Honda Odyssey vs. Toyota Sienna
15253555758107
  • boodadboodad Member Posts: 31
    Seems like a reputable source (FitzMall Toyota in Maryland) has just reported on the Sienna site that Toyota will offer Sienna 8-seaters in XLE and XLE Limited trims. If this is true, it looks like Toyota may have upped the ante in this minivan war.....Stay tuned...
  • hvan3hvan3 Member Posts: 630
    <<That is odd, the running boards that were on my 05 LE when I bought it are listed on the window sticker for $599.00. They are a nice addition.>.
    If it comes factory installed, then the window sticker for the running boards is $599. However, if you walk into the dealership (Parts Dept) and have them put on the running boards, they will charge you $1200 for aftermarket boards.
    I believe running boards are a great addition if someone is short and have small children.....
    www.qualitycustomboards.com
    BTW, we had them installed the boards for us for $125.
  • papohpapoh Member Posts: 2
    We bought a Toyota Sienna limited/AWD top of the line van about a year ago. 42G vehicle. Since then we have discovered that the tire pressure system does NOT work AT ALL with the run flat tires. My wife drove around for an unknown time with -0- psi in the tire and the system NEVER indicated a problem. Tires are shot and less than 15,000 miles on it.
    After dealing with both local and regional Toyota reps they have refused to do anything about this, though they did acknowledge the system does not work as advertised.
    If not for this problem, we love the van. But I will not have my family driving around in an unsafe vechicle and the tires are rated ONLY up to 50 MPH and only for 150 miles on low pressure.
    I would advise anyone considering this van to NOT get the AWD version with runflats. It is not a safe van due to the admitted nonfunctioning tire sensor and the first time someone gets killed due to this Toyota is going to be sued for a known defect.
    I personally will never buy another Toyota again, and just cancelled a pending purchase on a 50 grand 400h lexus hybrid because if this is the best Toyota engineers can come up with, my family is driving something else. We will be trading in a few month old Limited Sienna and taking a huge hit, but safety comes first.
  • 05ody05ody Member Posts: 103
    So are you going to buy another minivan? an Odyssey? seing how saftey is a big factor now adays the Odyssey has more standard safety features than any other minivan on the road. Dual front airbags, front side airbags, all 3 row curtain airbags with rollover sensors, traction control and VSA. All of thoes are standard on every Odyssey LX to Touring. I wouldnt buy a van with runflats...to much bad about them. If I would of went higher in class I would of bought the EX-L RES with nav. Too bad that Toyota didnt work out though, you should also consider the MDX if you canceled the order for the 400H :P
  • heywood1heywood1 Member Posts: 851
    You could buy conventional tires and available limited-use spare instead of taking such a drastic measure as dumping the car for a huge loss. And what will you get instead? A more-roll-over-prone SUV? Odysseys are safe, but no more so than a Sienna Ltd-- and AWD isn't available.
    Good move taking your name of the 400h list, though. The non-hybrid version is a much better value.
  • seriousdriverseriousdriver Member Posts: 4
    Papoh:
    You should file a complaint at the Office of Defects Investigation of the National Highway Traffic Safety Administration at http://www.nhtsa.dot.gov/
    in order to get it classified as a "known problem", and increase the chances of someone being able to successfully sue Toyota if and when this problem re-occurs.
    When you get the Sienna XLE Limited, its about as safe as the Odyssey. Compare the Odyssey LX to the Sienna CE, the CE loses in safety hands down. Its a no brainer. As I said, the Odyssey has more standard safety features. The CE doesnt have traction control, VSA, side airbags, side curtain airbags for all 3 rows...nothing. Odyssey LX has it all. When you upgrade in the Odyssey, its only for comfort not safety. Honda doesnt compromise saftey and doesnt make it an "option". I seen a couple days ago, an Odyssey Touring with Odyssey EX-L rims and tires. Guess the guy was smart enough to do the swap. :)
  • irgirg Member Posts: 197
    Before you sell this great van (and other than the tires you like it right?) get a set of new tires. A LOT cheaper than the depreciation hit you will experience. If you need snow tires, get two sets with wheels, and rotate them seasonally. The tire pressure system is somewhat gimmicky anyway, IMO and not just on the Sienna.
