If I were getting such low mileage from a 3800 engine, I'd have it checked out.
Even the 98 Pontiac Grand Prix GTP with the supercharged 3800 I had got 14-16 in town and about 26-28 on the road...
Thanks for the clarification!
Happy New Year, y'all.
Rocky
Bob
The published ratings from GM for the A6 FWD (6T70) are 315 \ 280 = HP \ TQ.
Thus, based on the Torque of this V8, this version of the trans. would not appear compatible with the Lucerne.
So – the real question (I think) is whether or not GM will release a 6T80 version – for higher torque applications.
The other possibility (I suppose) is a revised (a.k.a. Torque limited) version of the Northstar – retuned to match the 6T70’s limits.
AFAIK, GM has not officially announced a 6T80 . .
It seems to me that unless Buick does decide to aggressively go after non-traditional Buick customers (with something like a Lucerne GS, for example – something that I might be interested in) they have little incentive to go beyond the ‘antique 4-spd.’. It appears to me that most traditional Buick customers will likely not care how many speeds the trans. has. Thus the development costs & production expense associated with bringing an A6 to market may not appear worth the $$s and the trouble.
- Ray
Curious to see what happens here . .
Did this with the supercharged Regal GS thru the powertrain computer-easy to do.
I would be very surprised to see any changes to the Lucerne before the 2009 model year. I expect the 3800 to remain the base engine along with the rest of the powertrain (engines/transmissions).
First, it would fulfill the "expectation" that a car in this sedan category today has 5 forward gears (even if 5th is overdrive).
Second, the 0 to 70 times (approx) would improve slightly and be closer to the competition. This is meaningful to some potential buyers.
Third, the gas mileage would probably go up a little.
Fourth, the transmission would probably last longer if it were properly designed. Even with the extra shift and gears the load distribution would probably be make a longer life cycle.
To the average Lucerne shopper, #1 is probably the most important. And that is the same possible buyer who will accept the outdated V6 as a standard engine and be content.
1 - a wider ratio spread between first and sixth (as SLS002 said above)
2 – a lower first gear \ higher torque multiplication can provide better take-off & associated feel.
3 – a higher (lower RPM) top / sixth gear can provide lower noise and wear and better MPG, if all other things remain roughly equal.
4 – the steps between gears can also be closed somewhat – such that gear to gear RPM drop is less – and transitions more nearly ‘seamless’.
The A6 would typically (ironically) help the lower displacement and ‘torque challenged’ motors more than one with a relatively broad, flat torque curve. The supercharged 3800, for example, has a relatively flat TQ curve, and generates good torque from low rpm. The A4s (4T65E as in the GPs and 4T80 as in the Lucerne) have a reasonably wide ratio spread already – and the torque generated (similarly with my 5.3L V8) tends to largely offset having only 4 gears to choose from.
Additionally, the newer 5 and 6 speed automatic trans. design features ** should ** allow for smoother and quicker (more efficient) shifts. And (one hopes) that they will have been engineered to be more reliable.
“3rd gear is good for up to say 50” – SLS002
Well – I am not exactly certain what you mean here by ‘good for’.
First, in my current GM V8 Sedan w/A4 (GP GXP), second gear is ‘good for’ up to just over 100 mph. Meaning that it will achieve that road speed before requiring an upshift to third. Since you can force it to start in second gear, the speed range for second is (ahem) pretty wide: 0 – 100. So, in that sense, I’d say that second gear is good for 0 mph to 100 mph. [ And in fact, first gear in my GXP is good for over 50 mph. ]
Third gear can be (manually) engaged in my GXP at speeds as low as 10 mph. And it will pull quite happily – though certainly not as quickly as if the trans. were in second – or even first gear. And the actual (drag limited) top speed would typically (I have not tried it) be achieved in third gear, not fourth – as the deep OD ratio in fourth will kill acceleration. In third gear, at 6,000 rpm, the GXP would be at over 150 mph.
Third gear in the Lucerne then I’d suggest ought to be ‘good for’ 10 or 15 MPH to top speed. With the gearing and HP \ TQ specs, top speed on the Lucerne, I expect would also to be achieved in third gear – not fourth. So, again, the useful range of third gear (it is likely ‘good for’) 15 or 20 mph to somewhere well north of 100 mph. [ Assuming no limiter in the PCM. ]
- Ray
Still hoping for a Lucerne Grand Sport . . .
Now that would raise the 'buzz' factor for the Lucerne.
The northstar automatic has a 2.96:1 first gear, and a 0.68 overdrive. The overall ratio is 2.96/.68 = 4.35:1. The gear ratio averages about 1.63 from higher to lower gears. The six speed automatics are designed with an overall ratio of 6:1 or about 1.43 per gear. So the gears are closer together. Basically this means that shifting down will speed up the engine from 2000 rpms in the 4 speed to 3200 rpms while in the six speed it will go to 2800 rpms. In reality, the gears are not spaced evenly.
Aha.
