As for the S vs. H speed rating, that is mostly a measure of resistance to heat at sustained high speeds. Again, probably won't matter much unless you take it to the salt flats at Bonneville for a land speed record (doubtful).
Do this, though - make sure the tire pressure is never low. The 99S tire is less resistance to heat and rated for smaller loads, so at the very minimum make sure that pressure is always, always good.
Anyway, a couple months after the brake job, the car started rattling at stop lights, so far the mechanic hasn't found the problem, but it is irritating as all get out. Between those issues and the intermittent low tire pressure light that comes on for no reason, probably my last Toyota. 33,000 miles and the car looks great, but drives like a geriatric geezer.
The brake pads are cheap quality that's why they're not lasting. Toyota obviously saved money by putting on a cheaper quality pad that wouldn't last as long. You're not alone in short life on the brake pads. I don't blame you for not wanting to keep the car. If you do keep it and still need brake pads. You should get a longer lasting pad. Porterfield R4-S pads come to mind. Performance and longevity.
Plus if they cannot fix the problem of the rattling in 3 times before your warranty is gone, you can claim lemon law! :lemon:
Nope - in most states it's only for the first year, much shorter than most warranties.
I have 27k on my Sienna's brake pads and they still look brand new, but I tend to coast to red lights to save gas.
And make sure that you see the mechanic replace it with Toyota brand fluid, not whatever they have in bulk. They go cheap at the dealer replacing it with whatever is "compatible" should be the branded stuff out of the bottle.
Thats where I'd start first. If they dont want to help you at that dealer, take it somewhere else to get the trans fluid changed. Sounds like it's been in there way too long.
In any case it's not a fluid issue at this point, it's a tranny issue. You can't tell me that fresh fluid should be black and burnt smelling only 2 weeks after doing a drain/fill. Something is not right. Maybe the original fluid needed replacing earlier, but for the dealer to blame my cars woes on everybody else and then to tell me that now things are just peachy is beyond belief. Waiting for the next chapter to begin. Will keep ya posted.
Also, speaking honestly, I would take your car away from that dealer you've been going to! They don't know where the indicator lights are on the dash and have to ask you? what's next? they ask where the oil goes for an oil change?! Wow the incompetence you're dealing with is astonishing. But your patience of actually putting up with it, is even more incredible. you don't have to put up with it, take it elsewhere. Please do yourself a favor and DO NOT let these morons take apart your transmission! They DO NOT know what they are doing, it's obvious. Get your car to another dealer while still under warranty. And to blame someone else? That's typical toyota, been there before with them both dealers and the corporation.
If it is not solved then you need to get yourself an attorney, now a lot of people will say that approach is "Extreme" and overused. Well let's see, this corporation has postponed recalls and the government had to force them and fined them to make the recalls for the latest gas pedal situation. My point is, to just say "I wont buy another" is great but look they have your money, they're in breach of their warranty they contracted with you to provide. An attorney could remedy it, I dont think Toyota takes their customers serious until they get an attorney. Ridiculous, I know, but it's an option because you shouldn't have to put out $3000-4000 for a transmission (rough estimate) because of them just trying to breach your warranty!
on a side note about Toyota, they put out these commercials trying to convince the public how good they are. The truth is, the real owners of these vehicles know how they are treated and what the real "quality" of the product is. I dont see it being much better than Ford (yes I know ford has improved lately) or others. There will be people who say "Oh you're just one out of a million cars" or make some other excuse. No it's true, Toyota's quality has been going down the drain for awhile and the tides are turning against them for treating their customers like they are treating you.
but back to your problem, just drain and fill it again, then drive around, next week do it again, you'll get out 80-90% of the bad fluid that way. maybe it's easier for me because i do it myself, but that is how it's done without the power purge they're talking about (bad idea and they should know better, they probably do, just want to make sure they destroy your transmission then blame you for that). im confident that should solve your problems.
He had no answer to my question, then he said that his shop foreman is getting involved. What that means I have no clue, as I would have assumed that he should have been in on this from almost the moment they realized they had no answers to this issue.
The nightmare continues...
I opened up a case file with Toyota at 1-800-331-4331, and also did get in touch with the Gen. Mgr. of the dealership. He was very courteous and told me he would get back to me when he has the details, and gets the case file. He also did tell me that he was in a difficult position between me and the warranty company, since they don't necessarily do what the dealer asks, but only what they deem acceptable. We shall see what happens. Things are moving forward, but the outcome is still very much in the air.
so good luck to you and your saga. oh and if you missed it.. GET YOURSELF AN ATTORNEY!
I do have a question for ya though: What makes you so sure any other Toyota dealership would actually want to help me when the one that sold me my car is trying very hard not to?
have fun with your car, if this story is even true.. you won't get another response out of me, you don't deserve one.
The dealer mechanics are supposed to be trained to deal specifically with the cars they sell, so telling me they don't know how to service my vehicle is a ridiculous notion. My particular problem is due to the dealer not wanting to fix my vehicle on their dime due to it being covered under warranty. They did make the problem worse after I dropped it off by trying to recreate the AT Oil lamp condition, and you would think they would start to believe what I was telling them all along, but no, that isn't their stance. I have a case open, and have spoken to the dealer mgr, and we will see how this plays out. Maybe I should have towed it to another dealer if only due to the way my dealer has treated me, but I have faith that the open case file with Toyota of America will help.
Vsc/traction and check engine light (orange lights) click on after about 5-10 sec turning on the car. My car has been at the Toyota’s dealer where I purchased it 3 times for same issue in last 3 weeks and at this point it needs to go back again since issue is still there. When First time these lights came on 3 weeks ago I took it to the dealer and they run computer check. They told me it said something about the exhaust and when they checked my car one of the two kat converter was burned. I asked was that unusual for car in shape as mine and so little mileage on it, they said it normal and it happens from bad fuel. I by fuel at different locations but most of the time Shell since it’s close by, but I would not know if this is true or not since I do not know anything about the car except how to drive. I am female accountant who does not understand car structure. They said fixing price runs $600-$800 and they needed to order this part. However, they told me that car was safe to drive. I left their shop my lights where off. I was waiting to hear from them when part comes in to take my car so that they can change this kat converter they said was burned. When two days later my lights came on I took my car to the different dealer just to be checked for it issue. This dealer told me that his computer shows that I have issue with Evaporative Emission Control System Malfunction and they were unable to find any issues with my kat converter. I was advice to take my car back to the same dealer that originally looked into the car. I took car back to same dealer again and this time I was told that I do not have issue with Kat Converter and all sensors are working properly. No issue with the car at all. Took it home and two days later same lights come on. I am about to take my car back to the dealer after work today and I was hoping to find more about this issue so that I can present to the dealer what issue might be. I am becoming really frustrated with the dealer. I think they know what the problem is as well as solution, but they are just running me around so I can keep coming back and they keep charging their fee. I cannot believe this is an issue again and the part that is the greatest problem to me is that the vsc does not work, and the four wheel drive as well when these lights click on
Any insight anyone?
