NJ.
If your Ram is just waiting for a ride home, then yoiu're ahead of the game - hang in there!
kcram
where do I start on tracking my truck? What do I
tell them inorder to find my order?
Eric16
BOB
Keeping it short, I'm making something to ease winterizing the engine in my boat (GM 454ci).
Questions:
#1) When the thermostate opens to cool down the engine, does it COMPLETELY stay open until it cools to a certain temperature?
-or-
Does it open up for a few seconds, then close for a few seconds, (kinda like cycling open and close) until the engine is cooled enough to stay closed?
#2) Can the thermostate only open partially to let just a small amount of coolant into the block or can it only open completely or shut completely (no inbetween).
Sorry, again, for getting off topic, but this seemed like the best place to get a straight answer. Thanks in advance...
Brett
The thermostate on normal engines (and I presume on a boat) opens more the hotter it is. A 195 degree thermostate will be compltetly open at 200 degrees, and compelte closed at 160, and in between some thing inbetween. SO your second choice is correct: The thermostate opens as much as needed.
Here is the scoop:
The mirrors do not adjust in/out like brand "F" does, they are fixed. They are black, 7" x 10". They do fold in, if necessary. They are NOT electrically adjustable, they are manual. With that, I am assuming they are not heated. You can pivot the mirror, into either a vertical, or horizontal position. The one neat thing about them I had not seen mentioned anywhere, is both mirrors have small (appr 2 1/2" x 2 1/2") convex mirrors built in. Since the mirrors are standard on the chassis cab, there was no option number, or brice, on the build sheet.
I wonder when DC will make these mirrors available on the regular pickup trucks? Can't be soon enough.
I understand the transmission to be a four-speed, but watching the tachometer (and the road) while accelerating, it appears to shift four times, giving the allusion of five gears. I've read some comments about a "torque converter" on these boards. Is that the cause of the final drop in RPM?
Along the same lines, turning off overdrive creates two significant adjustments in RPM. Is the first the torque converter dropping out, and the second the gear shift from 4th to 3rd?
Also, is it normal for the truck to feel bogged down while climbing a 2/10 mile 10-15% grade? I'm not talking about a mountain, just a gentle hill. Pressing the accelerator doesn't seem to do anything. I have to take off overdrive to get it to drop down a gear, just to keep my speed consistent.
I'm coming from a 1997 Dodge Dakota SLT+ Club Cab 4x2, with 5.2L and Auto Trans, and never experienced sluggishness like this. Is it normal for the Ram, or should I be expecting better performance from my new truck's setup?
Don't forget that truck of yours weighs 5500+ lbs.
that is alot of gear to move down the road.
Wildman
What is the Jacobs Omni-Pak and wiring, and what does it do for you?
On my hills with cruise set at 60 the trans kicks down out of OD what sounds like 2 gears then immediately back up what sounds like one gear and holds that gear and 60MPH without going back up to OD.
Here's my problem/question. I've got 2700 miles on the truck. Until this morning, it climed those hills just fine. This morning it climed fine but I noticed that the engine started doing a light pinging when the revs went up with the downshift.
Same tank of gas as the last three days without pinging.
Am I starting to hear a problem or is this amount of spark knock normal after break-in?
Bill
Wildman
What Octane fuel are you using? I found that when I had my 5.9 Gas the best was mid-grade all around, and 90 + when I was hauling or pulling a load. I tried low test once and my truck pinged alot.
Wildman
I have just under 1000 miles. I flat towed one of my other vehicles for 250 miles, it didn't even know it was there. About 3000# in tow.
Absolutely love the truck. It rides very nice, and am pleased with the overall quality of the truck.
fphas
Good going, Dodge.
