Toyota TACOMA vs Ford RANGER - IV
Do you mean the amount of space in between the bottom of the tire and the road??? Hey, you're right! It IS the same!
"At TRD, we are proud to provide only "Toyota-quality" aftermarket parts and merchandise, which are available at Toyota dealerships nationwide."
I think we have run out of things to debate but I will take TRD's word on what they are and what they do. The definition of aftermarket from Webster's is as follows:
1 : the market for parts and accessories used in the repair or enhancement of a product (as an automobile)
2 : a secondary market available after sales in the original market are finished
If TRD says they are aftermarket and the they clearly fall under the dictionary definintion of aftermarket then to me they are aftermarket.
Does anyone have any knowledge of the amsoil airfilter?
smcpherr, obviously you must be talking about a 2WD Ranger not a 4WD when talking ground clearance? We have already gone this round in this room before. I have a Ranger with P265 75R16 all terrains and the ground clearance is about 1/4" lower than my friends TRD.
Pics spoog? I notice you keep dodging that one.
And the bubble bursts! TRD is aftermarket! LOL. And to claim their are more aftermarket parts for a Toyota than a Ford is showing true ignorance.
Off the topic. Has anyone else in here experienced the fullsize vs compact truck on the road scenerio? I had a guy in a Huge, I mean HUGE Ford F350 pull up behind me and ride my a.. for miles. I hate those damn big trucks that are for show only. Heck, you couldn't even fit those things into places where compacts/Jeeps go! They are only good for show, and to tow in my book. Have also had them try to race me, cut me off. Ok, I'm off my soap box.
See you in the hills.
Jack
Oh boy, 600 MHz is REEEEALY fast! Dell is rather nice compared to the Packard Bell. . .
(1) KKM Tru-Rev Kit (www.kustomz.com) or FIPK
(2) Cat-Back Exhaust (go Gibson or Borla stainless for extreme longevity)
A chip and the previous two mods work really well together and should get you about 30hp and 30ft/lbs of torque. After that you can look into headers, MAF's, TB's, ignition systems, porting/polishing, extrude hone, gearing, and superchargers. There are many other mods too. How much power you can get ultimately depends on the size of your wallet.
I think that exhaust referenced is about 250 bucks and the superchip from Kurtz Kustom is about 225 bucks. I splurged on the 25 dollar polished metal oil cap to dress the engine up a bit.
I think the 3.4 V6 is rated EPA at 16-19mpg.
Hmmmm, what does that tell me?
The reference to Ford SVT is as close as you can get, however you can order an SVT or buy an SVT new off the lot. I do not think that is the same on some of the TRD stuff, like the charger. I know that you can get TRD heavy duty suspension parts that exceed the normal parts and TRD brake pads that are not stock. The Toy parts place has those red and white boxes of the stuff.
It is not a bad idea for that stuff from Toyota.
OK will you buy borderline factory equipped and/or aftermarket?
To answer your question, if it is a Ford 351 but it is not a stock configuration, I would consider it aftermarket. Now the Mustangs today have a 302 but then there are Ford racing 302's. Different engine, then aftermarket.
Lets be more to the topic. If I dump a Ford 4.0L OHC Explorer engine in my Ranger, I am aftermarket even though I am replacing a 4.0L original engine.
Clutch cancel would have given me something to push while sliding back into that tree. Kinda take my mind off how bad my wife was going to be angry. . .
"Clutch cancel would have given me something to
That and an auto locking button for a locking diff probably would have gotten you out of that............................
Spoog, I think the clutch cancel switch comment was tongue and cheek. But if you really think it would have helped I would humbly accept your knowledge and wisdom on what this feature does besides allow you to bump the starter with the truck in gear. I'm serious, I am an off roader-more high speed desert- and I don't know what a clutch cancel switch would help me with. I know on one of my friends early Broncos he did not hook up his safety switch to his auto and you got be real careful you're in park or neutral before starting it.
2. To burn out a perfectly good starter motor and or drain a battery.
3. To put a kewl button on the dash so your girlfriend for the night can say "Was zat?"
Saw a segment on Trucks TV where they had a home workshop for you truck. Off the 80 amp alt. you get power for your power tools and an arc welder for repairing your frame on the trail. Can the TRD version be far behind?!?
"1. On a slope, stuck, cannot push in clutch for
fear of falling.
or drain a battery.
version be far behind?!?"
lol. Sounds like someone is jealous of options they can't get. Thats ok.
A clutch start cancel switch is useful in many ways. I guess you really dont do any serious offroading. That little switch has saved me a few times when I am driving like an idiot up a steep muddy hill and I let the engine bog out.
