Chrysler 300: Problems & Solutions
Is anyone else having problems like this?
Also, had them verify the chipping and flaking on the rim of the chrome wheels. They took digital pictures and sent them to Chrysler. New ones are now on order and Chrysler is replacing all four of them.
Even with these minor problems, my 300C is the best car I have ever owned.
A side note. I installed the new EG Classic Bentley grille. Wow! If you think people thought your car was hot before, just wait. Most people don't know it's a 300C! It took me 4.5 hours, lots of cuts, nicks and 4 letter words, but it's in and looks great!
As always... enjoy the ride!
Good going Continental for standing up.
Dennis
I have a 300C with 6500 miles, reported this problem in Jan 2005. My dealer told me a factory rep needed to see them. Living in the northeast (upstate New york) I took my 300 to 3 local dealers. One flat out said Chrysler wasn't doing anything about it, second said they were doing a good will to their customers only. And my dealer says yes Chrysler knows about the problem, which also is happening to PT cruisers , Pacifica and Ram 1500 pickups. The rim itself was not completed coated and is now wearing off. You can also see the problem on the inside of the rim toward the breakes. There is nothing they can do. I have asked for a replacement rims but my dealer says the problem will only happen again.
I have made my displeasure known and will fight for new rims. If you all notice the latest 300C's are full rims and no "plastic cladding" . Please reply if you have the same problem and your location. Thanks. Otherwise it is a great car. :mad:
> At our last meeting Chrysler advised us to make it a point to instruct
> each of our Magnum / 300 owners to rotate their tires based on the
> "scheduled maintenance guide." The guide shows every 6000 miles and that
> should be considered a minimum. Every oil change would be preferred. The
> tires on these cars are not the normal compounds and the cars develop a
> great deal of caster and camber when cornering which will cause tire
> cupping.
It does not differentiate between Goodyear or Continental tires or between models. My guess is that it only applies to the 18" Continentals. So, is it the alignment or do we all suffer from abnormal "compounds"?????
What is everyone's opinion on this latest spin on the tire wear issue?
Continental Tire Wear & Right Pulling Problem:
I had a Rep come out to Massachusetts and look at the pulling problem of my 300. I also asked him about the tire wear issue and he said it is different from the Pull to the Right. The Tire wear is a Continental Tire problem. They have admitted to the problem and are supposed to replace all tires...DO NOT pay any money for more tires! I heard it straight from a Tech Advisor from DM. I really like this car, but it's a total lemon.
As far as the pull to the right, I am getting more lies everytime I talk to them. We need to contact someone and get this story out there - FOX - CNN - Someone! I already tried this at 1 local station, but they didn't reply, so I am going to keep at it, and also dealng with a lawyer. I hate to do it, but the car needs to go.
dmiller5
Good luck!
The only problem I have had was with the pass.side,again plastic, exterior door handle that had a terrible squeak whenever used and my dealer replaced it under warranty. Other than that after 1200 Mi. no complaints.I will keep my fingers crossed.
They stated that WATER was getting into a sealed system. Da! Lets look at that. I have a trans that is sealed. I have a heat exchanger tied to the Radiator(clue water supply under pressure) and a sealed filler port. By the way, the dealer added an rubber "O" ring to that fitting and coated the area with silicone. A real great engineered application.
We'll see this afternoon, maybe an application for this states "Lemon Law"
Please post your finding including the dealer fix please
What is your build date ? I don't know the actual build date, but the delivery date to the dealer as April 1st, 2005.
TSB#: 21-011-05
Date: April 23, 2005
Models: 300/Magnum/Charger/Grand Cherokee (WK w/3.7L, LX w/ 5.7L, or LX AWD w/3.5L) equipped with a NAG1 (W5A580) transmission (sales code DGJ).
Model year: 2005
SUBJECT: NAG1 (W5A580) Transmission - Shudder When Torque Converter Clutch Engages
OVERVIEW: This bulletin involves thoroughly flushing the NAG1 (W5A580) transmission of any water contamination, replacing the transmission filter, and applying RTV sealant around the base of the transmission fill tube to prevent water intrusion past the fill tube seal.
SYMPTOM/CONDITION: The customer may experience a transmission shudder when shifts occur. The shudder is most noticeable with partial application of the torque converter clutch in 3rd and 4th gear.
DIAGNOSIS: If the customer experiences the condition perform the Repair Procedure.
NOTE: This condition may occur when only a small 0.5% concentration of water is present in the automatic transmission fluid. It will be very important to ensure that the transmission and torque converter is thoroughly flushed of any water and other possible contaminants.
