Thank you so much for your reply. The more my husband researches the MINI, the more anxious he is about the reliability. On another forum about MINI's, his question was answered with "forget about it - buy a Subaru". Unfortunately, not a good sign for me as I had my heart set on one.
We have owned a 2003 Mini Cooper S Hardtop since it was new, it has 151k miles on it, and we just ordered a new Countryman. My GF loves the current car, and was not interested in even test driving anything else. I tried to get her to test drive a Forester and a Tiguan, but after driving the Countryman for 10 minutes her mind was made up. Both of us really enjoy driving the current Mini, but as with the other German cars we have owned, it has not been trouble free. It’s not that there are constant problems, and it’s not like the car will leave you stranded, but it’s also not likely you will go 100k to 150k miles with no unusual issues, as you will hear from many Toyota and Honda owners. We are friends with at least two dozen other owners. We are willing to put up with a car that tends to need a few repairs over its life because it’s just so much more fun to drive. To us a car is more than an appliance. Before we ordered the Countryman we spoke to at least a dozen owners of that model. Again, the cars are not exactly trouble free, but only one said he would not buy another if he had to do it all over. Sounds like the most serious issue with the Countryman (especially the all wheel drive models) is that for the manual transmission BMW used the same clutch as in the smaller Mini S models, and it’s just not heavy duty enough for a car that’s 600-700 lbs, heavier. Lots of owners are complaining of smelling burning clutches and clutches that do not engage smoothly and need replacement within the first year. Sounds like you want an automatic, so that would not be an issue for you. Maintenance costs for Mini’s are not significantly different versus other makes, and a 3 year 36k maintenance plan comes with the car. They are not particularly difficult to work on. I’ve done much of the normal maintenance myself. You do need to assume you will be using premium fuel. I’ve never heard of anyone with a cooling system problem with a Mini. The air in our ’03 has always worked fine (and we have black car with a sunroof). So far as leaky sunroofs go, I’ve never heard of leaks on any car (Mini or otherwise), other than when owners allowed the drains to get clogged with leaves or other debris, or a gasket that was damaged through neglect. So far as engine power goes, that’s really a personal decision. You should take the time to drive one on the freeway. Based on the reported 0-60 acceleration times, I would think most people buying an automatic will want the turbo engine, and note that the base engine is not even offered with all wheel drive because of the added weight. Run flats usually do work as advertised, but they have a stiffer ride versus non flats because the sidewalls are designed to hold up the weight of the car without any air pressure. The demonstrator you drove had run flats. Did you object to the ride quality? We thought the Countryman that we drove rode very nicely. On the other hand our current car came from the factory with the sport suspension and run flats, and the ride was brutal. Several years ago we changed to non flats and carry a can of Fix a Flat. the other thing you need to know about runflats is that they often can not be repaired if damaged by a puncture, and they are generally more expensive to replace. Then again, how much is not likely being stranded by a flat worth? Hope my comments help.
I found a good deal on a used 2011 All4 automatic a couple months ago. I had test driven the All4 manual and auto at the MINI dealer prior to this. So here are my thoughts so far.
1. As far as reliability, the 2011 Countryman was part of a recall that affected turbo cars for a cooling pump. This was a circuit board replacement at the dealer (painless). I have read of 'several' owners of manuals not being happy with the feel or action of the clutch pedal. I felt the same way on my test drive. My last 4 cars were stick and I actually liked this car better as an auto. 2. My 2011 still has warranty left and I stopped at the dealer specifically for the recall, but let them check the car over. I thought the level of service was very good. They did the recall work, found and replaced a leaking gasket and changed the oil. Cost...zip. But regular servicings under warranty are decided by the onboard computer. Reading the owner's manual, they are spaced out a bit on the long side. I will probably get some things done earlier on my own. I have seen some owners complaining (on MINI owner sites) about dealer service costs. I've owned German, Japanese and American cars. Hopefully my costs will be more like a VW than an Audi. If you have another car, maybe you can put up with a MINI that you love 98% of the time. 3. The S requires premium. Appears that the base does also. I do appreciate that it gets much better gas mileage than my AWD Subaru or Audi did. My around the neighborhood mpg has been 24-25. 4. Can't help you there. No problems that I know of. 5. I don't have the sunroof, so I can't say. A Cooper I drove for a day made me wonder if the shade was adequate to really block the sun out on days I really wanted to stay cool. 6. I think the turbo motor is just fine for the All4. But think the added weight of the Countryman is just too much for the base motor. Just my opinion. The base motor 0-60 times were sloooooow. 7. Runflats work. Runflats are also harsh at times. Add the sport suspension, 18" or 19" tires and some people might be unhappy. The Countryman doesn't have a spot for a spacesaver spare, but some MINI websites are selling them. There is also a 'compressor fix-a-flat' kit from Continental that I will probably get for more security. You should definitely try the runflats on roads you normally drive.
