Visitor Agreement.
YOU get more work out of smaller space!
thus, smaller engines, more power with better mileage.
Material engineering has advanced exponentially in the last 4 years.
i'd buy all aluminum engine in a heart beat and not worry about it.
- Tim
Nutshell: Warping should never ever be a problem anymore.
hell, you can run GMs new motors (w/aluminum heads) without water and not damage the engine! what else do you want?
The 350 was "always heralded as better than the 5.4" ? Huh? The 330 has been out how long? 3-4 years? Where is this tidbit of fact coming from? The 350 is a fine motor but who would want an older engine over the 5.4?? Tim- maybe?
It may have been more "endearing" to Chevy guys versus the 351 but "heralded" over the 5.4?
people keep saying this, but I argue on how 'old' the 350 and 454 are. In '96, the Vortec year, they changed everything. I compared all specs to the '94 350 i owned. Bore and Stroke were different. all bearing types and lubrication methods changed. total induction and injection change. computers controls became exponentially more powerful and complex.
Accessories aren't same, don't bolt on the same, exhaust different....
get my point? nothing "old" about the '96-'00 Vortec 350, which I is ACTUALLY 348 cu. inches.
same goes for 454.
I was just trying to figure out why it was so "heralded" by the masses. In any regard, it seems that the 5.3 won't quite match up to the Triton when discussing terms of torque curve and hp. Ford conceded the mpg subject years ago.......
Check your timeline. You think Fords intro of the 5.4 FORCED Chevy to make the 5.3? Engines take years to develop. The 5.4 did NOT surpass the 350 until the same year the 5.3 was introduced. co-production with the 350. so strike that comment
Took for ONLY 3 years to surpass? they basically copied the "96 Vortec design. I don't know how much 'engineer' you have in you, but look at Popular Mechanics archives and they did details of Ford and GM engines back in '96-'97, then again this past year on Ford. The changes Ford made in '00 are EXACTLY the same top end changes GM made back in '96. Major induction and head design changes.
So actually, it took Ford 3 years to figure out what GM already knew.
Please delete the word "heralded" from your cache. Delete delete delete. my choice of word had a much greater effect than it should have. Have beer, calm down. what I meant was, it was common 'trucker' knowledge, that the 5.4 didn't have the power or mileage capabilities of the 350.
You can define better engine however you want to. obviously, to you, the 5.4 is better than the 5.7. You bought one. I didn't.
The old 5.7, new 5.7, and new 5.3 ARE ALL RADICALLY DIFFERENT.
5.7--> Vortec 5.7
Block change
Bearing/lubrication changes
reduced internal friction
cam Change
accessory changes
Induction changes
Head changes
Injection and combustion changes
Electronics Advance
RESULT: +10 ftlb, +45 hp.
Vortec 5.7-->Vortec 5.3
Totally different block, different metal
6 bolt mains
More bearing/lube changes
Cam change
accessories change
Aluminum heads
Induction slightly changes
Ignition Radically changes
electronics Advance
RESULT: Very wide powerband, More hp (albeit @ high rpms, greatly improved mileage.
My only point of disagreement was where the vortec 350 was "heralded" over the 5.4. (I can't delete-LOL!) What knowledge do "truckers" (define?--rigs? or pick-up guys?) have that inherently gives the 350 more power over the 5.4? And with these inherent advantages, does the 5.3 have it over the Triton as well? I think you would have to concede that there is hardly any difference in power between the two.
I'm a pain-in-the-[non-permissible content removed] aren't I?
Uh oh! I said Harped! what could that mean???
It just wasn't argued in '97-'98. the numbers showed it, the test drives showed it: the 5.7 had more punch than the 5.4. and it had GM's small block history behind it.
The 5.3's advantage is OBVIOUSLY, from various forums, very arguable. its been shown, that under load, with the hammer down, the 5.3 outpulls the 5.4 and the 350. but there's been mostly name calling and no real evidence around here of either's advantage. You yourself touted in another string that Chevy people can't argue the 5.4's superiority. Then I in the next sentence say the GM has wider powerband-yadayadayada.
they are definitely 2 entirely different engines with different engineering theories, and different feel on the pedal. i've pulled with the 5.3, and yes, it pulls better than the vortec 350. People trashing the GM line complain about the high rpm power peaks and I say--just drive one. there is a LOT of power at the low rpms too, it just happens to be a hair under peak.
The Ford engine seems to be superior in the 'cruising' range. all torque right there at highway speeds. but the GM has more torque at ALL speeds.
So, what would you like?
Doh
Already got it..
Damn Roc....you get ornary in that old Miller Lite age....don't ya?
hehehehheee
- Tim
LOL
- Tim
The V-6, when it is using less fuel per mile, will be more economical. When it has to work harder and uses more fuel, it may be less economical.
The V-8, because it doesn't have to work as hard, may achieve greater fuel economy, when carrying or pulling a heavy load.
Other comments:
V-6 with a counterbalancer
V-8 without a counterbalancer
You can reduce engine vibration caused by power pulses by
1. increasing the rotational weight (flywheel)
2. using a counterbalance
3. increase the number of cylinders to decrease or eliminate the time (in degrees of rotation) without a power stroke.
Has anyone had the pleasure of driving a V-12? Smooth, very smooth... like an electric motor.
Is GM listening? How about FoMoCo?
* One gear would be a manually accessible, compound low to get that load moving from a dead stop.
