Welcome Toyota Tundra - III
145679
  • budman4budman4 Member Posts: 2
    I guess I need some help with definiton and usage on 4wd systems. I have on order the 4wd limited access cab w/ TRD. I know it is part time 4wd but if it is raining and slick out can't you engage in 4wd high until the rain stops then shift out as not to screw up your system. This is one reason why I would buy a 4wd Tundra vs a 2wd. Full time 4wd is when you can be engaged in dry or wet correct? I still would appreciate some comments on the overall street ride with TRD?? Thanks for the help.
  • arkie6arkie6 Member Posts: 198
    I would not recommend running in 4WD HI just because of rain, unless you are going in a straight line only. With just rain on the road, you will still have too much traction to be taking curves in this 4WD. The Tundra does not have a center differential or other means that allows the front wheels to turn at a different speed than the rear tires. When you make a turn, the front wheels and rear wheels turn at slightly different speeds. This will cause binding in the drive train unless one wheel slips a little.
    Hope this helps
    Alan
  • wrwhittewrwhitte Member Posts: 5
    rs_petty:
    Good test-drive advice. And unfortunately, I think you're right....no such "perfect" vehicle for me. That's the main reason I've been searching these forums.....to get/settle for the "best of" by word of mouth.
    ferris47:
    Yeah, I'm replacing my Jeep Wrangler.
    Speaking of JGCs though, been doing more internet homework and found that the same NV242 transfer case (Selec-Trac) is available in the Dakota as it is in the Durango and JGC. Too bad the Tundra doesn't have something similar; the full-time 4WD is very appealing. Made me think about my second reason for liking the Tundra - the engine that's supposedly akin to the Land Cruiser. If money were no object the Land Cruiser would probably be in my driveway. Of course, if that were the case, I'd probably have an extra truck for all the dirty stuff too.
  • z71billz71bill Member Posts: 1,986
    I would not use the 4x4 system in a Tundra if the streets were just wet - it is a part time system. That is one reason I like the set up on the Silverado with autorac. You can use it any time you want - even if the street is dry. It only engages when rear wheels start to slip. It is so fast and smooth I can't even tell when it engages. I think Ford, Dodge and Toyota will copy it - may be worth waiting for. I would not buy a 4x4 without this feature - unless you drive off road or in deep snow / ice.
  • johns17johns17 Member Posts: 2
    I just got a new SR5 4WD Access Cab a couple of weeks ago. The dealer tortured me with delivery up to the last minute. It's frustrating that UPS can tell you the exact location of a $4 package in 10 seconds from among the 20 million they are currently handling, and a Toyota dealer has no clue where a $30K truck is until the carrier pulls in the lot.
    I ran from the dealer to get a topper installed and took off for Florida (from upstate New York) the next day for the holidays. I took it easy and didn't use the cruise on the way down, truck ran like a swiss watch. And continues to. Drives almost as good as my Lexus. No hint of any of the vibration problems mentioned in other threads. I have the TRD package with the wider 16" tires. The tires are Goodrich and have a fairly aggressive tread pattern but still ride smooth at speed. Great in the rain too.
    The engine turns a little longer before starting than I've previously experienced, but that seemed to be explained a few messages back as a design objective related to oiling. No indication of slow cranking yet, and it has been cold since I got back home the other day.
    Got 14.5 - 17.5 mpg depending on conditions. 16.8 at 80mph with the air on. Radar detector on also.
    It took longer to get this truck because it was not a "standard build" configuration at the time of my order in late Oct. I got the bench seat, which I find much more comfortable than the chincy armrests on the captains chairs. I do miss a power seat, though. This was one thing that made the truck difficult to find.
    I have the 3 in 1 CD stereo which works OK, but the sound is much basser than I care for. That should be easily rectified if I decide it really bothers me. I prefer the single changer because I change my mind on what to listen to as I go along and don't want to mess with loading magazines.
    I got this truck in white with a matching Leer cap, smooth sided and level with the top of the cab. I prefers to keep my stuff dry in the back but like to look as good as I can.
    My decision came down to this truck and the F150. Prices were almost dead even for comparably equipped trucks in my area. I liked the minor size advantages of the Ford and some of the interior features, but got scared off by lots of discussion in other threads on piston slap in the 5.4 V8 I was planning to get. I was favorably swayed by my experience with a used Lexus and other Toyos as compared to a number of Big 3 examples that have died early in our driveway.
    The Tundra has just over 3K on it now and I made the right decision. Thanks to most everybody who participates in these discussions as they were a big help to me in this decision.
  • bud_light_dudebud_light_dude Member Posts: 330
    I liked the autotrac on my Silverado too. However, when you say that Ford, Dodge and Toyota will copy it, thats somewhat an incorrect statement. The same setup, only different name, has been on the Jeep for many years now. So, actually GM copied it from Jeep/Chrysler. As a matter of fact, the new Dodge Dakota's have that same setup carried over from the Jeeps.