I like the car. It has just enough room for my needs. Gets better gas mileage than any AWD car/SUV with similar performance. It could never be described as boring. Options I would recommend (the blue tooth, xenons - I don't have them and wish I did and they're cheap as an option, I wouldn't have ordered the backup warning system - but it's actually quite good, the rail is stupid - at least go for the split or even opt for the bench). Hope that helps.
Thanks, Shark715! This is really helpful info to help plead my case. I've test drove quite a few cars now and I can't help going back to the MINI Countryman - the ride isn't bad at all, as opposed to the Kia Sportage that Edmunds suggested, even with the run-flats. I doubt seriously that I'd get up to 100,000 mi. on the MINI in the next 15-20 yrs. - I have a Ford Explorer, brand new off the dealer floor that I've had since '99 and I only have 74K on that after 13 yrs. It's still going strong but will be leaving with our daughter when she goes off to college soon. This Countryman will pretty much be an "around town" car for me (adding in a little fun with some side-trips once in a while) and I'm not usually rough on my cars. We'd probably get the Base model Countryman and not opt for the "S" or All4, so I don't think we'd get the turbo, but I am a bit worried about how much power the Countryman has. We live in the foothills and we have some slightly steep terrain once in a while. The other cars I've tried (in this Class) all seem to have this same issue and are not as quick as the Countryman was at all (and also not FUN!). Also, we have 2 MINI dealerships within 15 miles of us, so warranty repairs/service wouldn't be a headache. These are all "pros" in my book. That being said, others are advising my husband that BMW parts are difficult to get, they are expensive and that there might be transmission problems with an automatic 6-speed that Countryman offers. Also, husband has heard that the turbos are a problem. He's getting all the negative feedback and I'm only hearing the good things so we've been going round and round on this. All replies to my questions have been extremely helpful, so thanks!
Most anyone who posts here will typically have experience with one or possibly 2 MINIs. FWIW, my daughter bought a 2007, new, and now was over 85,000 miles on it. No reliability issues. 6 speed automatic has been fine. Closest dealer to her [ she lives in Maine ] is over an hour drive away, in Boston. She really, really wanted a MINI. - Ray Good luck.....
Agreed. My wife bought her 2005 Mini convertible 5-speed manual (non S model) new and has right at 70,000 miles on it.
I change the oil every 5K miles.
As far as maintenance issues go...
Under warranty:
- Right top engine motor mount replaced
- Thermostat housing replaced (with a redesigned upgraded one)
- The part of the electronic dash that controls the clock, which continuously lost time.
- Power steering cooling fan with a redesigned upgraded one.
Out of warranty:
- Another right top motor mount
- Passenger seat airbag sensor
- Leaking power steering fluid supply hose
- Battery.
She also was able to get almost 50k miles out of the original RFTs.
The car has never left her stranded.
There's little doubt in my mind that she would have had less maintenance issues with a Toyota, but then again, she wouldn't have enjoyed driving it nearly as much.
And, the later designed models (2006 onward) have an overall better reliability history IIRC...
