Ken
Did the corporate bean- counters dictate such a fragile lens on a relatively high-priced car? Did NO ONE at Toyota anticipate rock/debris damage to a fragile component in such a hazard-prone position on the car? Is Toyota now becoming the General Motors of the twenty-first century, now that they've captured the American market and perhaps don't have to give a tinker's dam anymore here, while continuing their attention to quality and detail at home, where such shoddiness is STILL not tolerated? I'm not just referring to fragile lenses, but, after following comments in this forum for quite a while now, I also mean doors which are jammed-shut, distorted glass, mis-aligned tail pipes, sloppy leather seats, etc. etc.etc...does this not remind anyone of the sloppiness which caused us to abandon U.S. auto makers in the first place??? Is anyone at Toyota of America reading these comments????????????
I've read of two accounts of the Sienna XLE Limited (First Toyota vehicle to feature the DLCC) having their cruise control to be wiped out by some road debris, then not being covered by warranty and having to shell out $2000 to have an entire new laser put in. I also read the same with Lexus LS430 owners over in their respective forum with the same problem. Think of a it, a simple chunk of plastic could prevent a $2000 repair.
And no, the DLCC doesn't have a protective lens already.
http://www.drivingcomfort.com/index.cfm?fa=p&pid=332&src=7543
Please excuse my lack of mechanical aptitude. What is the surround?
Also, in looking at the lens more closely, I've noticed that there appears to be a space of maybe 1/4 to 1/2 inch between the front of the lens and the back edge of plastic; perhaps this plastic is the surround you mention.
Also, when you say I may be able to "... tape it to the back of the surround ...," that has unfortunately confused me a bit more as to the meaning of surround.
Thanks for putting up with me.
Pete
Yes, they were able to fix it. They did not have the piece initially but got it on my second visit and installed it. It is a plastic sheath that covers a screw and holds it in place. It was definitely too small for the hole it was supposed to have been anchored in on the left side. My understanding is that they got another one and inserted it into the frame hole and it held this time. The left side is now quite secure. The cargo net is oem from the toyota parts shop in the dealership but it seems tight/too small. I have had nothing in it but it has pulled/loosened the attachment point on the right side of the trunk now. I ended up taking the netting down because I did not want it to pop again. When I bought the new net it said it was the same one used for the 2000 Camry. I found that hard to believe because I kept the one from my Camry and it is wider and does not pull on the attachment knobs. Perhaps it is a quality control issue with the nets?
Good luck with it.
Here is the beginning of the article, interesting. "DETROIT (AP) -- Almost every automaker made significant strides in vehicle dependability in a new survey, J.D. Power and Associates said Wednesday. General Motors Corp., Ford Motor Co. and Toyota Motor Co., the world's three largest automakers, were top performers."
http://biz.yahoo.com/ap/050629/autos_dependability.html?.v=6
I continue to experience it on a daily basis. I have been assured by toyota that they are not addressing the issue. I call at least once a week to see if they have changed their minds and to let them know I am still out here waiting for a fix. Their stance remains that car works as designed. There is nothing wrong with the car, this is according to the mid atlantic technical guru and the service managers at my dealership and the corporate customer service center (CA). They need to have a certain number or calls logged for the problem before they will even look into it. I encourage you to call the customer service number and let them know you are having the problem too. My service director refuses to drive the car with me, or evaluate it again. According to him they only have to look at it 3 times and say there is no problem then your only alternatives are to live with it, sell it or send it to arbitration. I suggest you make them drive with you until it happens, so that it is documented before they get to the magic 3x and then tell you tough luck/get over it.
I do have to share with you what my service manager told me .. you should be thankful you did not buy a Mercedes or BMW.. you could be out even more money hehehehe (yes, he really did laugh). :sick: : Somehow that did not make me feel any better...
Perhaps this highly technical photo will assist you:
laser thingy
Good luck,
Greg
The cruise control is returned to the non-laser mode by pressing and holding the cruise control activator toward the dash, per the user's manual.
Greg
Hello John,
The 4Q2 mudguards show to be available today. Would you give me a call at 1-800-527-5368 if you are still interested in these. I can get your info and get them headed your way or you can mail me back the info. The set of four with shipping will run you $87.26.
Bill G.
www.anythingtoyota.com
I decided to do this because of the reported $1400. replacement cost + my lens already had a couple of dings in it from road rocks.
NWBLIZZARD
NWBLIZZARD
If you never opened it how can you say you think the website is easier to use? :confuse:
I use Premium, Ultimate, super or whatever the station has that is 93 octane. the best trip MPG I get from my 2003 XLS is around 27 traveling the same route on the highway at 70. More Horsepower, bigger car and better milage...I can't ask for more at 1,000 miles.
Is that flexible vinyl-like sheet that is made for headlights? All you avalon owners should consider buying vinyl sheet protection for your headlights and foglights. It's cheap insurance against pitting and yellowing which eventually happens to all clear plastic headlights. I just replaced my headlights due to pitting on my 5 year old 300M. I could have avoided that if I had installed the protective vinyl. I bought the protectors recently and will install on my new HID headlights.
