The 3rd row does finally split 50/50 and works very cleverly. Even with the manual fold its extremely easy to use, both to lower and to raise up. They came up with a very clever design that automatically slides the lower cushion out of the way when the seat back is lowered. Hard to describe, but if you are familiar with the Volvo XC90 third row, you will wonder why Volvo doesn't immediately start copying this design.
What is so smart about the 3rd row design is that it is so light and easy to operate. You don't have to walk around to the side door to push the 3rd row seats up, you can do it all from the rear hatch with hardly any effort at all. The 3rd row is a huge improvement over the 05 design.
Also, does anyone have the "ordering guide" or some sort of stadard and optional equipment list for the Mountaineer?
The Explorer has both AWD and 4x4. The difference being AWD can be driven on dry pavement without binding up. 4x4 is for wet or loose surfaces. The 4x4 Explorer normally runs in AWD mode, shifting power to the front wheels if it detects any slipping. The driver can also select 4x4 High, which locks the center differential, or 4x4 Low which also locks the center differential but also provides lower gearing. This is intended for lower speed operations such as when rock crawling or pulling a boat up a boat ramp.
This is one of the major benefits of the Explorer over some crossover vehicles, they don't usually have anything but AWD, so pulling a boat out of the water may be more difficult without the lower gearing provided by the 2 speed transfer case. Also, in 4x4 mode, you don;t have to wait for the wheels to slip before power is routed to the front, power is already split 50/50 front and back. A lot of trucks only have 4x4, and no AWD, which means you don't get any traction benefit from the front wheels unless you select 4x4. With the Explorer you get the benefit of all, AWD and 4x4 High and 4x4 Low.
Here is how Ford explains it the systme on the Explorer-
Control Trac® delivers automatic torque split, low-range
Explorer continues to offer the advanced Control Trac® four-wheel-drive system. It includes electronic logic and a two-speed transfer case with a locking center differential.
Control Trac® is an advanced four-wheel-drive system that allows a driver to select between three driving modes:
The 4x4 AUTO (or A4WD) mode provides full power to the rear axle until the rear wheels begin to slip. Then power is automatically proportioned to the front axle as required for increased traction. This mode is appropriate for any driving condition.
The 4x4 HIGH (4H) mode effectively locks the center differential, providing a constant 50/50 torque split between the front and rear axles. It only is intended for severe winter or off-road conditions, such as deep snow and ice and shallow sand.
The 4x4 LOW (4L) mode locks the transfer case and engages a torque-multiplying gear set in the transfer case. It only is intended for off-road applications that require extra power including deep sand, steep grades and towing a boat trailer out of water.
2006 Mountaineer Owners Manual
2006 Explorer Owners Manual
Remember - Ford has discontinued the Taurus Wagon now that the Freestyle is out - they said as much in a press release. The Five Hundred is the replacement for the Taurus and the Freestyle is the replacement for the Taurus Wagon - albeit much imrpoved and with a higher seating position. It even has the Taurus engine. (The Fusion is slotted below in size and will not have a third-seat model).
While Ford has made the Explorer more comfortable and car-like ( as they have with the F150 truck line), it is not a car. I think too many suburbanites forget that.
Bottom line - the Explorer is a truck platform, the Freestyle is a car platform. If you don't know the difference, play it safe go with the Freestyle.
Same with the Explorer/Montaineer. Ford would bury the competition, and eliminate a lot of reputation issues if they did. And IMO, the Explorer is the best designed SUV in the class, by a mile.
any thoughts on how this will affect SUV sales this fall???...is this the beginning of the end of the SUV???...will they start installing diesels in them soon???
despite the problems, i must say the large liftglass opening on the 02 we have is one of the cars best features - it is extremely handy.
Because many people who buy truck based SUVs never use them offroad anyway, so they're looking at style, comfort, etc...
This may be years ago, but back when the Grand Marquis was truly a higher class model than a simple Ford, with vaue packs and discounts, I could buy a loaded GM for the same price as a moderately loaded CV...the CV was $12K and it was not loaded, and the GM was $12,500 and it was loaded with every option they had, certainly MSRP almost $3K more, but value pack and discounts brought the GM down...yes, cross-shop, always...
