I'm going to see if the dealer will add this.
Antenna: [geogecko] Yes, ours hits the garage door every time we pull in. I think all of the 4x4's and Prerunners would be high enough to have this problem. Ours hits a metal rib on the door, so I added a couple layers of the handyman's secret weapon (duct tape) to the door so that the antenna would not get damaged. The tape is the same color as the rib so it doesn't stand out. It's more quiet, too!
Thanks for info:
1. If you don't mind, how much did it cost?
2. Is it quiet - i.e. any rattles, wind noise?
Thanks for the information about the CB. Did you find a better place to mount the antenna to reduce wind noise?
I wonder if they make shorter radio antennas that I could just replace the standard Toyota one with. I know it just screws out.
Mileage report: Mostly city driving, but about 70% of my daily commute is highway. I got just a pinch over 19MPG. I don't know what octane rating the gas that was in it was, but I suspect 87. I put some 93 in, and we'll see how that works out.
If you don't want pen stripes on your truck, then I suggest you ask the dealer if it's typical that they put them on. I'm taking mine off right now, and it's been a slow and tedious process. So far, I've got all of them off the bed, now I've got the doors and front fenders to work on...
Should I be concerned about build quality?
[geogecko] I'm not sure how the end of the antenna (finial) is attached. If that could be removed, you could just clip a bit off the end of the antenna, then epoxy the finial back on. If you are going to buy another one anyway, what have you got to lose?
The 2TR-FE engine is the 4-banger and the 1GR-FE is the V-6 engine. (Why such stupid names, Toyota??)
Anyway, for 1GR with oil filter change, it says add 5.5 quarts.
(If it's your first oil change, I'd add a quart less than what it says, run the engine for 30 seconds, wait a couple minutes, and recheck the dipstick....much easier to add than take out and it's actually better to be a little low than a little high, too much can break an engine seal.)
Good luck!
Rick "Boo"
- coming from rear passenger-side (how far rear hard to tell)
- definitely more noticeable in cold (below freezing). seems non-existant when temps warm up
- also even when cold, is more noticeable when first driving vehicle and seems to mellow out after a bit of time on the road
- did not notice it when it was cold and I had a full load of firewood in back
Other than this annoying rattle, I do enjoy the truck and everything else seems to be of high-quality. I plan to have the dealer look at this rattle when I take it in for the first oil change.
Sorry to insult any 05 owners, but it looks like your truck is the guinea pig for "The New Tacoma"
A leaky cab? This seems inexcusable. They can't even put together a water tight compartment. what about the rest of the truck? It's very discouraging to hear about a truck I was once very enthusiastic about buying. (sigh)
It is sad when the a manufacturer with the resources of Toyota can stumble so badly. I think they were trying so hard to get Truck of the Year that they took their eye off the ball.
it's a great truck. i love it. does it have some minor things that could be done better? absolutely. go buy a Nissan, Ford, Dodge, Chevy, Hummer...whatever. 2005 Toyotas will be flying down the road long after all of the above mentioned have been recycled into the beer can that you have a firm grip on.
my truck is fine. does everything i want it to do. does it make a sound? yes. it makes some noise.
but overall it's everything i'd waited for. i agree that the leak issue is a big one and i'm sure it'll be addressed appropriately.
i'll keep rolling down the road with my beloved Tacoma. enjoy your Ridgeline (ugliest thing to roll since Pontiac Aztek).
guess i need to go on some ford and nissan boards and bash these guys so i can feel supreme as all of you do.
enough is enough.
But here's a fact - I bought a 1996 Nissan Maxima brand new. Drove it for almost seven years, racking up 130,000 miles. Never had a single thing go wrong with it. My expectation level is pretty high, but not impossible. Another Nissan I've owned - a 1993 Pickup, 2.4L, 5-speed manual basic transportation. Same reliability. No problems. Now, a brand-new truck design by a top manufacturer, to have a propensity to have leaky windshields, for example, is no small thing. All by itself, not a killer. But added to the other issues, it spirals down to the level of being pathetic. You got yourself something you like, so enjoy.
However, there are some serious problems (paint chipping, leaking). I think these seem to be limited to only a handful of people though.
I've got 600+ miles now, and it was raining pretty bad here today. I recently checked under the floor mat, and it was dry as a bone. I have not noticed any paint chipping yet, but have a set of running boards on the way.
