Lincoln Zephyr/MKZ
1515254565760
  • But speaking of Malibu, you may have missed the article's point. The previous Malibu was barely an also-ran in this market. The new Malibu has built momentum very quickly, far faster than the Fusion which had years of a head start. Both are doing well, but "only 37K" is nearly neck and neck with Fusion, even with Chevrolet using less incentives and less fleet sales with this iteration than with the last Malibu. I believe in giving credit where credit is due. I'm historically a Ford man, but the new Malibu, a real looker, has come from way behind and is now a contender in the mid-size field, being compared favorably with Camry and Accord for the first time.
  • akirbyakirby Member Posts: 8,062
    Sorry, I got Malibu and Impala confused and I was only referring to the total retail sales number compared to the Fusion.
    I know that the new Malibu is way better and GM is cutting fleet sales and incentives but I still don't think they've gone as far as Ford has nor as quickly. I do agree they're moving in the right direction and the Malibu is a good car - head and shoulders above what they have previously. But I still think they're 2-3 years behind Ford at this point.
  • brucelincbrucelinc Member Posts: 815
    On a side note, why is the Impala, one of the top ten sellers now, selling so many times the number of cars as Taurus?
    That is a real puzzler. If one can get past the dowdiness of the Taurus, they will find it is one heckuva good sedan. I get Impala rentals frequently and can't understand how they sell in such volumes. The Taurus is superior in about every way imaginable.
    I think it is primarily marketing. The Taurus is not advertised and our local dealers don't even have the usual Sunday ads for the Taurus anymore. When the 2010 eye-watering version arrives, I am betting they have a major campaign for it. Ford's standing is the strongest of the Detroit 3 now so the time is right to take as much advantage of it as possible.
    I think it's a combination of fleet sales and loyal GM buyers plus the less than exciting Taurus exterior which should be fixed next year.
  • bigtbigt Member Posts: 412
    How do we get a Forum started on this vehicle? I know so little about hybrids except I want one for the MPG and carbon footprint. For example, all of this talk about running the Milan up to 47 mph on electric only sounds good but what happens when you turn on the air or heat?
    Also I noticed in a picture it had a plug. I assume you are recharging something but since I live in a condo complex there is no way for me to plug in. I would have to stay in good standing with my girlfriend to go over there to recharge! Hmm, maybe two birds with one stone!
    There is no plug - that would be a plug-in hybrid and those won't exist in the mass market for a few more years. It operates just like a regular vehicle, nothing special that you have to do.
    Be aware that if you're buying a hybrid to save money it normally takes at least 5 years and sometimes as much as 10-12 years of fuel savings to make up for the added cost of the hybrid version. If you just want a hybrid and don't mind paying a little extra up front that's fine, but be aware.
    Heat is probably ok since there would be residual heat in the engine unless it's been off for a long time. And I think they switched to electric A/C so that may work also without the ICE - at least while the battery holds out. Early models required the engine to run for A/C which is one reason the early hybrids did so well on the EPA tests. Prior to 2008 the EPA did not use A/C on the fuel economy tests.
    I believe anyone can start a topic. I would suggest a 2010 Fusion/Milan Hybrid topic. The 2009 Escape uses basically the same system with minor differences so you could probably get a lot of answers in those forums.
    Per your request, I created a discussion over on the Hybrid Cars board.
    2010 Ford Fusion/Mercury Milan Hybrid
    Great and thanks Karen. Will it evenutally show up in the index of Hybrid cars?
    Not until it has a folder/group of its own. Right now it's a stand-alone discussion on the main Hybrid board. http://townhall-talk.edmunds.com/WebX/.ef27a26/ You should probably add it to your tracked items for now.
    My feelings exactly - the Taurus is probably the most underrated car out there right now - but man, it's one ugly car..... If you don't care what a car looks like, it's a great value, but then, if you don't care what a car looks like, you're probably in a SAAB already anyway.......
  • displacedtexandisplacedtexan Member Posts: 364
    LOL - I've always liked how SAABs looked. Of course, I still miss the more classic looking Volvo 240, or even the 850.
    As for the Taurus, I think it looks classically functional.
