Subaru B9 Tribeca (B9X)
1120121123125126163
  • x5killerx5killer Member Posts: 368
    looks awesome! I think you mentioned before what they are and the deal you got and where from and I might have wrote it down. if not I'll have to ask you again as i may want to do something similiar in the spring and will want to compare.
    Again. nice job, looks great.
    irst post my wife just purchased a b9 with nav/rse 7psgr limited... we traded in a murano SE also with NAV..
    Since i like to tinker, sat i decided to dive into the radio/nav screen and GPS all in one...
    TV screen is Kenwoord
    Radio is Panasonic
    Navigation Unit is an older kenwood model
    Big bonus for the folks with the same setup...
    *Nav Unit where the dvd goes, on the back has an optional connector for an IR remote and driver voice commands. I dont know if the software that is installed in our units supports voice.. the MIc cost 99, i think i will give it a try
    *TV/LCD here is the bonus, it has an additional RCA video input, thats right i connected my archos mpeg 4 player there and got video, after pressing aux multiple times, no sound. The no sound makes it interesting, since it leads me to think that some where there is an undiscovered Aux in that Subaru just did not connect.
    *Radio, i found the connecter where the audio from RSE/Aux feed audio into the radio...one could easily tap into the rear aux here.. i think, need to test. the subaru wiring diagram just is not up to par. if anyone has the complete manual on pdf please let me know. i did the 72hour thing and just got frustrated downloading all the bits and pieces.
    hey if you know what you are doing with schematics, please ping me.
    All this to fix some missing features that i think such an expensive car should have..
    Rearview Camera with reverse sensor
    Aux audio input where it can be used
    etc..."
    exciting info. have you tried the mic yet connected to back of the nav unit where dvd goes in? I wonder how it would detect the infrared as you thought it was being under the seat? This would be great to have voice command NAV and then all the Acura TL owners wouldn't have something over us. The 2006 bmw 5 series lets you use the nav while driving and i hate how it disables it, sometimes i just need a quick info on a diff way or something and the time it takes to pull over and stop to use it is more then what I'll save by finding a diff route. Even a redlight is usually not enough time to work the nav, it sucks.
    so there is a video input on the lcd screen for dvd? i never noticed it. not much use if there isn't sound.
    you found the aux inputs on the radio? This would be useful to many ppl that dont have the dvd option and are looking for ext. input to connect mp3 player etc. Personally I just run a cord to the back but considering i used that every day and the dvd rarely if never it sucks i had to pay 1800 for aux inputs essentially and that they are in the back.
    Not to mention the fact of having to get the 7 seater just for nav that they now offer with a 5 seater screwing us early adopters.
    "I want to find the parking brake signal wire that allows you to view the DVD on the front screen without being in park. its just like the aftermarket Kenwood decks that you just need to ground the parking brake sensor to fool the system..."
    any luck on this? I'd also be interested in disabling that so that the dvd plays on the front screen while driving as well if you wanted it to for front seat passenger etc.
    You are still able to switch to nav if you need to though right?
  • subienewbie2subienewbie2 Member Posts: 458
    Let me know if you figure it out and what part of Pa you live so I can make sure I never drive in that area.:)
    Keep us posted on your progress, putting the whole audio/visual puzzle together.
    Watch, next year Subaru will add an aux input in the dash.
    -juice
  • misramisra Member Posts: 3
    I am well aware of FM broadcasters, I'm looking for a hard line AUX in. I know it exists with the rear DVD, but I don't have the rear DVD.
  • cluelesspacluelesspa Member Posts: 648
    Yeah I found the wire... and based on the access instructions on the previous poster to get to the back of the video screen, I think you can access the wiring harness necessary. its in one of the wiring PDFs I received from Karen on this board. she got it off the Subaru Tech site, it shows a signal wire to Ground and has it labeled as Parking brake.
    it will work just like you have when parked. you can toggle between the video or the audio screen. or hit MAP and go to the NAV screen :)
    subienewbie2> and as far as the part of PA to stay away from is Pittsburgh ... :P
    Yeah all the info is already posted here along with the guy I bought them from online..
    After driving on them for about 5k miles. I absolute recommend going to 20" if you like to get more handling out of the B9! the handling is about 50% better... and at cornering if feels a lot more solid. there is no downside, if you like a more sporty drive.
