Visitor Agreement.
I made an appointment with the dealer to fix the rattle. In the interim, my daughter was in the car and noticed that the rattle was coming from the Sears Garage opener.
That opener was in my other car (Avalon) for years and I never noticed the sound.
New cars can do weird things to your mind.
I cancelled the dealer appointment.
2. lean to your left until your forehead touches the driver's side window.
3. postion driver's side mirror so that you see the tail end of the car from that position.
4. lean to your right the equal amount that you leaned to your left.
5. position your passenger sideview mirror so that you see the other tail end of the car.
Voila, blind spots eliminated!
Thanks a lot.
Since I have two kids with carseats in the back, I would almost never carry adults in the back. I fashioned the small side cargo net in the trunk as pictured in the manual and it is a perfect place to store the headrests for those rare occasions that I might need them.
I'm one of those people who has a "if it ain't broke, don't fix it" mindset. I think in a lot of ways it makes sense to wait until something is broken before throwing money into it. I am good about getting my oil changed at JL every 5-6k miles, and rotating tires every 15-18k. Is there anything else that I need to be doing?
For instance, JL recommends replacing the Automatic Transmission Fluid (ATF) every 30k miles. I have heard though that newer transmissions have a higher performance ATF that isn't supposed to be replaced until 100k miles. Would my 2001 TL fall into that category? I had my tranny replaced around 10k miles under warranty, so it's been about 50k miles with the current ATF. (FWIW, my transmission is covered under the extended 100k transmission warranty that Honda/Acura put out on most 99-01 models, so if it did break then maybe it wouldn't be so terrible...)
Also the trip computer miles to empty always seems
to be the same around 325 after a fill up.
Eddie G
As far as frequencies, personally I like the new TL's stereo at BASS +1 and Treble +2. Which car did you have before this one? Is it possible it had a terrible stereo with no bass and you simply haven't adjusted to what a good stereo should sound like yet?
This sound system is outstanding! What volume level do you put it on. It's not meant to be turned ALL THE WAY UP- no sound system is. Are you playing it for your enjoyment or so passer bys can hear the stereo? Adjust it so it sounds best for you- dulnev and I have different settings and we both LOVE the system. It's the best from the factory sound system....period!
FYI - For any REM fans out there, pick up the Document DVD-A. The instrumental separation is phenomenal.
The selection of DVD Audios at the Best Buys, FYE and Circuit Citys are very limited...even at Amazon. Forget about Borders or Barnes and Noble which usually carry more Classical and Jazz titles. Any luck finding a source with a large selection or is DVD Audio going to be like Betamax?
I frankly think this won't catch on for a long while (a few years), if ever.
nevertheless, i've found this place to have a very complete selection DVD audios out there
http://www.dvdplanet.com/main_dvdaudio.asp
Eddie
I don't mind being conservative but 3 gallons off is too much. Overall the car runs great.
I think everyone has the seat memory problem. It sounds like Acura is working on a fix. Very minor problem in my opinion.
I recently went to have the timing-belt tensioner replaced(factory recall) at the dealer. Since then, I have been getting 26 mpg on pure highway driving and 19-20 mpg on pure city driving. I am very meticulous with keeping track of this stuff. I track mileage on every tank of gas by reseting the mileage counter. I repeated it a few times afterwards using different gas stations and still the same results......almost a 8 miles per gallon drop!
I took it back to the dealer who hooked it up to his "computer" and said there was nothing wrong with it. He fed me some BS like "it's probably the changes in the weather." Of course, I have had the car for 2 years now and have been through the same weather changes, but never any drop in mileage like this.
I was wondering if any car experts out there could give me some advice on what it could be causing this change. Thanks.
I have to get this fixed it's driving me nuts!
I have also had ???????? about the temp guage accuracy. Also when you fill up what does your
trip miles to empty indicate? Mine always seems to be around 325 but the last time I reset it just before fill up and it indicated 270 doesn't make any sense.
