2005-2007 Toyota Avalon
189111314287
  • clarkingtonclarkington Member Posts: 3
    Considering all the new Toyota SUVs have both stability control and traction control as standard features, what are the chances that the new Avalon will have these safety features as standard also?
  • dmortholedmorthole Member Posts: 29
    The Avalon will probably have it standard on the top models like the Limited and XLS. It would be likely it will have it as an option on all the other models.
  • i_luv_toyotai_luv_toyota Member Posts: 350
    Is Limited going to be the highest, or is it going to be the XLS like it always was?
    How about the Touring, where does that fit in?
  • pmcb48pmcb48 Member Posts: 192
    There is an earlier post somewhere in this forum. I'm pretty sure it was listed this way, in ascending order of standard and/or available features: XL, Touring, XLS, Limited.
    Thanks, pmcb48!
    I can't wait for this new Avalon to come out. I'm giddy with anticipation!
  • abfischabfisch Member Posts: 591
    AVALON FORUM:
    I hope you are all correct with the options for the new model year. However, it is best served in debate, about AWD as an option. I am not sure where you all AWD contributors are writing from, but I write you from Ft. Drum, NY 30 miles from the Canadian border. Our Avalon 02 is equipped for winter, without AWD, and it does quite well. Acutally, AWD would have some negative aspects that we would have to consider. Our Avalon, with optional Winter Tires on all wheels, PIAA FOG and Driving lights, a stone deflector for the snowplows coming the other way on rural routes, as well as changing the washer fluid sprayers(Camry model type has a fine wide spray instead of the older two or three jet models) enhance the safety of the vehicle. AWD, has negative apects such as 4-5 MPG less regardless of when you need it, and is deceptive in its ability to brake and corner the vehicle on pack snow and ice. AWD only enhances acceleration, straight line and cornering, in poor traction conditions, a poor trade off for some.
    Winter drivers would do financial far better, by changing ALL tires to winter tires, putting more illuminating lighting on, and making sure all fluids, battery, etc. and in good working order. I have also found, the RainX winter washer fluid, SUPERIOR to any other on the market. It not only does not freeze in sub zero freezing temps, but the sheeting action from the Rain X product every time you spray it, helps with a decrease in icing under these adverse winter conditions.
    None of this is the gospel. I drive alot up here in Northern New York and regularly contribute to this forum.
    abfisch
  • warakawaraka Member Posts: 10
    abfisch
    What is AWD? I thought AWD was an acronym for "All Wheel Drive" and as far as I know the Avalon is a front-wheel-drive, not an all-wheel drive vehicle.
    Speaking of all-wheel drive, have any of you driven the new Acura RL with SH-AWD? The car is awesome and Toyota should seriously think of offering it in the new Avalon.
    Also, Toyota should offer a hybrid Avalon similar to what Honda has done with the Accord.
  • coug2coug2 Member Posts: 34
    I agree with post 518 - AWD helps with acceleration. Where we live, however, there is snow AND there are hills. AWD means when you stop on a hill (say, because the car in front is making a left turn), you can go again.
    Even more important, for us, AWD means we can get up the driveway without any problems. My toyo sequoia makes it up the driveway everytime without a problem (when in 4wd), my front wheel drive maxima is another story - first shovel the snow, second take two or three attempts and hope you stop before you come out the other side of the garage.
    If the avalon was offered with AWD, I'd buy it today. As it is, I'm not sure what we will do. The new car will be for my wife and she would like an AWD sedan. The suburus are ok, but kind of small and a bit rough. The RL is just not worth the extra 20k (versus an avalon - who knows what the new avalon will cost).
    We are even thinking about buying american (gasp!) - the ford 500 - big, soft, and awd.
    Also not wild about the little suvs- rav4/crv - can't get a rav4 with side air bags, both a little tight, noisy, and rough compared to a sedan.
    On the plus side, our inability to find the "right" mix means i'm saving $...
  • otis12otis12 Member Posts: 171
    If you need an all-wheel drive sedan? On topic, it seems to me that the new Avalon will be going up against the Nissan Maxima, though I have not seen interior dimensions. The drawing posted a few posts above reminds me of the current Max.
    My point was, and still is, there is a market for an AWD Avalon (i.e., in case it's not clear how this is on topic). The G35 is a sports sedan, the avalon is a Japanese Buick - roomy, soft and quiet. The G35, while a nice car, is not comparable.
    I'm not sure that the new Avalon will really go against the Max - for much of the same reason - while the maxima is not as sporty as the g35, it still seems to be marketed as a sportier car.
    The average age of an avalon buyer is 62 - avalon consumers are not buying the avalon b/c they want a sports car - they want a very nice, refined, dependable, roomy car. While toyo hopes, no doubt, to get a younger crowd - I doubt they will risk offending their core avalon consumer.
