Has Honda's run - run out?
19192949697153
  • davem2001davem2001 Member Posts: 557
    This generation or the next may have the last naturally aspirated four cylinder type-R engine.
    I dunno, Honda has never been big on turbos...for me personaly, I'd rather have a normally aspirated engine anyway.
    http://www.detnews.com/2005/autosinsider/0504/22/autos-159034.htm
    Home re-fueling seems like a great idea. I hope it turns out to be a practical solution.
    Bob
    Sounds pretty interesting - that would be a perfect commuter car for me.
    Sounds like it would be great for commuting and short trips. Is natural gas power like electric power though, where as you get towards the end of your range, your power starts to drop? For example, a gasoline powered car will perform exactly the same right up until the moment it runs out of gas, but an electric car will lose performance ability as the charge decreases. Since we're dealing with something under pressure here, I'd imagine that there would be some power loss, as you get down toward empty?
    The way I use my 'commuter car' - I drive about 15 miles each way, so 30 miles round-trip. I would just plug it into the refueler every night and it would always be almost full. The only big downside I see is that you could NEVER take the car on a long trip. The car I use to commute now, I wouldn't really WANT to take a long trip in, but if I really HAD to I COULD. That is one big drawback... other than that, it sounds like a great idea.
    is the difference between natural gas and propane? Don't they make some fleet vehicles that run on propane? The one problem I'd have with natural gas is that, while there is a pipeline that runs behind my property line in back, I'm sure it would cost a small fortune to have a pipe run the 650+ feet up to my house! There's a house across the street that uses propane, though. One of my uncles has a house that's heated with propane, as well. I'm guessing if someone like me wanted a setup like this, a propane tank setup would be much more feasible than running a gas pipeline through hundreds of feet of forest, swampy ground, crossing a creek and a sewer right-of-way!
    Not a big enough market for it, but imagine an NG Civic Hybrid. The IMA system could bolster power while also adding to the range of the vehicle.
    I gotta wonder exactly how Honda came up with those $/mile figures, though. Specifically, I wonder if it includes the leasing rate for the home fueling unit.
    Base engine was a 1.6l, related to the Miata's engine back then, 116hp or so.
    The 1.8l V6 made just 130hp, hardly worth the cost and weight and complexity of a V6. It never sold very well.
    Ironically Mazda's own 1.8l I-4 engine from that era (Protege) made 125hp, so there was just no need for that V6.
    Mazda's costs spiraled out of control and they went into cost-cutting mania and then sold to Ford. Poor strategy all around. :sick:
    We don't like it when bean counters run a company, but when powertrain engineers are given free reign they do stupid things too. The same company was marketing tiny V6s, rotarys, and Miller cycle engines? Make up your mind.
    -juice
  • carlisimocarlisimo Member Posts: 1,280
    newcar, thanks for that info.
    davem, I don't see Honda going the turbo route either (and I wouldn't like it), but I can see the Civic eventually getting more cylinders. It's growing to old-Accord size, after all. Which I don't like either.
    that cars like the Civic will ever get to the point that a V-6 becomes feasible. Looking back, for the most part the only smaller cars that got V-6 engines were mainly domestics, like the Dodge Shadow/Plymouth Sundance, Chevy Cavalier Z-24/Pontiac Sunbird, Ford Tempo/Mercury Topaz, and Ford Contour/Mercury Mystique.
    Over time though, those models have been replaced with newer designs that just use 4-cylinders. Ford essentially killed 3 possums with one rock when they launched the Focus, as it filled the shoes of the Contour, Escort, and, to a lesser degree the Probe. Chrysler's once broad lineup of smaller K-car derivatives has since been replaced by the Neon. And the Cav ditched the V-6 for the 1995 redesign, and now the replacement Cobalt only uses the Ecotech 4-cyl.
    Now if cars like the Accord start getting to the size of Intrepids, Impalas, and Tauruses (and they're really not that much smaller at this point) and Civics start getting to about where the Stratus/Sebring and Malibu, and smaller cars like the Mazda6 and Subaru Legacy, then I could imagine seeing a V-6 option. But for the time being, they have a ways to go.
    I think it will just get more displacement - the rumor is it will have the 2.4L from the TSX (at least in the top line Si coupe)
    Well, that's why Honda needs to bring in that new sub-Civic sized car. The Fit or the Jazz (I can't remember)... Yeah, the new Civic will be about the same size as an old Accord from the late 80s. The new Accords are about the same size as a Taurus.