    Just thought you would want to know.
  • derek737derek737 Member Posts: 5
    Seems to me that when you buy a drop hitch it should actually include the part that the trailer hooks onto! Went to pick that up at the local Toyota dealership and it cost me an extra $72 for the ball and mount! When I buy the option I expect to be ready for use. The spare tire lock consisted of two small metal assemblies that cost $45!!! Pardon me for saying so - but this is BS! Concerning the drop hitch, is this standard, or am I justifiably miffed?
  • thundercloud47thundercloud47 Member Posts: 4
    I am considering buying a tundra butI would like to know more about it's towing capabilities. I own a 23 foot camper trailer. I own an 85 ford f-150 with the 5.8 engine with a holley 4bbl carb. This truck pulled the camper with little problem. I like the toyota but dont see how a 4.7 engine could pull this camper even though it is rated to do so. I would like to hear other owners experiences.
    None of the manufacturers include a ball and or detachable mount. You are lucky if they include a transmission oil cooler in a tow package these days. I know that Toyota includes an engine oil cooler, but pretty sure you have to add the transmission oil cooler as an extra, which to me makes less sense than not including a ball and mount.
    Only the reciever and wiring will come automatically on all the manuf's tow pkg's.
    As for the lock, you can buy aftermarket locks for spares that are less than $25. It was your choice to buy one from Toyota.
    If you pay 27,000 to 30,000 for a truck, how much can a $45 lock or a $72 hitch ball really put you out. If it were me, I would have just got it all at once and financed it all in. It's much easier for me to make a monthly payment than to come up with lumps of cash for things later. That is why I drive a new truck every 2-3 years rather than an old one that possibly needs big repair bills.
  • donaddisdonaddis Member Posts: 4
    Has anyone taken their 4WD Tundra off road yet? I am curious if traction is sufficient without a locking rear differential or limited slip rear end. The Tacoma offers a locking rear differential and wondered if Toyota will offer this option on the Tundra in 2001. I don't intend to do any serious off-roading but will occasionally venture off road in the mountains of NC (both summer and winter) . I just want to leave the pavement with some degree of confidence. Any input or 4WD experiences would be appreciated.
  • rs_pettyrs_petty Member Posts: 423
    Here is my humble opinion. If you get stuck with 4wd a limited slip is really not going to help much. By that, I mean that if your getting in someplace that you really need that extra drive you probably shouldn't be there in a stock truck. You should have a locking front diff too with raised suspension, larger tires, winch, 2 other buddies in their trucks, etc... The right tires are more important than a LS diff. Get a come-along, block/tackle, 50' of cable and a tree saddle just in case and you'll be fine.
  • casper7casper7 Member Posts: 1
    2000 Tundras were available in June 1999. Does anyone have an idea when the 2001's will be available?
    Thanks for the info on the drop hitch. This is my first truck, so the learning curve is going to be a little steep. Still don't understand the logic of it though.
    The spare tire lock is a "key" type lock for the winch, instead of a simple cable lock which is easily snipped with a pair of bolt cutters. I know, I know, it was my choice to buy it - just feeling slightly gouged.
  • gilesgiles Member Posts: 15
    One reason they don't include the ball and hitch:
    Different trailer tongues have different heights
    and ball sizes so one hitch will not fit all. For instance my boat trailer takes a 1" drop hitch and my Jet ski trailer takes a 4" drop hitch to keep the trailers level. Can't give you any reason for the spare tire lock issue.
  • mikemillermikemiller Member Posts: 71
    I've had my Tundra off road a lot. I'm building a house four miles up a dirt road near Max Patch NC. Every time I go to the house (almost every day) it's a 4 wheelin' adventure. Max Path Rd has barely enough room for two trucks to pass and is slick ice at the moment. We had 3" of snow Tuesday that's been packed down to a nice smooth ½" of ice. The Tundra does great. My driveway (if you can all it that at the moment) has really deep ruts. I almost bottom out the truck, but it still goes through fine. I have a 4x4 AccessCab Ltd with the TRD package. The BFG's that come with the TRD package are OK. They are very quite on the highway and give an excellent ride, but I'm going to get me a little rougher tires when these wear out. I've had real good experiences with BFG T/A's in the past. As per previous post traction is really a matter of your brains and your tires. I've been driving Toyota trucks all over the country in all weather and road conditions, never got one stuck. The Tundra looks like it inherited all the good technology from it's predecessors. One thing that I have to watch though, is that my Tundra (weighing in at over 5000lbs) definitely has to take the slick curves a little slower than my pickup did!
    P.S. Welcome to the Truckin' world!