    I just put on the OEM wheels for winter. dont want to get salt on the new wheels, plus the tires are summer tires.
    driving on the OEMS again, I would say that the tire noise is the same between the 20" wheels and the OEM Goodyears. after the 20" tires wore in they quieted down :shades: other then the warning light for the Tire Pressure Sensor all is good with the 20" wheels.
  • shane850shane850 Member Posts: 36
    I just purchased some 20" wheels and tires as well. Now I am just waiting for the 4 new tire pressure sensors and I will be able to get them mounted and test fit to make sure there are no clearance problems. Then it is off to storage for them since I put studded tires on the stock wheels because I snowmobile in the winter.
    Here is a picture:
    <img src="C:\Documents and Settings\sfischer\My Documents\My Pictures\mbmyum.c.ang.jpg"
    I get a red X. Where is the photo hosted? Try Photobucket.com.
    -juice
  • b9driverb9driver Member Posts: 118
    After close to 10K miles I'd like to give a follow up review for the Tribeca. We were one of the first owners of these odd SUVs. Also driven in recent months: A Hummer H3, Pilot, MDX and a 2 year old Murano.
    I stand by my assessment of the Tribeca. No other small SUV can match it. They all fall short in some critical area and you simply can't take the Subaru AWD system for granted. It's best in class and a match for the Audi at a lower cost. The car has been amazing in heavy rain and standing water, stays planted and sure. Handling is great, but the weight takes some getting used to. The rear middle seat works fine for our baby seat, but make sure yours fits. Subaru admits that not all will.
    Handling remains entertaining, even more so when you consider the weight. But this is NO SPORTS car. A lot of folks with poor reading skills think this SUV should be a big WRX. That's not what it designed for. Still, I agree she could use 20 more HP/more torque. On the highway and 90% of the time the power is very good, but there are some holes in the power band. Flip to sport mode and things improve greatly, but you'll drink more gas. We're getting 18-19 MPG around town and 23-25 on the highway...really good!
    If you have kids...this is a GREAT car. It's roomy, comfortable and quiet. You'll know you've taken one of the safest routs and piece of mind is worth a lot to me. The luxury and comfort never quits and my appreciation of the comfort continues. What can I say? I just turned 43 and I'm tired of being buzzed and rattled all the time.
    As to the looks....Welllllll.....It seems that people who find this car ugly stay at home and play on their computers. I get nothing but compliments and raves over the interior. Most of the compliments come from women. I can live with that!
    Gripes? Yep...here they are:
    Give us more power..just a bit!
    Seats are a bit stiff and could use a bit more lateral support.
    Give us a Ipod input, it's 2006, not 1990.
    Rear cargo cover is from a Yugo, a real laugh.
    Rear seat legroom is a tad short for no reason, but still better than most
    DVD system is junk, can't be operated from front and blocks rear view. Do a head rest system with unit in glove box or under seat. More quality for the dollar and more veratile...though you're screwed with an Ipod!
    Telescoping steering column please
    Memory seats please
    Additional non-hidden 12V power please
    I don't love the rear view through the back window...kinda tight
    My problems with the competition:
    Honda Pilot and MDX.....second fiddle AWD system
    Nissan Murano....Too tight inside and too many around
    Hunner H3....Hey, I liked it, but is it reliable? Comfortable car and priced right.
    Lexus RX330...probably the only other car to match the B9. I like it. Not a bad choice if you can handle everyone else owning one.
    So, if you're able to change cars every 2-3 years, get one of these and just trade up for the next one. You'll spend a lot more to do better. A LOT more. My wife is a nurse and at her hospital it's "SUV land." The Tribeca gets a lot of positive attention. In the end YOU have to like the car though. If you have kids....dump the car and buy a Tribeca....or do what we're doing....add an STI. We're leasing one end of summer for a second car.
    Robert B
    NY
  • nowakj66nowakj66 Member Posts: 709
    How do you like the Tribeca compared to the Murano? Murano is another model I am considering.
    yepp you need to host the picture someplace. you can't cut and paste from your computer :(
    then use the link to the picture. cant wait to see them. the offset should be POSTIVE 40mm to 55 mm to make sure you dont stick out too far. did you check the offset? which wheels did you get? and where? how much .. all the good stuff
  • megreyhairmegreyhair Member Posts: 154
    http://news.yahoo.com/s/ap/20051123/ap_on_bi_ge/japan_toyota_gm
    Toyota wants SOA Indianna plan to built Toyotas. Wonder how that would affect SOA output?
    interesting part:
    Earlier reports have suggested that Toyota might produce hybrid vehicles at the Fuji plant.
