Visitor Agreement.
The 4.3L is just adequate in the S10. It will be an absolute pig in a full size (extended cab!) truck. Poor performance, poor mileage, and will be sucking wind at every little hill or when the A/C cuts in.
Sounds better, smoother, no acceleration robbing counterbalancer. From a 4.3 to a 4.8, only .5 liter.
If you never go over 45, have a high ratio rear end; the 4.3 MIGHT work.
I have nothing against the V8s, I have a 5.3 Yukon on order. I just don't think everyone needs the power of a V8. Anyone considering a V6 should drive one, then drive a V8. That is the only way to compare the two that makes sense to me. I would trust an extensive comparison test drive over anybody's opinion, including my own. IMO
The V6 is an OK engine in a toy truck like an S10, but woefully inadequate in a full-size truck.
Performance will suck, towing will suck, gas mileage will suck, trade-in will suck, and it will wear out long before it's time.
Hans
My V-6 Silverado long box 4wd auto with 3.73s runs great and has lots of power. The truck easily hits the speed limiter that is the same limit as the V-8s. I have not towed with this truck yet, but plan on towing around 5000 lbs. I have towed 5000 lbs. my S-10 Blazer (tow capacity 5600 lbs.) with the same V-6 less 10 horsepower. The Blazer weighs as much as the Silverado (within 100 lbs. according to the titles). I was able to tow in overdrive when not in the mountains and was amazed at the power. I was sold on the Silverado V-6 because of my experience in the Blazer. The overall ratios (tires/axel/trans) for both trucks are the same.
My gas mileage is OK. The highest was 20 mpg on the highway (at high speeds) and lowest was 16 mpg during town and 4x4 driving. The overall average has been around 18 mpg. I had a 98 Nissan Frontier 4 cyl 5sp 4x4 that got the same mileage and was very under powered! I guess the Americans are actually surpassing the Japanese in some areas.
Next time I think I would buy the 5 speed if the $500 manual credit is still available. The V-6 500 credit helped make the decision too.
desert 6 - If you only got 11-13 on a 2K Silverado short bed 2wd V6, then I think something must have been wrong. My 2K longbed V6 auto gets 20-27 (lowest 18), but I drive carefully. I think if you keep a truck of this type for 4-5 years, then condition will mean more than engine size. If you trade frequently, then the V8 has better resale in the short run (but you shell out more to begin with.)(BTW I also drive AZ with no noticeable power loss when AC on, although I never tow.)
Each to his or her own, IMO.
and auto. The V6 is a good motor for light
duty use. As for towing it is decent if you
are reasonable about performance. Biggest
trailer I towed was a 14x8 Wells Cargo trailer
with a dead weight of 2400lbs. Pulled it for
250 miles in 3rd gear at 70+ mph and the
truck returned 12mpg in the process.
My truck is slightly modified, K&N filter,
Gibson catback exhaust and 180 degree
thermostat.
BTW, I still have the stock 3.42 RE.
inactivity. It will be archived or deleted within
10 days.
Pocahontas,
Edmunds.com/Host