    But the Accord didn't get V6 until a generation or two later.
    The Civic has plenty of room to grow it's 4 banger, 1.8-2.0l for the new one, so I imagine the next couple of generations will still manage with 4 cylinders.
    -juice
    10 years from now, who knows?
    The rumor about the Civic Si getting the 2.4L from the TSX seems false to me... it's bad enough that the Civic Si will be getting the same engine as the RSX...if you gave the Civic a better engine than the RSX, it would really cannabilize RSX sales.
    well, at present that 2.4 only makes 200 hp, and the new RSX-S already makes 210 (in a much lighter car). Don't forget the current RSX goes away shortly after these new Civics arrive, and who knows what the next gen (if there is one) will have for power? You can bet it will stay one step ahead of the Civic SI - they have already made that mistake once. The S2000 makes 120 hp/liter, what if they could do the same with the 2.4L, and put it in the RSX-S for next time? Whoa, would that be fun! That would leave lots of room for the new SI to make 200 to maybe 220 hp and not encroach on the RSX's territory.
    that if they did to the 2.4 the same thing they did to the S2000's engine, that it would be one of those things where MT and C&D would post some incredible performance numbers, and maybe 5 or 6 people in the "real world" would figure out how to drive it to get that hp out of it. The rest of the masses wouldn't figure out how to rev it, and whine about it not having any power!
    well, the 2.4 has a longer stroke too, so I am not saying Honda could do any such thing. But I bet they will figure out a way to get the RSX-S up to 240 hp or more for the next iteration, if there is one, and then will boost the TSX to that a couple of years later.
  • stickguystickguy Member Posts: 54,048
    maybe the next one can be a coupe based off the S2000?
    That could be sweet.
  • gee35coupegee35coupe Member Posts: 3,387
    Seems to be a domestic thing. Look at the new Boneville with the big V8.
  • anonymouspostsanonymousposts Member Posts: 3,802
    Is there a problem with choosing the RL for the doo dads, AWD, and Acura name? So what if there are a couple of cars in it's class that are marginally faster, bigger, or even cheaper. I mean, the Mazda6 is slower, smaller, and less refined than the Accord yet you still bought one because...
    it wasn't a Honda.
    If that can be a reason to choose, or not to choose, a car then so can AWD, doodads, and the Acura name.
    At some point, enough has to be enough. No, it might not be the fastest or most powerful, but it is still very quick by any reasonable definition.
    SOmetimes these arguements become somewhat esoteric. It's the stats that matter, not how useful it is in the real world.
    I love the RL. I immediately sat in the GS and knew that it wasn't right for me. The RL seemed "right". The NAV was great. The seats were comfortable. Everything was nicely trimmed and felt nice when you touched it. The driving position was great. Only thing that's keeping me out of one is the price tag. I would rather have a mortgage-free house than the RL, or any other $50,000 car.
    The HP war is getting out of control. I drive my 160HP Accord and can't help but thinking why someone would say the Accord didn't have enough power to get them through day-to-day driving. It will do a very easy 100 MPH and still get 30+ MPG. Can't beat that IMO.
    the HP war has already BEEN out of control for some time. Despite that, the Accord 4-cyl sell four times better than the 6-cyl, maybe there is some comfort in that.
    These are all fast cars, but when you are in premium territory, a lot of buyers also want the bragging rights. This is one of the areas the RL falls a little short - not the fastest, not the V-8, etc etc. I wish the market didn't work that way, because it is slightly childish.
  • newcar31newcar31 Member Posts: 3,711
    " I mean, the Mazda6 is slower, smaller, and less refined than the Accord yet you still bought one because...
    it wasn't a Honda.
    Tee hee hee, you just have to bring that up, don't you? I've owned two Hondas, so that's not the reason why I didn't buy an Accord.
    Despite it being a little quicker and a little more refined, I didn't buy the Accord over the Mazda6 because to me, the Accord is that ugly.
    Besides, my version of the Mazda6 is 4 tenths of a second "slower" than the equivalent version Accord (5sp manual, 4 cyl). 4 tenths.
    How many tenths slower is the RL to 60 compared to the M45 or GS430? How much is that RL again?
