Dodge Dakota Crew Cab - II
As for mpg - 3.92 vs. 3.55 vs. 3.21 - the jury's still out. Haven't heard many 'huge' differences on these posts other than the 5.9 vs. 4.7. That seems to be the widest gap here. Including (oddly) the 4X4 models - they are NOT much of a penalty it seems. You'd think the bigger variance in mpg (Quads only) would be between the: 3.9/5-spd/2wd/3.55 & the 5.9/auto/4X4/3.92, and it is. The v-6 gets about what the 4.7 does. But in the mid-range 4.7, all combos are reasonably close (within a couple mpg either way) unless driven hard, as I do. Mine was averaging 14.5 in town & 16.9 hwy (at 70mph). But I drive pretty 'quickly.'
Recently, I've installed -- at HUGE expense so as not to void my warranty -- a 3.21 non-lsd rear ratio. Results to follow... but as of now are not very promising. Don't anybody try this for a bit!
I have the rear-end howl when I let up on the gas. Been there since day one. Loud too. I have put off having the dealer check it out because they are not too sharp, and if it becomes necessary to work on the differential I'm afraid it would make matters worse. Have had previous experience with the dealer, and I'm not at all confident the outcome wouldn't be worse than simply driving it as is. Needs to be checked out; if you do please post the result. Thanks. Bill
I've had the rear end howl since nearly new, but it isn't too bad. Maybe I'm just getting used to it. Since I put a Dynomax muffler on, I cant hear much else anyway. I get 14.6 mpg suburban city, about 1 mpg less than I got in my '97 V-6 Dakota Club Cab. Not bad, considering there's no performance comparison, and since I had to use 93 octane in my V-6 to keep it from knocking.
As for the decals, use a blowdryer on high, and hold it up to the decal, about an inch or two away, for 15-20 seconds or so, and you should be able to peel it with a fingernail. Do one letter at a time. Use wd-40 and a clean soft rag to remove the glue residue. Absolutely no effect on the clear coat. A sign guy I know removes and installs decals of all types for a Dealer, and I learned from him.
It also has torque multiplication and an electronic clutch for the 'lock up' function.
I will refer to the service manual to see if the fluid is 'drainable' I doubt that it is. There is little reason to change a fluid that is sealed so well that no contaminants can enter it.
Some modern automatic Xmissions have no provision for changing the fluid either... again, the unit is sealed so well from the factory there is no reason for it. (I believe the ford Focus may have a xmission such as this)
cowtownkid
cowtownkid - your mileage is the same as my 3.55 was, (now a 3.21 and not much different either). My biggest pet peeve to date (outside of the dealer not putting double-sided tape on my tailgate 'protector') is that $%#@ low-fuel sound. AND it happens - right on the money - at 1/8 tank. Drives me nuts! %$#@ D/C engineers... :-I
I just bought a 4.7, auto, SLT plus, quad cab this past weekend. Believe it or not I am giving up a 98 Camaro Z28 for this truck and so far I love it! I have a couple of minor questions if anyone can help me out here.
1 - What is the 'clip' for on the overhead console? i did not get the trip computer so instead I have this crazy clip that cannot hold anything! Does anyone know if I can remove it and put something else in its place?
2 - I bought a truck off the dealer's lot and as such was not able to get all the options I wanted - one of those being the fog lights. Mopar offers fog lights - does anyone recommend that or what should I do? I really like the look with the fog lights installed.
Thanks for all your postings on Edmunds. i have been reading them for a while and they really helped me when I went to buy this truck.
-my low fuel light/sound always comes on @ 1/4 tank even though the owner's manual says 3 gallons. my second tank (almost empty) got me 13.69mpg (4.7L,3.55lsd,4x4,80% city). looks like the third tank will be less. surprising since i consciously tried to keep my foot out of the throttle. oh well, no complaints :}
My 4x4 4.7 5spd 3.55 still getting mostly 17mpg at 3000 miles. This is mostly interstate and rural hilly roads. Very little city driving.
snowedin, local truck acces. place tells me the same things about the Westin bars. Do you think they will help entry into the 4x4 with the big tires or are they just for looks? Have you looked at fiberglass or molded steps like Starboards or Lund? They look a little more practical but not as cool. What you think?
