Visitor Agreement.
(Obviously Haynes is leaving some things out)
There is NO comparison between these two documents. The BOB is FAR more useful and includes ALL electric diagrams, Plugs, Connectors and ground points.The BOB also DESCRIBES all the systems in detail. All possible fail codes are spelled out. The operation of EACH component is thoroughly covered. The testing of each component is documented too.
I tried to use the company's digicam yesterday (before I started drinking!) to take some pix of My truck but the security guard caught me and gave me crap for taking pix on company grounds! (Catch22-I'm not allowed to take the camera home with me) I showed him the pictures on the digital camera's monitor "It's a TRUCK Man, I'm not stealing corporate secrets!" I know he was doing his job, but he sure was a real jerk! He even took me to the security office to check me out!!! He played Mr Tough Guy the whole time and then as I was leaving the office I heard the whole crew laughing at me! Obviously not Quad Cab owners!!!
http://www.techauthority.daimlerchrysler.com/
Anybody have trouble with bent wheels? I have aluminum alloy wheels on a VW GTi and they are relatively soft compared to a steel wheel. Hit a traffic bump at speed several years ago and put a big flat spot in the very expensive ($260!) alloy wheel. Low unsprung mass is good for handling but I would think that going off road (or even hitting a pothole with a load) with an aluminum alloy truck wheel might get them bent pretty easily.
Menchar
most applications including occasional towing, the 3.55 ratio offering slightly better mileage and subsequently lower RPM is the ticket. With the
available power of the 4.7, the truck will not tend to "lug" down in high gear and/or overdrive (never tow in overdrive, bad habit). The 3.92 offers more "grunt" at the expense of lesser fuel mileage and slightly higher RPM at a given speed. For towing heavier loads on a more regular basis, especially on steeper inclines, the 3.92 is the ticket. If you like "jack-rabbit" starts at redlights, the 3.92 will shine at this also given the fact of even poorer mileage. I have a 2000 Quad with 4.7,3.55 combination. Does great for my usage, and I do on occasion tow a very heavy duty 5X8 utility trailer. Despite whatever axle ratio suits your particular needs, definitely opt for limited slip differential (LSD). This is a very important and useful option. Good luck.
Bookitty
Thanks for any input.
Trglick
trglick
As regards LSD, Rick (iowabigguy) gave you sound advice. Believe you me, that the limited slip differential is a most worthwhile option.
Bookitty
I have two questions. I ordered and received a bug shield and summer grill inserts.
1) The bug shield looks like a real pain to install. No drilling, but requires separation of the grill by 1/4 inch to slide bug shield brackets into existing holes and screws. Anybody do this yet? I don't want to start yet.
2) Has anyone used these summer grill inserts? Seems not enough air enters to keep engine cool in a hot climate. Am I nuts, or should I avoid these inserts and use them in the winter only.
Thanks for the oil change tips. I have not changed my oil yet, but after looking at the oil filter location, I'm putting off the day. Sandman, how did the soda bottle get through the little oil filter door in the front of the 4.7?
Anybody that is interested in how they fit in a AC, I'm 6'5" and fit perfectly with room to spare.
Thanks. Keep the talk going.
Some of the fellow owners have stated that the computer reading is not exactly accurate.
Wasn't that a Chevy commercial?!? C'mon, I KNOW you guys couldn't have all fit in the QC if you were wearing your hats!!!
I find it more than adequate for our particular needs, but we also own a HD 5X8 utility trailer that can be pressed into service if required. I really think that it is the best and handiest vehicle when it comes to all around utilitarian usage; fun to drive and a delight to own. But don't let us influence you.
Bookitty
wax on... wax off... wax on... wax off...
grahamcracker, if you want to see what my QC looks like with the 3 piece deflector, go to http://www.geocities.com/txqc2000 and look at the pictures I posted on there.
I'm going to install the bug shield tomorrow. I was mainly worried about the grill, but it may not be too bad.
In the first 1000 miles, already two rock chips in the front. A bug shield is a must. I ordered my bug shield out of the Dodge Truck Quadratic book. Call 800-745-6037 for a copy. Their web site is www.quadratec.com. I just ordered the one piece, figured I could add the other two later. Thanks for the input. I'm still not sure about the summer grill inserts getting enough air into the radiator. It may not matter. They look good though, better when painted.
Gas mileage, I have yet to hand calculate my gas mileage, thought this was just the breakin gas mileage. But I am going to start tracking everything now.
Front bug deflectors: I got the kind you loosen the grill to put on, no drilling. check it out:
http://www.geocities.com/stang460_67/Dodge.html
(4x4 4.7 w/ 3.92)
Would like to know if they can be adjusted.