MikeS -- and what mileage would you get if you drove through town?
Or put in another way -- are there any traffic lights, stop signs, hills in your town? Are you using your A/C these days?
I use 89 octane gas and can match your freeway mileage, but can only get 20 mpg in town, averaging around 30 mph because of traffic and hills and with my A/C generally off. Summer is just starting here, with max temps around 72 F on nice sunny days...
havalongavalon "
I live in West Virginia, known as the Mountain State. So yes I have hills all around me. Although having been raised in California for 41 years I know what mountains REALLY are...Not these pesky foothills We also do have electricity and piped in water in our houses, with flush commodes. We actually have 30 or so signal lights in town.
The weather here the past couple weeks has been 90 degrees and dew points in the 70s. So yes, the A/C has been on full blast. I'm still getting that kind of mileage.
MikeS.
I got an estimate from a detailer for ~$600. to buy and install a custom fit 6 mil sheet on total front end plus part way up the hood. Seemed expensive at the time but still considering... Open for any other sources more reasonable.
NWBLIZZARD
NWBLIZZARD
MikeS.
I have the same problem with the hesitation at low speeds.Can not understand if the people in this chat room are not interested with the problem instead of what I consider to be lesser problems (laser vulnerability,mud flaps etc).Maybe it is just a problem that some people are experiencing.Sounds like I am criticizing those with other problems but it seems more pressing to resolve this problem with Toyota.
Appreciate your thoughts.
mel
Whew! Where are you located? Are there any other sources of protective film? I had 3M custom fitted to my LTD on the entire front end, hood + both mirrors = $275. Shop around.....!
zekeman1
Those owners have had the hesitation problem for fours years now and Toyota refuses to fix the problem. Toyota's standard line to them is 'it's works as it was designed'. That's NO consolation for someone who spent $30k+ and expected good value for their money.
I wonder if the 05 Avalon is using the same transmission/software?
Toyota Ken
"I also mean doors which are jammed-shut, distorted glass, mis-aligned tail pipes, sloppy leather seats, etc. etc.etc...does this not remind anyone of the sloppiness which caused us to abandon U.S. auto makers in the first place???"
Sorry to hear this is your observation. So far my wife and I have only had 2 issues with our new Avalon, a small blemish on the dashboard and ever-so-tiny scratch near the shift lockout on the shifter bezel/cover. Although I do not discount the people who have reported the other problems, after two weeks of ownership we feel like the Avalon XL will be a very dependable car for us. We're willing to bet our money (and time) on it. Personally I can say it's nowhere near the cheapness in quality that I find in the big three American auto manufacturers, whose cars I rent on business trips about 3 times per month.
Oh btw, on my last rental which was in Pittsburgh, I had aToyota Corolla. I returned from that trip wanting to buy one - the more I drove it, the more I loved it
I duct taped my piece of plastic to the back of this "box". Here's the website again if you want a better reference. link title
Park Pilot Backup Sensor is available at:
[sales@anythingtoyota.com]
Pete
P.S. It is surprising how many posts have appeared lately and how many different approaches to this problem have been discussed.
Perhaps I'll post some pics of these prongs later.
EDIT: I'm sorry this is a bit big.
Ok, the regular DLCC with my Sony plastic shield
See how I stick my fingers into the air dam?
You see these prongs on the right? I had to pull these to release the "box"
See the red arrow? It's pointing to where the prongs of the box hooks on to when it's snapped in place.
Hope this helped.
http://biz.yahoo.com/prnews/050701/laf038.html?.v=13
I have the same problem with the hesitation at low speeds.Can not understand if the people in this chat room are not interested with the problem instead of what I consider to be lesser problems (laser vulnerability,mud flaps etc).Maybe it is just a problem that some people are experiencing. Sounds like I am criticizing those with other problems but it seems more pressing to resolve this problem with Toyota.
Mel "
Mel, Avalonkitten appears to have a bad case of the tranny blues. Some others have reported problems but not as severe.
But the majority of us DON'T have a tranny issue or other drivetrain problems. We have been blessed with trouble free or only minimal problems. I've had my LTD since 02/10/05 7,200 miles and the only issue I have is that sometimes the drivers door won't unlatch.
If you were to read back through this entire forum you would find others talking about the tranny issues and rear glass distortion. Try reading the Jeep forums if you really want to read some serious complaints.
Toyota has built a great car at a great price. But it isn't 100% perfect every time. Looks like A'Kitten should either go to arbitration or hire a Lemon Law lawyer. Or sell the Avalon and buy a 99 Jeep Grand Cherokee. Now there is a vehicle with issues for you.
Or look at it this way, people have so little to complain about they find insignificant problems like non colored keyed mud flaps to complain about. Wow, that really effects the way this car runs!
MikeS.