Bob
The DTS also depreciates like a rock with a lead center, so you would have just lost more cash, as you would have paid more for it to start with. You would still have got the same mileage, and you would have lost a head gasket in the Northstar.
You're getting more mileage than the Explorer would have gotten you, anyway.... so smile :P
FYI: It's my observation that staring at the telephone has no influence over its generating an incoming call.
as far as the foot wells go... i dont have as much as problem with the size as ... why cant ford spend $10 and put in a dead pedal for your foot to rest like everybody else?
Polarized glasses take that glare away.
Polarized glasses also make a navigation unit almost unreadable.
The floor shifter does steal storage space which was very useful in the 2002 - 2005 Explorer / Mountaineer. Ford did put a shallow tray on top of the dashboard of the 2006 models, but that is much less useful that the previous tray in the console. For example, we stored ink pens, sunglasses, and various other small objects in the tray in our Mountaineer, but would not in the dash-top tray, as they could, and probably would, fly out and be scattered or even hit us in the face. A dash-top bin with a lid, as on the Fusion and Five Hundred, would be far more useful.
I did notice the seat in the 06 seems to go slightly lower to the floor than the 05 which for me makes the driving position more comfortable. The power recline is certainly a welcomed addition.
Today's expiration also seems to be true for all Ford vehicles. Any guesses on what will be in effect tomorrow?
Gas mileage on the sticker says it's up 2 MPG, even with 53 more horses, due to the new 6 speed AT, but that remains to be seen. As someone who likes to tow a big boat and realted recreational gear several times a year, the power will be great, even if the MPG isn't much better.
I wouldn't recommend the Explorer (or any below 20 mpg SUV) for someone who just wants an SUV because everyone else has one, and doesn't "need " an SUV. I get a laugh at the fact that SUV sales have fallen off a cliff lately - it shows just how many people really didn't need one in the first place - just a "keeping up with the Jonses thing" or some false sense of safety - now proven not to be the case. About 80% of SUV buyers who say they need them for the "room" would do just as well in any minivan - which are cheaper and get better MPG. But they're not "cool". Sheesh!
But I'm one of those who has a need to tow and have 4x4 capability (lots of snow/ice and camping in the mountains ), and if you need to tow and take the family gear, too, the '06 seems to be a major improvement in ride, handling, power and quiteness over the last generation. I was skeptical, but the test drive made the difference. At least it's on my list.
Besides the poor fuel mileage, SUVs tend to cost $10,000 more than a car. The high purchase cost was apparently not enough to deter buyers, but the fuel cost increases are apparently the straw which broke the camel's back.
Why, if I may ask is the new Explorer designed to attract female buyers? What is so feminine about it?
I doubt Ford will have trouble selling these. The Explorer has a very loyal owner base. Changes here and there aren't going to give Ford a tough time, it will give the competition (Honda & Toyota) a tough time.
Or the almost 300HP variable valve overhead cam V-8 with exclusive 6 speed auto.
Or the real dual spped 4x4 transfer case with a real life 4x4 Low.
Now if you were talking about a little V-6 grocery-get-er like a Honda Pilot, then yea, obviously that model is designed more for females who don't tow boats, or who never go off road and would not know the benefits of a real transfer case.
The fact that the Explorer is cleaner buring than a Hybrid Honda Accord might appeal to women, or maybe the safety features that aren't available on the Honda Pilot. And yea, the split power fold 3rd row seat on the Explorer probably appeals to women more than men.
Now that you mention it, the 06 Explorer seems to be unique in that it appeals to men who need the massive towing capacity and who undertsand the essential nature of a true two-speed transfer case that you just can't get with a Honda grocery-get-er.
The Explorer also would probably appeal to women who like the superior safety features of the Explorer and would certainly like the fact that it emits fewer polluting fumes into the environent. Women will also like the AWD capability that comes with the real 4x4 2-speed transfer case.
