I was told by the service mgr. at my dealership that no fix was available. He suggested using the manual shift function to downshift and stay in the appropriate gear.
Maybe I was too forgiving. I just said OK and goodbye.
I'm dubious about Toyota doing anything on a model that's been discontinued, but I'm willing to be wrong.
Meegwell
It is important to realize something here.
When you roll around, the car engages the clutch. Then the car re-engages in first gear when you press the gas. This makes the car lurch (pause while it chooses first gear, and then push in too high a rev in first gear). This is the gap I think you mean. It IS a design defect, but it is not fixable (because they all came that way) and it is harmless. One way to avoid it is to put the car in second gear (I'm assuming you have the dual manual/automatic transmission which you can switch to manual when you are in a parking lot before a speed bump) and then accelerate.
Just a thought.
Alan in Los Angeles
There seems to be a large price difference between the SLE and the SE. I am having difficulty finding out what the differences in options, etc. there are between the two. In other words what do you get on the SLE and not on the SE?
I just noticed that when I roll down either of the front windows, and rest my arm on the black molding, it is very brittle and scratches my arm!!! :mad:
I didn't notice this problem last fall. Of course, I didn't do the 'arm thing' during the winter, and was really upset when I noticed it this spring. My 06 vert is always garaged..... has anyone else had this happen? Can the moldings be replaced?
It is also important to inform the local TV investigative reporters. It could also be effective if national investigative shows such as 60 minutes, 20/20 and Prime Time were contacted. Toyota is a large corporation who obviously is not as nice as their reputation. A corporation like this can not afford such a comsumer problem in mainstram news.
Let's all make these SOLARA leaking problems media events. You will hear more from me. Toyota the company of quality cannot afford the world to know this major issue. It will cost them millions maybe billions. Put the word out to all you know everywhere you go. Also post the dealerships where you bought your vehicle.
I bought my Toyota at Bohn Bros. Toyota in Harvey La. (New Orleans Area, they have not been helpful in resolving the problem.)
If anyone knows other newer Solara convertible message boards I'm all ears!
The build date is located on the VIN (Vehicle Identification Number) Plate located on the drivers side door frame.
If the computer was bad, how reliable is its analysis of the original air bag? I'm supposed to believe that an air bag went bad, causing a 'short' that fried the computer. Is this believable to anyone else? Or do you also smell a service dept. covering its [non-permissible content removed]?
Due to LOTS of 'out-of-state parent medical issues' and resulting travel, the purchase of my backup camera has been postponed. But...I AM READY!
I went to the Crutchfield site, saw the BEC106 that you have...and also saw a 'Boyo License Plate Camera' (I think these are new....)
http://www.crutchfield.com/g_277650/Rear-view-Cameras.html
What do you think? My initial impression is that it might be too noticeable (possibility for theft) - do you agree? Is your unit pretty well incognito??
1) Leaking roof. Says he hasn't had a leak so far. Is there a way I can confirm this without taking the car to the car wash? :-)
2) Body shake. This is pretty easy to confirm/deny.
3) Hesitation on acceleration. Again-pretty easy to confirm.
4) Odors. Didn't smell anything when riding in it.
What other major things could I be missing? BTW, from what I have seen, my uncle takes very good care of his leased vehicles and doesn't gain anything to profit.
Can you get the maintanience history from your uncle or the dealer/service station that he had it serviced?
Re: your checklist:
I've got a 2006 convertible. I'm not planning on selling it until Toyota comes up w/ a hybrid version.
1) What I've learned on this and other channels is that a fast way to start a convertible leaking is to take it to a car wash. The water pressure is just too much I guess. IMHO a garden hose would be more reasonable.
2) It's there but it's minor -- not a big deal unless you've got a lot of bad roads in your area.
3) This is a function of the transmission as readers of this forum know. The workaround is to use the manual function. That eliminates the hesitation.
4) Thank goodness, we've never experienced that problem. That tells me not all Solara's will have that problem.
Questions for Edmunds:
Has anyone ever done any science on that problem? Were those cars all built in the same plant perhaps? Did they all have some other characteristic in common that could isolate the cause such as glue lots, upholstery or carpet lots that could have gotten wet and developed mold? Toyota ever come back w/ an explanation?
Meegwell
If anyone else has had this problem please speak up. My problem could be due to water creeping in and shorting out the wiring. At this point I just don't know. But I am highly frustrated.
It's currently at 31 K, which would be below the 36 K he's capped at. I can easily get his maintenance records. He's gets his oil changed every 3K.
Thanks for the advice.
frogham
The steering wheel is loose when turning left or right.
Does any one experience the same problem? Is so what was replaced?
Thank you for your time
I am really worried about how this is going to impact the car's performance in the winter. I will have to drive in snow and ice and know this is going to cause big problems in messy weather. If Toyota has made a fix for this issue in other cars why not this one? I bought a performance vehicle that does not perform. It is a great car other than this, but this is a huge issue. What can we do to make Toyota fix this?
I am amazed.
I heard the top should not be wasked at a high pressure delivery system car wash. Damages the sewing and can cause leaks. What do you all think?