    "Classically functional" is the best compliment I have ever heard about the Taurus styling. My father used the same words to describe the manure spreader that we owned when I was a kid. ;)
  • rickrick Member Posts: 3
    I own a 2008 FWD MKZ that was built in May 2008 and purchased in late July 2008. I have a high pitched wining sound that is noticeable between 20 - 40 mph. It almost has the same sound as a supercharger when it is spirling up. I previously owned a 2006 Mini Cooper S and the sound is almost identical to when the supercharger kicked in on that car. The transmission shifts fine and there is no hard down or up shifts from it. I can't determine if the sound is coming from the transmission or the air intake. Has anyone else experienced this? Are you just putting up with the noise or is there a fix for it? Thanks for responding.
    Not sure but thank God you are still under warranty!
  • fmirenzifmirenzi Member Posts: 3
    Scott I have a 07 FWD and I get around 31+ traveling to FL at the speed limits or about 2-3 miles above and coming north 29.6 again at the speed limits compare the avg MPG to avg. MPH the lower the avg MPH the lower the MPG low MPG meant you are sitting still a lot.
    This car for me gets better than expected :surprise:
  • steprov1steprov1 Member Posts: 8
    Hello to all! It's been awhile since I posted. Anyway, my '06 Zephyr has almost 39K miles and I'm driving from ME to FL next week. I brought the car to the dealers for service last week and was told that the rear calipers were binding and would have to be replaced. Luckily the car is still under warranty. And last Spring, the front rotors had to be replaced due to rust & pitting. This was also covered under the warranty. Has anyone else had brake issues? Other than this, the car has been very good and I hope to keep it until alternate technology vehicles become more reliable and with better cruising range.
  • theman123theman123 Member Posts: 170
  • They must still muddle through with the overall Fusion shape for a couple more years. Pricing it that close to the ES350 is presumptuous at this point..I wish them luck with that.
    But it does now look a bit more like a Lincoln, and I believe the new interior is more quiet than even the MKS. Should help a little bit to keep Lincoln in play. Now they need to upggrade the MKX the same way...especially needs a quieter interior, more akin to what the Navigator offers..
    At the car show recently, Ford was offering a $50 gift card for test driving one of their vehicles so I took a spin in a 2010 MKZ today.
    I really like the new front and rear ends but it would have been nice to change the greenhouse/roofline to take it further from the Fusion look. The interior is a nice upgrade although I do not care for the looks of the console. Overall, the 2010 looks a bit more upscale to my eyes than previous models.
    The MKZ has a pretty quiet ride. They have done a nice job with managing engine noise and it sounds more refined than the last MKZ I drove. It also has a more pleasing sound than my wife's 2008 Taurus which has the same drivetrain. The model I drove was an AWD with only a few miles so it seemed a bit lethargic but it would probably be better when broken in.
    For me, the ride was pretty compliant but a bit busy as you might expect with short wheelbase. While I did not push the car hard, it seemed to handle very well and not nearly as ponderous as a Taurus or MKS. The overall feel reminded me a bit of my LS - tight, solid, and well controlled. Individuals bumps are handled well but over seriously bad concrete roads the LS is smoother. The Taurus is softer than either of them but it lacks the quick reflexes.
    There are 3 relatively inexpensive items that the MKZ lacks that would make a world of difference to me. The tilt/telescope wheel should be powered instead of having an unwieldly lever. It needs rear seat AC vents. Last, and most certainly not least - IT STILL HAS A DAMNABLE PROP-ROD HOOD. Totally unacceptable in this price range.
    It has been a long time since I have driven an ES350 so I can't make comparisons to that. The sticker on the car I drove was around $40,000 and that strikes me as pretty high for what you get. However, I can understand why many buyers would find the MKZ to be a very pleasant, comfortable mid-size sedan. There are quite a few good sedans in this price range, though.
  • tiger16tiger16 Member Posts: 54
    Good post! I can't help but be a little disappointed in the new MKZ. Some subtle exterior changes and an overall nicer interior but, I don't think these changes will interest those that didn't care for the original Zephyr/MKZ. And Ford continues to fall just short of what they need to do to pull equal to the target competition. Did you note that the new MKZ only offers 7 exterior colors with no blue. What's up with that? They offer 9 and 10 on the Fusion/Milan and MKS. I guess I can understand fewer color options than the MKS but fewer that the Fusion/Milan - a mind bogler!