Well, I am not going to go into all the calculations because - well I can't remember all the ratios, but essentially the 3.92 is 10.4% lower than the 3.55, so (all other things being equal) the revs will be 10.4% higher - 104rpm per 1000.
This doesn't mean that the fuel consumption will be 10.4% greater though, you have to factor in the gearing, % of driving at different rpms, blah, blah, blah. Are you starting to see why I can't be bothered to work it all out??
Bottom line, expect 0.5 - 1 mpg difference max for the average driver / journey.
Fuel dong (hey, lets be fair - its more of a ding than a dong), does come on at 1/8th of a tank. BUT, that doesn't mean that you have 1/8th of a tank left. All cars have a little reserve capacity for various technical and consumer reasons (technically difficult to accurately measure the amount of fuel when the tank is nearly empty because it sloshes around so much; consumers are inherently dumb, if you actually told them that there was more gas than they thought then they would try and make it to the next gas station that was 0.1c cheaper).
As a result reckon on the guage reading empty when there is still 1 1/2 - 2 gallons left.
#2 GAS LOW WARNING. Just like everyone else 1/8 tank BING,BING,BING but when I fill it up it only takes 18 gallons. HMMM 24 gallon tank minus 18 equals 6 gallons left, that is a 1/4 tank left in my book so my gauge is off and the owners manual lied about there being only 3 gallons left when the warning chimes in. #3 dont even bother trying to use the storage bin between the front buckets, its reminds me of a volcano in its build design, little at the top and gradually gets bigger on the way down. It needs to be re-designed. Other than that I must say I am completely satisfied with this thing, got me 19mpg this past weekend on a highway trip doing 70-75 mph. not too shabby. SSL (sorry so long) I guess thats how Ill end all my posts from now on.
1) I have a 2 wheel drive Quad.
2) " " the 3.55lsd rear end.
3) " drive 43 miles (one way) to work. Most of it is a two lane state highway with little passing room. Three small towns to slow down for, and a total of 2 stop signs and 11 traffic lights. So my average speed is around 50 MPH.
I keep it in 5th gear, and that's how I'm getting 20+ MPG.
P.S. With the cruise set at 35 MPH (speed trap zone), the computer tells me I'm getting 34 MPG.
Just to throw a real curve ball in there I got 82.4 liters in once, it was below the red line and I don't recommend it. I was determined to get as much as gas as possible in though as my wife's company gas card was paying!!
Is it just me or are we running out of things to complain about? I think that is a good thing.
Allen-
I e-mailed them about availability and was told approximately 4 weeks and they would be shipping.
I was told the price is yet to be determined.
has anybody out there done anything other than modify the stock airbox? I can't help but think a air intake and a good cat-back exhaust should boost the HP even more!
Except for an occasional "slam" in the auto trans, everything has been super. Like better than 16.5 hwy and 14 in-town, but that's life. The auto clunk comes upon giving it some throttle about 15-20 mph, after decellerating for stop light and it changes to green. Maybe it doesn't know which second gear to choose, I don't know. One of my friends was ready to eject out of this bad boy it startled him so much. Been in ice, storm and used FWD about 1/4 of the 100 mile trip through the boonies to get to our house in N. GA to get the stove turned on to keep temp above freezing. Followed four other guys on 10 mile detour, dirt roads, field and whatever. The rubbing of the ice covered branches had me worried, but the paint job didn't have a scratch.
Towed 12 foot u-haul twice, about 400 miles total and didn't even know it was there. Used O/D cutoff, like they recommend. 3,000 rpm max at about 60 to 65. Haven't been above 90, solid as a rock, and I was a Chevy guy too!
Switched to Mobil 1 at 2,500 cause I love the stuff and it also did away with the yellow crud in the oil filler neck.
Got Grizzly push and brush bar and it looks great. Ordered step bars in Jan, they're not in a big hurry to make them, I guess.