    And I have had to replace normal regular tires on cars that lasted only 15k miles too (my last Saturn) because they used a soft compount. Whatever. A colleagues Honda Accord also last only a few miles with the stock tires, because they were inexpensive. Many cheaper and mid range cars/manufacturers use cheaper tires.
    My advice, buy some quality tires, and unless you are going on a trip, get a can of fix it flat for around town, and not take the big loss. I don't think anyone is making really good run flat tires. Seems like a good idea, but in reality they don't seem to be working too well. I also tried to get Saturn to compensate me on my tires, but to no avail. I bought new tires for it while I had the vehicle, and they worked much better. When I got rid of the Saturn, I got a Sienna, and couldn't be happier. I do plan on a get 4 new winter tires though just to be safe.
    All trim levels of Sienna have safety items standard for 2006.
    BTW: Some people may not want these added 'safety' features, as they add to the cost of insurance. More and more vehicles are being 'totaled' by insurance companies, due to increased vehicle features and content. Some buyers may feel that only having four or six airbags is enough.
    The Touring owner you saw has compromised the accuracy of his speedometer, and possibly even rendered his Tire Pressure Monitoring System inoperable.
    'There ain't no free lunch....'
    I dont see why people wouldnt want a safer vehicle?and it took the Sienna 2 years to make these thing standard. I think gas prices are more important then insurance right now, seing how if we cant afford to fill up the vehicle, might as well pull it off the road. I know about the tires and spedometer, but to me its worth it. I bought different tires for my 98 Accord, and the guy said my spedometer will be 5KM/H faster then what the car is atually going . However I will be getting some 19 or 20' rims for my Accord, I wounder how that will effect it. :confuse:
    Are eight airbags safer than six?
    So what if it took Toyota two years? Now is now. And for '06, the safety items are standard throughout the Sienna line.
    I'm tired of people complaining about the price of gas. Most people could mitigate the recent cost increase by brewing their own coffee at home, rather than hitting Starbucks five times a week. Or maybe make dinner at home once in a while, instead of going out for a fat-laden gut bomb at Applebee's.....
    Yes eight air bags are better then six, and Toyota claims to be better then Honda...I just dont see where it is better. And I dont go out and buy my coffee, I barelly drink it, and I cook my own meals at home, but the fact is I still have to drive to work and yes, that uses gas. And also the 6 hour trips so see my family that I take every now and then, I want the best gas price I can get. And the fact is, it took Honda to show Toyota how its done... :)
  • mcase2mcase2 Member Posts: 160
    The reason Toyota installed the lamentable junk run-flats on the AWD is because there is no room for a spare tire in this configuration. So, changing your tires is not going to solve the problem. You can't reasonably expect someone to pay 40K for a minivan and have to throw a loose spare in the rear hatch well where the groceries etc. are supposed to go. I own a Sienna (FWD thank heaven) and I love this car, but no way would I keep it under the conditions created by this obvious failure on Toyota's part. Toyota should replace the tires with quality run-flats for all AWD customers and fix the low pressure warning system, no ifs, ands, or buts. :(
    Well, then, Toyota's gonna have to invent quality run-flats, because there are only two run-flat options available for this van (Bridgestone & Dunlop). Easier said than done.
    As it should be, the tires are warranted by the manufacturer, not by Toyota.
  • ctalkctalk Member Posts: 646
    Simple, drive less. Save more :)
    I am well aware that the AWD models don't have a spare, hence the run flats. I don't know if it is reasonable to expect people either who have forked over a lot of $ to have to replace the tires. But every car/van/SUV sooner or later has to have their tires replaced. Whether you drive an expensive Corvette, a Sienna van, or like my previous Saturn, many tires that come standard (for various reasons) on new cars don't last that long. I'm not saying that's fair - personally I don't think so, I think 30k is the minimum that tires should last on an average vehicle like a Sienna or even my Saturn. With a Corvetter for example, they are a soft compund, and they just wear out faster because of the grip they provide. Funny thing is, that was the same explanation I was given about my Saturn tires, not exactly a performance car either.