    We have already discussed that those cars are V8's and are more expensive than the RL when equipped to match. The GS and M also come in 6 cylinder versions that more match the RL in price. I mean we do want to compare apples to apples don't we? Or do we just want to argue just for the sake of typing. I mean shoot, the Altima SE-R has nearly everything these cars offer except bragging rights and RWD. But the SE-R also has a stick, which many people on Edmunds place above the steering wheel. Less than $30k for a loaded one. Same engine as the M35. I mean if doodads aren't that important, you might as well go there.
    That's the reason I'm hoping for the IS250 to be the holy grail of what we all have been wanting. RWD, 6 speed, V6, Lexus reliability and best of all, a price near $30k equipped the way I want it. They are going berserk about what the IS may be missing, but to ME, the future paying customer, if I can get my 6'6' frame behind the wheel, we will go from a 3 Honda family to a 2 Lexus and 1 Honda and maybe 1 Mazda5 family.
  • bradkurtzbradkurtz Member Posts: 24
    I think Honda needs to rethink its position a bit. They are offering a free years gas ($2000) instead of a rebate in Canada. They have pressure on the low end from the quality cars of Hyundai and Kia, and on the upper end from the better styled and better fit for the American market cars like the 300, Mustang, 500, and upcoming Ford Fusion.
    The RL is more than competitive with the GS300 AWD and the M35 AWD. Comparing the RL to the V8 versions of the above is like comparing a 4 cylinder Accord to a V6. Sure the V6 has better performance numbers but it's also more $$$. The GS430, for example, is $10,000 more than the RL. Again, why keep comparing the RL to V8 sedans when it's competitors all offer 6 cylinder engines which sell better than the V8 versions anyways.
    And don't forget the 6-cylinder MB E Class and BMW 530 models also.
    Bob
    You know why, so don't pretend like you don't. Because the competion offers V8s and the RL doesn't. It wouldn't be that big of a deal if Acura's V6 could come close to matching the performance of the V8s, but it doesn't. That's the bottom line. I'm not the only one who talks about, just go read any magazine article on the RL, the no-V8 issue will be brought up. The best engine available in the RL doesn't match up with the best engine available from it's competitors.
    The GS430 is not $10K more than the RL and the starting model for the GS430 is not a stripper. AWD has never been necessary for the top dog model in this class, but a V8 is.
    But the "why" is the same empty reason as the one in the IS room by those people wanting a manual transmission in the IS350. There ain't one so move on. And those people that were in the TSX room complaining about the lack of options. There ain't none. The TSX was a resounding success as Honda sold many more than they planned. As in the case of the TSX, they aren't trying to take over the market. There are more established marques out there. They just want to carve aut thier own niche. That should be obvious in the fact that the RL doesn't have a V8, options, and comes only in AWD.
    As someone said before, the RL is already been a resounding success so far and the TL and TSX are selling strongly. To keep in the context of the forum, Honda's run is nowhere near run ou as far as these models are concerned.
    http://www.hondanews.com/CatID3001?mid=2005040151151&mime=asc
    "Moving on" is what I'm doing. Acura/Honda doesn't make the car I want to buy next, so instead of hanging around complaining about something that doesn't exist, I'm looking elsewhere. Had to do the same thing to Toyota after they quit making cars like the MR2 Turbo.
    Edmunds as-tested price in the comparison was $60,000. The RL has a MSRP of $49,000 with no options. I built a GS430 on the carsdirect.com website and my price tag came up to $57,000.
    Regardless, it's really irrelevant. Acura will probably sell as many RL's as it wants to, at least for the first few years. Sure the Lexus and Infiniti are stiff competition for the RL but the RL is also stiff competition for the Lexus and Infiniti for those who don't just gotta have the extra 2 cylinders. Sure the magazines may mention the lack of a V8 but they also say it's a great car and despite it's apparent lack of any redeeming qualities to YOU, it has done well for itself in comparison tests.
    "Edmunds as-tested price in the comparison was $60,000. The RL has a MSRP of $49,000 with no options. I built a GS430 on the carsdirect.com website and my price tag came up to $57,000. "
    "as tested" is the key phrase there. Edmunds has the base price for the GS430 at $51,125. If you have $50K to spend for a car in this class and you have to have a V8, you can get one, if you can live without NAV and AWD. Just go to the Lexus or Infiniti dealer. If you have to have NAV, and AWD, but don't care about the V8, you can get the RL. It's pretty simple. Don't pretend like you have to spend $10K more to get a V8 because it's just not true.