Super Audio CD comes in both flavors stereo and multi-channel, but don’t waste your money, TL doesn’t play SACD.
(that is what it is called on the CD ) that will play in the TL system. Dark Side of the Moon by Pink Floyd. It sounds great also. There is a website listed in an earlier post that has the most DVD-A that I have seen. I ordered four last night.
I have 650 miles on my new TL and the car has exceeded my expectations in every respect other than tires. I canned the EL's and put on Bridgestone LSZ's. Major improvement.
with that kind a eloquence on the TL audio system, I have to get one for no other reason than that.
Merry Christmas
I am extremely pleased with the performance of these tires and have driven them hard in the rain. I can imagine that if your car were parked outside at night the tires may need some time in the morning to warm up but I haven't experienced that yet. They are very quiet.
http://www.dvdplanet.com/browse_subcategory.asp?categoryid=305
Here are the list of the problems we've had so far:
1. Check engine light kept coming on whenever I let the car get over 4500 rpm in manual-matic mode. After 4 trips to the dealer and about a week in the half in the shop they finally figured out that it was a faulty crankshaft position sensor.
2. Seat memory keeps "forgetting" the settings. This is only annoying but we saved for a long time to get a car with these kinds of luxury features and this is really disappointing.
3. Trunk release randomly stopped working for about 15 minutes and then started working again. This actually happened one of the times we had it in for service and the dealer basically said "don't know why it's doing that but there's nothing we can do about it". Luckily this hasn't happened since.
4. The car idles like (IMO) a woodchipper. There is a very noticeable vibration from the engine when you're sitting at a stop light. Sometimes it's better than others but I just don't believe the engine is running right. My mother-in-laws 99 Hyundi idles smoother. The dealer says it's running fine. Anybody else think their car idles rough (even just a little rough since this is kinda subjective)?
Like I said, I love the car, the XM radio, DVD Audio, power, and styling. I don't like the engine feel. I don't know if I should hope that there's something wrong or not. One thing I have realized is that Acura Dealer service centers don't employ any mechanics. If the computer they plug into the dash doesn't tell them there is something wrong, they can't find the problem. I've been to the dealer for problems 5 times in less than 2 months and 2000 miles and I still think the only time they actually popped the hood was to install the new crankshaft sensor.
Anybody offer any advice or similar experiences? I don't get the vibration at speed that others complain about so I guess I've got one good thing going for me. I mainly want to know if anyone else thinks their TL idles rough (or is it "normal" like the dealer says).
I can tell you that my 1998 Accord was so quiet/free of engine vibrations at stops, that I would sometimes try to start the engine, even though it was running. But as I started getting more powerful cars: 2000 TL, 2003 TL-S and 2004 TL, the engine wasn't as quiet/vibration-free. The 2000 TL was just marginally worse than Accord in this respect, but the 2003 TL-S was a LOT worse. But it was still nothing annoying, I just knew that the engine was on and there was a slight vibration coming from it.
The 2004 TL improved on the 2003 TL-S and I can't say that I've noticed any vibrations or noise at stops. This doesn't mean they don't exist (I'll try listening to them next time I'm in the car), but what it probably means is that they are better or no worse than my previous car.
If your car is having some annoying vibrations at the stops, I would definitelly get it checked out. Especially given your other problems. I would also try to take it to a different dealer (if you have this option). Sounds like your car might've been among the first 10 off the assembly line and you may have yourself a lemon.
Regarding the rough idling, I'm just wondering if you usually leave the HVAC in full auto mode all the time. If so, maybe it's the compressor kicking in and out. Part of the reason I manually turn off the AC when not needed is that I feel the engine idles smoother that way.
The car runs at surprisingly low RPMs.
I'd love to hear if anyone else notices the same thing.
I should have never bought the first model year car, even from Acura.
BTW, had a big rattle that turned out to be the visor mirror cover rattling against the light on top of it.
