Any downside to buying a hybrid?
2456713
    Is the only way an HX can have it.
    They still make them so they must be selling somewhere?
  • rfruthrfruth Member Posts: 630
    1) recessed or "concealed" windshield wipers that freeze and can't be freed
    because the hood is in the way
    2) pantograph windshield wipers that can't be lifted away from the glass
    3) "switchblade" keys that eventually break and cost over $100 to replace
    4) cupholders that only hold small drinks
    5) cupholders that let cups tip easily
    6) locking glovebox right below CD changer that doesn't lock
    7) plastic shields and covers in the engine compartment that don't protect anything
    9) oil filter mounting positions that dribble oil all over the place when changing filters
    10) tiny print on switches, knobs, and levers
    11) spare tire wells that won't fit full-size spares
    12) power antennas
    13) wheels held on by bolts instead of studs and nuts
    14) 12v power outlets that you have to open an ashtray to access
  • railroadjamesrailroadjames Member Posts: 560
    I'd like to point out that, while living in northwest part of Indiana I have found the lack of an eng. heat gauge very annoying. Another bit of disapointment was the drop in MPG's in very cold wheather. I can only guess that it has something to do with engine running constantly due to severe colder temps.Summer,spring and fall I get 400-430 miles to a tank while in the cold of winter it drops to 300-340 per tank. Gas gauge seems inconsistant.
    Culliganman (a little tarnish on my star)
    What percentage of ethanol do they have in your winter gas? That knocks milege down horribly. I think there is a fix for the flakey gas gauge. Check out this TSB...
    rpgolfer, "Toyota Prius 2004+" #3968, 5 Dec 2004 10:48 pm
  • stevewastevewa Member Posts: 203
    I'd like to point out that all modern autos have the problem of being too complicated for the shade-tree mechanic or DIY. Some believe this to be a deliberate move by automakers at the request of dealers who want their service department's high margin protected.
    I had a 2000 Volvo V70XC which we recently traded in on our Escape Hybrid. In 57k miles worth of dealer maintenance I estimate we easily spent $3-4k on routine service. It was all but impossible to get out of the dealer's service dept for less than $100. Then at just about 52k miles the electronic throttle module called it quits. This is a $900+ repair. At 55k miles the accelerator pedal sensor dies, which I replaced my self at a parts cost of about $80 (would've been another $200 for dealer to diagnose and I'd bet they'd want to replace the $1000 computer instead of the accelerator pedal).
    Yes, hybrid cars are different and complicated. But the same is true of any new car. The benefits in terms of fuel efficiency and reduced emissions have to be weighed, and a simple cost analysis doesn't begin to cover it.
    That is true, however some are worse than others. One poster with a Prius paid $300 for a 12 volt battery from Toyota. Another was fighting with the dealer over a $2100 Catalytic convertor. Maybe it is foreign cars that rip you on repairs and maintenance. My wife paid $1549 for a power steering pump in her Lexus LSS400. I found a place that specializes in Lexus and the prices are about 25% of what the dealer charges for repair. For example the fuel gauge went bad and the dealer wanted $1200 to repair it. Our specialist did it for $330 the part was $240.
    By contrast to your situation with Volvo the Suburban I have is over 6 years old. It has always been serviced at the Chevy dealer. I did not buy it from him. He still only charges me $21.95 for lube and oil change. I have not spent $4k on that vehicle in six and a half years. That includes lifetime brakes at Firestone and a new set of Michelin tires.
  • p3ozp3oz Member Posts: 6
    I bought a used 2001 prius about a year ago when it was at 92k miles. So far I have come to know from the dealer is that the fuel pump(?) was replaced by the original owner. The tires were not what is recommended, instead it had tires with specs close to the one used. Other than that the one problem bugging me is the screeching sound from the right side (front) of the car on cold mornings when I go over a bump or a hole. I thought the noise may be from the shock absorber, but the toyota dealer service guys says it may mostly be due to the aging of the rack and pinion system - replacing which will cost me about 5K or more. But if I can do without that then there won't be any problems except the steering will get harder to turn with age.....they wanted to run a full computer test to check it out, but I haven't had the time. The other problem is the expensive tyres. If I go for Prius specs then it costs me a 100 bucks a tyre. Besides that the car still is averaging 41.8 miles/gallon.