    Did not know about autotrac on the Jeep. Does not surprise me if they had it first. Every Manufacture copies good ideas --
  • toytundramantoytundraman Member Posts: 19
    I received the mount for my drop hitch, but did not receive the ball. I would have been upset if my hitch had not been complete with the detachable mount. Good Luck with the truck.
  • pchengpcheng Member Posts: 162
    I may be mistaken, but I think the Tundra comes with a Transmission Oil Cooler. Guess I'm pretty lucky.
  • tp4unctp4unc Member Posts: 437
    received my Tundra with hitch AND mount. My hitch(Reese) was a distributor installed option so maybe it is different than a factory added hitch.(??????)
    pcheng,
    I'm with you on the tranny oil cooler.
  • rwellbaum2rwellbaum2 Member Posts: 1,006
    The Tundra has an auto tranny cooler. Almost any large engine with an auto needs one out of necessity. My dad had to have an additional auxilliary cooler put on his chevy 2500 because of overheating problems while towing an 18 ft travel trailer.
    BTW, I have some interesting info on caps for the Tundra. See topic 1372. I have now looked at every current canopy made for the Tundra. So if you got questions, I got answers!
  • cliffy1cliffy1 Member Posts: 3,581
    Yes, all Tundra V8s come with the transmission oil cooler. Tow capacity is 7100 lbs for the 4x4 and 7200 ofr the 4x2.
    A drop hitch may or may not come with the hitch depending on the brand but $72 is WAY too much. That part should not cost more than $30.
    My Tundra does extremely well with a 3300 pound boat. The "fly by wire" throttle comes in very handy in this application.
    I have owned several Toyota 4X4 trucks since '94 and use them off road and in snow. I have had only one occasion where the open differential could not get a grip. We had 34 inches of snow and I didn't feel like shoveling. I almost made it out and back but the snow packed higher than the differential and I hung up. 5 minutes with a shovel and I was fine. I really don't think the open diff is any real handicap.
    Considering the locker only adds about $200 to the price of a truck it seems like it is worth it.
    You pay over $2000 more for when you go from a 2 wheel drive with open differential to a 4x4 with an open differential. The way I figure it that gives you 100% more drive wheels (from 1 to 2)
    Adding the locker gives you 50% more drive wheels (from 2 to 3)
    I do however agree that for most drivers if you are stuck in a 4x4 (open diff) having the locker will not make that much difference. But in my experience the locker gives you better drivability on wet or snow/ice covered roads. For me the added traction is worth the small price.
    I would think Toyota will add the locker to the Tundra in the next model year and maybe also update the part time 4x4 system to something closer to GM's autotrac.
  • commodore1commodore1 Member Posts: 5
    Can someone please tell me if it is standard for 2wd Tundras to be equipped with open differential, and please give a brief explanation of open differential.
    All Tundras have an open differential. They do not have a locker or even limited slip - not even as an option.
    An open differential means only one wheel has power at a time, and the sad part is the wheel with the least amount of traction gets the power. So if you have one wheel on ice or in the mud and even if the other rear wheel is on dry ground - the wheel in the mud gets all the power. Also means when the street is wet and you take off from a stop sign if you give it too much gas only one of your rear wheels will spin. With the locker both wheels spin. I my opinion the locker is worth the money (although many people disagree)Pickups are light in the back and even with the locker it is easy to spin the rear tires when the road is wet. I have owned trucks with & without locker and would never order one without it.
    Just my $.02 worth.
    Thanks for the info. on differentials. I too would like to have two wheel traction over single wheel traction. I'm in no hurry to buy, it's looking more like wait until 2001 to see if there is more options.. I like Toyota I've had two, 86 Celica, 98 Avalon.. If the Avalon last like the Celica, then I'll have the tiger by the tail...
    Thanks again..
  • robbken44robbken44 Member Posts: 5
    I have just started looking at full size pickup trucks as my next vehicle of choice. Is there anyone on the thread who can point me to a web site that clarifies the various option combinations available along with pricing? The sites I have found so far are confusing, conflicting or incomplete. Honestly, I don't like to spend a minimum of time in the company of an automobile salesperson.
    I like to spend a minimun of time with automobile salespersons.
  • tylerz1tylerz1 Member Posts: 1
    Has anyone ever used this service? I would appreciate any comments if you have. There service is only located in North Carolina and Florida. Not living in either state I would have to drive to pick up the vehicle. Has anyone ever done this? Again I would appreciate any comments. I am interesting in the Toyota Tundra.
    tylerz1
    Just curious, you really drive with your lockers on in 2WD mode on rain and snow? I how fast are you driving? Have you ever spun out on an on ramp at 45 mph because your rear wheels wanted to go straight, but your front ones were turned? (I have heard this was a problem: I honestly don't know)
    I think the Silverado locker is different than Toyota (Tacoma). You do not manually turn it on and off. It is automatic. When is one wheel starts to slip (I think it takes 1 revolution) the rear differential automatically shifts power to both wheels. I do not understand how this is done but like the result. I have never had a problem with the truck plowing straight when I wanted to turn.
