Me thinks your dealer would be giggling all the way to the bank. He's ripping you off! The antenna costs (at Circuit City if it's not on sale) $39. What's a bracket for? Is this an aftermarket XM kit? If so, they're practically giving them away in order to get new subscribers. Antenna location other than on a trunk lid has been talked about ALOT on this board - I believe it's a no brainer! Roof/dashmount/package deck - it works fine (in addition to the lousy place Toyota wants to slap it).
Go see Best Buy or Circuit City or half a dozen other major electronics outfits and walk away from your dealer...unless you want the OEM kit. If you want that, shop around - prices are competitive amongst dealers or internet based Toyota parts places. Once you get it, enjoy it - I have one in each of my cars & love them, especially when you travel.
zekeman1
BTW, how do you teach Dyslexia???
Greg
1. There is a large section of Penn Turnpike where I-70 and I-76 overlap, so perhaps the Nav wasn't really wrong in that case.
2. The "Go Home" issue, are you referring to answering the "Yes" portion? If so, you need to wait until the prompt completes ("Are you sure you want a route to home?") and the dialog prompt shows up on the screen before pressing the voice command button and saying yes.
3. GPS is not meant to be 100% reliable. We don't have military grade equipment in this car, so sometimes the error can be as much as 50 feet. As a result, the system may think that you're at a somewhat different location when it takes you through a seemly longer route. Also keep in mind, though, the straight, simple route may not always be the fastest. Here in DC, especially, the straight and simple route is often the slowest due to speed limit constraint. The Nav does recognize the difference in speed limit for different segments of the roads, so perhaps it was guiding you through a route with shorter overall time.
Hope this helps.
Ken
I was on the PA turnpike recently and notice the same thing. I scrolled farther down the map and saw the name listed as I-70/I-76. Apparently the turnpike is aka I-70 between certain exits. I also have trouble with the voice recognition i.e. wgen windows are down, or there is background noise and usually just hit the DEST button and click on home. As for the route selection, you can choose between several after you input your destintation, and also specify roads to avoid (heavy traffic areas, or toll roads). While the system may not always direct you to the fastest routes, i think it does a fairly adequate job but it is not infallible and it is always a good idea to keep a map handy like you do incase you cannot receive the gps signal somewhere.
On a side note: Does anyone have wiring diagrams for the JBL system with nav? And has anyone had experience removing the rearseats?
thanks,
Evan
You can put the XM antenna on the roof, above the rear window in center, or on trunk in center, or, as I did, inside the car, on top of dash, at right end of defroster vents, just under the windshield. The Terk antenna is very small and virtually unnoticable in that spot. There is probably a slight penalty in reception with that location, but I've found it to be plenty good enough.
The point of getting the Toyota XM kit is so that it will integrate with your existing JBL radio and the Navigator screen display. Unfortunately, the display chops off the song title & artist to 10 characters - this can be annoying.
Look at post 5279 for picture of small Terk antenna.
Max
Thanks in advance.
I base this on a call with the service rep (who I called at 4:45 pm as he hadn't called "this afternoon" as he promised at 8 AM today.)
In order, here's what I have been told (I'll get the car back tomorrow):
1) RV Mirror bezel rattle: Could be replicated & there was a burr on the plastic anchor tabs. Corrected & driver side checked. We'll see.
2) Warped-mis-aligned glovebox: mine was worse than most, but they claim to have looked at 9 Avalons and all had a gap on the left side. They adjusted it as best they could. Attributed to the spring being on the right side, so the left side wasn't pulling in fully. Without the spring, gaps were fine. In my thoughts, design/cost saving flaw: springs needed on both sides.
3) Loose Driver Side Fog Lamp. We agree the lens is loose. It's assembled correctly. Will begrudingly order a new one, but in my mind a design flaw. They checked the Avalons they had, and it was the same way on several. Potential big problem for Toyota, as lights are "safety related" unlike glove cover fit & finish or rattles.
4) Parcel shelf area rattle: could not be replicated, but they installed felt at the contact areas for the shelf and the strut covers. I'll keep an eye on this one as others have said the strut tower placement needed to be re-aligned along with a resultant rear wheel alignment (I'll ignore comments about whacking them with a hammer.)