    Again I would say that is the dealers horrible markup on parts and labor. If you live in a town that is large enough, there should be a competent mechanic that is familiar with Toyota. He may not know all the ins & outs of the Prius yet, but he could probably get the computer diagnostics software and figure it out. My wife just had her 1990 LS400 into the dealer for the last time. He charged her $109 to change oil, filter and routine check. He had a list of about $5k dollars worth of needed repairs. We took it to this Lexus shop and he did all the work that was needed for $1,100. Two of the items were not bad. That included new ball joint, valve covers and pan gaskets, the fuel sending unit. He used to work in a dealership and said Lexus usually doubles the MSRP price on parts. Once your warranty is up on a car you need to find a competent mechanic. The dealers want to make it as expensive as they can to convince you that a new car is a better option...
    Many people changed tires to improve the handling. It will cost you a couple MPG. If you are in a cold place 41.8 mpg is probably not bad for the winter time. Lousy winter gas blend. I would get a second opinion on that front end it could leave you stranded at an inconvenient time and place.
    The original Bridgestone RE92 can be had from Tire Rack for about $55 ea. Make sure to get the XL rated ones. However, the original Bridgestones are generally hated by most "classic" Prius owners for their short lifespan and mediocre handling.
    As for your steering problem, there was a recall on the electric power steering rack on many early Priuses. Your dealer should check your VIN and see if the rack was replaced under the recall. Some of us also received a warranty extension note on the steering rack removing the mileage limitation.
    My experience as an owner of a 2002 Prius is that Toyota has done an excellent job standing behind the model and have gone out of their way to ensure a positive experience for the owner. I think this is because they realized early on that the Prius buyer may not be a customer who has dealt with Toyota in the past and they wanted to make a good first impression...
  • electrictroyelectrictroy Member Posts: 564
    "Have you have these problems?"
    I own a Honda Insight.
    NO. 1) recessed or "concealed" windshield wipers that freeze and can't be freed because the hood is in the way
    NO. 2) pantograph windshield wipers that can't be lifted away from the glass
    NO. 3) "switchblade" keys that eventually break and cost over $100 to replace
    NO. 4) cupholders that only hold small drinks
    NO. 5) cupholders that let cups tip easily
    NO(no cd). 6) locking glovebox right below CD changer that doesn't lock
    YES. 7) plastic shields and covers in the engine compartment that don't protect anything
    Where's (8)?
    YES. 9) oil filter mounting positions that dribble oil all over the place when changing filters
    NO. 10) tiny print on switches, knobs, and levers
    NO. 11) spare tire wells that won't fit full-size spares
    NO. 12) power antennas
    NO. 13) wheels held on by bolts instead of studs and nuts
    NO. 14) 12v power outlets that you have to open an ashtray to access
    Hope that satisfies you.
    Are you considering buying a Prius but turned off by the idea of the software glitches reported at http://townhall-talk.edmunds.com/direct/view/.ef64fbc/0? If you are reconsidering your place on the waiting list or other efforts to shop for a Prius, and are willing to share your perspective with a journalist, please respond to jfallon@edmunds.com no later than Friday, May 20, 2005 with your daytime contact information and city/state of residence.
    Thanks for your consideration,
    Jeannine Fallon
    Corporate Communications
    Edmunds.com
    MODERATOR /ADMINISTRATOR
    Review your vehicle
  • downthehighwaydownthehighway Member Posts: 19
    Last Friday I was about a week away from committing to one dealer or another to get a Highlander Hybrid. Then a friend called me from his vacation to intervene, because he had just read a couple of NY Times articles saying that both the Lexus and Highlander Hybrids get only a couple of miles per gallon more than their gas-only forebearers (both vehicles in the low- to mid-20s-mpg [considerably less than the EPA projections] ), and thus are not worth spending all that extra $ for. I found the Lexus article online, but apparently the Highlander one was in print only, which I have yet to see.
    So: do you know anything about this? Is it true that the Highlander Hybrid gets scarcely better mileage than the gas-only model? If so, do you think that makes it not worth getting? Owners, what are your experiences?
    Downthehighway
    Bourbonnais, IL
    Be sure and visit the hybrid Highlander thread. You will find a mixed bag on mileage. The only site I know of that keeps track of hybrid mileage has an average of 25 MPG combined. 11 owners are reporting from 19 to 29 MPG.
