Too bad it's only for the Japan market. (No plans announced for USA.)
http://www.sony.jp/products/me/xyz/index.html
http://biz.yahoo.com/prnews/040407/dcw010_1.html
I *want* this on my 2004 Acura TL. Anyone have any idea if the standard Acura nav system can be upgraded to this enhanced NavTraffic system???
It's an obvious use of the technology - I just didn't realize they were so close to offering it!
I'm in the market for a TL, not RL, but this is big news.
Here in L.A. we suffer daily due to too many cars, plus idiots flipping SUVs over in traffic lanes. I too *want this* before I plunk down my money for a TL Nav. Any info, rumors, etc. re: Acura's plans to migrate this to the TL platform??
So, the only phone numbers that can be looked up would be the 'main' number of the place, as listed in the directory.
If by "off the main drag" you mean on a road that isn't in the map, I would suspect you are out of luck. If they can't direct you to the location, they would be silly to put them in the database.
Is there an ongoing monthly charge for the navigation service?
Cost?
Who provides it/bills you?
Cost of new navigation DVD ?
Thanks...
Dave...
A disc will cost about 200 bucks. But you really do not need to update every year (assuming, and that is a big IF, that acura comes out with a new disc every year).
I have a 2001 and the new disc finally came out Jan 2004.
Good news... no monthly charge...
New disk cost is high though... and infrequent updates is not so great... too bad there aren't non-Acura disks available at a lower cost...
Dave...
But i have not updated to the new disc because my 2001 disc is still perfectly fine.
Question, if I want to check my voice mail at work I have to dial the number, then enter my extension and then a code. Can this be done in the TL using bluetooth feature without pushing buttons?
I have no idea if you can dial more numbers once you have completed a call.
Hopefully, if it is anything like computers, in 3 years' time a new unit would cost only $500 and you can simply yank out the old one and put in a new one.
It took a bit of time to get used to hit button, talk, hit button, talk,....
BTW, congrats on finally joining the club. May your TL give you lots of fun and mostly safe kilometers.
According to page 14 of the Navigation Manual, as long as there is a phone number on the screen, and there is a phone paired, and that HandsFreeLink isn't in use, the button should be enabled. I had made sure all three are true but the stubborn Send button just won't enable itself.
Any ideas on what I am doing wrong? Do I have a faulty Navigation System?
This is a sample of what the head rest displays look like http://www.cardomain.com/item/VIZ6590006038
Eddy
Jeannine Fallon
PR Director
Edmunds.com
MODERATOR /ADMINISTRATOR
Review your vehicle
One thing that you have to remember is that the TV tuner from avelectronic is programmed to be in the 'off' position. This means that when you connect everything, you have to press the power button on the remote to actually turn it on.
If you do order this thing (it's a little expensive at $525), you have to connect the red power wire to the cigarette lighter adapter, the yellow wire to the black ground wire, and the ground wire to a grounded bolt or something. If you have any more questions, let me know.
Oddly enough, the phone is not available at Verizon stores yet, it is only available via their website or at Radio Shack. Here is a link: http://www.vzwshop.com/motorola
Now if only they had a Bluetooth iPod!
carcar
Thanks again
GordS
Acura's service manager told me that Motorola has problem with their bluetooth and will release a new model of cell phone by end of year.
Anybody having same problem with V600?
If I'm getting a call from an important client or my boss, I'm now using the phone to pick up, which decreases quite a bit of the utility from Bluetooth.
Let me (us) know if you learn anything more -- like you, I've had relatively few other problems with Bluetooth (one other minor issue is that I find I need to reestablish the Bluetooth connection if I am away from the car for more than a few minutes).
Hope this will help you.