    There is no real quality run flats, so given this sitation, you can either keep replacing them with the same tire every 15k, or as I suggested in my previous post, buy 4 good non run flat tires, and get a can of run flat or subscribe to AAA. Not the ideal situation, I agree. But it beats selling a new van and taking the steep depreciation hit. Unless you don't like the van all around.
    I don't think Toyota will make this run flat issue right, mainly because the way tires are treated as separate entities to the vehicle. Which I don't like, but I am sure there is a good reason (for the manufacturer, not the consumer). If my JBL stereo stops working in my Sienna, I don't have to go to a JBL store and have it fixed. I take it to Toyota, and they fix it. Now if it is a part of the original contract that these tires will only last about 15k miles, and that is spelled out, then that is fair. But most people will assume that tires will last longer, unless specified otherwise. I know I was angry when my tires on my Saturn were practically bald after 17k miles, I took it to the dealer, but they were not willing to help in any way. But these were regular tires, and not expensive run flats. I agree that Toyota should do something to help compensate owners of the awd vans, maybe 50% for a set of new tires. Hisorically though, I think this is not likely. The tires come under different warranties, which usually absolves the car manufacturer.
    I agree it is not likely Toyota will replace the tires for the reasons you stated. I have already read of them throwing their hands in the air passing the buck to Dunlop. If there is enough complaint (and it is growing) Toyota may lean on Dunlop to actually prorate these tire like their supposed to. But that still does not get them off the hook for the tire pressure warning failures. I have little faith in this system as the owners manual says it takes EIGHT hours of driving over thirty mph to allow the monitors to adjust. The TSBs on the system sent to dealers say one HALF hour of driving. So clearly the manufacturer is not even clear on the ins and outs of the monitoring system. In the end, however, it comes down to this: the AWD Sienna will need a thousand dollars in tires every 15,000 miles (about a year for a lot of people). $10,000.00 in tires for ten years of ownership! No Way Jose ! That is simply preposterous. Toyota has a problem there is no way to dismiss it.
  • hansiennahansienna Member Posts: 2,312
    Don't buy the Odyssey Touring or a Sienna with AWD. :shades:
    There are many good choices with either the Odyssey or Sienna that do not require you to have problems with run flat tires. :blush:
  • slrsslrs Member Posts: 1
    My mother has an 05' Odyssey Touring (her eighth honda) and hates it! I debated between purchasing the same car and the Toyota and ended up with the 05' Toyota Sienna XLE. (I have myself previously owned 3 Hondas and one Toyota.) My only complaint about the Sienna is that while the middle seats are easy to remove, they are VERY difficult to put back in (and heavy.) My mom's main complaint with the Odyssey is that she is averaging 14 MPG which is much lower than what Honda advertises. To make things worse, the runflat tires which were featured as a luxury item, are only good for the first 15,000 miles and are very expensive to replace. After only 6 months of owning the car, her rear door, which is supposed to open with the push of a button, jammed and had to be put in for service. Her comment to me a couple of days ago was that she wished she had kept her 01' Odyssey.
    I once shared your frustration with the installation of the middle row seats. However, I sat down with the manual and found that if you hook the correct anchor bar and do it in the right order they go in quite smoothly. They are heavy, but also comfortable and well made.
  • jipsterjipster Member Posts: 6,296
    Consumer Reports 2005 October issue tested the Honda Ody EX at only 12mpg in city driving. :cry: Which is 40% less than EPA's estimate. They did not print what other minivans were getting in city driving. :cry:
    12 mpg is just plain awful. I am getting 19.6 on my Sienna XLE, and that is with less than 3k miles on it so far, and is only around town driving. Not great IMO, but better than 12, which I have a hard time believing is accurate. GMs big SUVs can do at least that, probably even better. I got a minivan over an SUV because of gas mileage, but also ease of use with little kids. I have an older Explorer and that hog gets about 14 mpg around town. It doesn't get driven as much these days. If it wasn't paid off, I would get a Civic or an Elantra - something a little more frugal. Almost $3 a gallon here.