5) Exhaust pipes: They agree that the driver's side is around 3/4 inch lower than the pass side relative to the bumper. Nothing they can do. A cosmetic design flaw: I pointed out that if it were a fender 3/4 inch out of alignment, it would be addressed.
6) Trans. Escalated to the Toyota Corp rep (as were all the other isues/problems I hope as we lost a car for a day and had to juggle schedules) with hopefully a software upgrade in 2 months.
Am I happy? No. I'll likely never do business with this dealer again. I've bought 5 cars from a great salesman. Too bad he doesn't run service: he'd never insult me pointing out the difference between an A pillar and a B pillar (over a pass side rear view mirror rattle!) or refuse to go over problems with the the car together. Literally, it was driven to a parking area and the Service Manager refused to have it brought back to review together.
Larry
Just came back from the dealership with the same problem. They also quoted me that the condition was normal. They checked three other cars on the lot and found the same loose fog lights. I have read other posts that the dealership replaced the lights and cured the problem. Don't know what to say. I don't feel that you're being picky. I too have concerns. Another problem is the exhaust pipes are not aligned. Again the service rep checked three other cars on the lot and said they were the same as mine. To them I guess they consider this mis-alignment normal.
Jeff
Sorry to hear about these flaws and also such poor treatment by a Toyota Service Manager. Shame. I'd be equally unhappy under these circumstances.
On your point 5) "Exhaust pipes: They agree that the driver's side is around 3/4 inch lower than the pass side relative to the bumper. Nothing they can do." Actually, there is something they can do tomorrow, since the misalignment is vertical. No special tools, it just requires a rubber hammer... Each pipe hangs from a stiff rubber piece that connects to a finger-like steel support that is bolted or welded to the underside of the car. In my car, a similar (though not so large) misalignment was corrected by a serviceman by bending the finger-like steel support upward, yes with a hammer. This raised the driver side exhaust pipe by about 3/8" and there is maybe space for a little more bending if needed. If this is not enough, possibly the passenger side pipe could be lowered a bit by bending the metal support downward. If you Search this Discussion, there were a number of posts back in March or April on this issue.
I'm also sorry to see that this design flaw propagated through at least 15,628 Avalons (I'm assuming this is your car serial No.?) given the early discovery and plenty discussions we already had on it.
Best wishes,
havalongavalon
Don't count on anything being done. I took my '05 in with complaints of the same phenomenon and they said that it was "the computer learning my driving habits". Talk about total bunk!!! Actually, I think what is happening is the computer recognizes the transmission is downshifting, which requires a higher engine RPM to maintain the same speed, but the computer is overcompensating by calling for a slightly higher RPM than what is required, thus giving you the sensation of speeding up, or lunging forward!!! I believe that enough discussion about this could prompt Toyota to do something about it...could be a simple firmware upgrade to the computer. The transmission in a $35000 car should not be doing this.
Jeff
fragmire, I agree.
For a few weeks when I opened or closed the driver's door, I heard increasingly loud, squaky noises coming from the springs that hold the door at half-open or full-open positions. Yesterday I finally realized that the two 10 mm hex head bolts that hold this spring assembly onto the door, had come quite loose. I tightened the bolts and this cured the excess noise.
Now, soon after I took delivery in March I had noticed another loose bolt in the driver door frame. You can see 3 very large bolts that I believe may hold the dashboard onto the body of the car. One of these bolts was very loose, so I tightened it then.
It would seem as if an assembly plant operator (or robot?) was asleep on the job when my car was assembled last January in Kentucky.
Disappointing. And alarming, because who knows what other assembly steps were incorrectly completed? What may come loose next?
havalongavalon
I am still learning about the NavSys (my first), and I am generally happy with having splurged, except for the @#$% "I agree" screen, and the woefully out of date data. I would expect better living in a major metro (Atlanta). Anyone know when an update will be available? I plan to complain to my dealer if I have to pay full boat for the first one.
I hoped to get XM, and I am really disappointed in the posts about the truncated information screens. That's a cheesy flaw in a car of this level. Being electronic, is it something that can be fixed? (I saw the aftermarket fix posted for the Prius' "I agree" problem.)