    I have seen other people post this type of problem and also that you can not go over 15mph - but I do not understand if this was just a Toyota thing or if all trucks with locker had this problem.
  • jiminpa2jiminpa2 Member Posts: 1
    Has anyone purchased a Limited with Toyota installed drop hitch? My dealer is saying they can't get the Limiteds with the drop hitch installed, something about EPA requirements. I noted at least one post earlier (450 is a lot to read) where someone had a limited with a drop hitch, and also where someone ordered a cat IV.
    The hitches I saw on SR5's on the lot looked to be CAT III (but what do I know - just comparing them to ones I saw on the rack at a local aftermarket hitch installer.
    We want to tow a horse trailer that can go 7,000 lbs (though usually will be more like 5500).
    Also, anyone one have experience towing heavy loads? Our current truck is an '85 F-250 heavy duty w/ 6.9 diesel. I'm concerned more about handling and stability rather than power.
  • brucec35brucec35 Member Posts: 246
    All this brand loyalty from Chevy dealers is admirable. It's also why they seem to have problems that never get fixed ( mushy brakes on '89-97 C/K's, transmission problems,awkwardly stuffed and positioned bucket seats, seats tracks that move, etc)
    I owned a '95 C-1500 and a '93 S-10. Never had a single problem. They were ok, but nothing too impressive. But I've heard a LOT about people who have had problems. The Silverado seems like a fine design, but they definitely do seem to have a lot of reliability problems, and the superior rear-seat room is fine, if you don't mind the extra size of the wheelbase(143" vs 128" I think) vs. the Tundra. (I can barely back my tundra and trailer in at my garage as it is, due to space constrictions)
    I currently have 5,000 miles on a tundra with zero problems. I love it, it's much more refined and car-like than my '95chevy, '98 ford, or '97 dodge trucks, and I use it to tow a trailer daily for work. It's plenty "tough" for my use. I work out of it, and the added refinement means less fatigue during the 3 hours or so I'm in it every day. That means money in my pocket in the long run.
    If you buy a Chevy out of brand pride/loyalty rather than reputation for reliablity and dealer integrity, then Chevy will just keep on ignoring the problems. I was dissuaded from the Silverado because of the numerous posts I've read here and elsewhere about their unresolved problems. When I hear they're "fixed", I will add them to the vehicles I consider as a replacement.
  • dscolarodscolaro Member Posts: 1
    This is not a rant, I am just supplying my opinion.
    I currently own a Ford F150 4x2 and I am looking to replace it. I narrowed my search to another F150 and the Tundra. I just drove an F150 (XLT Supercab 4x4 with the 7700 payload package and 3.73 limited slip axle among other things) and a Tundra (SR5 Access cab 4x4 with the V8. IMHO it is hard to even make a comparison. The Tundra is not able to compete with the likes of Ford, or Chevy and Dodge for that matter. At least not yet and if they don't make this thing bigger, never. Sure it has a nice build quality and the engine is a gem, but I want a full size TRUCK not a 4x4 luxury sedan! The Tundra I drove had captains chairs and while in the cockpit I felt cramped. The truck is so narrow that the arms of the captains chairs were attempting to ride up under my arm pits so I had to fold them back, they are completely useless. The bench seat may have been more comfortable but it is still too small. By the way, I am six feet tall with my shoes on. I don't know why they call this thing a full size truck. Marketing probably. Another thing is that the bed is considerably shallower than competing models. I have a large dog and I would be afraid of him falling out of the back! The truck handled well and had a smooth ride but this is not something that is real important to me in a truck in fact I prefer the stiff bouncy ride of the F150. Another point that you are all aware of is that there is no limited slip at this time and the configuration list is very short.
    We obviously purchase vehicles according to how they suite our needs and the Tundra does not suite my needs. As I said, this truck should not even be compared to full sized trucks. It is a nice alternative for someone who would like to move up from a Tacoma, Ranger or Nissan (whatever it's called now) or making a latteral move from a Dodge Dakota but I don't see a lot of full sized truck owners moving from there American models any time soon. Just my opinion.
    My money is going down on that Black XLT with the step bars and 7 lug chrome rims (for about the same money as the Tundra "mid sized" truck). See ya...
    Thanks to everyone who responded to my inquiry about the off-road capability of the Tundra
  • mslevymslevy Member Posts: 6
    Does anyone know how to get scuff marks out of the black overfenders? I have a few small scuffs and nothing seemed to work.