    As for the run flat discussion, why is it that they can't last longer than 15k miles or so? Is it inherent to the run flat design, or more of a case of planned obsolescence? If I had to replace them, I would not at $1k a pop, I would choose conventional tires without a spare, and take my chances, unless going on a trip. Either way, I am glad I have a fwd Sienna with a spare so I don't have to deal with this mess. Even more glad that my Sienna doesn't get 12 mpg - which would cost more over time than replacing expensive tires. To compound it all, a Touring Honda that has both bad gas mileage and expensive tires to replace. Yikes.
    Motortrend got:
    Odyssey: 19.8 mpg
    Sienna: 19.1 mpg
    And I believe the Sienna was on Premium.
    http://motortrend.com/roadtests/van/112_0505_minivans/index5.html
    NOTE...I did say the Ody 12mpg was from city driving. Not the combined 19.8 city/hwy you have Motortrend reporting. The crack investigative team from Consumer Reports reports that 90% of vehicles have the shortfalls in mpg than what EPA estimates. With the greatest discrepency occuring in city driving.(Some 35%-50%) So, Ody isn't the only vehicle with lower than stated numbers. But, it appears Ody is at the extreme of having the lowest mpg in city driving compared to EPA's estimate of 20mpg city.
    Well, actually a lot of people get better mileage then estimated. I dont own an Odyssey, but my Accord (V6) gets better mileage then estimated.
    I just find that odd that an Odyssey will get 12mpg from city driving.
  • andrewtran71andrewtran71 Member Posts: 840
    I guess it's impossible to make a great looking minivan.
    "Seems like a reputable source (FitzMall Toyota in Maryland) has just reported on the Sienna site that Toyota will offer Sienna 8-seaters in XLE and XLE Limited trims. If this is true, it looks like Toyota may have upped the ante in this minivan war.....Stay tuned"
    That's great.
    Now could they maybe make the front grille look better than a Chevy, Ford, Buick, Pontiac minivan, etc.?
  • cccompsoncccompson Member Posts: 2,382
    What is the basis for your saying that PAX is "only good for the first 15,000 miles...?"
    With a treadwear rating of 500, they should be good for at least 50,000 miles.
    Mine have more than 12,000 miles on them now and show no visible wear.
    Is the October issue out already? I can't locate this particular article online at Consumer reports ( I have a subscription) and would like to get a peek at it. Any info would be appreciated, Thanks
    I wrote that 90% of vehicles don't get EPA numbers on mpg...as reported by Consumer Reports. So, obviously that would mean that 10% of vehicles get EPA or better.
    I too find it odd that Ody gets only 12mpg in city driving.I thought it's actually mpg in city would be closer to 15 or 16...instead of the 20 EPA lists.
  • sciencemanscienceman Member Posts: 80
    Note that CR reported 13mpg for the Sienna in March for city driving. Note that CR does a real city drive--probably NYC (since they are based north of the city). In fact, the comparison for the Ody and the Sienna was as follows:
    City: Ody 12, Sienna 13
    Hwy: Ody 28, Sienna 27
    Overall: Ody 19, Sienna 19
    So the Ody and the Sienna were actuall quite comparable in Sienna testing.
    Well, basically the article talks about fuel economy and why the consumer are not getting EPA numbers. CR compared 303 vehicles for model -years 2000-2006. CR really did not discuss how the test was test up and run...pretty much just some of the results. They noted all test results would be available on their web site for free in a couple weeks. It looks as if they pulled a lot of info from previous tests.
    Some of the highlights...-hybrids had some of the biggest disparities between EPA and tested mpg...averaging 19mpg below city rating.....-EPA ratings are the result of 1970's era test assumptions that don't account for how people drive today....-Vehicles have changed.Since 1981 horsepower is up 89% for cars and 99% for trucks.
    Automakers conduct the government fuel-economy tests on a laboratory dynamometer. They can use hand-built prototype vehicles within EPA rules, to maximise miles per gallon in simulated city and highway driving. So, to me...Honda and all the other manufacturers are partly responsible for the inflated mpg numbers. They pretty much build their vehicles to get maximum mpg on the dynamometer test...but not real life. "Hey it's EPA that set those numbers not us!"