As I recall, the previous (FWD) SLS & STS did not offer manumatic control of the A4 trans., so that does make sense.
One thing (of many) that I enjoy and utilize almost always is the ability to exercise some additional control over the automatic trans. shift \ don’t shift algorithms. It seems that many people do not understand that a true manumatic will allow much, much more control than simply placing a ‘normal’ automatic in third or second gear, which (typically) only locks out the gears above the one selected.
I will need to drive a V8 Lucerne at some point – one reason is that (though I have read the brochure) I am not sure exactly how much control they have engineered into this manumatic as they have implemented it in the Lucerne.
- Ray
(Trans.) control freak . .
The Corvette's six speed automatic (same as Cadillac's STS_V automatic) has the following gears: 4.02:1, 2.36:1, 1.53:1, 1.15:1, 0.85:1 and 0.67:1. So the top three gears are close together. Third gear is also close to 4th actually. My Seville has the same top gear nearly at 0.68:1, but then 3rd is 1:1 and 2nd is 1.63:1. So, my 3rd is between the six speeds 4th and 5th gears, while my 2nd is a lower gear than the six speeds 3rd, although both of these gears are passing gears. On the six speed, with a 2.93:1 axle ratio, 2nd gear will go to about 65 MPH at an engine speed of about 6000 RPM's, making this gear a lower speed passing gear.
Bill
I thought that a retail sold car would have a fairly high priority but the impression he gave was that this is not true for cars like the Lucerne that are in demand. I got the impression from him that the priority is getting cars to the dealers - not on pre sold cars. Anyone out there who knows how it works or has had experience in ordering a Lucerne?
When a car is first introduced there is a prescribed distributin plan which is chosen by the division. It could be diferent for any model and depends on things like time of year introduced (convertibles), etc. Probably the Lucerne is the typical plan where the dealers that ordered the greatest number of the previous model (LeSabre/Park) get the first allocations. So the bigger dealers get the first 2 or 3 or 4 depending on previous sales rate. Then it starts to spread out to the smaller dealers. Your sold order should come after this initial distribution is complete. Otherwise anyone who had a sold order would jump to the front of the line and if there were a lot of sold orders the distribution system would never work. that is why they have the allocation method in the first place.
BTW, the new 3.6 that will be in the Enclave will have a reported 287hp. perhaps the Lucerne V8 will be replaced by a 287hp V6 in the future.
With the Lucerne the issue is what happens when or if, a large RWD sedan platform is developed. We do know that the 3800 V6 production is only around till the end of the 2008 model year. I expect the Lucerne to keep the 3800 till then. But it would make sense to dump both the 3800 and the 4 speed 4T65 for a 3.6 V6 with a 6 speed automatic. If the 3.6 with 250 lb-ft of torque is used with a six speed automatic, performance might be nearly as good as the V8's.
I think cars like the Impala SS would be more successful as RWD's.
With five adult passnegers, I noticed too frequent gear shifts. The V-6 car needs more torque. From other published reviews, it appears that the Northstar V-8 makes a very noticeable improvement that's worth the price difference and the mileage penalty. My other minor complaint is that I was not able to locate the rear defogger button. Where is it?
For reference, I am also the current and orignal owner of a 1995 Aurora V-8 (151,000 miles). I wish GM would build a sedan that would make me want to buy a new sedan--like the Aurora did. The Lucerne is just not exciting, the STS is too expensive and not as roomy, and the Impala SS is short on some critical features. The Lucerne is a good car, just not exciting to a 40 year-old male.
In the HVAC head. I used the 360 interior photo thing to zoom in. You push the large rh knob. I see the rear defrost symbol there. At least I think that is where it is at.
Most drivers of the V6 I picture as one or two around locally and travelling light. They probably won't demand of the car what some others will expect (rightly so).
The V8 is a strong option. I saw one parked outside the local hospital this morning. Black with chrome. Nice.
The HUD has to be fitted into the tight instrument cluster, a dealer showed me. I asked because my LeSabre has it. I like it when traveling and around town. I laughed at it when we bought the car because it was a part of the total package my wife wanted. Now I like it.
HUD has not just caught on. MOst feel as you that it is a waste of money buy once they get used to it they like it. Getting them to buy it in the first place is the hard part. Have you noticed that only GM uses them? Up to recently GM had exclusive rights to the technology. A couple years ago a number of suppliers started to push the other OEM's to use them but I do not believe any have done so yet. Once Lexus or MB starts to use them then probably they will take off as "cool".
They are also tough to fit in. They look like a bump on the IP top pad. You need to worry about windshield reflection of the unit. Does not work with poloroid sunglasses. Are not cheap, etc. But they are good for those with bifocals since you can read the unit w/o looking down thru the lower glasses.
Are BMWs cool these days?
A HUD was on the '97 GM car I had.
A substantially improved version is on my current GM car I drive.
It helps allow eyes on the road . .
Convenient.
- Ray
HUD believer . .