    Welcome to the Forum
  • falcononefalconone Member Posts: 1,726
    Edmunds is getting over 27 mpg with their long term Lexus. Overall you're going to probably get 6-8 MPG BETTER MPG. You have to weigh that against the price difference. If you are able to get a substantial price discount on the hybrid, then the purchase is more compelling. If you have to pay list, then you have to debate whether you want to pay the extra $$$.
  • bob259bob259 Member Posts: 280
    The kicker is for around 30 MPG you do pay a big premium, as none of the dealers I know of are discounting from MSRP. When you look at the top of the line Limted at $42K and the Lexus at $53K there are other makes available that cost much less, are proven in the long term and will get you good fuel mileage without the big prices tag or unknowns with a hybrid.
  • molokaimolokai Member Posts: 313
    I own a Prius and have 32,000 trouble free miles. There are many happy hybrid owners. CR claims a 94% satisfaction rate. The hybrid SUVs are another story. I admit it's hard to justify the premium for marginal gains. If the Prius didn't exist I'd be driving an Acura TSX.
  • mmreidmmreid Member Posts: 88
    I bought a HH quite by chance in June. Went to a dealer to check out the Prius and came home with the Hybrid. Very surprised that I got it. From what I've read I should not have been able to just walk onto a car lot and come home with one (we were visiting family in Nashville, TN).
    Anyway, we averaged 26 - 27 mpg on the trip back from Nashville to the Florida Panhandle. Same for next tank of gas which took us to and from the Gulf Coast on a vacation - some stop and go but a lot of rural highway driving.
    But back in town I'm averaging 23 mpg and not sure if it my driving (I traded a 2001 Acura Cl - very peppy little car) for this HH (I have Limited edition - it was the one they had on the car lot) and of course, driving with the air on - this is the Gulf Coast in the dead of summer. We grow mildew here as a cash crop.
    I've realized the coasting capability of the car so you are not using gas but I feel like I'm either driving too fast or doing something "wrong". I'd love some tips on the best way to drive this vehicle and also what grade of gasoline. I was told it ran on regular but wondered if higher grade would increase mpg.
    Would love to hear from other owners/drivers!
    mmreid
    If it says to run on regular, then please follow the manufacturer's instructions. Failure to do so, will result in problems. You seem to be averaging what others are in the forums here. Getting 27 MPG on the highway is pretty decent for a heavy SUV. I never got over 18.6 lifetime for my RX300. Good luck. You'll find yourself being quite happy. As you know, Toyota makes some of the most reliable cars out there.
  • mirthmirth Member Posts: 1,212
    Using a higher octane gas will not buy you any mileage, but it won't cause any problems either. Other than that, I agree with molokai - use what your manufacturer suggests.
    I read somewhere that higher octane fuel has a lower burn rate and the ECU will retard the ignition in cars not designed to run on premium. Some manuals say to avoid premiun and use regular unleaded. Not sure if there is any truth to it.
    ...but if people just use what the manual says, they avoid the issue entirely. The oil companies would try to convince you otherwise, lol.
  • jdkahlerjdkahler Member Posts: 50
    We have about 700 miles on our HH, 2WD basic model, 2 tanks of gas in hot Philly with a mix of very in-town (a mile or 2) to 20 minute city trips to some interstate. 26 mpg tank 1, 25 mpg tank 2. This is 50% better than the old and dying Windstar we traded in, and in every way the HH is an outstanding vehicle. Folks tend to get better mileage after break in it seems.
    BUT, you need to drive as if you WANT to maximize mileage. The combination of the electric motor and V6 make this a real peppy machine, and you can easily get the V6 running, which uses gas. A light foot and not being pushed at stop lights makes the vehicle run on electric. I'm learning to use the MPG gauge and take it easy - you have to be willing to let lead foot (ie most every other) drivers zip away. And from other discussions it seems folks aren't used to using cruise control on open highway. When things are moving around here you can set the cruise to 55-65 and watch even at that speed where the motor/battery take over and the MPG gauge goes to 50-60.
    Would we buy this vehicle again? Absolutely. Gas has gone up 15-20 cents a gallon in the time we've owned it, and while not a pessimist I take the realist stance that we're not going to see this stop despite the brighter views of some. If you're looking for a break even then you might or might not get it. In the bigger picture, every improvement in MPG reduces overall demand and that ight actually force the price down, help to kwwp down other energy costs and reduce the trade deficit. To us it was more than just breaking even at the pump, we think we've made a decision, given one that costs us, that is responsible. But we also buy wind-generated power from our electric utility and pay that premium too.