I've been reading other forums and now I've come to find out two of the most common complaints about the Countryman. They are:
1) The motor mounts seems to be a recurring problem but are fixed during the warranty period. 2) Cooling fans for both the transmission (?) and the power steering 3) Rattling or noises coming from various areas inside the car - some in the dashboard, some in the side doors. Apparently, these are common and the dealer can't find "fixes" for them. 4) No temperature gauges are featured. 5) Various leaking hoses 6) Stuck fan relays 7) A/C problems 8) Communications package not supported with Android-type phones
Do any Countryman owners have experience with these problems? If not, or if my info is incorrect, responses would be appreciated.
I don't have a Countryman, so I can't speak about many of the items you listed, with one exception.... Squeaks and rattles.
Squeaks and rattles are not acceptable in any decently made modern auto, and especially in an upscale auto.
Any dealer than can't sufficiently remedy a "duplicate-able" noise isn't much of a dealer, IMO.
My wife's 05 Mini convertible does have the occasional rattle/pop/squeak associated on cars with soft tops, but for a car approaching 70K miles and 7 years of age, it's incredibly quiet. The AC works as well today as the day she drove it off the lot.
I've found BMW is somewhat limited as to which bluetooth formats/phones it supports, but you should be able to get a list of supported phones from the Mini website or dealer. I do know some Android phones are supported, just not the specifics.
Earlier model Minis definitely had cooling fan issues and leaking/weeping hoses, but I don't know about the later generation models. Same goes for the upper-right-top motor mount.
Our 2006 MC (R50) with 68K miles on it developed a coolant leak. We had coolant problems while under warranty and they were "fixed" twice by the dealer. Somehow this does not show up at the current Mini Dealer (we bought the car new from at that time the only dealer in the State) which is closer by than the original one. At Our last major checkup we were told that we again had a coolant leak and that we needed a REDESIGNED Thermostat Housing because the original is faulty. The dealer cost is astronomical for such a job. ($350 plus) I decided to do it my self but I'm unable to find the REDESIGNED housing. Maybe I have to go to the dealer and pay top price.
Does anybody know where I can find this NEW housing so I can attack the job myself. (BMW/MINI P/N would be greatly appreciated)
Mr. Shiftright wrote: "Subarus are generally very boring and they have had their issues, too, let me tell you. Been there, done that."
Have to disagree with you here. I just got a 2007 Cooper S convertible and gave my daughter my 2002 (first year they were available here) Impreza WRX.
It was a beast. When the turbocharger kicked in, you bruised your kidneys. Cornered well for its size and ZERO PROBLEMS. Had one recall. Needed one battery in 10 years and let me know in the garage one winter when it cranked over slowly. Except for recall, it only saw the dealer for routine maintenance.
I just purchased a 2006 Mini Cooper S Convertible and on the steering wheel there is a telephone but the manual does not explain how to pair up your phone can anyone help with this?
I have a 2012 Mini Cooper Countryman and don't know much about the earlier models but on the radio controls, there's a "mode" button. I selected this choice (out of a few others, like "Aux", "Satellite", "Radio", etc.) which shows up on the radio readout screen - "Phone" being one of them. That's how I paired my android phone to my Mini. Mini Connected is a different set up and I have the standard.
One of the best Mini forums/sites I've found is North American Motoring. There are lots of posts about this issue for your year of Mini. Check them out, ask a question and I'm sure many 2006 owners will be able to hook you up.
Good luck! (By the way, I absolutely ADORE my Mini - one of the best cars I've ever owned! Can't ever wait to get behind the wheel everyday - the handling is fantastic!)
My wife has a 2005 Mini convertible with the phone controls on the steering wheel, but they're only for "show". There isn't any Bluetooth functionality in her car. The buttons do nothing...
I think you need to have the Mini module installed to make those buttons work--so if you didn't order that when new, you probably can't use the buttons. I have heard that people do buy bluetooth kits, like from Parrot, but I haven't seen an installation so don't know what's involved.