I am somewhat disappointed with the mileage on this truck. What disappoints me most is that I have the 3.55 rear, and the gear ratios in the 5 speed cranny translate to a complete lack of power in 5th gear at about 65 mph. My first impression when I got the truck was that I would get excellent mileage while in 5th on the highway due to the fact that this truck with the 3.55 only tach about 2k ram at 70 on the highway. It is sort of sad to think that dodge had to put such short gears at the top just to try and squeeze more mileage out of the truck. The fact that the 4.7 is an oh engine doesn't mesh well with the short overdrive gear since all the power in the engine is at the high rams, and this truck at 2k rams is only putting out about 100 up, even less if you cruise at like 60 mph in 5th. This translates to absolutely no grunt whatsoever when you drop the pedal. If you cruise in 5th at higher speeds, the feel is much better, but as many have reported, the mileage will drop even more. Its amazing to look at the Chevy OHV engines and see that their 285 hp V8 is rated at 16/20, and that's in a full-size Silverado.
If I could do it again, I would probably get the 3.92 rear just so I could use 5th gear more. Right now I barely touch it until I'm on the highway and can put the cruise control on, because the response is just not there. To put it all in perspective, if you put the Quad in 5th on the highway at 65, and my '86 Bronco II in 5th at 65, the Bronco II would out-accelerate the Quad till it hit about 85, then the Quad would start to catch up and ultimatly over take it.
I noticed a while back when somebody asked about the 3.55 vs the 3.92 rears, and there was a comment about 'not trusting my truck driving at 2.5k rpms its entire highway life'. Well, my Bronco II has run at about 3k rpms its entire highway life, and with 129k miles on it, it is still running.
THE POINT OF THIS LONG WINDED MESSAGE:
You can't have power and mileage. So pick whichever one means the most to you, because YOU CAN'T HAVE BOTH. (unless you're chevy)
I went to rear in shop, and asked the question before I bought the 3.92. He stated that the difference it took to start the truck rolling with the higher rear end compared to the lower rear end would most lily even out. He also stated that if both trucks had overdrive you might not be able to tell the difference because the engines trim themselves out with the computerize fuel system.
I did run the truck up to about 75 PR to see what it would tell me on the computer. I can't tell you if it is true, no way to check yet, but when I did that, the computer said that I was getting between 20 and 23 MPG, when I run at 67 PR it says about 19 to 21. this was all on about the same elevation(flat)and still very hard to believe. One of these days soon I will run highway only, give it the true test.
I still don;I know if anyone can adjust them to read right. If you hear, I would love to know before I go back to the dealer.
Don't get me wrong, I love this truck. I just can't believe the mileage it gets, even with the airplane gears they put in it.
As a side note, I was at the Philadelphia Auto Show last night, and I checked out all the 'other' quad cab vehicles (toyota, nissan) and I definitely would buy the Dodge again. I can't believe how cheaply built the Toyota/Nissan vehicles felt.
I live in NC (Raleigh) and have been lookin' real hard at a DDQC Sport. The package that I,m considering includes:
Quick order package 26B,Tire and Handling Group,Sport Plus Group,Deluxe Convenience Group, V-8 4.7 Liter Engine, Auto Multi-speed Trans., Power Conv. Group, Air, Limslip Axle, 3.92 ratio, Bedliner-UR,Floor Mats,CD,Cloth buckets, Leather steering wheel with touch controls, and sliding rear window. One dealer has offered it for 24,940 out the door (incl.3%tax).This includes $490 ad fees that I don't think I should pay. Any thoughts and/or experiences re this deal? BTW,Wow this is a Niiiice Truck!!!!! Thanx.
As far as the ad fees, I paid them on my Dakota here in Dallas. I would rather they just pad that fee into the sales price without listing it separately, like most businesses do. Even with the consideration that part of your sales price discount is coming from incentives, I think that out the door amount is great. Have you shopped the other dealers in your area?
24,940 not bad out the door. Now you can take that quote and make the other dealers beat it. As slow as things are, you should do even better.
Tach shows 2K at 70mph. I have 3.55 with 5 speed HD manual. Computer says 19 mpg on the highway. After trading in my Jeep Wrangler, I've been too happy to worry about gas mileage yet. Lets just say, the Wrangler was horrible with the juice.
-Otto
Trglick
http://www.geocities.com/rfroache2001/
Bookitty
I grabbed the digicam and took a bunch of pix but only figured out how to load a couple full sized pictures on the website for now. Thanks for the input on the Westin bars, they were a great addition. I did think about getting the chrome bars until I found out they were $150.00 more, but in the long run, the black powdercoat will probably hold up better and they work with the dark windows and splash guards. I got an Immobiliser security system installed last week... Well worth the price for the added security!
Bookitty
So, I'm wondering if there are any owners with the 3.9 engine and thoughts on it. I know it has less power, and speed than the 4.7, but would it be sufficient in that model for my needs? What about the mileage of the 3.9 versus the 4.7?
Right now I have a 2WD S-10 junk box with the inline 4, and don't want to underpower myself again, after that mistake.
Bookitty
I should haved guess from all the posts in this forum, and nothing about the 3.9.
Thanks again.
Can't wait to get rid of my S-10 4 banger!
the backround looks like the middletown/oxford valley area. could we be neighbors?
Good luck, and drive safely.
scottie