    The Indiana plant produced nearly 120,000 Subaru models last year.
    It wasn't immediately clear if Subaru production would be reduced or what the factory's total vehicle output would be.
    Actually they just cut Tribeca production by 50% IIRC.
    Thanks for the input, I will try and get a photo up later today or this weekend. I got them the same place you did, (www.dicounttiredirect.com) and the sales department said they were fit to the Tribeca. The offset is less than 40MM and this is the reason why I want to have them mounted...to confirm there is no rubbing now instead of waiting for spring.
    what is the offset? the OEM offset is +55mm. Anything less then that amount will be the amount that the wheel will stick out.
    the wheels I used were +40mm so they only stuck out 15mm.
    I would hesitate going to +30mm or less.
  • popa_sezpopa_sez Member Posts: 16
    Keep in mind once you modify your tribeca with new rims or new stereo's your warranty will be void if the problem that you have is a direct result of the modification. Most of you probably don't know, that the fuel readings on the tribeca are tied in with the radio. If you change out the radio, you will also lose some of the fuel readings. If you decide to put new tires and rims on your tribeca and you get new sensors, hopefully it will work, but if it doesn't SOA is not responsible for your modification so you will have to deal with the cost to fix the problem out of your own pocket.
    popa_sez
    Doesn't SOA say not to use studded tires on the B9?
    The owners manual says recommended winter tires are 255/55/18 stud less versions. I am guessing they said this as I looked for quite some time before I found a studded tire in this size by Cooper. There are quite a few "winter tire" versions that are not studded by various manufacturer's out there but none studded. I have friend's that own Subarus and have had no problem with studded tires. As all the tire are new and "matched" I don't believe it should be a problem and I have not noticed anything different while driving.
    It looks like the offset is +35 for the wheels. They are the chrome version of MB SUV "Yuma" in 20 inch. Discount Tire actually shows that you can go all the way to 22 inch for the Tribeca.
    I am a little concerned, but they guarantee if there are problems you can return the wheels and tires.
    I should know in a week or two as the tire sensors should be here by then.
    Shane
    Hopefully SOA is just being conservitive.
    But I asumed thr reason is that on snow - there is no problem since the tires bite into in it. However I suspect the problem could come when you are on dry roads which is most of the time. There in an emergency, the studs might cause the automatic systems to kick in when they should not because in dry roads (especially concrete) the studded tires have less grip.
    I would check with SOA to make sure that any drive train problems are not blamed on the studs thereby voiding the warranty.
    What "automatic systems" are you talking about? ABS or traction control??? Just curious, as they could kick in on dry pavement with the stock tires as well in an emergency..
  • kmartinkmartin Member Posts: 427
    Happy Turkey Day, everyone. May all your Subies deliver you and your loved ones safely to your many destinations this weekend.
    -Karen in AZ-
    (BTW, it's going to be 76 and sunny in Phx today...just rubbing it in :-)
    I was looking forward for snow today when they predicted 1-3 inches in the NY area. But when I looked out the window at 7 this morning, I saw none :cry: I guess I will have to wait.. :(
    BTW, wish I am at where u are, nice and warm.... :shades:
  • gsx95gsx95 Member Posts: 18
    very few things that i disliked on the Murano, there were two major ones of course. this is all subjective.
    The Good:
    Memory driver seat for two drives(SE standard) it sets the mirror, pedal and driver seat.. great feature really miss it.
    Radio remote would allow you to tune as well as move through the six radio preset.
    CVT Trans, you just dont know how quiet it is until you drive a regular tranny car.
    remote tire sensor display, reads out actuall tire pressure for all four tires (NAV option only). The subie tpms is very low tech
    Engine was smooth and powerful
    The Bad..
    fit n finish was not all that great, but i am not that picky
    It was not all wheel drive all the time, always front drive until wheels slip. you can lock awd, but after 20 it shuts off. the number 1 reason for trading it in for the subaru
    Handeling might be due to the SE suspension. the car had tendancy to skip the rear out, around bumpy roads were only two wheels hit a bump, same for uneven turns. #2 reason for selling.