You can be sure that if you buy the module from MINI, it'll cost an arm and a leg and a head. :P
Hello I am looking to buy a new mini cooper countryman BUT my dad has been telling there are a lot of problems with the car and with mini also. I right now have a Volkswagen TDI Jetta that has so many problems i want a new car. I when to look at them this weekend they drive like a Volkswagen bug. But what concerns me is what i have been reading about them Care & Maintenance of the car. I'm not looking to have to spend 2 to 5,000 to keep the car up-keep.
Really, only you can make that call. Some info that may help you...
a. my opinion is that forums for a particular make are very helpful. True, you'll have problems over-reported a bit (comparing percent of people who join a forum to research a problem they may be having, versus percent who join just to say things are swell). But by reading them, you'll get a feel for the various trouble spots and know what to expect. A very active one is North American Motoring, you can google for the actual site.
b. saying "MINIs have a lot of problems" is like saying New York has a lot of crime: it depends. Distilling the common things: the Countryman model had a thermostat / temp sensor issue at first that caused a lot of warranty work. New ones have the new unit. Countryman models also had some trouble with peeling chrome trimwork, again repaired under warranty but a PITA if you had one, of course. MINIs, not Countryman models, had a timing chain / tensioner problem with the 2007-2008 models that wasn't helped by those first years of 15,000 mile oil changes (and people thereby not even checking their oil level). Again, much warranty work to remedy, and some not, unfortunately. MINI made production revisions, of course.
c. All that said, there are many who report "normal" ownership...routine maintenance and no problems otherwise, replacing parts that wear out like tires and brake pads, etc.
d. You voiced a concern about spending "2 to 5,000 to keep the car up-keep" but didn't say over how long a span. MINI includes 3 year, 36.000 mile maintenance in the price of the new car. Many owners choose to pay for an "extra" oil change in-between scheduled ones (originally 15,000 miles, now 10,000 miles apart). MINI "major" services are scheduled at 30,000 mile intervals, can range from $450-850 for this service, from what I've read. If you plan on owning the car for a while, these services would add up.
e. Most people purchase these for their unique performance and driving qualities, and they're full of expensive German-engineered stuff that makes them that way. You can save a bundle by doing your own maintenance, of course, of all these moving parts. But (in my opinion) they won't ever be the appliance-like vehicle you might get with a Rav4 or CR-V (to name a couple of alternatives that are roughly similar in size/shape/utility). I own a MINI, and love driving it. My eyes are open that I'll need to maintain it, and repair/replace things that wear out that are complicated and more expensive than normal, really just like any other German-engineered car. I am capable of most normal maintenance, so that helped my decision.
A Mini will cost more than a Corolla to maintain, but then again, a Mini isn't a Corolla.
My wife has a 2005 non-S convertible, over 70K miles, and no significant issues.
She loves the car today as much as the first day she got it.
Every make and model has its issues and weak points. The thing I learned with buying a BMW product it to NOT purchase the first year run of a model. Typically, BMW products run in 6-7 year life cycles, with mid-cycle refreshes. By the time the series has hit its third year production run, they're pretty solid vehicles.
I agree with what others posted but wanted to add that, for 2012, the "S" models have had some issues with recalls but not the "Base" models (like I have). But, because of the warranties, people are having a great experience with MINI/BMW service and it hasn't been a huge deal.
When we decided on the Base Countryman, we knew that the "S" models had more problems (plus they were a lot more $$), so we chose the Base. I've said it here before, and I'll say it again - this car has been absolutely awesome, is faster than people give "Justa's" credit for and a blast to drive. The handling can't be beat, even with run-flats. I drove every comparable car out there and nothing came close to the joy I felt being behind the wheel of my Mini, plus I get all the cargo room I need, safety features, 34 mpg and comfortable passengers to boot. Yes, I'm a fan of the MINI Countryman ... yes, I am.
