Toyota Prius Accessories & Modifications
The only discussion I've seen on the internet about them was on muscle car enthusiast forums. They were more concerned about hp gains, hardly mentioned gpm at all.
Which goes hand-in-hand with the old proverb, " a fool and his money are soon parted".
Spark plugs are most probably the least important component in the ignition system. That is, you could use almost ANY brand of spark plug and get almost the same result. Some plugs are different in that they offer resistance to radio interference, or platinum tips for long life.
But a basic spark plug in the correct heat range will work just as well as a "super duper" spark plug costing X times MORE than a basic OEM plug.
SAVE YOUR MONEY!
I think I'm taking this question somewhere else.
Just don't expect them to take out the garbage, and fold your clothes.
They are JUST spark plugs!
If you are trying to get better mileage then make SURE the tires are properly inflated ( NOT 55psi ), and you by-pass drive thu windows.
Also, wear your tiny right foot for the accelerator.
I am not one who thinks everything can be "cured" by taking a "pill". Life is more challenging.
Sorry for the "snarkyness". As Jack Webb used to say, "just the facts ma'am".
cheryl
Thanks for any info you may be able to provide!
Eric
I am unwilling to pay the Toyota stealership $400 for a new FOB and programming charge ... but the lady at the desk said to open up the FOB and try manually unsticking the button once inside.
But how do you open it? I am at the same place ... battery compartment open, but no apparent way to get into the guts of it to get near the button. Did you ever figure this out?
After removing the spare metal key, then figuring out how to open the outer cover to the battery compartment (not exactly user friendly!) I removed the battery cover & battery. From this point the fob is not designed to be opened in a way to be easily reclosed after opening. I inserted a screwdriver into the spare key slot & whacked it good. The two halved split apart with some forcing effort. These two halves are glued together! Toyota doesn't want you in here- they want your $400 bucks instead! The circuit board can then be pried out with a fine screwdriver or knife. After cleaning the buttons & compartment pretty well, we were lucky - the button was no longer stuck. On a less complicated fob for my Explorer I was able to unsolder a good unused switch (trunk option) and replace the broken old switch & it worked like a charm. However the switches on the Prius fob are really tiny with really tiny tabs soldered to one side of the circuit board only and look very hard to try that switcheroo. I'm glad I didn't have to try that unsolder/resolder task! Now it should just take some good superglue & rubber band clamping to glue it back together. Good luck!