    CR city mpg figures ranged from 13% better than EPA sticker to 50% worse. They said their highway mpg more closely reflected the EPA's.
    Gas just hit $2.89 today in Louisville. When will this madness end? :cry::cry:
    Any European would gladly pay $4.00 / gal (after currency and volume conversions, of course). Right now it's over $6.00. YMMV.... ;)
    Some of Honda's cars (Civic, Accord) get great mileage.
    The Sienna and Odyssey are equal (in CR testing)
    But i notice other reviews, (MT, C&D) have much higher numbers in CR.
    I know my Sienna is doing significantly better than 13 mpg in the city, but everyone's version of city driving is different. I'm pretty sure if I had the Odyssey, it would also get better than 12. I don't have constant stop and go, because I live in a small city, but I do have very significant hills that can sure make a difference. I am finding I get right around 19-20, like CR is reporting in your post, but I have very little of highway driving in my average. I rarely get over 55, and even have some roads that have a speed limit of 10 mph! One way bridges in a college town. So maybe these estimates are pretty conservative by CR. I've been hearing on CNN we might get to $4 a gallon soon. I may have to stop going to work soon!
  • petlpetl Member Posts: 610
    This morning (in Ottawa) the price was set briefly at $1.20 a litre. Taking into account the exchange rate that's approx. $3.80 (US gallon). It's now down to a more respectful $1.04 (($3.30 US gallon). Did anyone spot the sarcasm?
    I also know I am getting probablly about 19-20 in city driving. And the gas here is almost 1.10 last time I checked and that was yesterday. It is outrageous! :mad:
    IRG,
    Your description of your town sounds very much like Ithaca, NY, where I lived for over six years (grad student at Cornell) until 2001. Is Ithaca your place of residence? If so, you are right about the hills and waiting for traffic at one way bridges. Strangely though, I was getting better gas mileage in my Toyota in Ithaca than I get here in Albuquerque. I don't know if it's the altitude or the fact that regular gas is 86 octane here. Anyway, we just bought our Ody two weeks ago and it only has 106 miles on it. I put gas in today for fear of short term price hikes--the wait at the station was very long. I only got 15 mpg for the first 106 miles with about 50% hwy miles. This is assuming that the tank was in fact full when I took delivery.
  • dygandygan Member Posts: 3
    The 2006 Ody is out. only 244-hp vs 2005 265-hp. Anybody know why?
    Also. Ody is 4500 pounds vs Sienna 4000 pounds. Why?
    Hey Scienceman,
    Good guess! It is Ithaca, and I work at Cornell (who doesn't!). I got here in 2001, so we just missed each other. It is such a great town. You would be surprised though at the changes here just in the last 4 years. We now have: Walmart, Target, Dick's Sporting, Barnes & Noble, Borders, Bed Bath...yada yada. Some people don't like these changes, I say it just adds more. We need the tax base here anyway. I have friends paying $8k/year in taxes for nice but small little homes in Ithaca. I just saw that AARP listed the top 50 companies to work for, for people 50 and older, and Cornell was ranked #5 on that list. Pretty cool. And 300+ of my colleagues in Alumni Affairs & Development just moved into a new building in downtown Ithaca, on the Commons. Trying to build up downtown more, and make it denser. New housing is being planned, etc.
    What did you study? I am a development officer in the College of Engineering. I've been thinking about putting a philanthropy class together - will probably take me a few years to get all of my materials and ideas together, if ever!
    Funny that your gas mileage is better in N. Mexico that in Ithaca, but you're probably right the altitude is much different. I lived in Taos when I was younger back in the late 70s. I would love to go back there, or Santa Fe, although I don't think I could live there long term. It has been so hot and dry here in Ithaca you wouldn't believe it. Every lawn practically has turned brown. The second hottest summer in history, and the dryest ever. We got a little bit of rain yesterday from Katrina, and we needed it.
