Is it all mechanical parts or is there a digital part (sensor)?
Is it possible that there is something wrong with Shock absorber and suspension system in TL?
And this may cause sometimes shimmy and sometimes not.
From what I hear the Blizzak tires are terrific in winter. I'm looking at buying some on TireRack.com. But I'm also considering buying their "wheel and tire" package - where they ship them to you already balanced, and I could just put them on the car myself.
My question to the forum is, have any of you done this? Anything I should be on the lookout for? It's certainly more expensive to buy the wheels AND tires, but I'm thinking it will be less hassle long-term to do it this way. I have plenty of room to store the wheels/tires in our garage or basement.
Presently the '05 has 52,000 miles and is running like a top. My plan is to drive it another five years and then give it to my daughter who will start driving at that time. So I think we'd get some good use out of winter tires.
Thanks in advance for your thoughts/help.
I don't necessarily believe them, but after two tires shops over 50,000 miles, and two sets of tires, I'm done trying to figure it out. I would take it to the Acura dealer but their rates are crazy (I can afford them, but refuse to pay it unless absolutely necessary). I just bought some wheels and winter tires on tirerack.com so we'll see if these are any better come winter.
Good thing I like everything else about the car!
just wondering how much it cost (or how difficult it is) to do the fronts or rears?
took the car back to my acura dealer had the tires balanced, a front-end alignment done and a little extra pressure put into the tires; even had the mechanic look at the suspension and struts/shocks to make sure everything was okay but I mean the car only had about 1k miles on it so I didn't expect it to; everything with the suspension etc was okay and the dealership said it had to be something with the tires; the balancing and front-end alignment did nothing to fix the vibrations/shimmy
since I had the base car I had the bridgestone EL400 tires on my car and if you read about these tires on tirerack.com you'll see how lousy of a tire they are; took the car to a bridgestone/firestone dealership and told them about my problems and they told me that bridgestone is aware of a problem with these tires causing moderate-severe vibrations/shimmy in vehicles and is why they came out with the top of the line bridgestone serenity's; these are an expensive tire roughly $245 a tire for the TL but I was able to make my case to bridgestone and was able to get a take off and have four serenity's mounted and balanced for $100 bucks total
I know have about 11k miles on the car and since having the serenity's put on have had no vibrations/shimmy in the car at high rates of speed; overall I've been very happy but these tires are really expensive and I could not have afforded it without the adjustment, but after reading the poor reviews of the EL400 on tirerack I'm surprised Acura is still putting them on the cars; just read the reviews on tirerack about the bridgestone serenity's and you'll see a night and day difference between the stock EL400s
Guess what? It's back again and I go in Monday for the 4th time?
Is this perhaps a known problem with 08 TL's? Mine only has 12,500 miles on it
Still hoping someone can answer my other question!
The odometer just hit 140000 on my 2002 TL-S that I bought back in Nov of 2001. I bought the wheel and tire package from TireRack for the first winter and 8 winters later I am just getting ready to replace the tires for this winter. (Last winter was a little more slippery than usual as I squeezed an extra winter out of them.)
It's easy to switch the wheels before and then after winter. If you clean the wheels, give them a quick coat of wax and mark them with chalk or a crayon, you can easily rotate them when you switch and both sets will continue to look almost new (as mine do).
I'm also thinking about changing and upgrading the brakes when I swap the wheels/tires for winter. I'm sure the info is somewhere in this forum, and I'll do a search, but if anyone knows this information off the top of their head I'd appreciate the following:
1) What upgraded brakes do you recommend for a 2005 Acura TL? I hear the Brembo brand tossed around quite a bit. I wouldn't mind a little more "oomph" in my braking power.
2) I recall hearing that I may need some sort of special tool to get the brakes and/or pads off, is that right?
A few days later the back brakes started making some weird scraping noises. Not wanting to bother Dad again, I called a local mechanic and inquired about the price. Cost to replace rear pads/rotors: $400. (I can only imagine what the Acura dealer might charge). So I went out and bought high-end pads again for about $45, and new rotors for ~$55 (for the pair; fyi Acura dealer wanted $130 EACH for the rotors). My Dad replaced them last night and once again said it was very simple. I'm not sure I'd tackle it on my own because I'm not that handy and I'm always afraid I'll mess the job up and wind up costing myself a lot more in additional repairs. But the car/brakes run like a top now.
I've hit 26K miles and it's time for the B12 service visit. I called my local Acura dealership and was quoted $260! I'm suffering from sticker shock.
Thank you in advance for your input!
Your mileage may vary.
I am now at 85,000 miles and the transmission has failed, but the car is now over 7 years old. Dealer is quoting me $2500 for a new transmission.
What are the chances I can get Acura to honor the warranty?
If they won't, can I get the transmission replaced more cheaply?