    One more time, this is a wonderful vehicle that both my van-driving self and Corolla-driving wife compromised on. We traded in both vehicles (forcing us to walk and bike more, a good thing!) and believe in the end we will be balancing cost/benefit toward benefit. And since I need something larger than a Corolla or Prius for my work it was a good choice. The HH is probably the best vehicle we have both ever owned, and adding in the many rentals from Suzukis in Australia to Mercedes in Germany that I've driven over the years, up with the very best I have driven. You need to decide the value, I'd highly recommend the HH - and working on driving different. - John
  • brightness04brightness04 Member Posts: 3,148
    The hybrid SUVs are getting more than marginal gains; more so than the lightweights like Prius. What's obscuring the matter is the way EPS rates fuel efficiency. A 33mpg conventional econobox uses 3 gallons of fuel in 100 miles driven, and a hybrid on even at 50mpg saves only 1 of those 3 gallons. A conventional midsize SUV rated at 19mpg uses 5.26 gallons in 100 miles; a hybrid version at 27mpg uses 3.7 gallons instead. That's a saving of over 1.5 gallons over the same 100 miles. The math gets even more compelling when a 10mpg sportscar or big SUV gets improved to 16mpg using hybrid; the 6mpg difference would translate to 6 gallons of fuel saved in 100 miles. EPS need to catch up with how the rest of the world rates fuel efficiency; people have to drive certainly amount of miles due to living arrangement; they are not given a government alotment of fuel and told to drive as far as they can (as in the current mpg rating).
  • kurtamaxxguykurtamaxxguy Member Posts: 677
    Higher octane "premium" fuel does burn more slowly than regular. High octane fuels were created to help retard detonation "knock" (fuel burning too fast/exploding) within high compression engines.
    Thanks to "detonation/knock" detection systems, many cars adjust timing to better match fuel to engine. But this often results in reduced performance.
  • spitazspitaz Member Posts: 1
    I heard that you can only use the air conditioning in "gas" mode as opposed to being able to use it when driving "electric" - - in ALL hybrids. If this is the case, it wouldn't make much sense to get a hybrid in AZ - where we use the air more than 6 months out of the year. My goal is to eliminate gas purchases as much as feasibly possible. Any info/experiences on this? A friend told me this and ended up buying a diesel VW instead.
  • priusguypriusguy Member Posts: 12
    Your friend is wrong. On my Prius, the a/c works in both electric mode and in no mode (when stopped) and works quite well. Today in VA it was 97 and I had to turn the a/c down. I filled up and got 49.9 calculated and 50.3 per computer. Not bad! BTW the car is 11 days old and has less than 1000 miles and I expect improvements once 'broken in".
    Your friend should have done his homework. Most hybrids (RH,HH,Prius) are able to run their AC when the engine is off. They have electrical AC systems. OTOH your friend who bought the TDI will be belching out harsh fumes when he is at a stoplight just to run his A/C.
    Spitaz - the above posters are correct, you can use the A/C in either electric or gas mode. However, it could possibly kill the mileage if you are using it most of the year. I don't have any figures, but I'm sure someone here does.
  • smootsmoot Member Posts: 14
    I'm afraid, especially here in Los Angeles, Car does indeed maketh the Man. You won't see a, ermm, lady, anywhere near a man who drives a Citroen Dolly, Dodge Neon or Hyundai Accent..heck, you won't even see a man near a man who drives the above either. As much as our cars define us, they can undefine us too. A Toyota Prius, for example...driven by a environmentally conscious individual or someone who has to have the latest thing....they rarely are both but up until the redesign of the Prius, I have only been witness to our friendly anorak driving the pre-hip Prius.
    Anyhoo, a friend of mine is on the waiting list for a Highlander hybrid, spending $10,000 more than the conventional Highlander. I guess for your serious long distance {off}-roadtripper, the hybrid is fantastic but unfortunately, most SUV's don't see the light of day on any off road for most are driven by road hogs who like to see their paintwork ever-glossy and their rims spinning. Friend is one of those rarities who is both environmentally conscious as well as rich. I can only stay away from the hybrid for now until I can safely say that I will save around $8,000 to $10,000 worth of gas in the next 5-10 years.