    Also, does anyone have have an opinion about ABS. My Tundra does not have them. Did I make a mistake not getting them? Let me know...
    Then what you have is a 'Limited Slip' differential. A Locker locks both sides of the axle together. They are always engaged manually, usually with a button on the dash board. You would never drive at regular speed with the locker turned on for the reasons I listed previously.
    You would only use a locker driving very slowly in very slippery condition in a straight line (i.e. mud, rock climbing, in the ditch, or getting out of really heavy snow).
    The way the Limited slip works is a series of clutch plates in the rear end pumpkin. There's a bunch of springs and plates in there, and as one wheel turns more than the other wheel it engages a gear that applies pressure to the clutch plates, as one wheel slips more, the pressure on the plates increases until both axles are locked.
    I've considered the Limited Slip in my Tundra and decided against it (for me). At first I really wanted it, but now that I think about it, the added expense, and noise, weight, and extra maintenance (though slight) isn't worth the 3 or 4 times a year that I would use the LSD. If I need extra traction, I would engage 4Hi. LSD doesn't help you in the rain because the only time it would engage is when pulling away from a stop. If your tire starts spinning in mid corner, you don't want LSD to engage, your rear end will come around on you very quickly.
    You can try this in a BIG parking lot in the rain. Drive in a big arc at about 25 in a low gear (i.e. 2nd). Then punch it at mid corner, as soon as your LSD engages, your back end will whip around. With open differentials, your inner wheel will spin, and the back end will slowly come around as the inner tire out drives the outer rear tire.
  • bob259bob259 Member Posts: 280
    Try using a dab of brake fluid. This usually makes the black come out nicely.
    You know, I think that a physiologist trying to get a Ph.D. could probably write a thesis out of the observations found on this topic. What I've learned is that everyone here interprets the information here from their own point of view. Pro-Tundra people view the same info differently from Anti-Tundra readers. Fascinating. After reading the last couple of post I thought I would throw in my own humble opinion, admittedly from my Pro-Tundra point of view. The latest Anti-Tundra fixation has been the fact that a limit-slip or locking differential is not available on the Tundra. This tells me that if the Anti-Tundra folks are down to this, the Tundra is a very well put together indeed. I mean if we're down to whether a debatably useful option is available, wow. Cliffy's explanation from the Toyota techs make perfect since. Toyota has not found a locking or limited slip differential that can take the V8's power that can last reliably over 100,000 miles. You know what this says to me? If you own an Old3 truck with one, it may not last over 100k. Considering I put 210,000 on my last Toyota truck I definitely expect to go over 200K with my Tundra. I guess Old3 truck owners shouldn't expect that. As I noted in a previous post, I've never owned a 4x4 with a locking diff, I've never had a problem getting out of some really tough spots. (By the way, for truck neophytes Toyotas are famous for this) You know Toyota wanted to offer this option (it's available on the Tacoma) so their decision took guts, and points to the heart of what makes them different.
    The other issue that comes up every once in a while is size. I've parked my 4x4 AccessCab next to many a Silverado and F150. Here are a few things I've noticed. A Tundra is shorter. The 4x4 Tundra is about 1" taller than a 2x4 Tundra, so they are essentially the same height. If you park a Tundra by say a 2x4 Silverado or F150 you can really see that they are almost the same size. Compare the hood, cab, and bed, side by side and you can see that the Tundra size specs don't lie. It really is that big. And don't confuse wheel base to truck length. The Tundra is practically the same length as the Silverado or F150, but its rear wheels are shifted forward compared to the Old3. This is what gives the Tundra it's great in city maneuverability. The rear wheels almost exactly follow behind the front. This means you don't have to swing wide to keep from hitting curbs when making turns and parallel parking is much easier. Compare a Tundra with a 4x4 Silverado or 4x4 F-150 and the Tundra looks smaller. The body of the Silverado or F150 are the same as on the 2x4 version, but because their 4x4 versions are about 6"(?) higher they seem to loom over the Tundra. It's a perspective trick. I have noticed that over the years the Toyota 4x4's have gotten shorter, while the Old3 have gotten taller. While this is not my preference, if Toyota's goal is to expand the truck market to first time truck buyers, this would be a good selling point. One reason I propose for this is that Toyota's transfer case technology has radically advanced, allowing them to lower their trucks. My 92 Pickup's transmission and transfer case where big and bulky compared to my Tundra's pancake shaped one. I also I think the Old3 have been having a truck height cold war. After all, if you want to make your truck look bigger cheaply, just raise it a few inches higher than your competitors. I plan to raise my Tundra as soon as the after market offers lift kits.
