"Friends Don't Let Friends Modify Cars"
Mr_Shiftright
Member Posts: 64,481
in General
That's the title of a recent article in Inside Line, written by Edmunds' own Jack Lanier.
The gist of the article was that the author has seen so many failures, break-downs and disasters with modified cars, to say nothing of degraded rather than upgraded performance, that he suggests, at the end of the article, the following:
"My best advice is this: if you don't like your car and want to make it better, buy something else".
What's your opinion of this point of view about major tuning & modification of stock cars?
MrShiftright
Co-Host
It's not for lack of trying, it's just that folks tend to trust their buddies a little too much, and their buddies are passing on 10 year old info that was faulty to begin with....and you see the potential for problems.
I applaud Edmunds for opening a group of topics like this - we can put out heads together and give people the straight scoop before they spend the money and make the changes...
After you've spent crazy money and spent all weekend making changes isn't the time to find out that you should have done things differently.
Perhaps he needs a chance in a well-built/tuned car instead. Just like there are lots of badly tuned or aftermarket built vehicles out there, there are lots of good ones as well. But the problem is that most of what goes on in the aftermarket don't make it into mainstream news. Very rarely do they--or a single individual--invite journalists to test drive their cars or have big press releases. Most of the time, the journalists in the aftermarket rags have to go out looking for them.
Although I don't have any first hand experience with the following, two examples (out of much more) of exemplary work are:
- Mark Stielow's (who's a GM engineer by day) cars has been prominently feature in Popular Hotrodding and other GM specific magazines, and even earning him a place in BFG's magazine ads.
- Jay Leno's cars built by his own Big Dog shop in Burbank, CA. A recent one that was displayed at SEMA and which got the attention of GM as well as used aftermarket GMPP parts is his sleeper-of-a-Toronado. Looks exactly like a Toronado right down to the tires, but sports a modified C5 chassis, rear transaxle, and 1070 hp and similarly torque (Mark Stielow's recent 64 Malibu also makes 1000+ hp with just 10 psi, btw)
I know that simply throwing out numbers does not a reliable car make, but one would assume these have to be as they are used a daily drivers by their builders, not to mentioned the fact that some have been worked on for years.
In fact, if anything, doesn't Edmunds' own feature article of the 690 hp SVT/Ford Racing-aftermarket parts Mustang at http://www.edmunds.com/insideline/do/Features/articleId=104572
contradict such statements as "if you don't like your car and want to make it better, buy something else"?
The only time I would agree with that statement is IF the features you want are already available. i.e. don't buy a car with a lower output base engine then modify it later to produce more power when you could've had the optional higher output engine instead. (caveat being unless there's a huge price difference)
So I think the article is valid if it presumes that any freshly built tuner car is subject to problems. If Jay Leno has been de-bugging his car for a year, sure, it's going to run a lot better after 12 months than it did the day they first built it.
It's cheaper in the long run, and much less stressful, to build on a common platform, than to be a total adventurer so you can have the world's only Northstar-powered 1996 Neon...
Bear in mind, I'm talking about average guys and girls modifying their street cars/daily drivers, and not building one-offs with Jay Leno's budget.
Conversely, I have done quite a few modifications on cars in the past. Changing the car can be quite fun and rewarding. So I guess my opinion boils down to, if you can afford it and you are not an addict to speed or alterations, have fun.
And aren't most of the "upgrades" in the bling-bling catagory anyway?
When you bolt something onto a car for one purpose, it affects any number of other things, sometimes not in a good way. You want stiffer springs, fine, you got 'em, and your car is lower and stiffer and feels good on the straight and smooth--- but then you hit a bump and pogo-stick across the road or you break your stock shocks in half. You didn't want that.
The Malibu is limited to "bling-bling", and for the record, I won't ever be referring to anything like that in any of my posts in here...
From mild to wild, you can take a stock WRX or WRX STi and make crazy power - same with many import and domestic vehicles, like my Ion Redline - several aftermarket companies are begging for owners to lend them their vehicles so they can trial fit intake and exhaust systems, and run computer programs.
I'm afraid, and no offense meant, but when you have a very efficient (to begin with) grocery-getter, rental car fleet type vehicle, about the only things out there are floor mats, door edge guards, and fuzzy dice.
Chevrolet has done an incredible job of wringing power out of the car while maintaining fuel economy - that mid size car market is a pretty hostile and competitive marketplace - there's little or no room for improvement on "efficiency" and very little power upgrade potential, short of a roots-type supercharger.
I don't think there'll ever be a perfect car for anyone that cares enough to notice details. Also, I won't be able to afford a great car when I buy one, but a year or two later I'll have the means for more... so I can make my car be like the more expensive one I could've bought then.
Yeah, big wheels can mean slower acceleration - if they have a greater rotational inertia. They don't always. But they do give you more grip, and some of us like that.