Hi, I just found your forum and need some help with my 2003 Mini. IO am a teacher, don't understand what is going on with my Mini, and I need help. I asked my mechanic if I need to replace the transmission oil, and he said that this car doesn't need it. I replaced the clutch a year ago. Now a new serious problem and my mechanic can't diagnose it, he is sending me to the dealer and i am in panic. About a week ago I started having problems with power when in 1st and 2nd gear, the car wasn't responding, going 6 miles an hour. Today my mechanic did a scan and can't find a problem. I drove back home *Unsafely because every time I stop and put on first the car struggles to move). After a 10 minute drive the car was overheating badly. Please tell me it is something easy, thanks.
Hi, I don't have a definitive answer. You mentioned overheating...MINIs have a coolant sensor that's tied into the engine management software, so that may be part of the issue. Your check engine light is on? Your MINI dealer will have equipment to read the code(s) that the monitoring system should be storing to help diagnose the problem.
A dedicated MINI forum like "north american motoring" might also have more info for you. Good luck!
Are you anywhere in the San Francisco Bay Area? I can send you to an independent MINI shop that knows what they are doing.
If you've lost power AND are overheating, this suggests to me a failure of the coil packs---the car is not running on all cylinders OR is running very very lean--either one could cause an overheat.
I'm surprised there are no codes, but if that's the case, then it's back to good ol' step by step diagnostics. First thing might be to test for spark in all four cylinders, then if that's okay, to test fuel pressure.
I don't think this is a disaster, but it could be as simple as a fuel pump or clogged fuel filter (neither will throw a code) or a more complex electrical issue.
I am looking into purchasing a used 2010 Mini Cooper Hardtop S with automatic transmission and 11,000 miles (clean carfax and originally made overseas in Germany) for $21K in CA and I've been coming across mixed sentiment on what it is like to own a Mini. I personally love the performance and how it handles but my main concern is the reliability such as maintenance costs, reliability, cost of ownership, etc. I just recently graduated and this will be my first car purchase so I want to make sure it is worth the investment. I have a few questions and would appreciate any and all feedback - thanks in advance!
1) I've been reading that Mini has made progressive steps to fix known bugs/faults in earlier models. Are there any known issues with the 2010 Mini Cooper S that I should be aware of?
2) What is the average cost of ownership per year after the 36K warranty is up? The factory warranty on the used car I'm looking at is up in 1 year so I need to figure out whether getting an extended warranty is my best bet even though it's not cheap, a whopping $2400 to be exact! However, considering my lack of knowledge about cars/mechanics - I don't mind investing in the peace of mind. An alternative would be to find a local independent shop that works on Mini's but how does the cost of services from these types of shops compare with the dealers? If it's not a significant difference, I will probably opt to get the extended warranty but open to suggestions.
3) I read that Mini owners should get oil changes every 7,500 miles and have also read a typical oil change can range anywhere from $70-140?! I'm getting off of a lease on a Honda Accord and an oil change is ~$30 so it will be a big difference.
4) Finally, after assessing my unique situation - would it make more sense to lease a new 2013 model (non-Sport)? I think they have a deal going on where it's $0 down, $250/month for 36-mo lease. I'm weighing my options and not really sure what the pros and cons are to buy/lease a car.
Hi, just some opinions after being in the MINI world for the past coupla years that started with my research to purchase my 2012 MINI Cooper S.
1) MINI changed to the new model (R56) in 2007. Many of those 2007-2008 cars had issues with the timing chain tensioner that was ultimately remedied. Of things you'll read about, that's likely the most common you'll find, along with the early design high-pressure fuel pump, again later models don't seem to have this as a common failure. Some early clutch failures were reported, but you're looking at an automatic. Earlier Gen1 MINIs (2002-2006 hardtops) had a CVT automatic that was problematic, again not an issue with a 2010.
2) Average annual maintenance is hard to establish, depends on the miles you drive. If you're able to lease, I'm assuming your annual driving isn't too far out of the "norm", 12-15k miles per year or fewer. Extended warranty is good peace of mind (I chose to purchase it for mine, since I'm planning long ownership) *and* find a good independent shop, as their costs are typically much lower. Since you're not working on the car yourself, both are good ideas. Longer term MINI ownership includes recommended coolant changes, brake fluid changes, that can get pricey at the dealer, less so at an independent shop. Overall, my opinion is that MINIs will require more care than a typical Honda or Toyota; that's balanced by the driving experience that they provide that is unique to them.