    It also bugs me that the least of the gas-guzzlers are the first to be made even more fuel efficient...the Honda Civic, Honda Accord, Toyota Camry and at last the SUV's like the Escape, Saturn Vue and Highlander are finally allowed to follow. When are we going to see Escalades, HumVees and other behemoths of the road less hateful to the environment? When is my future car...the beloved Honda Element going to be a hybrid...or at least a V6? You think incorporating the word 'Element' into the model name would mean it's a nature-loving, zen-like vehicle.
    My last point is will there ever be the reincarnation of the Far Ultra Violet car that was taking effect in the late seventies? Using a saturation of ultraviolet solar power, these cars {no, not the Sinclair monstrosity} looked as if they'd be the cars of the future.
    OK, I'm done.
    :D
  • caps04caps04 Member Posts: 6
    I paid about 50k for it. This buys me:
    1) Luxury of a Lexus (all the toys and safety features you can think of)
    2) Residual value of a Lexus
    3) Acceleration of a sports car or a V8 engine (0-60mph in less than 7 secs)
    4) Spaciouness/ride height of an SUV
    5) Gas mileage of a small car (hopefully..as of now I am getting 24mpg but expect it to rise to 27 once broken in which is what my other car gives)
    6) Lowest emission possible for a mass produced SUV or Car (SULEV)
    7) $2000 tax deduction (approx $3000 tax CREDIT for ppl who buy in 2006)
    I do not think there is anything better out there for someone who has the budget for it. So no downside as far as I am concerned.
    I don't think that people buying the RH will be eligibile for a $3,000 credit. I remember reading it is around $650 or so. Please correct me if I am wrong.
    ...it'll be around $600 or so for the SUV's I think. Only the Prius/Insight will be getting the big $$$'s.
  • ideleidele Member Posts: 200
    I own an RX400h and I completely agree with you. The price is a premium one but the car is definitely worth it.
    If you can afford a 400h, you don't need to worry about price comparisons or cost advantages. Enjoy your new ride!
    http://www.carpages.co.uk/lexus/lexus-rx-400h-20-08-05.asp?switched=on&echo=435563164
    "Police forces throughout the country will soon have the opportunity to trial the new Lexus RX 400h, the world’s first high performance hybrid SUV.
    Starting with Hampshire Police, the RX 400h will be fitted out to full police specification, including the Nemesis, camera monitoring system.
    and
    "The Lexus RX 400h is the world’s first premium SUV to feature a hybrid power system. It achieves a unique position in the market by not only delivering the low exhaust emissions and high fuel efficiency that are well-established characteristics of hybrid power, but also by providing the high performance that has until now been the preserve of large-capacity petrol engine models.
    The RX 400h’s Hybrid Synergy Drive® system combines a 3.3-litre V6 petrol engine with a 165bhp front electric motor that has a world’s-best power to weight and volume ratio
    , a high voltage battery and a generator."
    I've owned many German cars that required premium. I used regular with absolutely NO difference in running/starting etc. My sister has a 2001 Camry with a V6. I can't convince her NOT to use premium. She is throwing her money away.
  • SylviaSylvia Member Posts: 1,636
    Seems like a separate discussion. Let's get a separate discussion going to support this instead of "Any downside to buying a hybrid?" off-topic.
    I've moved the Octane posts to the discussion Premium v. Regular Gas - worth the extra money?
    A reporter would like to hear from consumers who, thanks to rising fuel prices, have newfound interest in hybrids and other fuel-efficient vehicles. If you have a story to share, please respond to jfallon@edmunds.com with your daytime contact info, city/state of residence and the make/model in question no later than Monday, August 29, 2005.
    Review your vehicle
  • bobgwtwbobgwtw Member Posts: 187
    The HAH AC is electrically powered when the gasoline enginre is off, Absolutely no difference in cooling capacity.
  • jack5225jack5225 Member Posts: 3
    My wife and I were looking at a number of SUV’s to replace out 2002 Chevy Trailblazer as we were having difficulties with the car that the dealership could not fix (or find, or duplicate).
    Anyway, we looked at Envoy, Toureg, Explorer, Expedition, Durango, 4 Runner and at the suggestion of my daughter and son-in-law the Highlander. We also gave short consideration to the Toyota Highlander Hybrid but initially thought the price was too high.
    Then last Friday we drove to upstate New York to meet with the builder of our second home.
    Round trip from our home to the building site -- about 300 miles roundtrip.
    After the return home, as I fillEd upthe tank I said to my wife...”this trip upstate just cost us $100! I think we know what car we need to buy.”