    I also agree that the console could be nicer. It looks cheap with all that black. It needs some wood, especially a wood shifter. A leather wrapped shifter - big deal. My Maxima had that. Some people may like the contrasting seat piping, I hate it. It looks kind of tacky and I think a lot of people will be turned off by it. Seems like a desperate and inexpensive effort by Ford just to be "different." If buyers really liked that look, I would think Lexus, Cadillac, Infiniti and Acura would have already offered it. No heat or A/C vents for the rear seating compartment. Who is Lincoln competing with, Camry or Lexus?
    There are so many minor and inexpensive things Ford could do to make the MKZ a true entry luxury car but, instead they offer free satellite radio for 6 months. And at a price equal to that of the ES, I fear the MKZ is in trouble. The Zephyr/MKZ offered a lot of bang for the buck and at several thousand dollars less could still only manage sales of about half the ES. What in the world makes Ford think they can jack the price up so much, especially when the MKZ isn't quite as nice?
    I was seriously considering trading in my Zephyr for the new MKZ but now, I'll be looking elswhere or holding off until 2011. The 2010 MKZ just isn't a mind changer.
    I just purchased the Mecury Milan Hybrid. I am getting 32 consistance MPG and average around 40 on those short trips to the store, etc.
    Traded in my 2007 MKZ. I am very happy camper with all the technology, etc.
  • redboneredbone Member Posts: 11
    I have an 07 Mkz as well but have very low mileage so I'll wait another year to get the Milan hybrid. I think that Lincoln will lose many sales to Milan hybrid.
  • tk329tk329 Member Posts: 3
    I am glad that someone else has posted the fact that the stupid rod that you use to hold up the hold should be used to beat up the people that made the decision to place it there. A couple of other things that tell you that the "Z" is closer to the Milan then the "S" is the lack of push button start,and the windshield washers on the hood,plus the hood rod. All of that except the price,which is closer to the "S". Figure!
    Think I'll take some time to vent some more. First of all, since we take the time & effort to post here, it's safe to assume we all actually want Lincoln to succeed. This is the only format we have to let the idiots at Ford know what they need to do to once again acheive profitability. Too bad they don't listen.
    Anyway, in my previous post, I stated I would not purchase the 10 MKZ. I went to the site to "build" one to see if I could be lured back. I found out some more disturbing things. The highway gas mileage is down from last year - not good for me since my daily commute on I-95 is 82 miles round trip. I have the Nav system an THX 6 CD changer on my Zephyr. Guess what, you can no longer get the Nav with the CD changer! You either get the Nav OR you get the CD changer. The Nav only comes with a single load CD. Even the new $2500 THX/Nav pkg is only single play. That's exactly what I want to do going 65 mph down I-95 - fumble with CD cases while trying to eject & insert CDs. Funny that you can get the Nav with 6 CD changer in Lexus, Infinti and Acura (didn't check Cadillac). Anytime you take away something that was previously offered, it's a downgrade. Once again Ford fails to meet the competition. And after checking the competitions' sites, I just can't get excited about the "new" MKZ interior. It's still several notches below. Look at the ES or the CTS. Not even close.
    So, in the 2010 MKZ, we have a prop rod, no air vents for the rear seats, a degraded audio system, a cheap looking console, fewer color choices (no blue), less gas mileage, low profile hard riding tires and a price increase of about $2K. This thing is looking more and more like a train wreck.
    The Lexus doesn't have a 10 gb jukebox or Sync either. You can rip 16 CDs to the internal jukebox - last time I checked that's a lot better than just 6 cds. Not to mention that you can use a USB flash drive or MP3 player with thousands of songs.
    And the price increase is mostly due to options becoming standard like stability control.
    At least get your facts straight before you start bashing.
  • Lincoln has improved the MKZ quite a bit since Zephyr days. However, the MKZ drives like a Fusion Sport--without so much sport. Behind the wheel, it does not feel significantly diffferent from other reasonably equipped, non-luxury mid-sizers like the Fusion and Malibu. For the kind of coin they charge, the "feel" from behind the wheel should distinguish this model more. I'm afraid that until Lincoln has the resources and time to fully redesign this model, it will remain an also-ran in the marketplace. But at least it is no longer a dud in the near luxury field like the 2006 Zephyr was. Some day Lincoln may actually build cars again whose resale value doesn't plummet like a stone. To get there, they will need something truly special.