Im stuck in a couple of feet of mud, with the engine stopped. Now, if I depress the clutch, I will get wheel slippage, which COULD possibly get me stuck and in need of a tow. Remember Cspounser...wheel slippage is NOT good when in mud or slick situations. Its sometimes the very thing that makes you stuck. So, i just keep my foot on the brake, and fire up the ole' engine without any slippage at all, allowing me to cruis e on up the hill. This sort of switch was developed for safari and military toyotas in Africa and the Himalayan area. It's a hardcore option. A CLUTCH bypass switch..if you will.
Now imagine someone who doesnt have this feature. The bog out their engine on the hill, but they have GOOD ground under them. So, they depress the clutch, and as they do, the truck slides back just enough to hit the previous deep wheel ruts.....they fire up the engine and put on the gas as the momentum of the truck is going BACKWARDS..........causing it to spin EVEN more in its own previous ruts, greatly increasing your chances of being stuck.
In my old 22re toyota 4banger, I had this switch as well. It saved my butt many of times.
It's okay if you dont understand it Cspounser. You dont really offroad that much. Its a VERY useful feature for any one travelling in steep, slick terrain. This is one of the reasons toyota is so highly regarded. They offer TRUCK features. They emphasize TRUCK features, not vanity mirrors and heated seats.
Like 4wheeler says " The toyota tacoma offers TOUGH TRUCK features the others just dont, and they ALL WORK. So we introduce our UNANIMOUS pickup of the Year,
the Toyota TAcoma"..
TRUCK TV? lol!!! More like REDNECK TV. I have yet to see a foreign vehicle on either cAR TV or TRUCK TV. Makes you wonder.............
Heck, all of TNN is just a big redneck fest anyways.
Perhaps you should read up on the Toyota design in starter coils...........gold plated anyone?
I NEVER had to worry about the battery draining too much from leaving my lights on all night either. I STILL dont with the Tacoma. Its called proper engineering. I used the clutch start switch COUNTLESS times, and it had no effect on those parts at all.
My neighbors would call me at night and wake me up telling me my lights were on in my truck, and that I better turne them off. I would always tell them " so. its a toyota. I dont care", and laugh. I wouldnt go out and turn it off.They would think I was nuts, but the next morning I would head off to work without any starting issues at all. lol. You just don't worry about those things with Toyota trucks.
Spoog, you claim I don't give links? All over the first and second Ranger vs Tacoma room I gave tons! You and others (hind, wsn,) would just dismiss them, or better yet not read them. I gave facts, sites, reviews, I'm just tired of posting them over and over and over and over..... and too just have them dismissed.
Spoog, pictures? keep on a duck'n we all know you don't own this TRD supercharged. Go find picture at least in a magazine and post it!LOL.
And spoog the one who claims his so called TRD SC
can beat a lighting? LOL. Lets try www.F150online.com and see some stats. how about 0-60 in 6.5, 340ft/lbs of torque, .88 skidpad, 13th fastest production vehicle EVER! Nope Ford is not performance minded.
See you in the hills!
Actually, I was off-road quite a bit this past summer. Whey I owned the 81 Toy P/U took it a few places that 2 wheel drives are not suppose to go. And the 71 Landcruiser I owned, well it can speak for itself as to where a cruiser can go. It did not need a clutch cancel switch.
There were just some nice trucks on that show this time, some hints on prep of a vehicle for water crossings and a real nice restored 55' Blue Oval F100 dressed out and powered by a 351cid Cleveland engine.
Say spoog, how many 1955 Toyota trucks have you seen in shows and on the road lately? Ranger comes from a fine line of tough trucks.
Seeing that 55 kinda remineded me of the chance I had in 1976 of buying a guys 54' F100. Regret not getting that truck now.
http://carpoint.msn.com/Vip/UsedRelOver/Ford/Ranger/Used.asp
But nowhere on the page does it say how it came up with those little colored boxes. Not to mention we have all beat the carpoint review people's opinion to death already. Remember accept both reviews (Taco and Ranger) or accept neither. So in answer to your post we didn't ignore your link we just found it to be not very valid. Don't you dimiss spoog's link because you beleive it has error in it? So your link is dismissed for the same reason. Case closed!
TRD Input
The local Toyota dealer here in NH has a SC 4Runner here on the lot. It is new. Does that make it aftermarket? I'm not arguing the TRD website quote, but it is coming from the dealer as part of the deal. Covered under the trucks warranty! Also if you get a cd player in most cars and trucks. it is called a dealer installed option or somtimes port installed. Does this make it aftermarket? Just a ?