3) Oil changes at 7500 miles are pretty common practice. MINI actually called for 15k mile changes originally, many felt that was far too long (MINI recently [3/2012] backed this up to 10k miles between changes). They take 4.x qts of synthetic oil at $8 per qt or so (unless you find a sale) and use a $13 oil filter, so parts/materials alone are $50'sh. Add a bit of labor so $70 isn't too bad, actually. There's nothing very special about a MINI oil change otherwise: drain the sump, change the filter, refill.
4) Your situation (you don't drive an excessive amount, and don't perform your own maintenance) may lend itself to leasing. Within the terms of the lease, you'd have a fixed cost and needn't allow for unexpected out of pocket repairs and maintenance. MINI warranties 4yrs/50k miles, and includes maintenance for 3/36. You could decide, in that time, how *your* MINI has treated you, and decide to keep it long term, or return for something else.
I really enjoy my MINI...for me, there's nothing else like it. Hope this was helpful!
I would add to those excellent comments that a MINI is not a cheap small car--so the maintenance costs are every bit the same as a 3 series BMW. Parts are expensive, and not every shop will work on them. You really do need to team up with a specialized independent shop that knows MINIs once your warranty is up. If you rely on the dealership or a chain store after the warranty, you won't be happy I don't think, with the repair costs, or in the case of the chain stores, with what they do to your MINI.
I don't know what I have done to upset the gods, but I felt like I walked right into vicious left hook when I took my car to service at the dealership.
I have a 2008 Mini Convertible that is in fine condition. It has done 80K miles (with no major issues), so it was due for Inspection II service. The price quote was $900, which made me almost choke when I heard that price. Is that really a fair price?
On top of that there were so many other repairs apparently urgently that it made me dizzy: fuel injection service ($240), coolant exchange ($240), trunk/hood switch replacement ($200) and Power steering return hose ($450). Those additional repairs came to $1130, bringing the total to $2K. They gave me a token discount of $100.
They also wanted to fix my radiator for $1100 and change 2 tires for another $650, but by the time they mentioned it, somehow I found the strength to whisper: "Stop! No more!"
Have I been ripped off? Is $900 for inspection II really fair? Are all those additional "urgent" repairs they threw in really necessary and priced fairly?
I feel like I’ve been duped and like a fool.
It would make me feel much better if someone could honestly tell me that I’m overreacting and that the dealership treated me fairly.
Any advice on how to negotiate a lower bill with the dealer if I'm being overcharged would be most appreciated.
It certainly sounds like you were ripped off. According to your service manual, what items are supposed to be done with inspection II? We used to own a mini similar to yours, but I cannot remember the specifics of the maintenance schedule. We now own a new 2013 countryman, but the maintenance schedule is completely different.
I can comment on the fuel injection service. While the dealership may tell you that they recommend it, it's just like asking your barber if you need a haircut. First of all, if it was needed as preventative maintenance it would be listed on the maintenance schedule in your owners manual, which is not. And even if your fuel injectors were dirty and the work was needed, it's easy to find a local garage that would do the same job for under $100. Same thing with the coolant exchange. You can be sure they made a huge profit on these two jobs.
With the switch replacement, it's not clear from your post which switch they replaced, but why was it urgent? I assume it was a switch that turns on the lights inside the car or the trunk or under the hood. On this item, it sounds like you could've taken your time to have the repair done and shopped around for a better price.
What did they want to fix on your radiator? And I can tell you for sure that $325 per tire is an absolute rip off.
Please let us know which dealer this was so the rest of us can avoid these crooks.
I have a 2005 1st generation Mini convertible, and yours is a 2nd generation, so my Bentley manual doesn't tell me what all is covered in your Inspection II service. I would ask the SA exactly what is done in the Inspection II they wanted to perform on your car.
