-June 2024 Special Lease Deals-
We also had our rear pads replaced at 12k and everything replaced at 24k, pads and rotors. Now we get the heavy brake dust back there, but that horrible noise is gone. They told us yesterday that we'd just have to live with the excessive brake dust on the rear axle. Any comments on this?
As long as he signs off on our complete policy, we'll have a oil change/rotation & tranny service at 30k miles.
Wish us luck!
The Sandman
Do you make MANY short distance trips? So your engine does not get run long enough to become full warmed up - 2 miles and then stop - let the car sit for a hour or more - then another short trip.
Drive where its dusty (like on a gravel road?
Spend EXTENDED periods idling or at very slow speeds? plus there are a few others. If you say NO to all of these - then schedule 1 is where you should be - the guy telling you to use schedule 2 is trying to cheat you.
Also just because the Mazda dealer sends you a notice that does not mean you need to run in there and get the service done.
Many people like to get the first oil change before it is technically required - so maybe the first one at 4,000 is not such a bad idea.
But after that I would go 6 months or 7,500 miles WHICH ever comes FIRST. This is what it takes to keep your warranty coverage - 3,000 miles is a complete waste - and for you would mean an oil change every 2 1/2 months.
BTW - I have a 2004 Mazda3 - I don't know if the maintenance schedule has changes - mine is 4 month 4,000 for schedule 2 and 6 months 7,500 miles for schedule 1.
They get paid the same to do an oil change - if your car needs one - as they do if it does not.
Many dealerships "fudge" a little on oil changes - tell you to change every 3,000 miles - or to use the severe schedule. Hard to find a 100% honest one - they can always say - We just want to help you make sure you take care of the car so it lasts a long time - or does not breakdown.
This next part is just my GUT feeling - so take it or leave it - I am just trying to help.
The oil change at the dealership will be around $25 - (between $20 - $30 at most places) - it will not HURT you too bad if you pay for an extra oil change every year -
Where you really need to be careful is when the dealership tells you that you need a 15,000 mile service - they will package a bunch of stuff together - oil change - tire rotation + balance - INSPECT brakes - CHECK front end alignment - INSPECT belts + hoses - CHECK CHECK INSPECT INSPECT - all for ONLY $295!!
This is where you really need to just say NO THANKS - use the owners manual - just do what it says to do - when it says to do it. 99% of the time this will save you money. If you think something is not right - like the car always wants to pull to the right when you stop - then have them check this out - but if every thing seems to be running like normal - then just do what the owners manual says.
It gets MUCH more expensive at the 30,000 miles service - it will be the same basic stuff they did at 15,000 plus an air filter - maybe they will want to replace your radiator fluid or transmission fluid - I have see dealers ask for $595 - and the 60,000 mile service will drain your bank account.
Agreed.
Agreed but with a caveat. The manufacturer requires that you follow their recommendations found in the manual. That's the minimum. If your garage identifies a problem area to have serviced, you can decide against the service but I would recommend that you at least monitor the area and look for additional advice/information. For example, many cars with four wheel disc brakes have issues with the brakes seizing and wearing down the pads and rotors. My dealership recommended a brake lubrication service which I passed since my brakes seemed to be fine. After hearing about the issue on the Edmunds forum I opted later to do the service as preventative maintenance; the result: my brakes at 50K miles continue to be fine. In other words, listen, learn and use your judgement.
Its been years since I replaced pads / turned rotors myself - but the only thing I can ever recall putting lube on is on the back side the brake pad - right where the caliper piston pushes into the metal backing on the pad - and maybe on some anti-rattle retainer thingy - this doesn't do anything to extend the life of your brake pads or rotors.
If you pay someone to take this much of the brake system apart - you might as well just replace the darn brake pads while you are in there.
Exactly. The service is pretty common where one has dirty road conditions (especially where salt is used to melt snow). The parts are removed, cleaned, lubricated and reassembled in about an hour and a bit.
How many $?
