-June 2024 Special Lease Deals-
If yes were you able to use all the parts: nuts, seals etc. or did you have purchase new ones?
I don't know where you got your stats but I think it's best to focus on the vehicle rather than the people.
I just bought mine this week and tried to change it but it seems the bulb is not the plug and play type like other vehicles. It seems that the factory bulb has 2 separate connector to it( assume 1 for daytime running light and the other for regular headlight). If anyone have suggestion or already got this done on their Tribeca, please send instruction or image of how it supposed to look like.
you mentioned in a post awhile back you had some squeaking that was finally fixed. I have some creaking coming from the front left tire area. It happens when I brake and when I release the brake both at slow speed mostly like for a stop sign. But also when I just go over a small bump like garage or driveway lip.
seems to be a brake/shocks/suspension problem but probably minor but very annoying. had it checked once & they just lubricated something & thougt they fixed it but didn't. having it looked at again tomorrow & hope they figure it out so if you or anyone else has an idea of what it may be let me kno so I can clue them in.
body shop is who looked before & thought they fixed it wth lubrication. I thought would know what it might be as they did the work in that same area of the car & it never made the creaking before the fwnder bender. so hopefully subaru dealership can figure out what's making the squeaking/creaking.
this was btw before changing wheels/tires so its not that & still does it after the change. Also, yes oe tire sensors work with new 20" wheels & tires.
Did you use all the original mounting parts or did it require some be new, like seals and nuts etc.
It took my guy about 30 mins. Instead of using precut, he used a roll and use a xacto knife to cut the extra after install.
It has been a minor annoyance but I look forward to having it remedied now that it was assessed what it was. Subaru dealership already had the part just have to wait for the insurance co. who of course wants to see it for themself.
they are a pain and just found out today that the body shop had to spend like $300 out of pocket that the insurance co refused or something so I'm not as mad at them for not seeing that the bushing needed replaced.
It will be fixed and done for good soon and wasn't that bad or happen all the time in the meantime.
But good to know what caused your squeaking for others if they have the same problem in the future. (was the hood hinges needed re-alligned and tightened).
Also, my dealership ordred and got the new rear hatch struts. I told them Subaru should know of the problem so it should be like a recalled , replaced part and no additional charge but we'll see if they charge me as they haven't said anything. They also claimed that they hadn't heard anything about it and that noone other tribeca owners that come to them had the problem.
But almost everyone here had/has the problem with the rear hatch struts not holding up the rear hatch properly right?
I mean mine wasn't so bad, it mostly fell if you didn't have it up all the way but i thin it has gotten weaker and is worse in the cold and sometimes even with it up all the way, the slight bump of the car loading something in cargo area will make it fall (on your head or back no less)though not hard or fast but still, its mostly annoying to have to keep lifting it or hold it up.
Bad enough it doesn't have an automatic rear hatch door like the RX and other mid size suvs but to have weak struts is worse. Its fine and an acceptable 1st year minor flaw but they should not charge me for stronger replacment struts. again we'll see.
Thanks"
not sure what you mean by Hid/Xenon as true xenons from what i know would be a total xenon conversion kit and a more expensive complicated process.
As far as changing the bulbs to more brighter whiter HId like bulbs, myself and i think a few others did do this. Most of used Sylvania silver star bulbs i think for the low beam and fogs and then there were a few choices for the high beam.
You can search the thread to find links to the high beam bulb choices and for posts about changing the bulbs. I can find the url for the co. i got the high beams from and the low and fog i got from pep boys.
I didn't install them myself and i think it is a little difficult and tight. I had subaru dealership do it.
hope this helps.
"Also, yes oe tire sensors work with new 20" wheels & tires.
Did you use all the original mounting parts or did it require some be new, like seals and nuts etc."
not sure what you mean exactly but the new wheels came with their own bolts and wheel lock etc. They did not come with hub centric rings that the installer said i needed and charged me for and advised me to get reimbursed for it from teh co. i got the wheels from as it should have been included. Not sure if there was already hub rings for the factory 18's or not and then why they coudlnt' use those.
My 20" wheels came with valve stems which they just ripped out and are then unusable, they were only rubber though. They put in the oe valve stems with tire sensor and then I put the chrome valve stem caps on them. The tpms works fine with teh new wheels/tires.
I did not want to have to purchase new sensors as my wheels will hold up in winter (not chrome) adn the tires are all season. I saved the oe subie wheels and the 3 remaining good goodyear oe 18" tires (one was useless after flat)
If I get a 4th goodyear eagle Ls-2 and put those back on with factory wheels when I sell it I will put the valve stems with sensors back on with original grey plastic cap.
The defective struts are covered under the bumper to bumper warranty. There should not any charge if they failed - unless there obvious damage from mis-use or an collision.