    "There are more established marques out there."
    And why is that? Honda was the first Japanese company to try the luxury thing out.
    I think most people perceive Lexus to be a notch above Acura. I'd even say that's happening with Infiniti now too. Why did Honda let that happen?
    You don't HAVE to spend $10,000 more to get the V8. However, the guy in the RL will be able to go just as fast as you once you get to cruising speed, will probably handle better, and will know which way to go to avoid traffic which will pretty much negate any performance advantage the GS has. Besides, again, why not compare the RL to the GS300? It is just as much as the RL once you had options to it.
    "However, the guy in the RL will be able to go just as fast as you once you get to cruising speed, will probably handle better, and will know which way to go to avoid traffic which will pretty much negate any performance advantage the GS has."
    Oh geez. Gimme a break. And you're serious too, aren't you?
    "Besides, again, why not compare the RL to the GS300?"
    Why not? Go for it. At least Lexus gives you the choice between loaded and slow, just plain slow, loaded and fast, or just plain fast. With Acura, you better like loaded and slow. :)
    others buy the Lexus. I mean they have to sell SOME. I mean there are gonna be those that won't buy the RL because of the way it looks. Thank God for options. Can't please everyone all the time.
    In fact, the performance difference is so slight that after the initial 6 or 7 seconds to 60 are over, I'lll be willing to bet that the driving experience will be so similar between a GS-anything, M-anything, RL that it doesn't really matter anyway. Then all you have left is whether you like the seats, looks, accessories. Judging a car on number of cylinders and 0-60 alone is kinda silly when you are spending $50k. Again, since the topic IS Honda's run running out, if we are looking at the RL, the answer would seem to be a no. The GS has been knocked for it's intrusive stability aids and Infiniti may drive like a champ but has that funky center console that I would never get used to. Just as some people won't buy an Accord because of it's "Buick" tail lights, there are some who won't like the other cars for [insert reason here]. We won't even go into the Bangelized Bimmer that I find very nifty looking...I just hate Bimmer interiors along with the I-drive.
    when is Honda going to offer a gas-sipper hybrid Accord anyway? Toyota is now delayed more than a year while it pumps out more hybrid Lexi - the hybrid Camry won't be here until the '07 MY, Honda could jump right into the void and produce a 50 mpg Accord. OK, maybe not 50 but one that could do at least ten points of mpg better than the existing performance Accord hybrid, and that wouldn't cost more than most buyers of family sedans can afford.
  • mariner7mariner7 Member Posts: 509
    I can't believe all the tortuous arguments. If you're going to argue there's hardly any difference at all between all the cars in RL class, then you must say there's no difference at all in the Accord class, driving Sonata or Malibu is as good as Accord!
    BMW has been charging a premium all these years because it builds the benchmarks. People recognize it and are willing to pay for it. BTW, many auto journalists are saying M is now the benchmark.
    The NYT in reviewing RL begs to differ with you:
    "The car has everything, except personality."
    "The feel of the big Acura seems closer to that of Lexus than to the competitive German set - it is more comfortable than sporty - though the car doesn't feel as detached from the road as some Lexus models."
    http://www.nytimes.com/2005/04/24/automobiles/24AUTO.html?
    "Judging a car on number of cylinders and 0-60 alone is kinda silly when you are spending $50k."
    It's not silly at all. It's silly to act like performance doesn't matter, especially at this price point. If you're spending $50K, why not judge the performance? When you're spending FIFTY THOUSAND DOLLARS, the performance differences are magnified if anything.
    Why does the Accord offer 240 hp and near best in class acceleration and the RL doesn't even come close in it's respective class? Why the difference in philosophy between the Accord and RL? It's common sense that performance matters more in the RL's class and less in the family sedan class.
    It's amazing how far you and anon will go to defend a Honda product. I still can't get over what anon says:
    "However, the guy in the RL will be able to go just as fast as you once you get to cruising speed, will probably handle better, and will know which way to go to avoid traffic which will pretty much negate any performance advantage the GS has "
    The performance advantage the GS430 has over the RL is wiped out because you might get lost or stuck in traffic in the GS without NAV. Wow. And then the icing on the cake:
    "the performance difference is so slight"
    But for the $50k there is no car that offers the combination that it does.
    http://www.edmunds.com/insideline/do/Drives/Comparos/articleId=104808/pageId=62812
    Let's look at the specs. And can't help but mention that the RL came in second to the Lexus. While the fastest car, the M, is last. Even more surprisingly, that "fast" car has an as tested price only $1500 or so more than the RL. It may be the drivers car but it didn't impress Edmunds.