I think people have very high expectations for Toyota, and especially a redesigned model. However, most people that have flamed the Taco have mentioned going with Nissan, Ford, etc. I highly doubt these vehicles compare (and have not had their OWN problems) to the new Tacoma. While Ford has gotten better over the last few years, I still believe their quality standards are not up to the Japan auto makers. Take a ride in an upscale sedan of Ford and then say, Acura or Honda, and tell me which one you think leaves a higher quality feel. There are decent American vehicles out there, but I find it hard to believe that they will outlast a Honda or Toyota.
I was one that was also waiting for the Ridgeline. Then, when I saw some of the more recent (real) pictures of it, I was like, what were they thinking? It looks like a cross between the El Camino and one of those jacked up AMC cars. Yeah, it's got what it needs, a nice, powerful V6, and some nice storage, but I think they could have made it look a little better. I don't know why Chevy and Honda think that slanted down area between the top of the cab and bed needs to be just that, slanted. Why not cut it off like Ford (SportTrak) and Toyota, etc.
This has been a long enough ramble. Bottom line, it's a truck, it's not perfect, but neither are any of you, and people still like you.
I wouldn't trade my Taco back in for anything else, at least not right now.
i like the Toyota. maybe you can buy my Nissan off of the used car lot. better get the extra warranty though!
Yep, the Ridgeline has some asthetic issues. I'm trying to correct them by looking at different rim styles, and buying it in black. It still may be futile. Honda has truly designed a innovative vehicle that the competition will have to acknowledge in their upcoming designs.
I am not disappointed in the truck at all, just with the dealer sales department. I guess I feel it could have been a better deal in hindsight.
look at all other toyota models they are all known for their reliability.... paint and water leaks can be fixed... will be for free in time.. but will your nissan be fixed for free in ten years when the engine sounds like a freight train and breaks down 3 times a year.... NOPE.... will the guys who have TOYOTA engines be laughing... think, you once thought a water leak was a big thing but now your spendin 3 gs a yeer to keep ure 10 thousand dollar truck road worthy....
sit in a toyota and youll feal great comfort.. look at a toyota and youl see prestige.... drive a tacoma and you will see a truck that drives like a car.... put 350 000 miles on a tacoma and you will find out the real reason why people buy toyotas...
water leaks and paint chips suck ... but a company like toyota will help out eventually ... they dont want to tarnish their image... the real reason you buy a toyota is because its a toyota.. ride looks and reliability all top of the line... dont call a tacoma pathetic... we will be laffin at ure girly men truck in 5 years... yup the tacoma isnt pathetic... its the truck of the year...
It hasn't been the proudest product launch for Toyota, and I'm sure they're working on the issues. I drive a Toyota Highlander now, and I'm happy with it. But I do think it's one thing to set out to win awards from the automotive press - it's another, much harder thing to deliver the goods to thousands of customers, and make them satisfied. I'd rather have a better-built truck that had not won anything. I'm glad I didn't buy one this year, but might next time.
Only problem I have that I'm going to address with the dealer is my Tacoma does not know that my driver door is opened. This is somewhat annoying since my doors will relock before I get the truck started and the dome lights do not come on. I typically leave for work before dawn, so it becomes a bit hard to find my cupholder to put my coffee in. I also have to remember to shut off my headlights which I'm not in the habit of doing since my previous car had the automatic shutoff. I never posted this because I've yet to read anybody else have this problem either on this board or the tundrasolutions board. It's a fluky problem that I expect the dealer will easily fix.
It's sorry to hear that the Tacoma is disappointing some folks out there. It does have a huge name to live up to. Three of my very close friends drive (not new) Tacomas and each one of them say they would never buy any other mid-sized truck. That is what convinced me to buy mine. Time will tell if mine holds up as good as theirs. So far, so good.
I have had my Tacoma (05 DCab 4X4 with V6) since November and have had no problems (no leaks,rattles or chipping). This is a very well built truck and a pleasure to drive both on and offroad. I have logged over 9000 miles on it and have no complaints (on and offroad). This is my first Toyota. In the past I have owned mainly Fords and was somewhat skeptical about the purchase. I'm glad I bought it! I hope all the complaining on this forum doesn't influence people to not purchase this truck. If you've done your research this is probably one of the best vehicles out there for the money.
All vehicles have minor problem in the first year of production, common sense would tell you the more you that as time goes by the product will improve due to consumer feed back and technology advances. Toyota has a great history of well built vehicles and I believe they have continued with this truck. So they have a couple of Kinks, they will get worked out. They know how, they have been building trucks for years. As far as considering the purchase of a Honda (truck), I am willing to bet that you will encounter alot more problems with it. Not only is it a first year product but it is their first truck. History in the industry shows that this will yield many more difficulties, not just in manufacturing but with service as well. I am not saying Honda won't put out a quality product just stating facts.
Sorry, just tired of the whining!