Don't remember if I posted, I was at the OBX over Christmas and had a chance to go off roading at the beach- the vehicle did very very well. I did however have to leave the transmission in 1st gear though and turned off the VSC- it kept wanting to shift to second, which would cause it to lose momentum- I had plenty of clearance and was able cruise right past a Nissan Murano that was stuck half way through the entrance at the deepest spot. I later went by and the guy driving it and said the AWD over heated! I've read on other posts that I would have to air the tires down, I did not- since not too many people drive on the beach during the off tourist season there were no tire tracks to follow- just fresh sand.
AKA1
A few questions. How does the 9" DVD screen affect the rear view. Is there a rear view camera or parking assist sonar sensors?
Looks nice on that photo....
What are they talking about? did you see this hub centric ring? I took the factory wheels off and put the new wheels with tires mounted on... used the new lug nuts that came with the wheel ... thats it. so curious what this hub centric thing was... :confuse:
I disagree - that blue looks awful on the Tribeca.
But we're all entitled to our opinion.
Bob
Almost all aftermarket wheels have an overly-large bore that accepts rings to fit the hubs of different vehicles. The ring looks like a large thick washer and is held in with a spring clip.
If you don't use rings, then you are relying on the lugs to center the wheels. This can cause balance problems, as lug-centric mounting does not guarantee hub-centric rotation.
If in doubt, you can measure the center bore of the factory wheels and the aftermarket wheels; ideally they should match (directly, or with a ring).
Craig
so this is not the lug nut bolt pattern then.. this is something different.
My aftermarket wheels were tapered holes so the acorn tapered lug nuts when tightened centered the wheel in relation to the bolts.
bummer all they did was paint the B9... they didnt even change the wheels or screen the fog lights...
They gotta ditch the chrome in that grille. A black honeycomb grille would look sooooo much better, even with that blue. The chrome really clashes with the rally colors.
Then again, I've always hated chrome!
-juice
B9 Caribe T
T as in Turbo! Caribe is how we say Carribean in Latin America.
-juice
Your post seeems out of context. What is a B9 Caribe T?
Never Mind - I get it.
I also like it - cool name - would look really good on the hybrid roadster
-juice
Craig
Bob
At first glance, I thought the static stability factor is lower than what I expected. But it's measured by the track width and the center of mass height. The tribeca is pretty narrow compare to something like the mdx...
Here's a link to the entire '06 SUV comparison chart: http://www.safercar.gov/Index2.cfm
Let's see how we did against the main competition:
Tribeca beat XC90, Highlander, ML, X5 and RX. The most recent X5 and RX series tested were '03 models. Tribeca tied Pilot.
Tribeca lost narrowly to Murano, which in turn lost narrowly to MDX. Most other SUVs weren't close, aren't really competitors IMHO, or haven't been tested (Touareg).
Overall, probably a B+ or A- performance. Competition at the top of the list is tight, but the rollover risk for the gamut of what NHTSA considers "SUVs" ranges from 14% to somewhere around 48%. Tribeca and Pilot were at 16% and Murano and MDX at 15%, all at the extreme top of the scale.
Highlander is the real loser. Scored worse despite being 2" wider than Tribeca and having 1" less ground clearance.
-Karen in AZ-
And for those of you that have done it, have you run into any dead battery problems?
the highlander 2006 got 17% only 1 % more then the Tribeca. http://www.safercar.gov/NCAP/Cars/3584.html
Saw a white pearl Tribeca this morning, in the rain. It stands out with a good visibility factor.
You can hard wire it to the existing adaptors, but don't overload the circuit or you'll just blow fuses.
-juice
I didn't look at the RAV as a competitor.
Most tire shops still use antiquated conical tire balancers that are very dependent on the wheel being "hub-centric".
Do a search for Hunter Engineering, and then use their locator to find the nearest tire shop that has a GSP9700.
I'm not trying to be a know-it-all, but I work for a racing wheel manufacturer and have dealt with this issue for over 10 years.
5 Pass LTD.
Titanium Silver
Slate Gray
Puddle Lights Front & Rear bumper guards
Hood Protector
The lease deals with our VIP discount were too good to pass up. 1500 trouble free miles after almost a month. I am still impressed every time I get in this car. The ride and road feel are top notch and fit and finish are perfect.
Before we bought the Tribeca, we went to the Indianapolis Auto Show and sat in nearly every SUV and Subaru had one of the very best looking interior layouts. Love it or hate it, the exterior will not be confused with anything else, which I really like. A couple of days after the Auto Show we went to drive the BMW X3 and X5. Both were 6 speed manuals with the sport package and they are superb handling machines. If price were no object we would have a 2nd BMW in the driveway, but when you look at the value for the dollar, I couldn't justify the extra money.
I would say that the Tribeca handles about as well as a non sport package X5 for less money and you aren't sacrificing all that much. I wish Subaru would offer the Telescoping wheel and 6 speed manual, though. I plan on adding the Driver Side memory function from the '07 model when parts are available.
I am fairly impressed with the MPG thus far, especially knowing that Subaru's aren't really broken in until around 10,000 miles. So far we have averaged around 22mpg highway.
This is really a great vehicle and I like it more every time I ride in it. I'll keep you posted on MPG as it gets a few more miles on it.
Bob