    It was not as good in the snow as our prior two outbacks.
    we just love subaru's
    >>Rear seat legroom is a tad short for no reason, but still >>better than most
    Murano rear seat is like an old checker cab, very roomy
    i agree very disapointed, i plan on fixing this with an ir repeater, doing the parking brake disable tweak to run vid to the front. Also working on a rear camera hack with the nav system, you really do need a rear cam in this car.
    for the folks following this thread, i've figured out the pin out for the navigation system. i should have a unit with a rear cam attachment with reverse sensing wire in about two weeks. also working on a website to post info, whats cool is that we do not need o cut the stock nav cable. i am going to start working on the aux input..
    the readio is made in mexico, anyone have a contact that can get us the wiring digram for the stock radio in the b9?
  • fljoslinfljoslin Member Posts: 237
    Does Subaru really use Goodyear tires. No wonder that you are complaining about the handling. Get some real 18" tires and then compare the handling to the 20" tires.
    Also, try to find the wire to disable the driver's side airbag. That way you will only get to crash once.
    I have the generic wiring diagrams for most everything. However, if I remember correctly, the aux is indirectly hooked from the dvd system through something else and then through the audio system...almost as if Subaru wanted to make it impossible for us to figure it all out :-(
    Check my profile for my website...you can email me from there...
    -Karen in AZ-
    Thanks for the comparison. I thought you might need the 3rd row in the Tribeca over the Murano's two rows.
    I am looking for something larger than our 2002 LLBean which has been pretty much bullet proof. Just a little small and I am tall so a bit cramped for me as well.
    As a prospective purchaser of both here are my observations.
    Pros Murano:
    - lots of legroom front and rear
    - seats seem more supportive and longer bottom cushions
    - 3.5 L Nissan Motor seems more powerful
    - CVT
    - better mileage
    Pros Tribeca
    - third row
    - Subaru reliability
    - advanced awd
  • saedavesaedave Member Posts: 694
    A fairly big negative for the Murano if you drive on potholed streets like here in Chicago: A jarring ride.
    I'm a passenger in a Murano quite often and the ride is vastly inferior to my 2005 VDC wagon. BTW the Murano's mpg is considerably better than my VDC in city traffic.
  • vger105vger105 Member Posts: 57
    Another consideration for us was the dash.
    The Murano's looked cheap and unimaginative, while the Tribeca's is a work of art.
    Just curious if this is an SE or SL Murano that rides stiff?
    I think you can get bigger optional rims on that crossover, so it might depend on the suspension you chose.
    Bob and I got to drive these back-to-back on an accident avoidance loop. It went hard left, then hard right.
    The Murano felt lazy and rolled a lot, in fact one driver got the inside rear tire off the ground! Yikes. :surprise:
    The Tribeca rolled less and felt more stable in that test.
    Murano had softer leather, but other than that I much prefer the Tribeca's interior, it just feels $10,000 more expensive inside.
    -juice
    It is an SL (the less expensive version).
  • raybearraybear Member Posts: 1,795
    The Tribeca outhandles just about all the competition, the tires are nice and fat and grip the road just fine, for an SUV!
  • c_hunterc_hunter Member Posts: 4,487
    Will they stand by that guarantee when you need four new wheel bearings in a year or two? A 20 mm jump in offset is asking for bearing trouble in my opinion. Nobody seems to worry about that but it happens all the time. In fact, of all the things people worry about -- rubbing, appearance, etc, bearing loads are the most important mechanical consideration tied to offset. I am sure the market is slim pickins for large wheels that properly fit the Tribeca, but there are many choices in 17-18" wheels with the proper +48 to +55 offset most Subarus use. Hondas and VWs take the lower offsets, but all Subaru-specific wheels are in the +48 to +55 range. I'm sure it's only a matter of time before we see larger wheels with a proper Subaru offset. At the moment, Tire Rack only shows 18 and 19" wheels for the Tribeca.
    Craig
    the tires I purchased had a +40 mm offset so only 15mm more sticking out then OEM. Even the wheels on Tire Rack for 18 and 19 are +40 mm offset as well ;)
    and its not only the grip of the OEM compared to the new 20 inch tires. there is a definite improvement in lane switching on the highway. going to the lower profile 20 inch tires. the diameter of the tire is the same as OEM but the lower sidewall just makes the B9 less sluggish on lane changes and it feels noticeably more sure footed. it "feels" like the car is sitting lower to the road more like a sports car feels. I know its not any lower but the handling is hands down better. add to that the increase grip due to the VR tires over the Goodyear HR OEM tires.
