Visitor Agreement.
SEE EDMUNDS TOPIC #802 " TOYOTA TUNDRA PRICES" LINE 130
or
TOPIC# 795 "TOYOTA TUNDRA- HOW MUCH DID YOU PAY ?" LINE 319
Ford F150 was my 2nd choice but I felt more comfortable in a Tundra.
Also would like to know if anyone has had any problems with any cab high shell they have had installed .
Thanks Bill
Just an update 3100 miles and still perfect. Kinda feel bad changing the oil as it is still immaculate. No problems with the truck at all. Getting about 15 MPG with mostly around town driving and will be taking a road trip this week to check the highway mpg. Still the best truck I have ever owned. No Vibs, trans problems, rattles, shakes or creaks. The only thing that could be a little better are the low beam headlights but that is nit-picking. I would definitely recommend this truck to anybody reading this and shopping.
Anybody have any suggestions for a leather cleaner and conditioner. I am thinking Tanners.
606
Thanks for the quick response went down to the dealer today and talked to the installation dept.
they were supposed to call me later today they had a sr5 coming back with the flairs installed .
They never called. I get mine installed on Thursday slightly narrower I can live with .
Thanks again Bill
Rhinoliner - awesome, i was going to have linex put on but after the dealers' spray gun screwed up twice before my appointment so I decided to forget about linex (maybe it was just the local dealer) if their stuff doesnt even work properly i dont want them to ruin my truck. So i got rhino, excellent job nice texture that is not as smooth as linex - but isnt the purpose of the bedliner to protect from scratches and keep the beer cartons from sliding all around the back? it does that very well.
Tires - Very aggressive and surprisingly quiet, not enough to notice really unless you listen for it on purpose. The performance offroad more than makes me forget about 30% more noise than the puny 245/70 Dunlop Grandtreks. Only problem is my mpg is quite low 12.9mpg on 60%city 40%hwy - well it takes regular and has 1600miles.
Drove into a 4ft hole in the ground and my left front was in to the skidplate, right rear was up 2ft from the ground. Tried to reverse - no help there, switched 4wd HI, backedout without any problem and continued my search for more 4wd challenges. found a rocky creek with about a 40% dirt incline on the other side - no problem, my offroadingbuddy with his Lariat F150 4x4 (5.4L triton, look for a drag race shortly) was scraping his running boards after he followed, he made it but only echoed with my laughter.
He's buying a WARN 9500i winch which i was going to get at first, now after a series of trips, im going to Walmart and paying $29 for a comealong - i cant justify a winch anymore - if i ever get stuck, maybe. I already know that will prove very difficult to accomplish.
Silverado owners - look at your truck from the rear, the ground clearance is not all that great, the bottoms of your shocks stick out as far as your rear diff - careful of rocky trails because those will snapoff liketwigs if a rock catches them - compare the toyota backend. Ford is notas bad as Chevy/GMC but worse than Tundra.
(I traded my 91 Corvette for the tundra and i could not be happier - quality is lightyears ahead) im glad i test drove before i bought.
5 bucks you win the race!
up close
late
RWS
Are you 6'8" 375lbs. now?
Absolutely Flawless after 4000 miles.
This is one well built TRUCK !.
One thing that puzzles me though, Any time the
truck is shifted from the park mode and into the
Drive mode a very distinct noise is heard after
rolling the first several feet. I asked the service manager at the dealership about this and
he said this is normal and explained that it is
some kind of diagnostics (the abs system checking
itself). It does this at every shift change weather hot or cold starting of vehicle, so I assume he is correct. I'll probably call Toyota's consumer hotline to verify this and let others know on this Forum. I was wondering if anyone else noticed this on thier Tundra also. Any help
on this subject would greatly be appreciated. Other than this the Tundra is one Smoothe and Precise Machine. Looks like this is going to be
the "LEXUS" of all Pick-ups !
AL, CQ, DZ, LF, and Gulf States Toyota's
distributor installed options DG, P1, B8, and DH.
I had visited six dealers in the area of which 2
had a vehicle I would accept. I chose Carl Hogan
in Columbus, Mississippi based upon the best price
and closed by their offer to deliver the truck to
me in South Mississippi (300 miles). However, I
wound up driving the new truck home and they are
going to bring my car down this weekend. So far I
am very favorably impressed by this machine. Any
one wanting a good 1994 V8 T-Bird, please contact
me.
Consumer Reports says the truck is 75" wide. How wide is it mirror to mirror? My garage door is 94" wide.
Do 4x8 plywood sheets fit between the wheelwells flat on the bed floor? Or does the plywood go on top of the wheelwells? If so are there a place for stakes to put across the bed like on the Ford Ranger?
Thanks for your help.
4x8 plywood lays all the way on the bed floor with about 1/2" to spare. The amount of room may depend on you bedliner, if you have one. If you get the 6.5' shortbed, the 8' long plywood will come about an inch from the end or your tail gate when it's down.
Also, my Toyota bedliner does have positions for 2x4's to be positioned to divide up the bed, or to build a second "floor" higher than the wheel wells. I don't know if a naked Tundra bed has such features. I guess this one good feature bedliners I forgot. Still hate them though.
Yes there are 2 slots on each side of the bed to place 2x4's to divide or raise the cargo.
Not too shabby for a 1st year design!
take the "mini" version (as seen on f-150 light duty) If the Tundra could take a plow I would
trade my F-250 super duty today! I have not had
any problems with it, but it is not..well...a toyota. (wow! if i posted this on the ford thread they would rip me to pieces) what i mean is
it lacks refinement. i also own camry/acura and am use to this refinement and would expect the same from the tundra, now if i could just equip one with a plow!
in previous owned trucks, I had a "RHINO-LINER"
sprayed in. I must admit it took alot of research
and shopping around before I committed to having
this product applied to a $30,000 Truck.
A neighbor of mine had one in his Ford for over
3 years and it looks good. (He is a Carpenter and
is always throwing cinder blocks and building materials on that liner.) So it looks as good as
I felt it should for that kind of service.
No deep scratches,peeling,discoloration,or any sign that this stuff will fail for the life of any
truck! I was able to watch the spray in and I'll
tell you, that stuff is never gonna come out.
It is sprayed in layers to a 1/4" thick and sprays on like an epoxy adhesive.
I am very pleased with the appearance and solid
surface the Rhino-Liner has.
Not to mention all the benefits of having a Truck
bed that is totally protected from all that would damage it.(Water/moisture/VIBRATION).If you ever
saw a "slide-in" bedliner removed from a truck-bed
you would'nt buy that truck. Paint is scratched/to
bare metal in rub areas,which in turn rust.
I would recomend this product to anyone interested
in protecting thier truck-bed.
This stuff is affordable also. Mine got done for
$370 for a "over-the-rail" installation.
Toyota's bedliner for the Tundra is $345.
I'll post my experience with this liner as time
goes on for those that are interested.
It is a very normal noise and you will get used to it.
chevy
found out they don't have a plow for them.He traded in his 96 2500 reg cab for it too because he was sick of all the problems it was having.
i guess he's in the same boat now again......
tundra sounds pretty good from the factory so yours must sound killer now!
Please continue these discussions in Topic 1468 Welcome Toyota Tundra - IV.
Front Porch Philosopher