* Closer gearing to handle the torque curve.
* Maybe an "extra overdrive" for the best economy when running on the freeway when empty.
* Conventional automatic operation (with tow/haul switch) with a semi-automatic capability.
Am I really dreaming? Yeah, probably!
I should mention that it is a propane powered vehicle since I work/own a propane company. Benefits of this fuel source are many, but the clean-burn is amazing. It was also used primarily for commuting with light-duty tow/haul.
I should also mention that I am shopping for a new '00/'01 Silverado/Sierra and despite my past experience with the V6, I'm torn over the V6/V8 question. There are pro(+)/con(-) to both.
V6
+ purchase price is $1,195 less ($695 for the 4.8L plus loss of the $500 V6 discount)
+ proven durability (personal experience)
- lacks V8 power and durability should medium to heavy tow/haul come into play
V8
turn the V6 +/- around
Bottom line: It's a personal decision for each of us based upon our own needs and knowledge. I appreciate the content of this topic lists and those who contribute to it. Your opinions and experience help educate all of us.
If you can,drive both setups,long enough to get used to them,and see if you can take it.I got a '00 Sierra 5.3 3.73 4x4 ext cab SB in May,I love it,I never get less than 15 mpg around town,and it runs great.My previous trucks have all been slightly,or very underpowered,and I couldn't wait to start hopping them up,but I don't feel that way with this one....
Barry
mileage. I also think the V6 is a little more nimble in handling, due to less engine weight, but that is just my impression.
The $1K+ costs of the V8 over the V6 is still a major point to overcome. I'll check on the '01 model spec sheets. I believe that the 4.8 is required for the new Traction Control option on the 2wd.
Barry, your truck sounds EXCELLENT. Best to both of you.
Jim
LB = long bed (8 ft)
http://www.autonews.com/html/main/stories/gmfutureproduct814.htm
I would've liked to see the MPG numbers on a 4.2L Silverado. I'd definitely consider buying one vs. a V6 S10 or the 2001 4.0L SOHC Ranger. Oh well.
especially in eastern mountains
Ken-o
Sounds like you need V8 version....I wouldn't think the V6 would tow a 5th wheel (or anything else) in the mountains very well. It may tow them, but it may harm the truck in the long run......just my 02 cents......I'm in no way a truck expert!
John
Ken-o
I test drove a 01 V6 5spd the other day and it rode great. The ride was alot better than my 00 ext cab. I didn't feel the road vibration and sensitivity in the steering wheel. It was real tight, like I want. Hope the feel will last.
Thanks again.
John
John
According to carsdirect.com, a Base Silverado V6 5sp 8ft box (no options) invoices for $14,472. The same truck with 4.8L V8 and auto invoices for
$16,915.
I'd certainly consider a V6 5sp in the regular cab 4x2s. They are the lightest Silverados at about 3900lb versus 4200+ for Ext Cabs 4x2s and 4600lb and up for Ext Cab 4x4s. The V6 5sp also has slightly better EPA MPG numbers at 17/23. (That's almost identical to V6 compacts like the S10 or Ranger which come in at around 18/23.)
I'm looking to trade in my old V6 Ranger 4x4, but I'm concerned about MPG. So I'm considering the V6 5sp regular cab Silverado.
Of course, this isn't the Silverado to get if you do lots of heavy hauling or towing.
They are 99063 and 99363A regarding the mismachined crankshafts on these engines. The fix is to r/r the motor. Evidently, these chopped 350's have a tendency to vibrate. You can find this on the nhtsa website under 2000 Silverado.
If the seats vibrate, there is now a fix for it. Has to do with replacing the seat rails to eliminate that seat "shake". Boy, after awhile I begin to wonder about these trucks.
Good luck!!
If I buy and V6 and it vibrates, I'm finished with GM for good! One thing for sure: I'll drive that baby for about 50-100 miles before signing. Haaaa
I think I'm going back to my orginal plan: used 98 or older Z71.
Thanks for info....
John
overall thats pretty good. What do you normally get for mileage on straight highway driving. I have a chance to get a holdover 2000 at a good price but the 5.3 scares me a bit. I don't tow or haul at all so I really don't need the power of a 5.3l.
ED
auto. Only problem has been rough idle which the dealer said was dirty injectors - dealer flushed injectors under warranty. Idle is "normal" but not perfect - I am the anal type - most people wouldn't notice any problem. Starts, runs, accelerated perfectly - just that slight rough idle.
Still no shakes. Have velvets and Edelbrock IAS -smoother ride/better handling - but still a truck-like, not car-like ride.
Worst mileage has been about 18 MPG - all in town - careful driving gets me 20 MPG in town. Highway mileage is much better, but I rarely drive highway. Good truck - but thinking of getting new Tahoe/Yukon with LPG bifuel for tax breaks.
Good luck - I know you went through a bad experience with your previous ado. My 2K was my first new vehicle purchase and it confirmed what I already knew - no vehicle, even a new one, is perfect. I just expect that I will have less repair cost over time with a new vehicle.
Why not rent a 2K V6 ado from Uhaul for a weekend and see how it performs? Those trucks really take a beating, so if it performs well it might indicate what you could expect on a new one.
Thanks again.
John
3.42 RE. It's a good motor but don't expect to
win any stoplight to stoplight drag races. If you
are dead set on getting this setup do get the
option 3.73 RE. My next project is to swapout the
RE to a 3.73.
Good luck