-wsn
Why do you think a 96 4runner with 100k miles list for 14 grand? Because the darn things just go and go and go and go. As usual for toyota, they lead all mid range SUV'sin ground clearance.
They offer the best offroad options as usual, and the v6's can be fitted with the TRD SUPERCHARGER.
Many magazines and reviews consider the Explorer to be the wrost offroading SUV currently manufactured. It and the Expediion and EXCURSION have the dubious distinctions of being extremely poor offroaders ( check ot EDMUNDS land cruiser vs Expedition test). Also a recent review in MOtor trend had to have the Expediditon towed several times while the Grand Cherokee, Rodeo and Tahoe just plowed along.
If you like to tow and want people comfort, ford makes excellent SUVs. If you want sportiness, solid handling, responsiveness, and good offroading, steer very clear of the Ford SUV's.
The Ranger is by far a better vehicle off the trail although it too is hampered with a highway suspension and designed with that similar Ford philosophy.
The 4runner could be improved with more shoulder and leg room. But how can you go wrong with a vehicle that has such freakish resale value? The thing is a tank. It will take anything you dish at it. Very few vehicles are built to the standars of a 4runner.
Hey Vince......shall we dig into the NHSTA data on the Explorer verse 4runner!!!!! hahahahaha!
The runner is even more bulletproof than the Yota trucks. lol.
But in line of Toyota reliability I can offer this comment. My 78 Corona with the 20 R engine required a starter at around 100K. It is an electrical component and is subject to wear and tear and on a 4X adverse elements. Also, it is only as good as the battery, which after 3-4 years in most cases is well into it's life. For example, if your stuck, starter under water and or your engine has sucked H2O you may not be able to use the feature.
I was mearly SUGGESTING spoog that using that clutch start cancel switch creates a strain on that component. If starters heat up too much damage could result. The book on my sons recently purchased 94 suggests to use it ONLY in a difficult situations to use the motor as a seudo winch to attempt to extract the vehicle from the situation. Notice I said "attempt". It is a nice but not necessary option.
spoog says:
"Many magazines and reviews consider the Explorer
manufactured."(psst, I left the spelling errors)
Wile I do not dissagree that the 4Runner is a notch above the Explorer, I suppose you could cite quotes on your comments that directly compare the two. Otherwise it is only what you often accuse vince of:
Hearsay.
Check out the review in Edmunds : " Battle of the Big SUV's".
Check out the 98 Motor Trend review of the "battle of the sport utes"
Check out the 98 Road and Track " Battle of the middle class sport utes"
Check out Petersons offroad 99 review of the 4runner.
Indeed, the most telling aspect is the inherent design philosophy put into the Explorer. It always has the lowest ground clearance, the suspension is always favored for the highway ect.
The fact that Ford was placing Taurus brakes on their Full size pickups and SUV's also leaves a b ad taste in the mouth.
Anyhow, this is all off topic. However, the design philosophy of the companies that make Rangers and Tacomas IS important to this discussion.
On the other hand, I believe the Ranger to be a capable off-road vehicle when properly equipped. It might not be the creme de la creme of off-roading, but it hasn't been castrated into a mommobile like the explorer. Ford doesn't build any serious off-road SUV's anymore. The old Bronco is gone.
I'm not getting down on explorers. I like them for what they are, a decent, safe family hauler that isn't hampered by the weather. I think the expedition and excursion appeals to those who are lacking in other areas. I wonder if they've ever read Freud...
Expedition vs Land Cruiser, LOL. And once again spoog fails to mention the huge price difference, along with the interior dimensions, available V8's, towing capacity, passenger capacity. The Expedition dwarfs the Land Cruiser.
OK, I'm off topic I'll stop.
And spoog ducks again, pictures?
And no rebuttle to the F150 Lighting? Truth hurts huh? Ford is not performance minded, right?
Cspounser, I agree it's sort of like a winch. I don't think it will help you much if you're already sliding backwards with your engine stalled as spoog alluded to way back when.
-wsn
Good points about the SUV's.
Vince:
Are you SERIOUSLY telling this board that the Expedition is a better vehicle than a Toyota Landcruiser?
Did you read that Edmunds comparison test? Did you read the part about how the " Expedition felt like it would fall to pieces after three drives on rough roads"?
Come on Vince. You are talking about the LandCruiser here. It is a legend. The highest resale value of any vehicle, period. The things are absolutley bulletproof.
Also, I find it interesting that Ford copied the
third remove-able third seat idea from the LandCruiser.