    As far as interior room, I guess it's what you are used too. I think all the truck makers are a little behind in realizing we all want full-blown crew cabs now. I do know that the Tundra has about as much rear seat room as most of the 4-door cars I see on the road today. Many of the other complaints about the Tundra's interior are just caused by it being different from what you used to. I felt this myself. I had gotten used to driving my 4-Runner a certain way, I would drive with my left elbow on the window ledge holding the steering wheel and rested my right hand on the shifter. When I got my Tundra, I couldn't do this anymore. I had to find a new position, left arm resting on the armrest and right elbow on the capt. chair armrest holding the wheel. After a day or two it felt natural and comfortable. I think a lot of what we're seeing is that a lot of people are looking at a truck or a Toyota for the first time. They've driven the same basic interior configuration for a long time, the Tundra's is different. I think the Tundra has had remarkably few complaints considering the number of people who are trying it out that have never looked inside a truck before. Remember the guy a few weeks ago who thought the Tach/Odo didn't looks as good as a Maxima's or Lexus!
    Sorry for the long post, but every once in a while I have to get this out. This conference is important to me and I appreciate everyone's contributions. I think this does a lot of good for prospective, new, and current Tundra owners.
  • smcpherrsmcpherr Member Posts: 114
    Some good points, I have to agree with you on most of them. I come at this forum from a different point of view... I drive a F-150, and love it and would recommend it to anyone. I don't think a Tundra would prove to be adequate for my daily needs. However, the "significant other" in my life is considering a truck so I read these posts trying to get a feel for the worthiness of the Tundra (for her). I have a few comments I would like to add to your thoughts.
    First, I agree, the Tundra is a very nice truck. However, I only shop at "big 'n tall" stores so space IS a daily need (as mentioned above) for me. Sorry, No matter what the numbers say, the Tundra is still cramped. My Ford is not.
    Second, yes, the Tundra drives very well for a truck. However, ALL CURRENT FULL SIZE TRUCKS DRIVE WELL FOR TRUCKS. Technology has improved, and not just at Toyota. Auto makers have found out how to carry a large amount of payload and still be forgiving to the driver. I have driven a Tundra, and I don't think it is remarkably better driving than my F-150. It may be a bit better, but I don't feel that the difference is great enough to say the Tundra is hands-down the better driver. Again, my opinion.
    Third. I don't care if the Tundra offers LSD or not. I haven't ever had it in a truck, and I can't think of when I needed it. If you get stuck in 4wd, LSD ain't gonna help (at least not the differential kind). If you are at a stoplight and you loose traction on wet pavement, take your foot off the gas. I can't think of a time where LSD would actually be a necessity. A locker could be of advantage, but how large a percentage will that be used vs. the number of Tacomas that have them. Sorry, I have offroaded quite a bit in my life and never needed it. I can't imagine the daily driver / weekend warrior needs it too often. People who have them will probably will use them incorrectly and shatter their driveline. I know when I lived in LA, at the slightest hint of moisture falling from the sky (I hesitate to use the term rain. I always said LA downpour = Midwest mist) people would just be itchin' to throw their trucks in 4wd. The thought was that if it wasn't used it'll go to waste. Never mind how bad it was for the truck.
    Fourth. I think the Tundra will appeal to the average car driver looking to upgrade to something with bigger trunk. Trucks getting better gas mileage and cheaper gas and less concern for the environment set the stage for this. Speaking only about ex-car drivers, I think a high customer satisfaction may be caused in part by these car drivers who are pleasantly surprised about how well the Tundra drives compared with HOW THESE FIRST TIME TRUCK BUYERS WERE EXPECTING IT TO DRIVE, NOT COMPARED TO OTHER CURRENT MODEL TRUCKS. Combine this with Tundras shorter wheel base, and these drivers may be wondering why they didn't do this a long time ago. Well, its a good thing they didn't do this a long time ago. Not that long ago trucks were awful "truck-like." I do wonder how many of those first time truck buyers will stand by their trucks after the new car scent wears off and they realize how much they miss their Camrys. I also think the same thing about ALL new truck drivers, but the Tundra seems to have more first-timers than long-timers (forgive me, those of you who are out there) compared to the people that buy new Big 3 Trucks. I think that Toyota is one of a few companies that should be thanked for this change. I don't think the Big 3 knew there was a problem until they looked at Toyota's sales figures. But, on the other hand, I do hope that Trucks do not become any more civilized... A lot of people will be running to the super-duty models if the light duty trucks become too urban. I don't drive a truck for the trunk.
    Let me finish by saying thank you, both for reading this, and for the wealth of info you have provided me (and the entertainment). This is not intended to be a Tundra slam, just an extension to Mike's thoughts from an "Anti-Toyota Fanatic." I am looking to add a truck to my family, only time will tell what she likes.
    By the way, I know what LOL means to me, but it doesn't seem to fit the comments you guys are always making... what are you using it to stand for?