    Your Odyssey should improve I would think. I got almost 25 mpg when I drove my Sienna home from a dealership in Maryland, back to Ithaca (long story). But that was 80% or more highway. I hover at almost 20 now around town, which isn't too bad I guess. I think a hybrid Minivan is in order soon. Your Odyssey has a more powerful engine, and as a result, it just uses a bit more gas. The price you pay of having the fastest minivan on the market! Gas is expensive everywhere. My mother-in-law in Atlanta said it had really spiked there yesterday, one station charging almost $6/gallon. And she used to gloat how much cheaper it was there than here. Ha.
    So do you miss Ithaca at all? Or is Albuquerque home now? Two very different places. I remeber Santa Fe as a very cool city, expensive now from what I have heard. Take care.
  • artgpoartgpo Member Posts: 483
    Engine output is the same as '05. Change is due to new government standard of measurement.
  • autoguy1autoguy1 Member Posts: 87
    Too bright?
    Not so sure. I'm just trying to figure out how I can get them into my 2004 Sienna XLE LTD. ;)
  • davantdavant Member Posts: 294
    As pointed out earlier, the feds metric for HP changed, not the vehicle. You asked:
    Because 4500 for the Ody and 4000 for the Sienna are what the scale said when they weight them? Are you comparing apples to apples (similar models, for instance don't compare a CE Toyo to a Honda Touring)? Seriously though, it comes from the added weight of more bells and whistles or at least the materials they are made of. Despite the weight differential I assure you the Ody has better acceleration and feel. As discussed and disputed in this forum, the Ody is Accordlike, the Sienna is more supple, almost Lexuslike. Bottom line is the small wt gain of the Honda is not crippling compared to the 15 or so pony deficit of the Sienna. Both are fine vehicles.
  • hondakid1hondakid1 Member Posts: 7
    Since all of the changes are occuring for the new 06 odyssey... are there going to be any standard equipment changes like in the LX to EX models. I know the LX doesnt get the roof rack and has some other exterior styling differences and the interior has a different look as well. I would like to see the alloy wheels on the LX model as well.... for a 25 K vehicle... generic rims and hubs dont cut it for me, as well as manual doors........ (because my parents got an LX and i want them to trade in for an 06') Or maybe they sould trade in for a Sienna which i really liked as well (they did to). anyone have any info or recomendations?...
    yeah - don't buy an LX...if it doesn't cut it for you...don't consider it.
    there is a reason that the LX has steel rims, and manual doors. there are people out there that don't want the additional expense of replacing a bent alloy rim, or the hasstle with autosliders. they don't need a roof rack.
    it's ok for a manufacturer to offer different trims levels...honda is very good about minimizing the number of combinations. and if you want to upgrade the vehicle, you can get items like the roof rack and alloys, and x-CD changers / DVD RES and the like.
  • calgarydrivercalgarydriver Member Posts: 4
    Hi, Folks...
    I'm a newcomer, so please bear with me. I've been sucked into the vortex of deciding between Sienna and Odyssey. We live in Calgary and go to the mountains pretty regularly, either to ski or just to spend the weekend at a family place. I'm trying to come to a conclusion on whether we really need AWD. We have a couple of pre-school children, and we're safety conscious (my wife is actually safety obsessed!). Our current vehicle (Toyota Highlander) has AWD, and we put good snows on it every winter.
    The Sienna, of course, offers AWD--but unlike the Highlander, has no spare. Instead, it has run-flat tires, about which I have heard very few favourable comments. I have no first-hand experience with them and know very little about them. I don't even know if there is such a thing as run-flat snow tires.
    So here's my dilemma...is it better to have AWD with run-flats (snows or all-seasons) and no spare, or to have FWD with "regular" tires, in which case I know I can get a good set of snows and have a spare? Which is better/safer for snowy mountain driving in general? Which would be preferable if one were to suffer a puncture miles from nowhere in the mountains?
    We have only driven AWD vehicles for the past 10 years (a Subaru Outback before the Highlander), so it's really the only kind of vehicle we know any more. We know we need a van, and it's between the Sienna and the Odyssey. The AWD/FWD question, with the run-flat and spare implications, is a big one we could use some advice about! Thanks.
