Thanks for the heads up regarding the other group. I've been busy and have not had a chance check back in or reply. I have everything fixed. The blower problem was a voltage controlled resistor between the blower motor and the ground. It is $140 at the dealer. I have a temporary fix. I bypassed the resistor and ran wire to ground on one the mounting bolts. Now the blower start when I start the car. I went ahead and flushed the system then converted to R134.
Also fixed the electric window buttons. The factory said they wanted $228 for a replacement so I opened them up and cleaned the contacts with a strip of 400 sand paper. Now they work like new.
Steve
this about it
i have own 2 300zx
85 non turbo auto , 87 non turbo 5speed
and i own maxima, 240sx ( two of them) 89 & 96
? So far i have replaced the Fuel pressure regulator. and checked the comp for codes and it didnt give out any? Plus all of the fuel pressure is right in it ? So if u have a idia of what it can be let me know please ! thanks
oh and i have a 84 300zx with automatic trany and the turbo in it! Thanks for any answers or advice that u may have !!
I have a 84 300zx turbo.
I have a 1991 300zx N/A. my engine is bad and needs to be replaced so imp thinking of installing a twin turbo engine and trans from another 300zxtt.
Can I do that? And if I can I want to install a bigger turbo any advice or recommendations???
Thanks for helping.
300zx +2 and the 300zxTT were the same size. Because Im thinking of swapping a japanese 300zxTT into a 300zx +2 does anyone know if this is possible?
I UPGRADED THE INTERCOOLER AND HARDPIPES, NOW THE CAR SMOKES ALOT SMELLS LIKE OIL, FRIEND TOLD ME THE CHANGES MUST HAVE CHANGE THE OIL SENSOR , I AM GOING TO HAVE ALL CHECK OUT BUT I HAVE TO WAIT UNTIL APRIL..WHEN I AM WORKING
numbers on the rim are BT 220 / 8J x 17H2 / ET35
says "moda sport" on the rim, and just "moda" on the center
The only information I have been able to find out is that this was a private label made for Tire Rack.
If anyone could point me in any direction to try to find this wheel, it would be greatly appreciated.
