rogerf :surprise:
I installed the hitch and wiring harness on my 05 LE CC. It's a breeze. If I remember correctly, there's a total of 6 bolts to attach the receiver (get your self a 6" socket extension to make things a little easier and some lock-tite). There's a pre-wired plug on the frame to connect the receiver harness to, and an extra bundle of wires to install up in the cab in the space behind the kick-plate on the passenger side. I forget the part number, but you can buy it from Lee Auto Parts (http://www.leeparts.com/ I don't work for them or have any connection except as a satisfied customer, Do check everywhere for the best price.) There were directions in the box when I got mine. There's no soldering, taping, or wire-nuts to mess around with, just "plug and play."
"The anti-lock brake system does not operate at
speeds below 3 - 6 MPH (5 - 10 km/h). (The
speeds vary according to road conditions.) Self-test feature
The anti-lock brake system consists of electronic
sensors and hydraulic solenoids controlled by a
computer. The computer has a built-in diagnostic
feature that tests the system each time you start
the engine and move the vehicle at a low speed in
forward or reverse. When the self-test occurs,
you may hear a ‘‘clunk’’ noise and/or feel a pulsation
in the brake pedal. This is normal and is not
an indication of any malfunction. If the computer
senses any malfunction, it switches the anti-lock
brake system off and turns on the ABS brake
warning light on the instrument panel. The brake
system then operates normally, but without antilock
assistance.
If the light comes on during the self-test or while
driving, take the vehicle to a NISSAN dealer for
repair. "
Taken from Page 5-29 of the owner's manual.
1 - I have had my truck in some serious mud in the past 2 weeks(WV hunting season)and this thing goes like a tank there is a very steep hill on our hunting club and it's mostly clay. and this truck and 1 jeep made it up every day. everyone else walked or road ATV's.I loved every minute of it.
2 - you have to be very careful on wet roads. you do not want to go into or out of turns very hard or the rear wheels will break traction. my guess would be the HP causing this. i haven't had any other problems with the tires. This truck put's all other mid size trucks to shame. it's like having an ATV that is street legal. I now have 10,000 miles on mine and have no problems at all. Except a deer ran into the side of me at about 60 mph $1,400 worth of damage. Paint is really thin on this truck!!!!!!!
Frontier, current factory wheels are supposed to be 16" x 7" 5-spoke alloys, would like to use a taller, narrower (75 or 78 series tire) of the same circumference as the original 265/70-16 so as not to mess up the speedometer and computer (same revs/mile) but
15 inch snows are a lot easier to find and less expensive than 16 or 17 inch stuff. Does anyone have any experience with finding what 15 inch steel wheels fit a 2 wheel drive 2006 frontier, clear the calipers and are 6-7 inchs wide, will consider alloys if I can find them priced right. Are wheels for 2005-6 Frontier the same for 2 wheel drive as 4 wheel drive or do they have different off-sets? Would also like to know specs on plain steel lug nuts for same..all valid comments appreciated
I like the trip computer offered on the le. Does anyone know if you can get the trip computer installed on a se?
Also where is a good place to shop for frontier accessories.
I've had my 05' 2WD CC LE for about a year now (love it!) but worry a little about traction in the coming bad weather. Is there any way to add the ABLS (active breaking limited slip) to the truck now? Any thoughts or insight would be appreciated.
http://www.reverendbiker.com/frontier/mirror.htm
Jason
Thanks for your question. The Frontier beat the Tacoma to win our 2005 Tough Truck Shootout, but the Tacoma topped the Frontier to take the crown in our 2005 Midsize Truck Comparison Test.
What's the difference between these two tests? Well, the Midsize Truck Comparison was designed to single out the pickups best suited for the average consumer. The Tough Truck Shootout was designed to select the truck best suited for a consumer with a more extreme set of needs. As we mentioned in its introduction, the Shootout wasn't concerned with "calculating price points and comparing features lists;" instead, the aim of this test was to "see how these trucks tow up hills, run on the sand and race over washboard fire roads."
The Frontier won top prize in the Shootout on the strength of its ruggedness. But overall, we think the Tacoma is a stronger choice for most consumers. This is why it won the Midsize Truck Comparison, and why it was our pick for 2006 Editors' Most Wanted.
Warren Clarke
Content Editor
Edmunds.com
Still quite glad I got the Frontier. I do push the limits off-road and it's done well so far.
Snow will be its next test and we may get enough to test it this coming weekend.
81 Trekker
"The Frontier won top prize in the Shootout on the strength of its ruggedness. But overall, we think the Tacoma is a stronger choice for most consumers. This is why it won the Midsize Truck Comparison, and why it was our pick for 2006 Editors' Most Wanted."
They also said it was the best truck for the way home. What ever....
I just picked up an '05 SE KC and I love it.
I have nothing against the Tacoma, but the non explanation makes no sense to me.
I'm new to this forum but have had my 05 Nissan Frontier Nismo 4x4 since August. I love this truck. I test drove the Tacomo before buying the Frontier and loved the Frontier more!!!
I am trying to find the Intake Air Temperature sensor to install a performance module from The Juice Box Company. I can't find the IAT sensor. If you know where it is please take a good picture for me and email it to me! The picture below was taken by my phone and sent to my vtext.com account.
Also please give me your opinion on installing this module as well as where I can get a performance module specifically made for my awesome truck!