The disc brake lubrication service costs C$100 (U$80) for the four brakes. If you have this done towards the end of the year, my dealer throws in a free winter tire installation (normally C$20- C$30).
In Engrish please?
When the AC kicks on it almost causes the engine to die - runs like crap when compressor is engaged.
Then today a dead battery - I had the battery checked two weeks ago because it seemed like the car was turning over a little slow - it checked out GOOD - I hooked up a battery charger and it will not even take a charge.
Anyone else having AC compressor or battery problems - my car has the dreaded 10/2003 build month - so I could be the first.
Bummer!
What's the mileage on your Mazda3?
Down here in Florida, a battery usually only lasts a good 2 years and I've gotten into the habit of just swapping it out at the 2 1/2 year mark. It always dies at the wrong time and I prefer that not happen. Maybe foolish, but the 1st time my girls had the '01 Altima alone...the battery died. A frustrating experience for all.
The Mazda3 has had more problems - in the 38 months we have owned it than any other vehicle I have ever owned - including cars I bought used. More trips to the dealer for problems than our last 5 cars COMBINED. But
She likes the Mazda3 because it is the car she learned to drive in it - and feels comfortable driving it. She likes the way it looks also - I figured I would make the decision this summer. I even considered getting another Mazda3 - but that would be hard to do - considering how poor Mazda has treated us - by Mazda I do not mean the dealer - I am talking about Mazda corporate.
28k 05 3s ... in Florida, a battery usually only lasts a good 2 years ... habit of just swapping it out at the 2 1/2 year mark.sandman46
Is that because batteries hate humidity? I have heard that although the cold is difficult on car (especially including batteries and other electricals) heat and humidity can be worse. Mine has miraculously survived five severe winters to top 84,000 km (52K miles) and is still chugging along. We've got our fingers crossed as we head to 90K :surprise:
Worst case would be say a turbo car with battery in the engine compartment in AZ or FLA.
The Sandman
It's the parents that usually know best. Don't use emotion but logic to dictate if you should keep the car or ditch it. Personally, if I were you, I would get rid of it. She'll probably thank you someday as opposed to be mad at you when she gets frustrated with the car.
Good Luck.
One more thing, did you have the dealer add the mirror as a dealer-installed item? I know there are specific mirrors for the various Mazda models, and if the dealer added it make sure it's the right one for your specific model ("i" vs. "s" etc.)
I was told that with an Acura you must have the engine RUNNING or it will not program -
If you program a GM vehicle the engine must be OFF or it will not program.
The guy from Homelink said - in general US cars - engine
off - cars from Japan - engine must be running.
How is the Altima's mileage compared to Mazda3S?
You would think they would know, but the salesperson I dealt with spent at least 10 minutes with a manual trying to confirm which mirror was the right one. Mine also comes with the compass, whereas others don't. I didn't get the outside temp reading because the S-GT model has that. Anyway I'm glad my salesperson was careful and hopefully your's picked the right one also.
I tried everything last night to make this Homelink work and it still does not work. I am placing a call today about it. When you hold the two outer buttons down to program the homelink, the green light is suppose to blink and it does not. I have tried over an hour, even with the car on. I will call the dealer about it. Any suggestions?
Homelink
I had a similar experience with my Toyota. Tried numerous times to program following Toyota's instructions in their owner's manual. No Luck. I went to Homelinks website, and followed their instructions, it worked first time! There was a minor difference, but I forget what it was now.
One more thing. Follow the instructions to clear all buttons before re-trying to program.
The Sandman
Thanks for the advice. I have been at this site many times. I will try it again. I just got off the phone with Homelink and they said that I got a bad unit. Maybe and maybe not. I am not sure what to believe anymore. I would love to make this unit work, so I don't have to get a new one. I wish that I knew the difference what you did to yours to make it work. I had the car on, but in the garage, does the car need to be outside? I will check this web site again. What tab did you go to for the homelink directions?
It states to hold the outer two buttons for 20 seconds to clear the memory, the light should blink, and does not. This is the problem that I am facing. I can't even get to the programming part of it.