    Have you driven the ES/Camry? Just curious if those are any better and if so, how?
  • Yes. The Camry is a nice solid feeling appliance...fairly quiet but no one would write home about the handling. The ES is more serene, more smooth. Not a "fun" drive, but the engine never sounds taxed even when you floor it, interior materials are impeccable at this price level, and the ride is pillow soft (again, not the car for spirited cornering). It really coddles for something based on the plebeian Camry. It is not a styling standout though. It is tasteful but anonymous. Though it shares not one panel with the Camry, unless you are a car guy like me, you might even mistake if for an uplevel Camry on a quick glance.
    akirby, thanks for the response to my post. I don't quite understand it though. You said to "get my facts straight." Exactly which facts were not straight? I said you can no longer get the Nav with a 6 CD changer - THAT'S A FACT. You consider the MP3/jukebox thing to be better - that is nothing more than your opinion. All that only works if one has the equipment, knowhow, time and desire to take advantage of it. I'm sure there are many potential buyers out there that would still like the convenience and simplicity of a 6 CD changer. Seems like Lincoln could have still allowed the Nav and changer to co-exist. Doesn't seems like rocket science for crying out loud.
    Also, I said the base price increased by about 2K - THAT'S A FACT. Your comments about "things" now being standard is merely an attempt to justify the price increase. The problem with making certain things standard is you force people to pay for things they may not want. I'm sure there are potential buyers that do not want to pay extra for stability control or for sat radio or for cooled seats. My point is, adding more to the base price may not be good market strategy. Leave some things out and let the buyer decide if they want to pay for them. Your average buyer is going to look at the price of MKZ and Lexus and may very well say - I'll take the Lexus since it costs the same.
    Here are my other comments on the 2010 MKZ:
    Fewer exterior colors offered
    No rear air vents
    Less highway mileage than the 2009
    Low profile tires
    Again, which of these statements is incorrect? My comments concerning the ugly, cheap console and degraded stereo are opinions. Not right or wrong but, opinions. I'll give you that. You told me to get my facts straight before I start bashing. One might suggest that you brush up on your reading comprehension skills so you understand what you read. That way you can more appropriately bash the post rather than the poster. Fair enough?
    One last thing concerning the Camry/ES thing. I have access to both. Family members have the Camry and a good friend has an 09 ES. I driven both. Toyota has done a good job separating the Lexus from the Camry. The Camry is no where near the MKZ but, the ES is nicer than the MKZ (my opinion). Other than some trim, I don't think there is much difference between the MKZ and Fusion/Milan.
    You implied that losing the 6 cd changer was bad without mentioning that they've offered something better in it's place. With the internal jukebox you load it from cds - put in a cd, download it, put in another, etc. That is not much different than loading 6 cds except that it can hold 16 cds. This does not require a computer or anything other than putting cds in the radio in the car. You also implied that the car was $2K more expensive than last year without mentioning the added standard equipment. And the stability control is standard because the government is mandating it within a couple of years and all mfrs are doing that. So go complain to the government.
    Just because your statements were "technically" correct does not make them less misleading. I'm with you on the lack of rear air vents and fuel mileage and I'll even grant you that the MKZ is not quite as nice as the ES (but I bet it handles a lot better based on the Fusion/Camry comparos). But it's not nearly as bad as you make it out to be.
    I haven't driven a 2010 Fusion or Milan but I have spent some time in earlier models. While the ride quality of the MKZ might not be much different, the MKZ is much quieter and 3.5 engine is smoother and more powerful than the 3.0. I see that as important as the better trim. The quieter interior, and especially the quieter engine under acceleration moves the MKZ up the ladder a bit from the Fusion/Milan.
    As for the CD player, the jukebox feature is very cool and simple to operate. It really makes the old 6 disc changer obsolete, IMO. I like the fact that you can download the CD and then use it in your home system or another vehicle. You don't need multiple copies of the same CD.