    Smcpherr good to hear from you. Sorry, I get carried away with the Pro/Anti, Us vs Them thing every once in a while. I agree with just about everything you are saying too. "Big 'n Tall" guys will have it rough in a lot of trucks, but they should give the Tundra a chance. The Ltd's 8-way adjustable power seats worked for me but I'm a medium guy. Maybe the 60/40 bench would work for a bigger guy? I was considering the F150 when I was looking for a Tundra. It's technology really advanced with the redesign back in 94(?) In fact when I had trouble getting the Tundra I wanted, I was .0001" close to getting one. A couple of things kept me waiting for the Tundra. First, the Tundra is a perfect size for me (except it's too short). I would never have sold my 92 pickup if I had gotten an Xtra-Cab. I need room for the significant other and my dog. A two seater doesn't fit the bill. But the Tundra is just right. I also wanted more power. I was very disappointed with the F150's power. I test drove both the 4.6L and 5.4L engines. After driving the Tundra's I-Force the Triton felt very weak. You eventually got up to 60 after a lot of whirring and purring. The power to weight ratio of the Tundra excites the 18 year old in me (still haven't lost a red-light drag race yet). I did like the fact that the F150 has the 5 Speed option with a V8. But Toyota's Low Emission efforts with the Tundra make me feel less guilty about driving a V8, very cool technology. I only wanted a manual transmission to help in winter driving, and I'm learning how to use the automatic for this now. I also suffer from quite a bit of brand loyalty. Toyota has done me very, very, right in the past. They seemed to have led the way on many things, with slow and sure technology advances always done right, so all things being equal, which for me they are not, I would still buy Toyota to reward them.
    As far as the Tundra handling, you're right they all handle better than they used to, but the Tundra had something different. Like the difference between a Cadillac and a BMW. It may be subtle, but there's a difference. It's all in what you want. I do plan on putting an anti-sway bar on my Tundra. Being so heavy I can't turn the curves like I used too.
    I agree with you whole heartedly on the LSD. Much a do about nothing. The following is defiantly in my humble opinion, but I think GM in particular tries to sell their trucks by the options it has rather that the real meat of the thing, the truck. A GM product manger's motto might be "We don't want to spend more on a new truck design, just add options they never know!" Seems short sighted to me, we'll see. The new Silverado I test drove seemed like old tech with lots of gadgets. The rear seat backrest was a winner though, but not enough to make me get one. I know I'll probably get flamed for saying all that. I do wish Toyota would offer more options, but if I had to choose, and it appears we do, between a solid truck and options, I choose the truck.
    I agree with you too on Truck not becoming too nice to get dirty. I defiantly see the truck status symbol thing starting to happen. You know, "SUV's are so passe everyone has one!" I know lots of Atlanta suburbanites with a full size truck, just because they have disposable income and they go to Home Depot every once in a while. I suppose this segment is starting to influence marketing research. I can't think of anything off the top of my head to make a truck more "civilized" than we have now, but I'm sure they will think of something. I do know that full size truck's up until now have been made for work. I have wanted, and it seems I'm not alone, a truck with a more comfortable ride and interior. But there does come a point where making it more comfortable takes away from the usability of the truck. I'm mean can you imagine taking a 2000 4-Runner out to haul hay or muck around on the farm? The interior would degrade so fast it would be worthless in no time. To me this is a major problem for truck manufactures to solve. Make it more comfortable, but keep it durable at the same time. Since they haven't solved the problem yet, they may take the easy way out and produce an upscale SUV with a bed truck line, and a no frills, less comfortable super duty truck line. I hope this doesn't happen, or if it does I hope Toyota comes out with a "Super Duty" truck line. They could bring back the "Titan" name for it. But I want both comfort and interior and exterior durability in one truck! It just takes more creativity on their part. I would pay even more for one of these perfect future trucks. Yeah, creativity that's what we need! The perfect truck has not been invented yet. Maybe we need to start a serious "future truck " conference to bounce around ideas. Then if we could only get any of the manufactures to listen...
    I just put 2 and 2 together and may have figured out why some folks want a locking diff(LD) option. I haven't priced it, but I suppose the LD is a relatively cheap option from some manufacturers, where as upgrading to 4-wheel drive is more expense. So, if you bought a 2x4 truck with an LD option you get a poor man's 4x4. Lock the diff when you are totally stuck, otherwise you have a 2x4? Is this why everyone wants an LD?
    I apologize for all the space I've taken up today. Every once in a while I go through these talkative phases and then I'll be quite for a while.
    The locker is made by Eaton and per their web site it is a locker not a limited slip. I really don't care - it works fine for me. It added $200 to the price of my truck.
    Mikemiller - agree with your poor mans 4x4 (almost) I want one on my 4x4. That at least makes it a 3x4.