Chas
What do you know. They paid it in full.
Give it a try. They cannot do more than say NO.
I'm reluctant to buy new remotes because I'm not sure they are the problem--especially since #2 hasn't been used much at all. Appreciate your help.
To relink repress both lock and unlock buttons simultaneously and wait for the 1 SECOND SINGLE red light . The double red blink indicates unlocked !
Step 2: Page 101 owner's manual
Note that the memory settings are ERASED when you unlink and resets it to default, so you may have to go back into the car (after relinking the remote) and reposition your seats and outside mirrors to where you want them. THEN on the DRIVER's door, PRESS and RELEASE the MEMO button (you will hear 1 beep from the door) then IMMEDIATELY PRESS button 1 on the DRIVER's door (or 2) to lock in the new positions into remotes 1 (or 2) respectively (then you will hear 2 beeps from the door). Also, be sure the car is in PARK with the ignition ON the II position (idling works also as I recall) to do this otherwise the positions will not be locked-in.
Hope this helps and that it works for you. Let us know..
I had 3 mechanics take a look at it and they can't figure it out. It's almost like a knocking sound. At first we thought it was exhaust...like a loose heat shield.
was told by my Acura dealer that this was factory misalingment of the glove box and dash and they worked on it for two days and replaced the glove box
got the car back and no change in the buzzing/clicking vibration sound in the top part of passenger side dash; the noise is really bad on secondary roads with a lot of bumps; it almost sounds as if there is a piece of plastic or something loose in the dash and when you go over a bump or an uneven road it makes the noise
I'm at my wits end because the noise really gets annoying at times and I can even hear it sometimes over the radio when blasting it at volume 14!!!
I really like this car but I mean the noise is ridiculous and I mean the only thing Acura could do if I make a stink is to tear the dash apart to try and find the noise
The gaps and misalignments were fixed a little bit with the replacement of the glove box but it still doesn't look as good as the driver side panels do and if the glove box and dash are loosening up and pulling away from each other then that might be loosing something up in the dash that when I go over bumps you hear this rattling/clicking sound
any information, similar noise experience, and recommendations would be greatly appreciated!!!!
I tried your suggestion and viola! got both remotes linked. It was stupid of me to assume that 2 LED blinks meant ok/linked. I thought that because the memory button for the driver's seat beeps 2 times meaning "memorized."
Your patience and detailed response is very much appreciated.
Due to my chaotic schedule, I won't be able to take my '07 TL in for the service (B12) at 27K miles until this weekend. The "service due now" message is now flashing and the oil is at 0%. Are there any risks with driving it for a few more days until I can take it in for servicing?
Is driving my TL for another 50 miles completely detrimental to my car?
Thank you in advance for your expertise and input!
I dare say you could probably drive another 500 miles without any detrimental effect to your engine. I just don't think the electronic service minders are as sophisticated as they try to lead you to believe. For example, can those things really measure accurately the actual condition of your oil? I think for the most part they are just a fancy mileage counter. Yes, your average speed, avg operating temperature, etc are factored in to a degree, but at the basis of it, it's still a mileage counter.
Thanks for the input on the "service due now" message.
Onto a new issue- the tighten fuel cap message has appeared periodically and it started up again last night after I filled the tank halfway. I unscrewed the cap and then tightened it again (several clicks) but that didn't seem to fix the problem. Any suggestions? It's a little bizarre not to mention annoying!
What should I do? My friend says her emissions lite came on when she didn't get the gas cap on right. She had to have it reset. Mine is not under warranty. Will this cost much?
Thanks, again!
But if that doesn't work, then be sure to take it in and have the dealer run a diagnostic on it.
I happen to think it is sinister, menacing and it's sharklike design is purposeful and I get compliments on the car all the time.
Oh, and lets also not forget that the TL is Acura's best selling car right now.
Hummm, guess you are in the minority on this one. Personally I think the 2007 TL is a ripoff. Way too small and overpriced. The new TL is as big as the RL and drives like sports sedan should. You'll be waiting another 6 years before this body style changes with a mild refresh in between. Maybe you should look at Lincoln.
Anyway, I have had my TL AWD for about three months now and I have never gotten a negative comment.On the contrary, I was at a gas station several weeks ago and two dudes walked up to me and said that the TL is the hottest car on the street right now.They also went on to mention that mine was super hot-
*White diamond pearl with the ebony interior
*35% Tint
*Wood Wheel
*Back up Sensors
*Wood Shift Knob
*All Weather Mats
Picking up the Cargo Net this weekend.
Just wanted you to know that this method worked! I had to go out of town and was worried about the light. As I left the gas station, the light went off.
Thanks for your input! I'm happy again!
Loangirl 1
again, i seriously doubt a total stranger insulted you at a gas station. geez, the stories people make up to justify their feeling.