    You and I are in agreement on the other features and those lacking. And, yes, I think the price gets a bit steep in spite of the more standard equipment. I really haven't driven any of the MKZ's competition so I can't make direct comparisions but I know that the ES with options can get up into MKS pricing territory fairly easily.
    If my choice was between an MKZ and a 2010 Taurus Limited, I would take the Taurus in a heartbeat and pocket a few thousand bucks.
  • Remember that the 2010 Fulan is significantly quieter than it was (adopting much of the 07-09 MKZ noise suppression). LIncoln did make the 10 MKZ quieter than the 09 though. The 2010 3.0 liter is much improved over the 09, and the hp gap between that and the 3.5 is now far less. Plus, the same 3.5 is now available in the Fusion. None of the engines sound refined under hard acceleration, but otherwise, NVH levels are very good.
    Yes, and the difference between the 2010 MKZ and 2010 Fusion/Milan may not be so great.
    Like others, I have read that the 3.5 "is not as refined" as Japanese V6s. The only Japanese V6 I have driven lately is my boss's Acura RL. I admit that the engine is pretty sweet. However, I really like the sound of the 3.5 and it is a lot smoother than the pre-2010 3.0. I also think there are some perception issues around this "refinement" argument. Other than smoothness and sound, I am not sure how you measure refinement.
    http://media.ford.com/images/10031/10MKZ_Refined_Powertrain_Sound_Quality.pdf
    If mfr = (Honda, Acura, Toyota, Lexus, Nissan, Infiniti, MB or BMW)
    then
    engine is refined
    else
    engine is not refined
    endif
  • Looks to me like different people like to hear different things, but bottom line, there should be a change in the sound perception of wide open throttle between the 09 and 10 MKZ. Given what I've been reading (haven't seen or driven a 10), the MKZ should sound better, and given that it is significantly more quiet than the already pretty quiet 09, it is probably now more serene than the the bigger MKS. Will be interesting to compare.
    The '10 MKZ really does sound better. Actually, to my ears, the sound quality is about the same except it seems further away or more muted. If I recall correctly, they changed the airbox on the '10s specifically to reduce the engine noise.
    I think the base MKS 3.7 has more engine noise than it should - more than a '10 MKZ. Again, I have no objection to the quality of the sound - just the quantity. I look forward to the sound of a twin turbo MKS, though. They even have a tube that runs from the air intake up to the passenger compartment to enhance the sound- like the new Mustang. If I don't like it, I will plug that tube, though!
    Sounds to me like they spent all their resources on the Fulanz and Taurus and the MKS will have to wait another year or two - except for the ecoboost engine.
    While the MKS will never suit everyone, the twin-turbo engine is really all it needed to satisfy me. I quibble about a few other things but we could do that about any car. Nearly 350 ft.lb of torque at 1500 rpm can help me forget about some of its other shortcomings.
    The MKS already has the structural enhancements that the 2010 Taurus is getting. Other than some engine noise from the 3.7, the MKS is a very quiet car and I think the suspension tuning is about right, considering its mission. While totally worthless to me, "park assist" will be available. I guess that trumps adjustable pedals from a technology viewpoint. ;)
    I don't think I've needed to parallel park in at least 15 years. I can't even think of any place around me that even has parallel parking spaces available. But I do think it's neat.
    I think rather than gripe about what the MKS doesn't have (yet) that we should applaud Ford for not holding back on the Taurus features. In the past that would not have happened. That's a good sign. Ford is priority 1 right now, Lincoln is second and Mercury is only getting crumbs. Which is the right way to do it.
    Well this will make some peopels brain hurt. the 2010 Lincoln MKZ is as nice as a Lexus350,
    About.car:com review of the 2010 Lincoln MKZ
    This is going to stir things up a bit.
    :shades:
  • texasestexases Member Posts: 11,171
    Hmm....been needing to replace my '96 ES, but the new ES doesn't do much for me, and the previous MXZ styling was not so hot. The new one is much improved. I'll have to take a look.
    This is more like it! Some activity on this board. Lincoln can sure use the interest. In a previous post, I pointed out that the highway mileage is down. Does anyone know why? Seems like the tweaking and, from what I understand a new tranny, would have created better mileage.
