Visitor Agreement.
Bookitty
is equipped with, but my 2000 Quad cab with 4.7 V8
and 5 speed averages 17-18 mixed (no heavy city traffic) and 18-20 on the road @ 60 MPH. On limitted access highways running 70 MPH, it turns in 20-21 MPG. Above figures are using cruise control and are averaged from the onboard computer
as well as manual configuration (calculator). Ben,
this is a pretty large vehicle and the stalwart but old design V6 is really marginal for the truck. I don't know your driving habits, or the type of terrain traversed, but it does sound low. Using the defogger engages the AC compressor, and that can somewhat affect mileage by placing an even greater load on a power plant that is marginal from the start. When I considered a Nissan Crew Cab before purchasing a Dakota, the same demon emerged. Not enough engine to properly do the job. This is my second Dakota, but my 1995 Extended cab had the 5.2 V8 and ran like a "raped-ape." Were I you, I would voice my concern(s) to the area D/C representative. He/she may be contacted via the dealer. Insist on meeting with them. Yours is the voice that must be heard prior to any group action. Quoting what others say is purely anecdotal and means little. Try to document in writing, mileage results with dates and fuel consumption notations. Good luck.
Bookitty
Also has anyone had any experience with spray on bed liners? I've heard that they are quite good except for the lack of dent resistance that a conventional liner would have.
Bookitty
I've had experience with spray-ons for awhile now. A previous truck I had, I installed a Rhino lining spray-in. When my cousin recently sold the truck, the liner was still in near perfect condition after more than 8 yrs. No fading and very little surface abrasion from carrying concrete. I had a Line-x liner put in (on?) my QC very quickly after purchase and it looks great. I do not think that the impact resistance is a factor. the spray in has a cushioning effect and if the impact is great enough to hurt it, it would be great enough to crack a hard slide in liner. The only thing I would caution with spray-ins is cargo with sharp edges can cut it. wood with nails protruding, engines slid with the edges not protected, sheet metal slid on edge, ect. can do damage. The upside is that a "touch-up" coat can be applied to repair these defects.
Good luck on your decision, and we hope to see you in the owners club groups soon.
2wd 3.9 city 19, hwy 29
2wd 4.7 city 17, hwy 29.
I then called the Canadian agency that tests and publishes the sticker mileage seen on new vehicles, they had the same figures that Chrysler had. (No surprise there, but again no specific information on the QC). I then called Chrysler Canada again asking for QC mileage, same answer, standard cab only. The same figures.
I then called Chrysler USA to see if they had any information on the QC. No, once again standard cab only. Their figures converted to Canadian gallons are:
2wd 3.9 city 19, hwy 26.4
2wd 4.7 city 18, hwy 24
I also asked if these were the values used on the new vehicle stickers, the answer was yes. Now this is a contradiction of a previous post above that stated that the sticker stated higher MPG for the 4.8 then the 3.9. It was this post that really drove me on my hunt for more information. Now I can see that these figures may be better than what you get during real driving conditions but it seems to me that the 3.9 would still prevail. Now another possible factor that could influence the difference between the QC and the standard cab would be the weight difference:
Curb weight standard cab 3852 lbs
Cub weight Quad cab 4161 lbs
Since these figure have a difference of 309 lbs. I have a hard time believing that this is enough to give the 4.7 an advantage.
I know that the Canadian figures are from tests performed under laboratory conditions however I don’t know if they include any passenger weight during testing which would fuel Bookity’s explanation of the engine being under powered.
By the sounds of all the posts it sounds like the 4.7 is a real GEM however I’m coming from a Mazda 2200 so the 3.9 will be like going to heaven for me. My final decision was based on economics. (As well I will not be loading up the truck very often). So in conclusion I don’t believe I’ll recoup my $1230 extra for a 4.7 through gas savings.
Since I actually ordered 2 days ago I didn’t have to go back and try to change my order to include the 4.7.
Can’t wait to get the new truck!
Thanks for the reply on the spray on liner, sounds like the way to go.
Bookitty
the 4.7 L , wouldn't go any other way.
