That being said, I could have removed the film before selling the car and had a pristine looking paintjob, but I chose to leave it on -- the next owner was thrilled that the front was protected and didn't mind the slightly pitted look of the film. Otherwise, no yellowing (3M guarantees it won't yellow for life) and the film remained virtually invisible from 5 feet away.
Brian
No surprise, Forester and Outback both managed the same thing.
Let's see how the IIHS tests go.
-juice
Keep me posted, my email is in my profile
AKA
AKA
Exactly ! so all that needs to be done is tap the signal wire to a ground...
I know Karen and a few others would be interested in buying one if someone got ambitious.
the issue will be how to automatically get the video mode to appear. I dont think just by putting on the parking brake the video appears on the front NAV screen. I have to hit the Audio button to toggle it on.
The light on the steering wheel was just a thought- with the controls already pre-lit on the steering wheel, glare won't be an issue- Saab's have a nice feature, all interior lights except for the speedometer can be turned off when driving in extreme darkness. My B9 is one of the most well lit cars out there now, especially the instrument cluster- each and every button that can be lit up has been lit up, not to mention an LED bulb on the head liner that casts a red glow over the console and blue (indiglowish) lights in the cup holder that makes a clear cup of water look blue. If Subaru has gone as far as that- why not the badge on the steering wheel, or the scuff plates on the door sill?
you dont need to engage the brake at all. I think even one click the brakes are starting to engage the wheel...
if you instead connect the sensor on the back of the TV Screen unit and bypass the brake circuit you can fool the system into thinking the brake is on without affecting the emergency braking system at all.
Did you know the front hood latch release lever is directly below the Celaeno star in the Pleiades? It's the right-most star.
-juice
Craig
If you're just attempting to do the lights or a single strip on the hood, try it yourself, but the bumper piece is very complex and not easy to work with.
B
-juice
But I'll take a peek, I'm curious to see if I can at least find Mars!
-juice
http://www.jb.man.ac.uk/public/MarsNov.jpg
Note The Pleiades is to the left of Mars, and looks like a fuzzy patch with adverted vision. Looking directly at it will allow you to see the individual stars. Binoculars will provide a better view.
Good luck finding "our namesake."
SirCadillac
-juice
Paul in MN.
I like the pearlescent effect on the new white color.
-juice
(5-pass, limited, w/NAV)
The pearlecent white is cool! I need to find some chrome finish wheels for it.
Paul in MN.
Eric
Would be great if you could publish a 'how to'. Have you already determined which camera you would use and how it would mount?
Keep up the informative good work
-juice
Rear Site Mirror
http://www.kenwoodusa.com/products/ListProduct.aspx?k1=2&k2=8&k3=57&pr=1976
It is not too diffcult to feed rearview camera to the nav screen but will the video/image have the correct orienation?
The video/image need to be reversed otherwise some1 walking behind the car from pass. side to driver side will come out as some1 walking from driver side to pass. side on the screen.
The KVA-S300 should work nicely. Crutchfield.com sells it for like $200 and should be available 12/26.
BTW is there room for such a unit? dimensions: 9"W x 1-5/16"H x 6-11/16"D
There is also a company that sells license plate frame camera. That should also work well since you will only need to drill a small hole for the wire, maybe behind the plate. I can look for it if some1 is interested.
-juice
Other than that, we LOVE our Tribeca! It has exceeded our expectations in every way.
BTW, I bought the newest Roady satellite radio:
http://www.circuitcity.com/ssm/Delphi-XM-Roady-XT-Satellite-Radio-Receiver-SA1017511P1-/se- m/rpsm/oid/134830/rpem/ccd/productDetail.do
but I haven't had a chance to install it yet.
-juice
-juice
http://www.cars101.com/subaru/tribeca/tribeca2006.html#accessories
-juice
How did the installer route the wires?