But my biggest beef is the recently emerging popular topic of the seats. I realize now that I was so taken by the technology and sheer beauty of this car, that I did not pay enough attention to this all important detail. I'm still experimenting, but after excellent seats in my last two cars (Maxima and Passat), these are a real disappointment. Hard, no contour, no lateral support and lumbar is too high. The only positive is the power bottom extension (which is primo!). I'll be interested in any ideas, because this one issue may really kill the experience for me.
Sorry for the long post. As a newbie, I had a lot to say.
Bill
Mackabee
Denton has a toyota dealership, too - about 10 miles from my house, but Richardson made me a better deal and besides the dealership here always caused more damage to my vehicles than they repaired! I really like the service manager at Richardson. I didn't complain about the rough shifting transmission to them, but will mention it next time. It is really annoying. My 2000 Avalon was sooo smooth shifting - couldn't feel or hear it at all.
Mackabee
I think I know what is wrong with you car but you have to go through the usual dealership incompetancy first, followed by the Toyota Corporate turf back and forth to the dealership, followed by the regional guy taking a drive with you and not knowing what it is. All happend to me. True story. What a different Toyota Corp. than 10 years ago. The vibration can be a number of things. First try the balance of the tires, then see if the wheels are true and no run out. Then have the bright people check the front rotors. Sometimes when they make them, they cool them too fast and the runout is bad on them. That usually happens at higher speeds, while the former at lower speeds. Again, this all happend to me. If this does not work and the front passenger seat belt and seat still vibrate, I can tell you exactly what it is left. But I will let you check these areas first. You can get back to me if you want.
abfisch
Engine 3.5-liter DOHC 24-valve Dual VVT-i V6
268 hp @ 6200 rpm
248 lb.-ft. @ 4700 rpm
Also leasing and finance rates are WAY up for the 2006.
Before any work was done I asked the service manager if he felt confortable in undertaking this job and he assured me this is no problem. I was down this road before and swore I would not ever let a dealer try to fix a new car defect. I am on my 4th trip to get this fixed. Some parts will have to fall off before I ask for warrenty work again. I am not bitter, just not happy as I expected from a Toyota dealer. ange1
The seat comments are interesting. Are the complaints primarily about the LTD seats? We tried out an XLS last week and found the seats to be a great fit and very comfortable. Of course, this was on a test drive, but I found nothing to suggest they would be a problem long term. But then, all bodies are different too.
abfisch
Reminds me of early in my career at a large computer company. An instructor replyed to a comment about 'bending'. He said "We don't bend things. We FORM them." You may want to use that term when suggesting this method to your service manager. :-)
Again, I encourage all who have complaints/problems, to go to planetfeedback.com and sent your feedback directly to the top people at Toyota who can put things in motion. The little guy has no clout, and you are dealing with people 'here and there'. Not a concentrated focus. Much better to all send your input to one guy AT THE TOP who can drive things down. If he gets inundated with complaints, things WILL happen. Try it.
I could get to the site and the message that they are in the midst of a relaunch.
I did previously get an email from them stating that they would be doing this. I think they are consolidating with other services and expanding. They say PlanetFeedback is just taking a brief siesta while it gears up for an exciting re-launch. They will return shortly.
In the meantime, you can find their mission statement here: http://www.planetfeedback.com/mission.html
To be on their mailing list when the site re-launches, or if you would like to beta test and provide feedback on some of their new services, send an email to: consumer@gmail.com I just did that.
This is a great tool. I have used it in the past.
Jerry
The method of measuring power or torqe vs rpm can change, mainly what accessories are on the engine, is there an exhaust system, water pump attached, power steering pump, etc. Testing standards have been set by SAE, DIN. Maybe there is a new update to some of these standards - I don't know.
Max
"by bending the finger-like steel support" ... "We don't bend things. We FORM them."
Sure. I just remember watching my service manager and a mechanic raise the drooping left tailpipe by BENDING the supporting piece. But if you want to be more FORMAL, suggest your service manager to FORM, REFORM, CONFORM or DEFORM this support. Whatever works!
havalongavalon
havalongavalon
havalongavalon
Yep, whatever strikes his palette best. Same thing, only different. :-)
Just don't piss him off, or ask him to do something he thinks is improper, or he may refuse to do anything for you.