    Why would you not want any extra drive wheel for only $200. Can you live without it - yes, would I base my decision on what truck to buy based on the rear differential - no.
    I have seen the comment posted before that Toyota did not put a locker on the Tundra because they can't build one that will last over 100K miles. I think the Landcruiser has one so that does not add up to me. Any Landcruiser owners want to comment?
    Good points. Even though I will always own a 4x4, I would have bought the locking diff. I was disappointed when I learned it was not available on the Tundra. Since a 2-wheel drive vehicle is really a 1x4, and a 4-wheel drive is really a 2x4, it would be nice to have a 3x4 for a minimal amount more. I was a Boy Scout and learned the motto very well, "Be Prepared". But as I said before a 2x4 4-wheel drive has gotten me out of everything so far, and not having it was not going to make me not buy the Tundra. All the good points of the Tundra outweighed the bad for me.
    After your Land Cruiser revelation I went to the Toyota website and see that the LD is available on the LC with an "Active TRAC electronic full-time 4WD system"! Wow, there's something to think about! All I can say is that I have no idea, except it must not be rated for the heavy towing the Tundra is required to do?
    On my perfect truck ideas theme I want a fuel-cell powered electric vehicle with an electric motor on each wheel for true 4x4 traction and let a computer handle the turning slippage complexities instead of a differential. Of course I would also want adjustable vehicle height(AVH) (since there aren't drive shafts anymore, why not?) say from a computer maintained 1" ground clearance for efficient high speed highway travel up to 2 to 3 feet clearance for some serious Off Roading! The adjustable height could also be used to shift the weight forward when carrying a really heavy load. What do you think?
    AS long as we are dreaming may as well add 600HP at 200 RPM and 1,000 Ft pounds at 150 rpm, with redline at 10,000 RPM and 5000 HP. 0-60 time 1 second - all for $10,000.
    The ride height is already available on the range rover (I think)
  • powercatpowercat Member Posts: 96
    Your big and tall comments don't fly with me. I work for a forensic engineering company and drive a company 97 F-150 almost every day. It always has something wrong with it from day one. The paint comes off in chips, it is noisy inside, fit and finish is incredibly sloppy, it is uncomfortable to drive, steers and handles extremely loose, etc. In a word, it sucks! I try to drive my Tundra when I can because I HATE the Ford. My Tundra can haul, or tow just as much as the Ford and do it in style. I am over 6'4" ,weigh 260 lbs. and I also shop at big and tall stores and I am much more comfortable in my Tundra with plenty of room to spare. If my wife was looking for a truck that wasn't going to get a lot of work I still wouldn't recommend a Ford. Don't take this personally but I don't think the two even compare. That of course is my opinion.
  • ferris47ferris47 Member Posts: 131
    Just a quick question. How much oil did you guys put in at the first oil change. I know it was more than the recommended in the manual. I seem to remember 7 Quarts but I could be wrong. Thanks for any info.
    Sorry to hear that you don't like the Ford. I don't know what to say to you other than that. I had a 97 F-150 for three years before I got this 99, and I had none of the problems that you refer to. No paint chips, no excessive interior noise, the fit and finish of my truck is very nice, it is very comfortable to drive, and the steering and handling is very nice. As I said before, I feel that the F-150 and Tundra are very similar vehicles in these areas. I have been very happy with my trucks ability to tow/haul... true I do not do it much but when I have towed, even very heavy loads don't bother it any. I expect that the Tundra is similar in this respect too. I am over 6'6" and 315 lbs, so I am a bit bigger than you, and sitting in the Tundra made me feel too uncomfortable. Something about it, maybe the window curved towards me too much, or the center console was in my way, but something bugged me about it. I couldn't place it then, and I don't remember it well now, but I remember thinking a swift elbow to the window would free up some room... I am glad you like your Tundra. I don't think of myself as a Anti-Toyota person, I just didn't like the Tundra. I agree that Toyota does have a better reputation for quality, but I don't buy things due to what they have done in the past. When the lease was up on the 97 I looked at all the options, Toyota included. Toyota dropped out because of interior room, and Chevy and Dodge both dropped out because I prefer the look of the Ford, and I feel that it was a good choice and if nothing changes between now and when I go to buy another truck I would prefer to buy the Ford. But, the next truck I get probably won't be mine to drive, so I am educating myself again on the available options before we go shopping.
    I think the point to the LS is that Toyota couldn't find one "in the market price" range they wanted to keep the Tundra in. They could design it and manufacture it, but not at the price point. The TLC goes for 55k and it uses a computer to apply brake pressure to the wheel that slips. I learned how to do this on farm trucks (2wd) back before limited slips where first introduced. Still do it if I need to - don't need no stinkin' computer to drive for me.
