Dodge Dakota Crew Cab - II
haven't installed yet, but their web site has
instruction for the install, seem like it will be a piece of cake, the folks at Starboards are
on the ball, making sure you get the right thing.
The jewel came with factory wheel flares so I've got that aced.
I also have a sprayed in liner made by Carefree. Paid $425 for it. I asked the dealer what the difference between his liner and Xliners and Rhino Liners and he told me it his had a higher tensil strength and didn't need to be applied as thick. Also, Rhino (I don't know about X-Liners) sand down the surface of the bed to get good adhesion. Carefree heats up the bed so that the paint and the coating make a good chemical adhesion to each other. Who knows which one will work better for you......it's all a matter of personal preference.
KnK
robert
Also, does it seem that the 2wd are being built and delivered a little faster than the 4wd. My dealer says it shouldn't take any longer than 8 weeks, but I'm leary after seeing all the delay problems posted here.
and ordered the flares. I installed them myself.
Took my time and only took about 45 min. to
install.
Regarding the 2-tone paint and the flares, look
at some of the 4WD trucks in 2-tone paint and in
your color and look at the color of the flares.
Then it's quite simple, if you like the combo
order that color from the parts dept. and
install 'em yourself.
Good Luck
renegade69
cowtownkid
The Extang cover comes with snaps that you can loosen and swivel. This will allow you to tighten the cover in the summer and loosen the cover in the winter. But, the snaps will not move along the rail system. They are fixed in place.
I went with the Sportmaster because (it was $20 cheaper) the snaps can be moved around the rail system. Handy if a snap breaks and you need to replace it.....then you don't have to replace the whole rail! It also has some adjustment that is made in the tailgate rail to allow for summer and winter usage.
It's your choice......here are the links:
http://www.pickupspecialties.com/prod03.htm
http://www.pickupspecialties.com/extangclassic.htm
Anyway, my 1500 mile update is that I gained 1 mpg once the motor broke in. For those of you who don't remember, I have the 5.9, auto, 3.92 lsd, black, sport, 4WD. I went from 13 to 14 in the city....... I can't wait for a road trip to see what it will get then and this thing will absolutely squall the tires.......alot like my '70 Dodge Coronet R/T with a 440.
I guess I am gonna have to take mine in and have the seat checked because mine squeaks too. I gets pretty annoying if I don't have the 8 speaker infiniti sound system cranked up (I really like the way the rear view mirror dances when the bass hits! It's tremendous).
Enough about mine...... keep me informed about everyone else's. :-)
Jeff
Got my Dak Quad about 2 weeks ago (ordered either last week of Jan 1st week of Feb LDSG 4X4 with th 4.7, Auto and pretty much optioned out.) I checked the bed after reading all of the posts and sure enough it was out of alignment by 1/2 inch. Got that fixed but now my brakes are acting funny. They will fade when you are at a stop light (go right to the floor if you don't pump them back up!) The dealer cant seem to find anything wrong with them though they are going to go ahead and replace the Master Cylinder. Anybody else have any problems with the brakes?? Also the dreaded ticking noise is coming from my engine compartment the dealer said it is the injectors but I told him to look at the TSBs. I thought that the TSB only applied to Daks manufactured up to a certain date. Has anybody recently picked theres up and still had the ticking noise??
Jeff
I want to do a suspension lift,at least 5" to run 33"-35"(I have 31") tires.I might need the body lift too,to fit the 35"....If I go that radical.
I would like to know the mag. that you saw the body lift in.The only lift I've seen is in Petersens 4 wheel and off road mag.Let me tell you that lift isn't just a body lift,it has 39.5" tires! Its awesome and is the same color as mine.
Let me know the mag.Anyone else that has any info,chime in,this is my favorite subject..
Allen-
Question: I can see doing small lifts for slightly bigger tires but going up that high seems to be more dangerous than valuable. I see that the project Quad has "bogger" tires, which to me implies mud holes. Although I've never done it, it would seem that there would be uneven bottoms in mud holes and that would create an even higher potential for a "super-lift" truck to tip over.
Finally, can a truck, like the one in the magazine, be a daily driver?
Allen-
www.4adodge.com/glossary/sema/index.html
Allen-
Or by the way, my drivers seat had a little problem, too. Three loose bolts and one missing bolt that hold the seat to the truck frame. Makes me wonder how many other bolts are missing!
To answer spike50, safety is in the hands of a driver. I have never even come close to flipping any of my lifted trucks. With a lift comes large and wider tires. I even did a 50 mph power slide on the freeway to avoid a van that had hit the wall, and I was driving an isuzu p/u with 5" lift and 33" tires. My old daily driver was a Dodge fullsize stepside with 38.5" tires and 12" lift. Never a problem, Never an accident. Trucks don't crash, drivers do!
Next step, pick up a 3" pvc "lazy 90 degree elbow (called a lazy street 90 by plumbers) Cut back a 1/4" notch on the large end and slide it directly over the throttle body. Fits like a glove! 1 hose clamp will do the trick. Then just run a pice of 3" pvc to the air box and use a 3" coulpler. The coupler will fit the outside of the airbox perfectly with just a little force. Makes a tight fit. Sand and paint the whole thing black and it looks like a factory unit. Total cost $4.57 plus a can of epoxy spray paint. I have installed several high dollar "Ice man" as well as "k&n" intake kits for friends (I'm the local shade tree guy around here) and mine looks just as good. Gives a really throaty sound from under the hood under heavy accelleration!!! Gotta love it! If you cannot find the "lazy 90, use a standard street 90 and streach the factory black hose between the coupling and the 90. Use the factory clamps and it will hold very tight.
Use a hairdryer on them and they should lift right off.
Told you it was tricky!!
I can't wait it is making me nuts all this waiting on lift kits (a lot of people on this site can understand the pain that is waiting...I won't list names,bookitty..sorry)Just trying to lighting things up!
I'm on my way to get the May issue..Did anyone get my link? Except for Ozark...He is the only one that gave me any feedback,Thanks by the way..
On that site you can see Quads accessorized,nicely I might add.Keep me posted on those westin nerfs..I'm still undecided as to which ones to go with..
Allen
Susan
KnK
Happy Quadding Everyone!
Anyway I guess I have to wait. This summer isn't that far off(looking on the bright side).If anyone else has Info. on this topic please do tell!
Allen-
flexible flaps it will ....
no liner or cap ......will do a bed mat of p/t plywood...
all for now....slr
Love reading all the informative posts here-keep up the good work.
"2000 Dakota Pickup 2WD 8 cyl, 4.7 L (287 cid), multipoint fuel injection. 4-speed automatic trans. w / lockup torque converter."
Very strange company, D/C. I guess they don't even read their own spec sheets before marketing & sales get a hold of the products. I wonder what else is not quite copacetic in their vehicles. :-O