There is about a 10 k price difference between the two vehicles, and it is worth every penny to get the LandCruiser.
"Toyota should be
afraid, very afraid when Ford puts this V6 in its
Rangers. "
Once again, Vince plays the "waiting" game.......
"...If Ford did this the Toyota will be sorry...."
" Just you wait toyota when Ford does this....."
" NExt years Ranger will scare toyota........"
" IN a few years the Ranger will have this........"
lol. Lets talk about the TRUCKS WE HAVE NOW....you know, the one you BOUGHT that sits in your garage?
Or are you running out of straws to grasp Vince?????
http://www.edmunds.com/newtrucks/2000/ford/explorer/xlt4wd.html
you get this and more about Explorer:
Since...1991...Ford Explorer...at the top of the sport-utility sales heap."
"...the Explorer gets just about everything right..."
"The interior instills a feeling of quality..."
"Ford has a philosophy of building vehicles that everyone can be happy with."
"...thinking about buying a sport-ute, chances are you've already checked out the Explorer. If you haven't, do yourself a favor and find out why there are so many of these trucks on the road."
and from here:
http://www.edmunds.com/newtrucks/2000/ford/expedition/xlt4wd.html
"...Ford Expedition...nice balance between comfort and function, and its ability to seat nine people makes it popular with large families and those who have to haul stuff around. Nevertheless, we can't overlook the Dodge Durango and the outstanding Chevrolet Tahoe and GMC Yukon when discussing big trucks. In the last few years, the mid- and full-size sport-ute market has gotten very competitive and the choices are much more difficult to make."
Hmmm where was Landcruiser mentioned in the compare?
Sooo, why don't you list your URLS that you are refering to that are not favorable to the Explorer and Expidition, ok?
Could it be that you are refering to the Town Hall compares between the two where people offer their OPINIONS?
Here is the URL:
http://edmunds.com/edweb/whitmore/99Full-Size.SUV.Comparo.rt.html
(note: some aspects of this conversation ARE relevant to the inherent design philosophy of the makers of the Toyota Tacoma and Ford Ranger)
"Helping us navigate Class I and II trails was probably no big deal for Tedeschi, but it proved to be more than enough for us to gauge the off-road abilities of our assembled troop of vehicles. When the dust settled, it was clear that there was one vehicle in the group, and only one, that was purpose built for serious off-roading: the Toyota Land Cruiser"
"Unfortunately, the Expedition was perceived to be the vehicle most likely to break during the off-road section of our test, and proved too difficult to drive confidently during the on-road section of our test. It was also the most difficult vehicle to load with our luggage, because there is little room behind the optional third-row seat. The third-row seat can be folded, which is what we did in our test, or it can be removed entirely. However, folding or stowing the seat knocks the Expedition down to five-passenger capacity.
The Expedition is a sales-leader in this growing market, and will remain so as long as people keep buying big sport-utes. Like many of Ford's products, the Expedition takes aim at a large group of people instead of a narrow, targeted market. The result is that the Expedition can win the sales crown without being the best in any single category. The idea is: appeal to a broad group, sell to a broad group. From a business standpoint, it's hard to argue with that type of idea. However, since we're journalists, not businesspeople, we'd like to see Ford concentrate more on a few specific areas, like on-road handling and off-road ruggedness.
" WE WOULD LIKE TO SEE FORD CONCENTRATE MORE ON A FEW SPECIFIC AREAS, LIKE ON ROAD HANDLING and OFF-ROAD RUGGEDNESS".
Pretty much what I have been saying all along.
IT WAS CLEAR ONLY ONE VEHICLE.......ONLY ONE VEHICLE..........ONLY ONE VEHICLE.........TOYOTA DESIGN PHILOSOPHY......ONLY ONE VEHICLE........TOYOTA DESIGN PHILOSOPHY........
Although none of the trucks in this test was a slouch, none came close to matching the Land Cruiser's interior luxury, highway performance, off-road prowess, and all-around livability. Not the biggest, but by no means small, the Land Cruiser can haul seven people with its optional flip-down rear seats, or can move a considerable amount of gear. Beyond that, the Land Cruiser possesses an unimpregnable build quality that no amount of off-roading can tear apart. "
What was that you were saying about the Expedition and Land Cruiser Vince? Lol.
DONT even get me started on the 4runner vs explorer issue.
These design philosophies are passed RIGHT DOWN the LINE, wether you beleive it or not. All auto manufacturers stake out a philosophy with their more expensive models, and pass that engineering philosophy right down line. This has been proven and CLEARLY shows. The Landcruiser Expedition comparison tests mirror EXACTLY the Tacoma /Ranger comparison tests in 4wheeler and Petersons Offroad.
