Frank
Keep them flying.!
Gives you some idea of what your into if your looking for a V6.
And wow, they have one V6 Sport loaded up with custom stuff resulting in a sale price of about $33500! You gotta love the creativity they use in taking your money.
I have the Everglade Metallic color.
Heres a link to picts:
http://rav4world.com/forums/album_pic.php?pic_id=1056
I know the driver space will be a bit smaller than my present Chrysler in terms of legroom but from what I could tell it wasn't that bad. The test drive was good but I was floored when I had everything rolled back for my comfort as driver, then hopped in the back seat (I tilted that seat back as well, which slides it back a bit more too) and *still had room*! More room than anything else barring a Pacifica (which is a squashed minivan with rather bad gas mileage and poor sight lines... but spacious and an awesome Nav setup!) Even a hulk like the Jeep Commander had almost no room back there, so I was pleasantly surprised to find so much room in the Rav.
Me either and I've had my 94 Civic since new with no problems with the fuel pump. My car is frequently below 1/2 a tank and infrequently below 1/4 and 1/8, but it does happen and there have been no ill effects.
Anyway, as an experiment to see how "low one can go" I don't think any permanent damage would be done, but I'm no expert.
Gogiboy
But I'm not certain of that.
Are we having fun yet?
And to get fuel economy, you never have to run it dry to see the numbers, 1/2 a tank is good enough..
rs in boston
Not a huge issue I understand, but I'd just like to know.
My wife's Toyota Tacoma Dual Cab 4WD has over 40k and no issues.
So this get me to the next question, do they put better brake pads on the 4WD versions of all their vehicles? Just the Tacoma's/Tundra's? Neither?
I've been lucky with my fuel pumps, since I do tend to drive to the 1/4 mark. And gas is heavy so I'm probably saving $10 a year on fuel by not refilling on the 1/2 mark - ok, that's a stretch. :shades:
Now I drive 40000 mi/yr mostly at highway speeds and almost never brake until at destination. Lots of stop and go driving will obviously increase your need.
To add some life to your brakes:
Be careful of driving 'hot' brakes through puddles and deep water to avoid having them warp.
Plan your stops well in advance and coast whenever safely feasible.
There are often larger diameter brakes on the larger vehicles and the SUV all have disk/disk whereas the cars usually have disk/drum.
- Marty
The previous RAV was the best pick of any small SUV in both frontal and side tests by the IIHS. Although the tests havent been done yet I would be shocked if it still wasnt the best. Toyota's and Honda's are always up in the highest rank.
Could you read the link under SUV and share your thoughts? They winter tested both the Escape and the Highlander with the VSC, which I believe is the same system on the RAV4. One of the testers complained about the VSC as well!
http://www.canadiandriver.com/articles/pw/traction2006.htm
Anyone have any thoughts on the Subaru Outback Wagon 2.5i AWD system vs. the RAV4's? I'm going to check out the Outback tomorrow, they now have a $2K rebate in my area. That along with high inventory levels (possibility of getting it at invoice), brings it into the competition arena....for me, thanks for any thoughts.
I better not mention the current level of my power steering fluid reservoir.
I hate to revive this angle, but I'm still in disbelief with Elway Toyota of Denver. Visited them this afternoon, and had a good visit with a salesperson about Rav4's. Four hours later, a different salesperson (one we never met) is calling and accusing me of being a spy working for another dealership! :mad:
I've spent the rest of my day drafting letters to them and Toyota corporate. I'm glad they aren't the only game in town - sure other dealerships in the area will want my business, right?
Looking forward to having more to contribute than this rant, and thanks to the community so far!
When I drove another one a week later this did not occur.
Later on I thought it might be the hill holder function or what ever Toyota calls it.
Any one know about this?
For the average driver, probably not.
You're correct in the utility part, but it's interesting to do a side by side comparison on edmunds to see the differences though. The 4 cyl. O/B has some advantages over the RAV4, such as H.P. and the one thing that stood out, was the towing capacity for the 4cyl. O/B (2700 LBS.) that's 1200 lbs. more than the RAV4! I don't know what the criteria is for towing capacity is, other than (H.P.) suspension and brakes, but it's a fair amount of weight difference, which may be important for me in the future.
Not at all, as you say for the average person, in fact the Highlander in the article placed ahead of the Subaru! It appears that I'll be somewhere in the Northern part of the country next Winter, so I'm trying to educate myself on what the best thing for me is. Maybe the RAV4 (VSC) is better suited for an ex-So.Cal like me. I find that I have a difficult time reading the road conditions.
I'm headed out today to drive them back to back. The RAV4 V6 is waiting for me to test at 9:30, should be interesting. In my neck of the woods the 4cyl. are now $700 over invoice, but the V6 is at MSRP.
Toyota is being extra cautious I suppose. I would like the option of turning VSC off at times. If they are worried people would forget to turn it back on, they could make it like the window defroster thing..but on after 10 min instead of off.
If the vehicle happened to be AWD that makes this a much higher probability as the rear braking is never as STRONG as the front and so the rear wheels will often continue turning if "driven".
thank you
I suspect the VSC is not totaly clairvoyant and if you practice some you can probably produce what they did for the ad. The truck handles very well but will require some common sense so that one does not over do it since the CG is higher than a performance sedan.
Funny I was wondering if that was a Limited in the ad.
Keep us posted on MPG etc. By the way, what did you get on it and what price versus invoice did you pay?
Enjoy!