Specifically want to know if either of these needed holes drilled for installation, and if either can be installed while keeping the trac system.
Any other suggestions would be welcome, but I would want to get a folding hard cover.
Unlike some other manufacturers, Nissan hasn't given aftermarket tuners access to its ECU code so you won't find any performance chips or handheld tuners like the Hypertech available for the Frontier. Jet advertises that they will re-flash your ecu, but they're the only company I've seen that is doing so and I don't trust them until I've seen some dyno numbers. If you're going to do some performance work on your new Fronty you're pretty well limited to intake/exhaust tweaks; that's not all bad--with an exhaust and CAI my truck has dyno'd at over 235 rear wheel horsepower--almost 300 at the crank--on 87-octane fuel. Not bad for a normally aspirated V-6. For more info, see my Frontier web site.
jack <><
http://www.reverendbiker.com/frontier/frontier.htm
rail to mount the rear latches. I am not sure
how you would be able to lock a hard tonneau if
you did not have latches in the rear.
If the latches were not attached with screws
I am not sure how secure it would be.
I like my Fold-A-Cover very well and no prob-
lems with it so far. it is not waterproof, but
I do not get very much water in the bed when I wash it.
OkieScot
I went to your site and found that you installed a Gibson Catback system! It sounds awesome! I just ordered a Banks Power Catback system for my truck and should be getting it in by the 20th of this month. God bless!
Could you post a picture of your cover, by any chance...
Also, did you install it yourself or had it installed?
If you bought it on the web, would you be so kind to give the merchant address and cost...
Thanks in advance!
The only picture I have of my Fold-A-Cover is at www.picturetrail.com/okiescot. It is not a
close up and does not show the interior nor at-
taching points.
I purchased it from a local dealer and they installed it. You might be able to get a bet-
ter picture of the cover at www.foldacover.com.
Sorry I could not help you more. Maybe one of these days I'll learn how to use the internet.
I do have a digital camera just not the smarts to get it on the internet.
I think it is something about not being able to teach old dogs new tricks.
OkieScot
Bob
Bob
Bob"
I'm 6-1. With the driver's seat set where I am comfortable, I don't fit in the rear seat of the Tacoma, but I do in the Frontier, though still not as comfortable as in a larger truck. The limiting factor was real-world leg room. Fortunately, most of the time I use the rear seat for storage. In that respect, the rear seat of the Frontier is easier to stow and has more folding options than the Tacoma, which requires a multi-step process and removing the headrests to stow.
Dan
I've sat in both the rear seat of the new Tacoma and Frontier. I'm 5'9" and found the shape/angle of the Tacoma's rear seat to be the more comfortable of the two. It just fit me better. IIRC, the Frontier's rear seat backrest was a bit more upright. It felt more like a church pew.
Bob
http://www.pcoverhaul.net/frontier
Thanks a lot for sharing very useful information on the modifications you made with the rest of us here!
I'm thinking about installing the aFe system (not sure about the Gibson exhaust yet) and I wonder in doing so would it effectively void the manufacter's warranty if something happens (God forbid) to the engine...?
Happy Holidays!
flaman
OkieScot
If you want to assure yourself of complete, no-questions-asked warranty coverage, keep your vehicle completely stock and use only OEM parts during the warranty period. I prefer to keep the mods simple and count on the goodwill of my dealer's service rep, who is a pretty good guy.
What you say makes good sense; unfortunately, I don't have good sense. At age 8 I helped my Dad make a go-cart with a lawnmower engine, and when he turned me loose with it I made my first mod--removing the throttle governor. Maybe it's just a sickness, but I just can't leave any motorized vehicle in its stock condition. I've bolted superchargers to two past vehicles and promptly fried the transmissions on both; not to worry--it just gave me an excuse to modify the trannies. Lord help me.
Regardless, hang in there. New model years are known for having bugs and yours will work themselves out.
Would you mind letting me know the manufacturer of your nerf bars, and how you like them? I have looked around my area a bit, but the ones I have seem seem a little thin.
Also, where did you get your exhaust?
HOW GOOD IT IS?
HOW MUCH SHOULD I PAY? (I'M NOT ASKING FOR OPTIONS)
I REALLY LIKE THE STYLE, I TESTED DRIVE ONE AND I AM ABOUT TO BUY ME ONE.
ANY ADVISE WILL BE APPRECIATED :confuse:
polished stainless steel nerf bars. I got them
from 4 Wheel Parts in Oklahoma City. you can
go to www.manik.com to get more information.
If you look at the exhaust pictures of my truck you can see the mounting brackets. The bracket that is welded to the tube was not polished from Manik. I had that done as well as buying ss bolts and nuts and having them polished too.
I have had the Maniks for about 3 months and so far I really do like them, no problems.
The exhaust was installed by Kinney's muffler Shop in Bedford, Texas. You can see more at:
www.kinneysmufflershop.com. I have the 22" Flo-Pro dual in dual out muffler and had a pair of 12" resonators installed in front of the muffler. The resonators cut out the raspiness. It gives a nice mellow tone up to
1900 rpm and then it starts getting a little loud, not as bad as the 40 series Flowmaster.
I can cruise on the road up to 73/74 mph before
you hear more than a nice soft almost V-8 sound. That is about as fast as I ever drive anyway.
OkieScot