You should also have a service schedule in your owner's manual packet that describes in detail both Inspection I and II tasks.
IIRC, BMW claims coolant is a "lifetime" fluid (its described as such in my 2007 Z4 and 2010 328i). You didn't say, but was your power steering system leaking? I ask, because I did have the power steering return hose replaced in my Mini at around 60K miles. Was there a problem with the trunk/hood switch? Why did it need replacement?
In my opinion, the SA is "selling" you service not required or recommended by BMW/Mini.
What was the radiator issue? Was it leaking? The tires may indeed need replacing, but you would be hard pressed to find a more expensive place to purchase tires than the dealer.
First of all, unless you're a mechanic, you are dependent on the info given you by the dealership. If you've been lied to, its not something you should see as a failure on your part.
If you've already approved the work, you're probably on the hook, unless you can prove there were no existing problems with the replaced parts. In any case, I'd ask to speak with the dealership manager and voice my complaints in a clear, calm manner, stating how you feel you were taken advantage of. It may do no good, but its certainly not going to hurt you in any way. I believe I would distance myself from this business as much as possible.
I was wondering if any one has had difficulties with the maintenance of their Mini Cooper due to the fact the Mini Cooper is originally a foreign car and was brought to the US by BMW which is also a foreign car company. I know that my mother has had trouble when fixing her Volkswagen because she had to wait for the new parts to come from Germany. Has anyone experienced this with their Mini Cooper?
Shouldn't be a problem as Mini parts usually come through the BMW network and there is also a healthy aftermarket for this car.
The only time I could foresee a parts hang-up is if some trim piece or interior upholstery part breaks on a brand-new 2013 model. Sometimes it takes an automaker a little while to catch up on spare parts manufacture while they are producing an entirely new model.
Hi everybody just wanted some advice on what I should be focusing on to keep my car running smoothly. I have a 2007 Mini Cooper that is nearing 100,000 miles (currently at 93,500) and I am just wondering what kind of maintenance stuff should I be doing to upkeep my machine to avoid any serious problems. Any advice and tips would be great, and if you could include estimate prices that would be great.
Have you ever had a coolant flush? If not, you're overdue.
When you have the oil changed, does someone look the car over top to bottom---checking for leaks, brake pad wear, tire wear, worn belts or hoses, worn suspension parts, torn CV joint boots, etc.
Have you ever had the brake fluid flushed? Also not a bad idea if it's never been done in the last 6 years.
I'm not sure when your spark plugs are due for change. My Mini is the older supercharged model and so my specs might not be right for your car.
Why would it be a problem? Toyotas, Nissans, etc. are also foreign cars but usually have no supply issues, except in rare cases due to weird events, such as tidal waves and earthquakes. We've owned a 2005 Mini convertible since new and never experienced any parts shortage needed for repair completion.
I'd be surprised if any 1st line automaker selling in the US today would experience supply issues on any model but the most unique, limited production models they sell.
Heya. I'm about to send this off to BMW North America Customer Relations, and I thought I'd share it here. It's a hoot:
To Whom It May Concern:
I brought my last MINI into service several times for a squeaking sound made by the clutch that I described as sounding like “a creaky door,” a problem that was attempted to be repaired more than once. The repairs included replacing the throw-out bearing, I believe more than once, and replacing the entire clutch assembly.
That car was bought back by MINI after that problem, along with a few others, couldn’t be repaired.
At an arbitration hearing hosted by the BBB AUTO LINE, _____, a west coast MINI representative, said something interesting when he heard that noise in my MINI: he said it was within factory specification.
He said something that had been considered a problem on my last car, something for which MINI bought the car back after it couldn’t be repaired, was spec.
_____ also said, upon hearing another noise produced by my clutch, a sound that was unable to be verified seven times by MINI’s factory-certified technicians, that it “happens in my car all the time.” He also used the word “normal” to describe it. He was able to experience the condition within a minute or two of getting in my car.