Parts required:
13 P/N 05013457AA Fluid, Automatic Transmission, MS-9602 ATF+4, Qt.
1 P/N 05010884AA ATF - RTV
1 P/N 52108325AA Filter, Transmission Oil
Special tools:
9336 Special Tool - Transmission Oil Dipstick - Used for LX
CH9401 StarSCAN™ Tool
CH9404 StarSCAN™ Vehicle Cable
REPAIR PROCEDURE:
This repair procedure involves a triple flush of the transmission. Follow the Repair Procedure carefully to ensure that all residual contaminated fluid has been removed from the transmission, especially the torque converter.
1. Raise the vehicle on an appropriate hoist.
2. Inspect that the fill tube seal is properly installed to the transmission housing.
NOTE: The seal between the fill tube and transmission housing is correctly installed when the top surface of the seal is flush with the outer surface of the transmission housing. If the seal is not correctly installed (extends up above the transmission housing surface) then its position must be corrected prior to proceeding further.
3. Loosen (but do not remove) the lower fill tube attaching bolt located at the base of the fill tube (Fig. 1).
4. Loosen the upper fill tube attaching bolt.
5. Verify that the transmission fill tube is centered (no side loading) in the transmission housing opening and seal.
6. Tighten the upper attaching bolt to 40.7 Nm (30 ft. lbs.). The upper bolt MUST be tighten before the lower bolt is tightened.
7. Tighten the lower fill tube attaching bolt to 11.9 Nm (105 in. lbs.).
8. Thoroughly clean the base of the fill tube and the area of the transmission where the fill tube mates to the transmission housing.
9. Apply ATF-RTV sealer, p/n 05010884AA, to the area where the fill tube mates to the transmission housing.
NOTE: Verify that the RTV sealer is installed completely around the base of the fill tube and completely seals off the transmission housing fill tube seal from possible water intrusion past the seal.
10. Remove the transmission oil pan. Drain the transmission fluid.
11. Thoroughly clean the transmission oil pan.
12. Install the transmission oil pan. The pan gasket is reusable.
13. Lower the vehicle leaving the rear wheels off the ground.
14. Fill the transmission with four (4) quarts of ATF+4 transmission oil.
15. Apply the service brake and start the vehicle engine.
16. Shift the transmission into drive, release the service brake, and lightly accelerate the engine speed to allow the transmission to upshift through all forward gears.
17. Apply the service brake and stop the wheels from turning.
18. Shift the transmission into reverse and release the service brake. Let the wheels turn for approximately 5 seconds.
19. Apply the service brake and stop the wheels from turning.
20. Repeat steps 16 - 19 two more times.
NOTE: At times, the transmission may go into “limp-in” mode due a to transmission generated DTC. The DTC must be erased/cleared before proceeding further. The transmission fluid may not be properly circulated in the transmission if the transmission remains in “limp-in” mode.
21. Stop the engine and place the transmission in the PARK “P” position.
22. Raise the vehicle.
23. Remove the transmission oil pan. Drain the transmission fluid.
24. Thoroughly clean the transmission oil pan.
25. Install the transmission oil pan. The pan gasket is reusable.
26. Lower the vehicle leaving the rear wheels off the ground.
27. Fill the transmission with four (4) quarts of ATF+4 transmission oil.
28. Apply the service brake and start the vehicle engine.
29. Shift the transmission into drive, release the service brake, and lightly accelerate the engine speed to allow the transmission to upshift through all forward gears.
30. Apply the service brake and stop the wheels from turning.
31. Shift the transmission into reverse and release the service brake. Let the wheels turn for approximately 5 seconds.
32. Apply the service brake and stop the wheels from turning.
33. Repeat steps 29 - 32 two more times.
34. Stop the engine and place the transmission in the PARK “P” position.
35. Raise the vehicle.
36. Remove the transmission oil pan and filter. Drain the transmission fluid.
37. Thoroughly clean the transmission oil pan and pan mating surfaces.
38. Install a new transmission oil filter, p/n 52108325AA.
39. Install the transmission oil pan (gasket is reusable). Torque the pan fasteners to 8 Nm (71 in. lbs.).
WARNING:Risk of accident from vehicle starting off by itself when engine running. Risk of injury from contusions and burns if you insert your hands into the engine when it is started or when it is running. Secure vehicle to prevent it from moving off by itself. Wear properly fastened and close-fitting work clothes. Do not touch hot or rotating parts.
CAUTION: Transmission oil temperature readings are taken using the StarSCAN™ tool. The transmission oil temperature can be read ONLY when the gear selector and transmission are in either the Reverse “R” or in one of the Drive “D” / forward gear positions. Always set the vehicle park brake AND apply the vehicle service brake when taking transmission oil temperature readings. Take a transmission oil temperature reading and return the
I found the build date 03-05 (thank you for letting me know where to find it)