    The GS won the 0-60 not only because of the V8, but even more importantly it weighs 200lb less than the RL. Mainly because it's a smaller car in every exterior dimension that costed $10k more as tested. The RL has 3 mpg (10%) better fuel economy than the V8 equipped cars too. So I gess it ain't as close as we might have it.
    So if we keep the RL's "class" where it belongs, i.e V6 Sport sedans that have AWD and cost around $50k, the RL is dead where it needs to be. The M and GS both have those models. If you HAVE to have a V8, you can't get one in an RL. If you HAVE to have AWD you can't get it with a V8 in the segment. Acura may lose a few customers by not having a V8, but that's okay.
    BMW loses a few by having 215hp 525 and the 255hp 530 and the 530 bases at $48K without leather and automatic. But it weighs a lot less and can be had in a manual. Maybe that's why they are the class of the field. But hey we knew that already.
    Audi comes only in AWD too and weighs 4150 lb. in V8 trim. But that nose. EWWW.
    Lexus's V6 is a 3.0(this year) and is the only way you can get AWD. That V6 only has 245hp. But the 6 speed auto does help it get 21/27. The price as equipped is near the same. It may lose a few with that small V6 though.
    The M has a V6 gets 17/24 mpg, 280hp, weighs 4000 lbs and has a $10000 premium pack to equip as the RL. May lose a few
    Benz has the new 268 hp 3.5L AWD and a 7!!speed automatic and a $52k base without leather. May lose a few.
    Looks like all of them have points that may turn a few people off. So the RL isn't alone.
    I don't see the philosophy being all that different. The RL has more power than any of it's V6 contemporaries. And it is probably near the fastest AWD version. Don't see where Acura has dropped the ball there. You know, if we keep apples to apples. Not even gonna go into the RL's reliability record vs it's contemporaries.
    Reading the May 2005 C@D comparing the GS430, M45, blah blah. RL was second only to the M. And rated the RL the best looking car of the group along with other bests like ergonomics and amenities. And no I didn't write the article. But hey, who cares what the magazines think?
    Sure would be nice to respond to a post that's not the written equivalent of "nuh uh" for change. This is getting tedious.
  • seminole_kevseminole_kev Member Posts: 1,696
    I will be interested to see the sales of the Infiniti M, Lexus GS and the Acura RL after a year or so. Most interested to see the sales of the Infiniti as they've (in the past) been real hit or miss with their products. Curious if they will follow on the G35's success or not.
    And first in the Car and Driver article that you mentioned later in your post.
    In the Edmunds test, they all got 15 mpg, so I guess it's dead even.
    I do. It did get second, and this is what Car and Driver had to say about the reason why it placed second:
    The Acura RL misses the top slot in this test mainly because of the company's habitual restraint. Acura engineers could have made the RL bigger, but instead made it smaller (retaining much of the previous model's interior volume). They could have gone to a V8, but they used a VTEC V6. They could have changed to rear wheel drive but chose to adapt a front-drive platform to a novel all wheel drive system known as SH-AWD, which can shift torque fore and aft for traction and side to side to generate extra yaw for cornering.
    I'm not going to type the whole article, but you get the idea. Coulda, woulda, shoulda, 2nd place. Between Edmunds and Car and Driver, the M and GS each have a 1st place finish and the RL has two second place finishes. The M may have scored last in Edmunds, but that test only had 3 cars.
    In other words, NUH UH!!!!!!
    The difference between the RL and the GS300/M35 is significantly different than the difference between an Accord and a Malibu/Sonata. The Accord is over-engineered compared to those two. The RL is about a second slower to 60 than the M45 and GS430. Okay. We got it. A TL can go 0-60 in 5.6 seconds. Does that make it a better car than the M45 and GS430? Heck, a Neon of all cars will keep up with them all. Does that make it the best car. When talking 5-6 seconds to 60, arguing over which is faster is irrelevant. They are both fast when you consider the top selling cars and trucks in the US are in the 8.0+ second range.
    "the RL doesn't even come close in it's respective class?"