Be careful out there.
Allen-
I suspect tomorrow the Doc will be calling to tell you you're a little bit pregnant...
Do let us know.
Chad
BTW: I ordered a green automatic 4wd QC SLT with 4.7 engine. Extras: skid plates, split rear window, and body mouldings. Ordered from carorder.com
Bought my quad a K&N air filter, $44 and some change. It's the some model as last years if you have the 5.9 litre so the '99 fits the '00.
By the way, there was another guy at the dealer this morning that had a quad also getting some rattle fixed from his back seat and we got to talking about mpg..... he said he gets 27 mpg on the highway, 20 in the city......V6, auto, 2wd, slt model...... I was astonished! Anyway, I told him about this little site because he seemed pretty proud of his quad like I am! Anyway, raod trip coming at the end of May..... Nashville to Dallas... looking forward to it!
Jeff
5.9, auto, 3.92 lsd, 4WD, Sport, black, buckets, etc
anybody else have a manual, i read it at the dealer one day (i thought)
robert
and I did not order the Tire & Handling Pkg. so I
will have the smaller wheels and tires. I was wondering, when I upgrade the tires, what is the largest tires that I can fit without any modifications?
BTW-My first time to post and I just want to let all of you know this a great (and informative) discussion.
I guess the other decision you have to make is what size wheels you want to run. Those Goodyears come on 15" x 8" wheels. Since you're starting over, you could go with 16" wheels. You loose some side wall and maybe some weight carrying ability but you probably could get a tire under the 31" diameter limit. This might not be the way to go since I see that you're getting a 4WD. Don't want to be cutting tires or busting wheels in the boonies.
Feel free to read that chapter yourself...
The torque converter has TORQUE MULTIPLICATION and the electrically operated lockup clutch. This is a fully computer-controlled unit that actually CUTS ENGINE POWER during shifts to improve smoothness. It also has special features that use JUST ENOUGH hydraulic pressure to keep the clutches from slipping. (NO WASTED POWER which is lost as heat) The input and output shafts are constantly monitord for speed and the pressure is raised until the measured slippage is zero. This also allows the computer to 'ease' into the gear shifts. This makes re-programming the computer a new 'tool' in fixing problems or to improve shift patterns.
The DOWNSIDE is that since it is computer-controlled, it is subject to 'bugs' or 'glitches' like any software. It is virtually IMPOSSIBLE for programmers to consider EVERY POSSIBLE CONDITION.
69rookie = I got the 235X75's on the standard rims (15x7's) when I bought mine. Very good combo if you stay under 80-85mph (I don't). The chassis is a bit taller with the stock setup vs. T&H package, so I'd guess some pretty big tires and/or wheels would fit under there (17X9 RT's with 255X60's on mine). For 4X4 stuff I'm sure spike50's correct. Also, see previous posts by ozark, bpeebles, a_j and others... The Dakota web site (I forget the .com name) has a tire diameter calculator on it - pretty amazing - handles hundreds of different combos.
i guess i misunderstood what torque multiplication was, thats for the correction.
robert
Anyway they did order me a new seat cover and installed it($308.00)Lucky I didn't have to pay!Can you believe 6 weeks before I noticed?In my defense I don't sit in the back and that's where I was when I saw it.
As far as this Rubber molding,they had to order me new ones.I told them to just glue them back on but the owner wouldn't let them.I'm not sure why.
The moral of this story....No matter how excited you are when you get your quad,take time to look it over.Although I didn't get "screwed" for lack of a better word.I think they could have given me a hard time.I just thought I'd share that with anyone who cares..
PS go out and look at that rubber molding(between the doors)you can see it with them closed.It's at the top.I have a feeling this might not be just my truck,as BOTH sides were coming off.
I hope I am wrong about this.
Allen-
What do u think.?... cancel the order.??... and take that pretty little blue NEON on the floor#@#$%^&(()... Maybe I can Squeeeeeeze a pressure treated deck into the hatch.
Signed FRUSTRATED