    Interesting article (about avalon!):
    http://wardsauto.com/ar/auto_toyota_says_next/
    We all are certain that there will VSC standard or optional. But what about the idea of Vehicle Dynamic Management(VDM)found on the next GS being available?
  • bubbaboybubbaboy Member Posts: 7
    what is the difference
  • kicker9kicker9 Member Posts: 57
    I believe abfisch wanted to refer to Traction Control, not AWD. It's a nice feature, but, not really necessary with a good traction tread, I too live in upstate N.Y., about 20 miles south of the Canadian border adjacent to Vermont. My previous car was a Lincoln LS w/traction control, I frequently turned it off in the snow, there are times when you need the ability to spin the tires.
  • mmccloskeymmccloskey Member Posts: 168
    Greetings:
    I was browsing the Japanese Toyota Site and ran across the attached pics of the MARK X. It bares a striking resemblance to the previous images that have been posted regarding the next Avalon. The front grill area appears a bit different and the interior is not as 'plush' as it could be, but maybe, just maybe, this is very near what the new/next Avalon may look like.
    Regards -
    M.J. McCloskey - 2K2 ES300 + 2K3 Sport Trac
  • future1future1 Member Posts: 103
    The new Mark X is described as a rear wheel drive car with a choice of either a 3.0L or 2.5L V6, targeted for Japan only. This is not what the consensus opinion seems to be about the 2005 Avalon.
    Even more characteristic is the following reference: "The Mark X features an enhanced structure that better absorbs the impact if the vehicle strikes a pedestrian, and makes such an impact more survivable for the pedestrian." That's not Avalon -- we American drivers dont mind killing an occasional pedestrian, and we are more likely to pay premium for another airbag inside the vehicle, not for the one outside of it.
    However, just like the new Avalon, Mark X is an attempt to attract younger buyers, so perhaps Toyota decided to kill two birds, so to speak, with a single stone: redesign once, sell everywhere.
    Reference: http://www.japantimes.co.jp/cgi-bin/getarticle.pl5?nb20041110a2.h- tm
    The most interesting fact that I got from news about Mark X is that there are baby boomers in Japan!
  • finfin Member Posts: 594
    Nice pictures of a good looking car in someone's auto market. Maybe here in the U.S. Thanks.
    The front end of that car is nasty. The interior is sweet looking, though.
    If that's the new Avalon, I hope they change the front end, because that Mark X's is just plain gross.
  • mcclearyflmcclearyfl Member Posts: 149
    It's always interesting how people's tastes differ. I find the Mark X styling very well-integrated and appealing - wish I could say the same thing for the external styling of my current 2003 XLS.
    The side profile of the Mark X looks a lot like the side profile of the Avalon found on the "fax" picture, the one that's green. Especially the window's profile
    You're telling me!
    I always have thought Toyota got it right the first time, but as the owner of a 96 XLS, I might be a little biased! :)
    I hope Toyota doesn't mess up this new Avalon, as I would like to have another Avalon in the future.
  • gteach26gteach26 Member Posts: 576
    If that is the new Avalon.. I'll TAKE IT!!! REALLY nice inside and out. I just wonder what the backside looks like.
    I wish Toyota would give up some info. I'm in the market come December and unless I can get to see if the next Avalon will peak my interest I'm going elsewhere.
    Lucky for Toyo the highest car on my shopping list is the LS 430. Boy would I love to save the dough and get a nicely equipped and roomy Avalon.
    But will it be gross looking?!?!?!?
    Here is a rear/side view of the Toyota Mark X - which could be the upcoming 05 Avalon.
    This particular view gives the car a rather sporty demeanor - far moreso that the current Avalon. Whether this is the next Avalon or not, it's far more stylish and would have more appeal to younger buyers.
    We only have about 10 weeks before we know what the REAL 05 Avalon looks like.
    Regards -
    M. J. McCloskey
    Thats a very attractively styled vehicle, and I do like the front fascia, contrary to some here. However, the hood of the car seems unnecessarily long.
    I REALLY hope this is what the vehicle will look like, instead of that bulbous monstrosity that had been circulating, and even appeared in Car and Driver.
    ~alpha
  • rctennis3811rctennis3811 Member Posts: 1,031
    Nope, the Mark X IS NOT the new Avalon.
  • bklynguybklynguy Member Posts: 275
    have you seen our new Avalon in person ?
  • rdeweyktrdeweykt Member Posts: 6
    You are correct sir. The new Avalon will not be in showrooms until the spring of 2005. New 3.5 ltr V6 w/arround 270 hp.
    could it be the next IS ? (or some other new Lexus)
  • bperrymanbperryman Member Posts: 15
    Is it possible to get either of these installed at the factory rather than in the after market. I plan to buy the new 2005 Avalon--I have a 1996 with 172,000 miles and I love it more every day but need a newer car for long trips. Thanks
  • wesgwesg Member Posts: 24
    Please..what is the definition of "spring of 2005". I've read that the new model will be introduced in January and I hoped it would be ready to order at that time. Is "spring" March through June? Thanks for your input...