    But it does. When you look at V6/I6 competition the RL is right in the thick of things while offering AWD. If you want to compare apples to apples then look at the M35, 530, E350, etc. Don't look at 540's, M45's, and GS430's.
    So now that the Acura is in 2nd place Edmunds rankings and those of the other magazines are pure gold, eh? Seems like not to long ago when a certain mid-size sedan was placing 2nd to the Accord and several people, yourself included, discounted magazine reviews as pure crap. Hmm, my how times change.
    Sorry, thought that might interrupt the ongoing RL feud for a blissful second or two. And I do (hate electric power steering). It makes the steering vague in every application of it I have driven (including the TSX, which I drove yesterday and I believe has electric steering, but I could be wrong). The best so far is the A3, but even that is a bit weird - a little light at most speeds, and pinky-light like a 70s Eldorado when stopped.
    Steering is not what it used to be - manufacturers are now using enormous tires which I think inherently make the steering more vague on-center - that is a lot of tire to move to a new direction. Then you have silly things like BMW's active steering, and now I hear the new GS has a version of the same thing.
    Would love to see Honda get gutsy and build some small light cars with manual steering again. If it were ever to happen, there isn't another company out there that would dare try it.
    PS response to post a ways back: I would LOVE to see the next RSX become a fixed-roof version of the S2000. Not that it would ever happen - the inevitable price alone would kill it.
    OK, forgive me, it's late, now back to your regularly scheduled programming...
    I dunno about manual steering anymore, except in cars like the 2000lb Lotus Elise.
    Manual Steering in my experience:
    1991 Toyota Tercel (1950lb): great
    1992 Nissan Sentra E (2266lb): not so great
    A lot of that is the engineers' fault... the Tercel is great at any speed, and not even too bad when stopped (unless you're used to American cars).
    The Nissan is pretty tough at low speeds and a pain when parallel parking. It has a great big steering wheel to minimize effort (so big it hits my knee unless I sit almost lying down) which means it'd be even worse with a Tercel-sized steering wheel.
    But I'm sure some of it has to do with weight, and you won't find many modern cars available in the US at less than 2500lb. I know weight has something to do with it because when I'm parking on a hill the steering becomes a lot harder or easier depending on which way the car's facing. (The Tercel also has an engine that was engineered to be light - which is everybody's Tercel burns oil - and I'm sure that helps vs. the nose-heavy Sentra.)
    The stupid thing is that Honda switched to electric steering in the Civic because that was the only way to physically accomodate the new (struts) suspension setup and high cowl line (unless you accept 2% fuel economy increase as a good reason). The ensuing reshufling of the engine bay required a high-mounted steering box. Well I don't want that new suspension and high cowl line!!
    (not that the previous Civics had good power steering either)
    I think you're mixing up plain powered steering with "electric" steering. True most cars these days have powered steering, but some of these newer models are electric-powered steering which is different. That's what Nippon is talking about.
    " If you want to compare apples to apples then look at the M35, 530, E350, etc. Don't look at 540's, M45's, and GS430's. "
    Tell that to Edmunds and C&D. They compared the RL to the GS430 and M45. You can't win with me, so you might as well stop trying. :)
    "So now that the Acura is in 2nd place Edmunds rankings and those of the other magazines are pure gold, eh?"
    I didn't bring up the magazines and Edmunds.
    "Seems like not to long ago when a certain mid-size sedan was placing 2nd to the Accord and several people, yourself included, discounted magazine reviews as pure crap. Hmm, my how times change."
    Lol, when in doubt, bring up the Mazda6. "yourself included " Lol, I never discounted the magazines as pure crap. Go back and find my posts where I cried about the magazines not picking the Mazda6, come back here and re-post them. I'm waiting..........
    Car and Driver is great. Nice try.
    No, I think I had it right. The two cars I've owned (Tercel and Sentra E) both had no power steering of any sort. The early '90s Civic, just like the Sentra, had no power steering in its base version (Civic CX, Sentra E).
    I've also driven a 6th gen Civic DX which had power (hydraulic) steering, and that was overboosted and had no feel. No Civic with power steering has ever been known for its feedback so it's not too great a loss that they've switched to electric.
    The Mazda3 (except the European 1.6L version) and Golf GTI / Audi A3 have gone electric and the reviews on that haven't been good. So, I don't like electric steering either, even more strongly than I dislike regular power steering (but I don't think manual steering is practical with modern car weights).