  • rorrrorr Member Posts: 3,630
    First - run-flat snow tires are available in sizes to fit the AWD Sienna should you go that route. The Ody Touring (as sold in the U.S. market) is equipped with a proprietary runflat system for which snow tires are not available.
    Second - I've heard good things about the FWD Sienna equipped with traction control/VSC. If the snow conditions you anticipate are not so deep that clearance is an issue, a FWD setup with good snow tires all around may be a viable alternative. Remember, AWD is great for acceleration; but it doesn't help that much with turning and not a bit w/ braking. The traction control/VSC is standard on the AWD Siennas but optional (at least on the '05 models, not sure about the '06s) on the FWD Siennas.
    Your best bet (at least for you peace of mind) may be to simply arange a test drive in snowy conditions. The van will be equipped with the all seasons rather than snow tires, but you might get a better feel for how well the traction control/VSC helps you to maintain control in inclement conditions.
    As you know, the Ody is not available with AWD. However, all trim lines of the Ody have traction/stability control as standard. This may not be an issue in Calgary since in all likelihood the Siennas should be equipped that way as well. It definitely WAS an issue when my wife and I were shopping at the begginning of the year and found very few Siennas locally with traction/VSC.
    If you have used AWD very long, I doubt you would be satisfied without AWD or 4WD. The 4WD in my Ford F-150 and Blazer LT are very nice when driving on roads when there is snow. I feel much safer driving in snowy mountains with 4WD. (BTW, there is a mountain range called the "Snowy Range" in southern Wyoming just north of the Colorado-Wyoming border between Laramie and Rawlins and I have driven there many times).
    I would not drive very far out of town without a good spare tire. For me, an AWD Sienna with no spare tire would be unacceptable. It appears that the Highlander remains the best choice for your situation or if more space is a must, get a large SUV with 4WD and a full size spare tire.
    Off subject: How expensive is fuel in Calgary where the Alberta province exports large quantities of gasoline?
  • ewtewt Member Posts: 127
    If you're willing to give up the ability to fold down the "60" portion of the third row, you can have AWD and a spare in a Sienna. Toyota makes a kit to mount a spare into that part of the third seat well. When my RFTs wear out, I'm replacing them with regular tires, and buying a spare. I'll carry a tire repair kit, a can of fix a flat and a portable pump for around town use and throw the spare in for longer trips.
    I'm not really that unhappy with the Bridgestone RFTs on my AWD I've gotten 23K miles out of mine with 80%+ purely urban driving, which is better than I've gotten with previous cars and "regular" tires. They''re not completely gone yet, but I probably only have 3-4K more miles left in them. I'm mostly doing it for cost (RFTs are roughly 3X as expensive) and ride reasons (the RFTs magnify some bumps). If the cost weren't so much more, I'd probably just get another set of RFTs.
    I would get the AWD Sienna because applying power over a larger area in slippery conditions gives you more opportunity for grip thus maintaining better control. I grew up (still doing that at 44) in MD and 4WD was invaluable. Todays automatic AWD's have gotten better and on the Sienna, only sacrifices 1 MPG.
    Something is seriously wrong if folks are getting just 25K on a set of tires but maybe that's just how the PAX/RFT's work, self mutilation for peace of mind.
    Have you also considered that RFT's may be mounted to special rims so replacing them with traditional tires could mean buying new wheels too? This may also render inoperative or create constant alarms in any Tire Pressure Monitoring System. I can't say for certain if special rims are on the Sienna but I'm absolutely sure they are on the '05 & '06 Odyssey Tourings as they use a proprietary 17.5 inch rim. Dealers apparently swap the whole thing out, rim and all, as an assembly, local dealers here have none on hand today. FYI, the Honda RFT's were standard stock on the Michelenian Falcon but that Star Wars scene wound up on the cutting room floor. In true Big Lots style we Ody owners (I will be as of next Tuesday) get the leftovers.
    Consider us lucky as Honda S-2000 owners that get a front flat have to rotate the rear tire forward to use the temp spare aft (maybe it's reversed as it's late but you get the idea). I like the idea of buying at least a pair or maybe four $300 tires every 25K miles stinks.