    Also, some posters have waxed royally about the jukebox thing. I still like the changer but, I'm open minded. Supposedly, this thing can house 16 downloaded CDs. I'm not sure what the benefit is if your collection is extensive (I have over 400 CDs). What happens to the other 384+? Seems like I can only load them one at a time after the intial 16 so, essentially, it's still only a single play. I'm not trying to bash the system at this point, I'm just trying to understand it. Can someone direct me to a website?
    At this point, I'm no longer considering a 2010 MKZ, however, a little knowledge can't hurt. And who knows. If I can get through this CD thing and Lincoln offers a dressup option for the ugly all black console, I might change my mind.
    You take 16 or so CDs (assuming 600 mb each on a 10 gb drive) and you load them one at a time, and tell it to copy to the internal drive. Then you load the next one. Only takes a few minutes from what I've heard. Then you have all the songs from all 16 CDs available to play all at once. Just like having a 16 CD changer except you don't have to change from disc to disc. Then you still have the single CD slot if you want to listen to something different. Or you can delete a ripped CD and rip a new one anytime you want. The only thing you lose is that it takes a couple of minutes to rip the cd to the internal drive. You can also use iTunes on your computer (for free), load all your CDs and put them onto a usb flash drive as MP3s and have all of them available (or whatever will fit on a flash drive) at once. A 8 gb flash drive would hold at least a thousand songs (at slightly lower quality than audio CDs).
    So what do you think of the article posted above?
    Tiger, there is usually a logical explanation for everything but, off the top of my balding head, I can't tell you why the EPA highway rating dropped by 1 MPG. The aerodynamics are a bit better on the '10 and it is geared more favorably for highway fuel economy than the '09. Logic would tell us that the '10 should be a bit better. I will keep digging on this one.
    I get a lot of Ford/Lincoln information from the link below. I am not nearly the audiophile that akirby or you are but here is a quote from the information sheet on the MKZ:
    In addition, the system features a 10 GB hard drive jukebox, allowing Lincoln owners to store up to 2,400 favorite music tracks.
    Somewhere else on the media ford site, it mentions 150 hours of music can be stored. In any case, if you have 6 CDs loaded in a 6 disc changer and you own 394 more, wouldn't that present the same issue as you describe in your post?
    http://media.ford.com/brand.cfm?make_id=2593
    My thinking with the CD changer is that I can rountinely eject one or more and load one or more at any time. I quite honesty don't know how this 16 CD archive for the jukebox works. Can the 16 (or any amount) routinely be changed? How do you cycle through over 2000 tunes to find what you are looking for? Especially while you are driving down the highway at 65. How long does it take to download a CD? I can load 6 CDs in a changer in about 30 seconds. How do you organize the 2000 tunes? How quickly can you access a particular tune? A lot of questions so, you can see my ignorance here. Perhaps the jukebox is a bit of audio evolution - like the 8 track being replaced by cassette and the cassette being replaced by CD.
    I'm planning on getting a 2010 and I really want to like the MKZ more than I do right now. My Zephyr has been the most dependable and durable car I've ever owned.
    A Lincoln rep demonstrated all of that to me at an MKS preview event last summer but I don't remember all the details. It is voice activated and you can just press a button on the steering wheel and say, "Bruce Springsteen" or whatever, and it would find it. You could also say the name of a particular song and it would find and play it. I think there are some demonstrations of the capability on U-tube.
    I make no claim to being an expert on in-car entertainment. It sounds like you are far more of an audio buff than I am but for my simple needs, I thought the jukebox feature was a big step up from carrying around CDs. Of course, I usually just listen to talk radio......
    The Milian HB Juke box is 10 gig and can hold an estimated 2,472 tracks of music in the 'Gracenote' musical database. Gracenote is the engine of the Navigation system of the MKS also.
    http://www.gracenote.com/
    At first I thought you could record songs from Sirus radio however the record option only applies to CD's. I am not sure where the 16 cd number is coming from. Basically you put a CD in the drive, select the tracks you want to record and it copies them off the CD and onto the Jukebox. The CD could contain regular .cda stuff or mp3's including play lists you have created on the disc. As long as you have space in the Jukebox you can put all the tracks you want there.