That was my main gripe.
Now THAT is a 4 wheel drive machine compared to the current landcruiser.
Oh by the way, it and I NEVER needed anything like a clutch cancel switch or a locker. . .
Just thought I would share. . .
Did you even bother to read the link? Edmunds chose the Landcruiser "hands down"!
They picked the Expedition "most likely to break"!
They SINGLED out Ford and basically called them a good business marketing company, but not much else. They even went so far as t say that Ford needs to concentrate on making more rugged vehicles!
They picked the Landcruiser for its ON ROAD HANDLING, OFF ROAD PROWESS, EVERYDAY USE, COMFORT!! EVERY SINGLE CATEGORY AVIALABLE!
What is it you don't understand about the english language?
I am NOT concentrating on just offroad. The Landcruiser took the cake i nevery single category they offered in that comparison test!
HEre you go!
( all quotes taken from http://edmunds.com/edweb/whitmore/99Full-Size.SUV.Comparo.rt.html)
"but at the end of our journey the decision of who builds the best full-size sport utility was easy to make. "
"After a few minutes behind the wheel of the Toyota Land Cruiser, each of our editors agreed that it offered the best on-road performance of any truck in this segment.Nevertheless, there was nothing else in our test that even came close to offering this truck's level of control and ease of operation on the freeway and two-lane roads. "
Are you getting this yet?
NOTHING CAME CLOSE ON THE ROAD.
THIS is WAY too easy Vince:
"The Ford Expedition finished last in our on-road-driving test because it is simply too much work to drive. The Expedition's overly sensitive steering required constant correction and its body roll was the worst of the bunch. The Expedition wasn't just spooky on the two-lane portion of our test; it required two-handed steering on portions of the Interstate. A 5200-pound vehicle should feel more solid than did our Expedition. "
"The fact that our Land Cruiser proved to be the best off-road vehicle came as no surprise to our guide from Arizona Adventures, Drew Tedeschi. Tedeschi has guided off-roaders for nearly two decades, and has tackled some of the toughest terrain in North and South America, Europe, Africa and Asia. He thinks that nothing compares to Land Cruisers when the road ends. "
"When the dust settled, it was clear that there was one vehicle in the group, and only one, that was purpose built for serious off-roading: the Toyota Land Cruiser"
"Palmer agreed, stating that the Land Cruiser was so good that it was almost boring on the relatively easy trails we traversed. I found the Land Cruiser to be the most forgiving of our novice four-wheeler mistakes. The Land Cruiser refused to punish us for stupid approaches and departures, literally gliding across boulder-strewn terrain. "
Remind anyone of another review? lol!!!!!!
Design philosophy right down the line.........
"Unfortunately, the Expedition exhibited a great many creaks and groans when traveling over the rougher portions of the trail, prompting Wardlaw to wonder whether or not it would be able to stand up to the routine abuse of off-roading for any extended period of time"
"Wardlaw, who thought the Expedition's ovoid and protruding dash looked like a mass of melting Jell-O. "
READ VINCE:
The Expedition is a sales-leader in this growing market, and will remain so as long as people keep buying big sport-utes. Like many of Ford's products, the Expedition takes aim at a large group of people instead of a narrow, targeted market. The result is that the Expedition can win the sales crown without being the best in any single category. The idea is: appeal to a broad group, sell to a broad group. From a business standpoint, it's hard to argue with that type of idea. However, since we're journalists, not businesspeople, we'd like to see Ford concentrate more on a few specific areas, like on-road handling and off-road ruggedness"
And FINALLY:
"The hands-down winner of our full-size sport-ute roundup was the Toyota Land Cruiser. Better on-road than many cars, better off-road than a mountain bike, the Toyota swept every driving test we could throw its direction.
You are probably wondering if we are off our rockers, since Edmund's typically prizes value over pure performance, and there is a $6,000 price penalty for those who choose the Land Cruiser over the Denali. Is the Toyota really worth that much of an increase? You bet it is.
In the final analysis, it looks like Edmund's editors made the right choice on that fateful night last fall. Our choice then for best full-size sport-utility vehicle was the Toyota Land Cruiser, and, after a multi-day flog through all types of conditions, it remains so. Nice job Toyota. Now, if only we can agree on where to hold our next editorial meeting. "
Vince...I think it's time you turned your computer off and walked away........
From Edmunds:
"Although none of the trucks in this test was a