("Tunder Bay"),during the winter, there would be no question in my mind. Besides covering the area to support my dealer (logging and construction equipment), I attended the logging shows held there as well. The resale factor would be sufficient to offset the extra cost. 4WD will burn more fuel. Also, there is a difference between "never getting stuck", and driving pretty much when and where you choose. In either event, opt for limited slip differential. The 3.55 and the factory tow package along with the heavy duty service group. These options should suit you well. Good luck.
Bookitty
A manual you just do it. Electric? How do you get enough juice to get it to shift? Jump it?
I am looking at trading in my "all options" 98 extended cab on a new quad and like only half of the recent Dakota updates. I'd prefer the positive feel of the manual transfer case and the old gauges were better. Who's idea was it to remove all the information (words, numbers, etc) from the guages?!
I do like the heating/cooling controls better and the new CD/stereos compared to the old. Still can't find a decent seat, though. My 6-way power buckets were decent but the cheap, cheap three position lumbar "switch" just won't cut it. It also stripped when I leaned back on it one time to get my wallet out of my pocket. They fixed it, but I am careful not to put too much preasure on it. It feels close to stripping again.
So now I must decide between getting the quad and replacing the seats with aftermarket or getting a particular fullsize truck that have superior front seats, an extended cab with as much room as the four door Dakota, additional options unavailable on the quad, and equivelent mileage with more HP (to make up for the weight increase) but cost more money. I've been sitting on the fence for the last year and am starting to fall further away from the Dakota even though the 60,000 miles in mine have been a pleasure. Will Dakotas ever get good seats? That would help make the decision easier. Although buying a high end Quad and replacing the seats is still cheaper than a high end full size, I don't look forward to finding the right seats and, more importantly, a reliable shop to do the job right.
What is everyone else doing to solve the Dakota seat issue? Does one of the three available lumbar "clicks" actually suit everyone?
By the way, loved all of the quads I've driven from a performance and handling standpoint and definitely would get the 4.7L and be satisfied with it replacing my 5.2L.
Is the R/T wheels an option on the QC in 2001?
Damn-near perfect! Didn't skimp on any options and I love the 4.7.
I installed a Roll--Lock tonneau cover and had the dealer provide
a MOPAR bed extender.
Now the warning: I figured I'd buy the extender from the MOPAR
Accessory catalog because I liked the looks of it. You can get them cheaper
elsewhere (paid $235). Well guess what? NO REPLACEMENT
PARTS ARE AVAILABLE for this stuff. Called several dealers to find out
how to get parts. They say they don't know who makes this stuff and can't help.
Bottom line: break one of the plastic do-dahs that holds this stuff together,
you get to buy another whole unit.
Regarding aftermarket seating.....In 1987 I purchased a new S-10 extended cab and within the first week of ownership had Recaro seats installed by a local shop in the Dallas area. I've given thought to doing this once again, but as you are, purchasing the full size seems the better option.
Glad I stumbled onto this message board because I was looking to see if there were any trends with the 2001 MCs. Didn't really see any other than some people saying they had to take the 4.7 back in to get the timing adjusted. So far, only driving it 20 miles home, didn't notice any pinging.
Definitely in love with this 4.7 versus 3.9
Bookitty
May I ask how much the X-Liner job is for a QC ?
I also plan to put the 275/60R17's on the wheels (the size that's on the Durango R/T) as opposed to the 255/55R17's b/c I think they fill out the wheel wells better. As far as I can tell from test driving the Durango R/T, there are no problems going with this size (ie. tire rubbing on wheel well, etc.).
Thanx
tuvtest...I sent you an e-mail this a.m. regarding pics of the new Ram. I too would like to view any and all .jpg's you take of the '02 Ram.
davids1...Assuming your Ram 1500 Quad is an SLT Plus with the multi adjustable power seats, you may be disappointed with the front seats in the Dakota Quad. To be fair, the seats please most drivers, but there are a few of us who would like the option of upgraded seating from the factory.
Bookitty
- hey, it was a rough week!