    Once the tracks are in your jukebox you can create play lists for them. As for accessing them you have a ton of options:
    Play all tracks, play list, play genre, play artist, play album, etc. While driving you can access all of this stuff via voice commands such as play Bob dylan. Or you can say search genre, search album, search artist, search track. You can even use a 'refine' command after whatever your initial search results came up. So if you said search jazz and then a list of jazz came up you could say 'refine artist Paul Hardcastle' and his tracks will come up and then you could say 'refine album Hardcastle 5' and the tracks from that come up without you touching a button.
    If the 10 gig is not enough than Sync allows you to plug into the USB port any media device. I have a 2 terabyte device that fits into the compartment by the driver seat! :) Whatever you plug in SYNC starts indexing all of the media and playlist files contained on it. Once the indexing is done all of the commands referenced above via voice are availiable or you can touch screen them. Lots of the commands can be touched by the passenger also.
    For us ole-timers who cannot remember which Hendix song is playing you can even ask 'whats playing' and it will read the metadata tags and tell you.
    Supported media files are mp3, wma, wav, and aac.
    If you don't have USB flash drives or devices, plug in a Ipod, Zune or any other media player and again everything is indexed including existing playlist you have on the device.
    Also if you have a USB port phone charger just plug it in and off charging you go. Or you can always just use your home phone charger because in the rear you have a real standard 120 volt outlet for your laptop or phone.
    Sync will also create new playlists on the fly if you want. If something is playing just say 'create similar playlist' and off the indexer will go.
    If you still need a music fix start streaming music frm your bluetooth enabled phone.
    If you get bored of just audio stimulation put in the concert DVD and watch that. When you are stopped you get the video and audio. Once you start moving you just get the audio!
    In my opinion in this area this system is a 'homerun'. Now if we can just get the Washington Nationals to do the same this season I will really be happy.
    As for the car, downtown yesterday at night and as the valet brought it out folks were saying stuff like, 'wow, did not know Mercury had a hybrid, and it looks like a real car'.
    Since you can only copy songs to the jukebox from CDs I assumed it was storing songs in CD audio format and not MP3 format. In which case 10 gb would only hold about 16 CDs (at 600 mb each). If it's ripping the songs in MP3 format then that would explain why it can hold up to 150 hours of music rather than just 16 or so. That's the equivalent of about 150 cds. So it appears you can load your entire cd library (or at least the first 150 cds) directly onto the jukebox. And I'm sure you can delete old ones and add new ones anytime you want.
    Soooo.........6 cds or 150 cds plus one in the disc slot. Hmmm.......that's a tough one.
    Gee, this jukebox thing is sounding (no pun intended) better all the time. So, if I can still "change out" whole CDs somewhat like a changer, I could be happy.
    About the article on the MKZ. I have no doubt that there are areas that the MKZ has improved (ride, quietness, performance) and it is probably on a par with the ES in many ways. Overall, I'm sure it is nicer than my Zephyr. A few things bother me. One is the gas mileage. It's not so much that it decreased 1 mpg; it's more the fact that it decreased at all. I just think the proper evolution would be to increase gas mileage when you tweak a car. The 17.5 gallon fuel tank also bothers me. My weekly work commute is over 500 miles and an extra gallon or two would really be nice. The other things pertain to the interior. It's an improvement but, for what it's supposed to be, it could be better. A nicer steering wheel, some wood on the console, a wood shifter and for sure, rear air vents. And the real frustrating thing is that these items are not high dollar items - they're mere pennies relative to the price of the car. They're a bunch of little things that collectively contribute to the definition of a "luxury" car. At least offer some of these things as interior enhancement options. I think correcting these "little" things could help change the pervading perception of Lincoln and help sell some cars! Check out the ES and CTS interiors.
    I agree things could be better, but Ford seems to be making progress. I've asked an inside source about the fuel economy. FWIW 27 seems to match or exceed the competition so it's not like they're behind the curve and I'm sure there was a good reason for the drop.
    The interior design is fine and I think they just need to add some wood to the center stack and make some slight upgrades. I bought a Fusion rather than a Zephyr back in 2005 just because I didn't like the interior. I think the new one is a lot better design wise. Of course that's just my opinion.