    The next day we purchased the Toyota Highlander Hybrid. We picked it up yesterday and it really has more power than I expected and seems to be the perfect choice.
    Jack
  • bvisailman1bvisailman1 Member Posts: 5
    Well you can start to look at the Hybrids,,,I drive 24,000 miles per year and get 20MPG. I've calculated that with gas in the $3.00 per gallon range I will save over $10,000 over 5 years.....I am ready to dump my Lexus GS 300 for the Prius. As Gas rises above that level my savings will increase....monthly savings will be almost $200 per month...
  • zodiac2004zodiac2004 Member Posts: 458
    Dumping an older car for a new hybrid for saving gas costs is in most cases penny-wise and pound foolish.
    Assuming you take care of your cars, your GS should be good for many more miles. The depreciation and transaction costs of buying a new car will wipe out any gas savings for many years.
    Not to mention a Lexus GS is head and shoulders above a Prius in ride quality, luxury and comfort.
    Post the details about your GS and we can have a better idea.
  • fndlyfmrflyrfndlyfmrflyr Member Posts: 668
    I agree, but with the price of gasoline zooming towards $4 per gallon, the break even time period is now more realistic.
    We bought our Prius because the old car required repairs that exceeded the value of the car and we wanted a fuel efficient car that had stability control, curtain airbags, and a nav system.
    BTW, the Prius is luxury car quiet and rides very comfortably. A GS, in my opinion, is nicer, but not head and shoulders above.
  • zacharyazacharya Member Posts: 71
    I have to agree. I was actually thinking of buying the new GS hybrid when it comes out, but I am quite content with my Prius. It rides very quietly and now everyone at work wants to know more about it. Especially now that gas is $3.09/gallon here!!!
  • midnightcowboymidnightcowboy Member Posts: 1,978
    The Lexus GS is leaps and bounds above a Prius. Anyone that thinks are close to the same, has never really owned a GS and may not have even driven one!
    Neither car is bad, but they have completely different sets of buyer demographics. No one, cross shops the Prius with a Lexus GS 300 or GS430.
    Cheers,
    MidCow
    There IS a reason why the GS (even the 300) costs more than twice as much as a Camry - a car that may be comparable to the Prius).
    The Prius chassis is based on the Toyota Echo. There is nothing you can put on that chassis to make it even mentionable in the same sentence as a Lexus GS.
  • smariasmaria Member Posts: 279
    Just a few more downsides, to add to the discussion. I don't own a hybrid, but I test drove a Prius when shopping for my most recent car. Here were the negatives that I found:
    (1) Lack of selection. When it comes to cars, different people have different preferences when it comes to things such as styling and space requirements. The odds of your "favorite" car (most comfortable, most enjoyable driving experience, best size/shape/design, etc.) being a hybrid are low simply because there aren't many hybrids to choose from. So, if a consumer is set on buying a hybrid, the lack of choice forces the consumer to compromise for what's available.
    My personal experience with this lack of choice: Among other things, the interior styling of the Prius just didn't do it for me...I wish I could've chosen a different 5-door hybrid, but of course there's nothing else available.
    (2) Some of the newer hybrids are too focused on "performance" and not focused enough on maximizing fuel economy. Take the Honda Accord Hybrid for example: it's got the same horsepower and torque as the regular Honda Accord V6...a 4-cylinder version would get significantly better gas mileage. As it is, if you're willing to sacrifice horsepower, you can get near the same gas mileage as the Honda Accord Hybrid just by buying a 4-cylinder non-hybrid Honda Accord! Why pay so much more for the Accord Hybrid...not to save gas, more realistically it's to increase performance without increasing gas consumption. Give me a 4-cylinder Accord Hybrid and I'd consider it...not the V6 version though. Why is everyone so obsessed with horsepower?
    (3) Specific to the Prius: I'm 5'10", and when sitting in the back seat I couldn't rest my head on the headrest without my head hitting the roof. In my opinion, the aerodynamic design compromises the interior space by one or two inches too many in the back.
    Ok, hope this churns up some conversation :D
    That is not true. The Prius engine IS an atkinson cycle engine of the commonly used engine 1.5 ltr engine used in the Echo. Both chassis are different completely. The wheel base of a Prius is much larger than an Echo. They both drive entirely differently too. An Echo is a wonderful commuter car too.
    smaria,
    Excellent points! I agree with you. I also like cars with manual shift.
    cruis'n in 6th :shades: ,
    MidCow