Other factory-certified MINI technicians were, after seven service visits, unable to verify something that is, as your company puts it, “normal.”
Is it OK that MINI’s factory-certified technicians can’t verify normal conditions?
I realize that you stand by your factory-certified technicians. I would, nonetheless, like to know if it’s OK that MINI’s factory-certified technicians can’t verify normal conditions.
I am, as _____ pointed out, a “loyal” customer. I appreciate your direct response to my question.
What model year and model is your car? Are you talking about the hooting noise that many owners hear from their clutches when starting off on an incline with a cold clutch?
We have owned a number of BMW products, including three mini coopers. As is the case with most domestic and imported vehicle manufacturers, they maintain several parts distribution centers Around the country so they can quickly provide any dealer with a part that the dealer might not have in stock. But it sounds like they may not keep parts that they rarely have a call for. For example, someone I know needed to have the diesel engine completely replaced on their BMW x5. They had to wait about 10 days for the engine to be shipped in from Germany. But in their case the vehicle was under warranty, and their dealer had already provided a loaner car.
Personally, I wouldn't consider an entire engine replacement an everyday occurrence, so it wouldn't surprise me at all it it took a similar amount of time for the same repair in a diesel Ford or Chevy PU.
I would expect a higher volume gasoline engine to take at least a week.
My daughter's 09 Nissan Versa had he CVT in it replaced at 49K miles, and it took the dealership a week to get a new unit in and install it. I thought that was a reasonable time frame for such a task.
I just purchased a 2005 Mini Cooper hard top and so far the only issue has been that the vanity mirror keeps fallling off of the passenger sun visor. It also seems like the vanity mirrors are pretty much impossible to use because they wont stay open even when they are not broken.
Has anybody else had this issue or looked into replacing these altogether with something from a different company or vehicle? It's a little thing but it would be nice to be able to have all the parts in my new mini be functional.
Also if anybody has any tips for a new mini owner let me know! My new mini is coming up on 90k miles.
The buttons stopped working. I replaced the key battery. Still doesnt work. Problem started after battery ran down and car was jumped. Any advice on what to check? Key works fine manually and I followed the instructions to initialize the key. I have an 04 mini
Mercifully my mini was a lease and is now long gone, I have made many posts here about what a quality wise piece of junk the car was. To which I got many replies that others didn't have the same issues and the problem must have been isolated or mine.
Well 6 years after ridding myself of the mini and the shake & jerk CVT transmission vindication is mine as I recieved a class action settlement notice to be reembursed on any money spent on repairing the transmission. Of course mini denies any wrong doing
Mr. Shift: Given this, do you regret buying your 1st Gen Mini? Do you wish you'd bought new so you would have had a warranty? In other words, how does your experience factor into the new vs. used debate. Finally, what do you think of the new 3rd Gen Mini from what you've read? Sounds quite good to me. Much faster acceleration with the standard engine + larger interior, while still posting c. 5-10% higher mpg numbers. And yet the price is only slightly higher. In other words, more and better car for about the same money, which seems to show that BMW wants to accelerate sales significantly. We'd be interested to hear your analysis of Mini in the market now, with a special eye to the topic of this thread about whether reliability has gotten better for the brand. Thanks in advance.
I hear the new Subaru BRZ is a hoot to drive, though, so you should give that a test drive.
And btw - I really HATED the Subaru!!! :P
- Ray
Good luck.....
Under warranty:
Out of warranty:
- Battery.
6) Stuck fan relays
7) A/C problems
http://www.miniusa.com/bluetooth/phones_new.html
Every manufacturer is going to support iPhones.
http://new.minimania.com/web/Item/NME7616/InvDetail.cfm
Good luck!
If someone can please help me on this thank you
Any experience, knowledge, advice is appreciated!
- Recent college grad
Thanks for your comments.
It happens whether or not the clutch is cold.
It sounds a lot like this: https://www.youtube.com/watch?v=uOmGqYyTdqg&feature=youtube_gdata_player
I've given up. Godspeed.
