Everyone in the family is impressed with the handling, roominess, and build of the cars. It's a car that provides more than expected.
Only complaint is from the kids since their cars only had AM/FM radios
Economy wise my AVEO is on target. The first fillup was at about 150 miles and provided me with 29.5 mpg. The next 3 fillups were higher between 30.5 to 31.5. This is combo driving (city/highway) with quite a bit of stop and go. I haven't done any pure highway driving, but expect that 35 mpg is very realistic.
All in all I'm very pleased with car. and would rate it a "9" (Nothing is perfect)
without reservation. Designed by Italians, built in Korea, badged with a bowtie
the Aveo is a true winner.
Do you have any ripples? I don't remember them when I bought the car in March '05. Should I be concerned?
I'll try to get a pic and link it soon.
1) How exactly does the "flip and fold" feature work for the rear seat? How much stuff have you been able to load into the car with the seat folded down?
2) I have read a few articles that sing the praises of the aveo in all areas except acceleration...basically it doesn't have the power to tackle an up-ramp onto a freeway. Is this true?
3) Does anyone have the 6 speaker upgrade package, and if so, how does it sound?
thanx from NC
Here is a link, you can click on the picture to get a better look.
Rostra 250-4371
I had a Ford Aspire and none of those came with cargo covers. I made one out of a sheet of thin plywood, reinforced with a 2x4 along the part just behind the rear seat so it wouldn't bend with a couple of dowels at the corners so it could pivot up. I covered the whole thing with a hunk of automotive carpeting I bought at Pep Boys (in a shade of gray that perfectly matched the interior). I even added the little straps attaching it to the hatch so that it moved up when the hatch opened.
I bet you could do the same, especially if you could borrow someone else's cargo cover and use it as a pattern. It's well worth the effort; it cut the road noise in my Aspire considerably.
What kind of front suspension does the 2005 have? I would be shocked if it was anything but McPherson strut.
This person makes them himself. I bought and installed one on my Aveo and other than the fact that it is a slightly brighter (grey), it is a quality piece. Very impressed with it. It's worth every penny.
Steve
If you check the epa information at fueleconomy.gov it gives a detailed explanation of how they test and many factors that affect fuel economy. They have a very good list of standard things like air filters, tire pressure, wheel alignment, etc that all can affect economy.
FYI the highway ratings are tested with an average speed of 48mph and a top speed of 60mph for 10 miles. How many people actually drive with a top speed of 60mph on the highway?
Run it with the AC on and window open for a couple of mins just before you stop for the day.
I think there's a mold or bacteria that can grow in the air ducts with condensation from the AC so opening the windows helps get rid of any moisture.
After using the AC , before you get to your destination turn on the heat that will help to dry out the AC ducts so mold will not build again.
Dave
As soon as I scrape together 200 bux I would like to order a Rostra kit and install it myself.
At least that's how I think it works. It happened all the time with my S-10, and other cars, mostly in the winter when the air is dryer.
My theory is that it has something to do with the type and amount of plastics used in the upholstery fabric.
Doesn't hurt, btw.