  • buckwheatbuckwheat Member Posts: 396
    The note mentioned below speaks to when the 2005 should appear, the date has been pointed out on this board before, it is taken from a Toyota press release dated 09/15/2004
    *NOTE: The 2004 model year Avalon will continue to be sold until the launch of the 2005 model in February 2005.
    The full article which speaks more about 2004 can be found here.
    http://pressroom.toyota.com/photo_library/display_print.html?id=2- 005Avalon_r
    That car (Mark X) has an almost 2005 RL-like look to it.
    No I have not. But if you LOOK around and use some insight, we can already tell it's not the new Avalon. The new Avalon is FWD-based and built off of the Camry platform. The Mark X is built off of the Crown/Aristo (GS) RWD-based platform.
    You're right, but that doesn't mean the new Avalon can't look similiar to the Crown/Aristo/Mark X.
    I can't wait for someone to submit a post like this with the REAL pics.
    Toyota PR is maddening. This car is coming out in February without so much as a hint of what is to come?
    Building suspense? Protecting the 04 Avalon's sales? Nah. How about, boring me to tears!
    Yuck.
    We have Avalon postings with fuzzy facts relating to engines, body and other features, so what is next if Toyota wants to keep everyone in the dark? Well, we can go somewhere else! Has anyone compared the loaded Camry...or the Lexus...as replacement for the Avalon? Or....a competitive company other than Toyota (perish the thought...and it's a free country, isn't it?) ???
    Maybe someone in the Georgetown area will spot it and have a digicam handy ;)
    I work at a New Jersey Dealership and keep ?? the engineers during training. Our official launch for training purposes is in March. The new vehicle is usually out just before that. The New Avalon will be built off of the new Sienna platform and will be the biggest sedan lexus or toyota currently has.
    I concur with you on all counts!
    Give us at least a shot of the new Avalon, even if it's covered in camoflage, we can at least figure out the car's general shape!
  • toycashtoycash Member Posts: 139
    The Avalon probably will be XM ready like certain Camry, Solara, and Land Cruiser models; but I don't know for sure.
    Just to make a couple of things clear. There will not be a AWD Avalon. The 2005 will go on sale in Feb. of '05.
    Darn! I was hoping for an AWD. The new Acura RL becomes more interesting all the time...but, it's not the quality Toyota. And...thanks for the info on the sales date. February is OK and maybe there will be a specification announcement earlier. Thanks, toycash.....Wes
    Dealers now have the options list and the basic standard equipment list.
    I'd love to see it. Any dealers here?
  • flyfish4lifeflyfish4life Member Posts: 103
    Toycash or anyone, I realize this is not the proper forum, but have you heard any other rumors for future 2006 Toyota vehicles, specifically the Land Cruiser. I have been reading 2006 for the LC and one publication indicated March 2005 for the launch.
    Can't wait to see the Avalon in person, hopefully Toy turned it up a notch in design.
    3 "official" pictures of the 2005 Avalon were posted today on the Autoweek discussion board by Coolmatt, who seems to know what he's talking about. He previous posted there the B&W faxed photo. These views (front/rear/interior) match that. Not sure how to post pictures, so here is the link (the pictures are on page 2):
    http://forums.autoweek.com/thread.jspa?forumID=31&threadID=10- 202
  • coolguyky7coolguyky7 Member Posts: 932
    This seems to prove the previous black and white spy photo credible. These are official drawings as Toyota puts out other sketches very similar to these before its vehicle launches.
    Some observations about the pictures:
    It looks like there will be steering wheel controls for both audio and the climate control system (which is dual) like in the Prius.
    Gauges look to be Optitron.
    That blue screen like in the current XLS will be used again. It seems to have the displays for audio and climate control, and it is recessed into the dash like the current model. Interestingly, there is a large space in the front of the dash with a cover over it. Perhaps this is where the navigation will go versus the current setup.
    There will be a gated shifter with that sport-shift feature.
  • douglas1douglas1 Member Posts: 130
    My guess is that the front of the dash with the cover over it will be for the HVAC and Radio, CD and Cassette units.
    Doug
  • rcf8000rcf8000 Member Posts: 619
    Very impressive. Raises the bar for this class of vehicle. Styling doesn't break any new ground, though.
  • motownusamotownusa Member Posts: 836
    Wow that's a lot of power going to the front wheels. I hope they offer an AWD very soon otherwise torque steer could be a serious problem for Grandpa. :) Fit and Finish looks better than most Lexus. I hope they can keep the price under $35K.
  • cove148cove148 Member Posts: 117
    Impressive information. How is Lexus GS300 going to compete with a smaller engine and a price tag $15K more?
    This may be the sleeper, especially for those who could care less for Nav & brand name and wants a quality car, with some size, for a reasonable price
