This is an update from my earlier post. After complaining to the dealer about not being able to auto connect my T637 to my 04 TL's Handsfree Link and after working with the people who work in the toll free Bluetooth help line, the dealer has finally agreed to replace the car's Handsfree Link's Bluetooth module.
And that fixed everything. My phone now auto connect and disconnect to the Handsfree Link just fine. This tells me that although T637 is an Acura-certified Bluetooh phone, earlier Handsfree Link module may have compatibility problems with it...
So if you have an Acura-certified Bluetooth phone and it doesn't quite work with your car, you might have to replace the Handfree Link's Bluetooth module as well.
Has anyone encountered a similar problem, or know what may have caused this?
No. (For your safety, as well as that of the public!)
I wondered if anyone else has experienced this?
BJ
Yes, I have disconneted the battery, put in the code and sat in a wide open area with no buildings or trees, engine running and not moved the car (about 5 times now). Always waiting with the battery disconnected for 30 minutes in between attempts. I get the message that the GPS antenna could not get a proper signal.
Any ideas???
Dealer told me they make updated DVD's available on-line annually in January. Don't know if that's true.
Not for free though, I wouldn't expect.
My preference is to have the screen at maximum brightness in the daytime, since if the sunlight hits it, it will still be readable.
However, at night I prefer minimum brightness so it will not distract me or impair my night vision.
On my 2003 Murano, the system will hold both of these settings separately. On my new TL however, it seems that the brightness setting is common to both day and night mode.
Is there any way to retain each setting so I do not have to change it every time I switch between day and night mode?
Later
If I speak clearly and repeat the commands in the exact order that is repeated by the system, it allows works.
For example: "radio 680 AM" "radio 101.1 FM" "XM channel 130" "play cd disc one track 5" etc....
The exact commands in the correct order are on the "info" screen under navigation commands. I think that's the trick...along with speaking clearly.
It take some time to enter the info in the system, but it is worth it. I wish they have a simpler way: like if you can synch you PDA with the nav phone book either by blue tooth or using the type 2 slot in the DVD drive in the trunk.
Does any body know what is the use of the type 2 slot in the back?? Acura is quiet about it!
I used to have a BMW and the position of the car on the map was nearly exact over 95% of the time. I have watched this for a couple of weeks and it is not specific to certain roads.
Anyone else seen this?
not only can I get it to work, but it often tells me the time when I'm experimenting with different voice commands! I don't blame the car, though - there's so many different commands, I just experiment w/o looking at the exact lingo.
an update for an '04 TL is $185 + $6 s/h. At the following acura website, you can enter in your car's info & it'll tell you how much it is. You can then go and purchase an update if you want.
https://iweb.alpine-usa.com/Acuradvdsales/naviorder.php
