Visitor Agreement.
At this point, it's hard to say exactly what's causing the problem. Once there are enough reported cases of this, and Mazda understands the problem, they will hopefully come up with a fix.
Or maybe we'll see them ad a scoop of some sort, or ducting to route air a certain way.
-juice
I guess it will be hard for such person(s) approve one even if necessary.
I do not see nice, cheap solution.
Only solution seems to be to limit boost and change engine HP ratings which causes different kind of PR disaster.
Probably few returned cars too.
Krzys
I wondered about buying the first of MS6's. I went through a year of tweaking when the first Lincoln LS's came out in 99. The car never did run right
That's what our service manager thought could be the problem.
There is no cheap solution. I doubt you will see a hood scoop. The problem is only with the NA version on the car. The Australian and European version have 238 HP, or so I was told. I don't think the car will sell with that type of performance.
The turbo was the reason the car was delayed here as well. They wanted to fine-tune it. Maybe they didn't do enough R&D...
It's not fuel-related either, considering that owners running 93 octane are getting the problem as well.
With our below freezing temps I do like how fast the car warms up, when you are shivering and want heat. I am so curious how the 90 degree summer will affect the turbo.
I doesnt bother me now, because I dont demand the hard driving very often. I'm sure its a concern for Mazda though.
You should do that anyway. Keeping the clutch depressed will result in premature wear of the clutch throwout bearing. You should only depress the clutch when shifting gears, when coming to a stop, or when starting from a stop. In fact, you don't even need to use the clutch at all when stopping. You can just move the gear lever into Neutral without even touching the clutch.
It just made driving a stick look complicated.
Its hard to change after 30 years.
Now I know my children in there 20's drive there manuals wrong because as I was taught by my parents, I taught them. One of them has stopped shifting down, but the oldest drives the "old fashioned way".............
The creeping in slow traffic will always be hard on the clutch
Speak for yourself!!
I learned to drive in the late 60s and learned to drive (and love) manual trannies in the early 70s. "Keep your foot off the clutch" is how you extend the life of the clutch. I agree that stop and go traffic is hard on a clutch and a leg, but the principle is the same - keep your foot off the clutch at all times when you are not actually shifting gears.
I've also never understood braking with the engine, which is what I think you are saying. It's a lot easier/cheaper to replace worn-out brakes than an engine.
:P
Krzys
It wouldn't be the engine, but the clutch that would need replacing.
Not only is it recommended to downshift when descending hills (so the brakes don't overheat and fade), but if you rev-match when downshifting, it's no more clutch wear than a common upshift.
Krzys
Funny thing is I think I was taught that is against the law to leave your car in neutral at a stop in case someone hits you from behind. I still do it, though, since I think it is unlikely my foot is going to come off the brake pedal. I might have to rethink this now .... Oh, wait! I'm LEASING the car so the tranny only needs to last 3 years.
How does being in gear at a stop sign save wear on a transmission? That doesn't make any sense. How does neutral wear the transmission. Automatics might ought to be in gear but not a manual.
I found where he said that. And it really made no sense at all.
link title
Considering the transmission is designed to be used continuously but the release bearing isn't.
Donzy
I haven't driven the car on snow/ice, so I can't comment on the AWD system in that respect.
Overall driving impression- this car is a blast to drive! It's a rocket and never ceases to amaze me. For my 80-mile/day commute, it's pure joy. The seats are comfortable. Its suspension is firm, so you feel more road bumps. But, I expected that from a performance sedan. On the downside, it allows a lot of road noise into the cabin on coarse pavement.
I didn't pay MSRP. I got mine for $200 over invoice.
Its used only to gear change. otherwise foot is on the floor. I agree, you should keep your foot off the clutch.
Tires are fine in rain.
I have had them in 2-4 inches of snow and some ice with no difficulty.
correct me if i'm wrong, but when the car shifts power to rear wheels, the 4wd light comes on. if that is so, then the car rarely needs to do so. i have only seen the light when accelerating hard in first gear while turning, and once on some loose sand. With these tires, I think that it is pretty much a FWD 99% of the time, even in rain and snow.
This is just one example: iPod audio link
The connector is on the driver's side of the radio.
Click here to see a photo of the back of the HU
The iPod adapters plug into the port on the right of the photo, next to the antenna jack.
(The port on the left side of the photo is the main power/audio connector.)
BTW, to actually remove the HU, you will need to remove the glovebox to access a screw holding the HU to a support bracket.
Here's a pic of my iPod installation:
This is where the iPod adapter is stowed. (The cable runs down the back of the HU, under the shifter console, where it connects to the adapter):
The vendor (therpmstore.com) has excellent customer service. I would contact them and ask some questions about the audio link product and how it compares to the Neo.
Beyond that, I don't know much about the other product, but it's obviously much more expensive.
Donzy
2. I've read some of the discussions about this 'power-loss' problem. Just how serious is this? What percentage of cars does it affect. Where can one find independent information on it?
3. Mazda recommends 93 octane for the MS6. Here in California, the highest I've seen is 91. How does 91 affect the car and its performance?
Thanks -
Writing from Los Angeles
Mazda will hold the US debut of the 07 MazdaSpeed 3 at the NY auto show. April 13, 9:10 am is the scheduled time.
-juice
You going?
-juice
1. Does anyone know whether Mazda offers a hands-free cellular link for the MS6? I've searched their website and can find no mention of it?
2. Just how serious is this power-loss issue? What percentage of cars does it affect. Where can one find independent information on it?
Thanks -
