Visitor Agreement.
Two questions, how much was the V710 phone and what is the signal meter?
to make calls. If someone tries to call me the call comes through but the phone doesn't ring nor
does the HFL notify me of the call. Any suggestions?
On my phone, I have configured it such that when making outgoing calls, it will always go out on the handsfree device (in this case, the TL). However, every time when I dial a number on my phone, even though the phone is linked to the car, the call will still go out on the phone, not via the car. The strange thing is, I can tell that the phone did transfer the call to the car and I can tell the car does attempt to carry the call as I can hear a brief dial tone through the car's speakers but then it was transferred immediately back to the phone.
This also happens with incoming calls but only when my phone isn't connected to the car--if I have Bluetooth enabled on my phone, but not connected to my car, an incoming call will cause the Bluetooth connection to be established, and the car will attempt to carry the call, but then it was immediately transfered back to the phone.
This 'outgoing call on handsfree device' feature works correctly with my Handsfree-enable Bluetooth headset though. So regardless what Acura might tell you it's a problem with the phone, I suspect TL's handsfree implementation does have its own bugs.
The only thing that works for me is when my phone's Bluetooth is enabled and connected to the car, the car will take incoming calls correctly.
Meanwhile, if I am making outgoing calls and I want to dial it via the car, the only way is to do direct voice dialing through the car or using a pre-stored number in your phone book. Pain in the butt but I can live with it...
I don't quite follow. How do you mean? You mean you enable Bluetooth on the phone, but turn off your car?
I meant that Bluetooth is turned on on the phone, but the phone isn't connected to the car (Basically, the Bluetooth on your phone is in 'standby mode', i.e., you see a Bluetooth icon on your phone, but not the blue circle).
I find that sometimes even when the Bluetooth is turned on on the phone, the phone won't automatically connect to the car's handsfree. Most of the time I have to explicitly choose Connection->Bluetooth->My Devices->TL->Connect on my phone. Do you not experience this problem?
(There is a Bluetooth icon on the phone, but no blue circle.) I have the Sony Ericsson T616.
What is the blue circle?
I don't know, 'cause I don't see it on my phone.
Hopefully calwhiz can elaborate.
Hope this helps someone.
John
Making calls is fine, but receiving is a problem.
Try keeping your phone set to vibrate when using the Bluetooth feature in your TL. That's worked for me and a lot of other people.
bodble2, I remember my old T68 also automatically connected to TL every time, but not the T637. So there is some incompatibility between TL and T637.
However, as I said, my T637 has no problems to connect to other nearby Bluetooth devices automatically. Just not with the TL...oh well.
Hopefully the technology will improve with time.
Which is odd, since the T630 and T637 are basically the same phones, just with different GSM frequency...
If not successfully paired follow the Acura handbook on handsfree pairing from scratch.
What the phone says is not always correct. My phone occasionally gives the message "bluetooth connection lost", despite the fact that it is not.
Even when the DVD is out of dte major towns and major streets are still found ans it is still very usable. New strret will not shown up and it will have to recalculate. However you can always mark new places as "waypoints" or "POI"s and then you can find them again.
Hope this helps!
MidCow
Thanks for your response.
If I recall correctly, Acura charges about $190 for an update. I figure I am going to wait at least two years to update due to some major new road construction/road alignment activities going on near my home and work.
Before I buy an update, I plan on talking to my new car salesman and having him verify that the new updates contain the road construction updates once they are complete.
I have been extremely happy with the Nav system in my car. I am somewhat directionally challenged so it is an invaluable tool for getting around in less familiar areas. We liked the system so much in my TL, that when we bought my wife a new car, we got her a navigation system in her car as well.
Good luck,
Jeff
It found a whole bunch of Costcos....One in Quebec, and 15 or so in Utah. I live in Virginia. At first I figured it was because the Costco was fairly new, but that doesn't answer why it couldn't find the one down the road in Sterling which has been around for years. We're not going to be needing directions to Costco anytime soon, but it makes me wonder what else is messed up. Any ideas?
The typical situation when you need the Nav is that you are going somewhere you have never been and you have the address. In this case the Nav will get you there by entering the address unless it is on new road that came after the DVD version you purchased.
I travel for work and find the Nav well worth the $$$$. My guess is it will pay for itself over time in gas mileage savings from not having to wander around finding places. It is also safer than looking down at internet printed directions while driving. I hope this helps.
I think Acura and Honda should get these faeatures since they already have both XM and GPS navigatiion in some vehicles.
I wonder if they are thinking about it?
Just got it back today and i am concerned, dealer had to replace the navi control unit, anyone else have this problem?? ALso, how do you know if the replacement control unit is new and not refurbished i dont want a refurb on my mdx that i have owned less than a week and now only has 325 miles. also, how doi know if the navi control unit is interchangagble with the previous years or is it the disk that makes the changes?
any insights would be helpful, i am really bummed about this.
