Yes I should have. That is much better phraseology. However, since the engine is designed for 87 octane and the timing is retarded accordingly, nothing will be gained in using higher octane. The engine can't take advantage of it.
But I'm concerned about this acceleration lag that you speak of. Is this in the 4 cyl, V6, or both. I would think that with 269hp in the V6 the thing should fly like a freakin' rocket.
thanks,
Jeffer3
I'm very interested in hearing about people's driving experiences with the 4WD.
First, what is this Electronis-On Demand 4WD and how does it work.
Second, how would it compare to the Outback's AWD, or a V6 4Runner's full-time 4WD systems. And under what circumstances can you put it in "lock". Can you keep it locked if driving on dry roads? I ask because often the surface conditions will vary depending on whether the plows have gotten there yet.
Any real world experience that people have would be nice to hear about. I live in the Northeast and driving conditions can get pretty dicey at times. I'm more interested in handling/driving conditions in the snow rather than off-road but would like to hear that too.
tx
Jeffer3
Essentially the 4WD vehicle drives in 2WD nearly all the time. When the sensors detect a slippage in the front wheels some of the torque is sent to the rear wheels until the the slippery situation is past.
At low speeds for difficult situations the front and back wheels can be locked 50/50 with the press of a button. However this 'lock' comes off automatically above 25 mph, then you're back to driving a front wheel drive vehicle with some torque sent to the rear when needed.
Are you sure about that?
If premium fuel is recommended, then maybe not.
I ask because Nissan rated the Armada at 300hp on 87 octane, and the Infiniti QX56 at 315hp on 93 octane.
Dynos test told the truth, and owners found that putting 93 octane in Armadas yielded a 15hp boost, and 87 octane in a QX yeilded a 15hp loss.
Timing isn't fixed, it's adjusted on the fly by the ECU. If premium is recommended, then I'm sure Toyota powertrain engineers programmed the ECU to advance the spark timing a bit to make more power. Or to retard it when knock is observed from the use of lower octane.
The part I don't agree with is the idea that the timing is set at a fixed point (say, 10 degrees before top dead center). The ECU surely adjusts it.
On my Miata the timing is manually adjusted. OE setting is 10 degrees BTDC. I have it set to 14, 4 degrees advanced. You can go up to 18, but if you do, you have to use premium fuel.
Modern ECUs do this for you on the fly.
We're talking high compression with the V6, I'm sure it does this.
-juice
The difference between the two is the compression ratio is higher on the Spec V, so it makes more HP and torque. The ratio is 10.5:1, which is actually lower than the RAV4's.
Premium fuel is required on the Spec V.
The SE-R (non-Spec V) makes just 177 hp from the same displacement with a lower compression ratio.
Point is, the RAV4's V6 has high compression, nearly 270hp doesn't come for free.
-juice
Who said premium fuel is recommended? Not according to my owners manual. And, just for the record .. I've never experienced any "lag".
- hutch
-juice
- hutch
-juice
Cylinder and head design, valves, cams, and probably timing would have an affect, sure. But the primary factor is still the effective compression ratio.
How would your turbo run on 87 octane? :P
-juice
my GN won't run on 87 lol
Frank
Too bad, actually.
-juice
Frank
Ya know that there is a TSB out on the throttle lag issue. Go see the dealer for a reflash of the prom..
-juice
That's all that I've ever put in it and it runs fine.
Jimmy Drew
Thanks for any help.
I noise does go away 1 mile or less into driving and braking.
Second, I had my 02 Camry's oil was changed at my tire guy while in for an inspection and tire rotation. I have dealt with them for years and years but this was the first time they changed the Camry's oil, I usually have the dealer do it because they have a shuttle service which is convenient. I noticed a smoggy smeel in the car for a few days. I thought it was the oil burning off. I drove less than 100 miles before stopping back this morning. They guy popped the hood and noticed the oil knob was very loose. He appeared very embarrased and said it must have vibrated loose. I think we both knew it was never tightened. Anyway, he re-checked the oil level, it was full. He wiped the surrounding areas and said everything should be fine. Sure enough the smell is gone. Could this have damaged my engine in any way though. So far its running normally.
FYI:
If anyone has had any water in the passenger front seat around the console, tehre is a TSB to correct this now...also one for the problem where you lifet the lever to recline the seat forward and it does not spring forward....the TSB corrects this as well.
Yes, the first stops in both vehicles that I drove that day were noisy, but as soon as the coating of rust was gone so was the grinding noise .
Jimmy Drew and his Pocket Rocket...
Besides, the 'perfect' diesel hybrid is one in which the engine has no mechanical connection to the wheels. Take a 1.5L engine with a turbocharger that would typically be employed on a 3-4L engine and tune it for maximum efficiency in a very narrow rev range so that all it does is charge the capacitors and batteries. People would never buy it because it doesn't 'feel normal' to them.
Ward's Auto World did indeed include the "Toyota 3.5L V6" as one of their choices for 2007's best engines, but the engine specifically mentioned in the article was the 2GR-FSE as used in the Lexus IS350. The RAV4's engine (as well as the Lexus RX350's) is the 2GR-FE. The difference is that the -FSE employs a combination of direct and manifold fuel injection to maximize performance for specific engine operating conditions, where the -FE engine only injects fuel into the intake manifold. The difference is pretty substantial- ~35 hp and ~25 lb-ft of torque.
I can tell you that the 2GR-FE engine is pretty special in its own right- 1195 kPa BMEP was the realm of supercharged engines just a few years ago. I'd say that the short answer is feel free to tell all your friends that you own one of the best engines in the world.
Besides, even if the compression-ignition engine could pass 50 state certification, it wouldn't change the fact that the RAV4 was never designed to accept a hybrid drivetrain.
Don't get me wrong- if there were a clean hybrid diesel vehicle on the market, especially one with the utility of the RAV4, I would be the first in line to buy it. The problem is that there aren't enough of us for Toyota or anyone else to invest the resources necessary to bring it to market.
Sorry to step in here, but I doubt the 2001-2007 Highlanders were orignaly designed to accept a Hybrid drivetrain either, yet as we all know, there is a Highlander Hybrid. Unless I totaly missed your point.