    15mm = .59 inches that is sticking out. I doubt that it will affect wheel bearings. The other person is out 20mm = .79 inches.
    I wouldn't go 22 inch wheels because the profile would be too low that I would worry about banging them on potholes. plus the cost of the tires jump up as well ... everything is pretty compact around the center hub area so most anything with the proper offset should fit.
    That 0.79 inches, with about 1100 pounds weight on the wheel, puts a delta of 72 ft-lb moment on the bearings even under static load. That may be significant. From ProCarCare:
    "Generally, you should not increase the offset more than 1/2 inch (12mm) or tire width by 1 inch (25mm), or you'll create further problems. Increasing offset 1/2 inch (12mm) or tire width 1 inch (25mm) will put the entire extra tire width 1/2 inch (12mm) to the outside, where it may not clear the wheel well. Increasing the offset also has the effect of loading the front wheel bearings past their design limits and can actually "cock" the bearings causing rapid wear or premature failure."
    Note that when they talk about "increasing" offset it would mean the same thing in the context of bearings.
    The bottom line IMHO is that an offset change of 0.59-0.79 inches is a lot in the context of Subaru wheel bearings, which are not known to be especially robust.
    Craig
    It's not the amount of wheel/tire sticking out that matters for the bearings, it's the difference between the wheel mounting face and the wheel centerline that matters -- that's going to determine the off-axis moment/torque applied to the bearing.
    Craig
  • chrisc5chrisc5 Member Posts: 2
    New to the forum and B9 stewardship, as I'm leasing, coming out of a Honda Pilot that was leased also.
    Initial observations/thoughts (after 1 week)
    Love the styling and interior, thats what drew me to the car. Lot's of power, sport mode is fun, seems to really hold the shift points a lot longer.
    Quirks: no doubt mentioned on the forum: gas mileage could be better, needs a telescoping wheel and audio controls that go through your pre-sets, not the next channel up. Did not notice this during the test drive. Rear vision is a challenge, especially compared to the Pilot. Also wish the "accept" button on the Nav was not so far away, since you have to do this every time you start the car. Memory seats should be available as well.
    No car is perfect ergonomically, Subaru needs to improve some aspects if they want a larger slice of the pie. Having said that, I still like my B9 and like the driving experience --- way better than most SUV's/Crossover vehicles.
  • b9ctb9ct Member Posts: 16
    I know the OEM Radio is Panasonic. Are there replacements available? What brand are the speakers? Is there an amp attached?
    Are there replacement bulbs available for the headlights that seem to be less than adequate per this board and consumers?
    Can the rearview backup camera be wired to the NAV unit directly?
    Where can I get detailed manuals for B9? (Mechanical and electrical?)
    Thanks for your help. Hope to post answers rather than all these questions soon. :)
    As a question I forgot above, is there a list of websites for aftermarket parts?
    I think all your questions were answered in the previous posts on here. do a search of this forum... if someone doesnt repost the answers to all those questions ;)
    I still think those changes are small, especially when some people are using multiple spacers 1" and even bigger. Or what about those cars with the wheels completely sticking out of the wheel well? :D
    The wheel bearings that were fragile were the 02 and earlier Forester and the 01 and earlier Impreza. The rest have been fine.
    -juice
    In those particular cases, the bearings themselves were OK, it was improper installation that could screw them up (and did). Subaru has since gone to a different design on those vehicles. And I think the Forester/Impreza issue was primarily on the rear wheels that don't have the same bearing/offset nirvana issues as the front "steering" wheels. The biggest effect of decreased offset comes from moving the steering arc away from the "dave point" (point where the steering axis intersects the ground), which causes the outside tire to move forward and the inside tire to move aft in corners. This gives an illusion of sharper cornering but all it does is put the steering mechanism in a shear and load the bearings. There are posts over on Nabisco discussing this. You actually get better handling and longer bearing life if you can maintain the correct offset and dave point. There's a reason for the stock offset!!
    Craig
  • jeffmcjeffmc Member Posts: 1,742
    Pretty nice little B9 Tribeca review from the Texarkana paper: http://www.texarkanagazette.com/articles/2005/11/26/local_news/features/features02.txt