In any case, lots of people know that lowering springs need shocks designed for those spring rates, that overly large exhaust pipes are bad unless you're turbo'd, and that air intakes are only good for a couple of hp, up high in the rev range.
We have a ton of easy-to-get information from reputable magazines (well, some of them) and online forums where people share what's worked and what hasn't, for specific cars.
And while I haven't done it, I'd get brake upgrades if I could afford it. I drive up and downhill a lot, and I've experienced brake fade before. Soon I'll get new pads and fluid probably, but I weren't a student I might upgrade the front brakes from the base Sentra's to an SE-R's.
Then there are examples like a WRX wagon given the STi treatment, and a 3-series wagon turned into an M3. I like that.
These are still in what I consider the envelope of stock though, the modifications are largely factory parts.
Even with aftermarket parts, there is an envelope of modification, usually I find an intake, an exhaust, and a chip calibrated to work with those modifications seems to have very little effect on the car or any of its systems reliability. I also generally change the brake pads to something that doesn't fade on a track day. I think a plus-one or plus-zero fitment on the tires or wheels helps alot. The track tires are 225/50 while the street tires are 205/60. Given all of these things, I would still consider this car to be stock. These minor modifications shaved time from my lap times, and I still get the same gas mileage (unless I am running the R compound tires, which i wouldn't do).
Cars have gotten so bland and so designed for the least common multiple, personalization is pretty easy. Going from those 205/65 15s to 225/50 17s will wake up the handling, and the incremental increase in wheel weight is low when going with a lightweight alloy. Adding a sway bar may get rid of some of the engineered in understeer and make the car actually fun to drive. Slamming the thing to the ground though is detrimental, especially on cars like the classic SE-Rs that had limited suspension travel from the start.
Once you start to make really dramatic modifications to a car, you are essentially creating a new car. Fieros being used as kit cars are really no longer Fieros, and no one would say a Lotus is a Toyota even though it has a Toyota motor (or an Isuzu one). Additionally, sloppy, poorly planed or engineered changes by a tuner doesn't mean an idea isn't sound, just poorly executed.
Today's cars offer a great deal of performance, but they are designed to appeal to too many different people. A series of well proven, well designed, and well implemented upgrades or modifications take a car from something that is okay to drive to something that is actually enjoyable or fun to drive.
Then there are poorly thought-out things, e.g., putting some sort of forced induction on a vehicle to tremendously increase engine output without beefing up the rest of the driveline and suspension to handle it.
But on the other hand, there ARE mods that have been extensively tried out by the aftermarket/modding community and which have tremendous positive benefit for a vehicle. For example, on my Mazda 6 (s sedan/5-speed AT), there's a known tendency for the transmission to run a bit hotter than it should, so a lot of owners add in-line transmission coolers. There's also a CAI/MAF map customizer package that's relatively easy to install, has apparently very good support from the manufacturer, has apparently solved the problem with engine faults being generated due to the way CAIs alter the fuel/air ratios, and now has several hundred installs in the field over the last couple of years with no apparent problems.
In short, I guess I'd say that there will always be experimentalists, and there will thus always be failed experiments; and, too, there will always be the thoughtless and the stupid, so there will always be people doing mods to their cars that make no sense whatsoever. But in this day and age, there are so many people modding cars, and so much shared information, that for many cars there's a huge number of mods one can do with great confidence that he will be enhancing his vehicle's performance.
For those who don't like to modify, I say enjoy your car and be well -- but some of us just get bored seeing ourselves coming down the road, and most of us like something to go a little better, stop a little better and handle a little better. Moderation is always key, at least for a daily driver. But for a Sunday ride, the sky's the limit. Just think what hotrod shows would be like without any hotrods! (Or SEMA, or Hot Import Nights, or the local drive-through).
Passion about cars is what drives these forums, and most of what comes straight out of the factory ain't passionate. Even Mercedes has AMG....
"Friends should advise friends how to properly mod their cars".
I personally think it's time for this thread to be transferred to the infamous archives!
'06 Civic LX coupe
'11 BMW 335i coupe xDrive
'13 Honda Accord sedan (wife's car)
Little Ferrari Lost (Inside Line)
Many of the new cars are in desperate need of a larger exhaust, better header, free-flow CAT, etc. You 'll see considerable power gains with just those simple bolt-ons as well as a cold air intake and such. The reason the new manufacturers are conservative with those is because they want to get good gas mileage and have the car be relatively quiet. A bigger exhaust and better header would make the car louder (and reduce sales). A cold air intake alone makes the car much louder at WOT. My car gained 12.4hp at the wheels with only a cold air intake and 7.5lb-ft of torque. I had it dynoed before & after at the same shop (the same day). Then 2yrs later the header added another 5.8whp. There is also a plethora of aftermarket electronics and computer programs out there to load new fuel maps and other things to your computer to gain horsepower. This of course affects your gas mileage which is why it's not done by the manufacturer. There is ALWAYS mods to be done to improve the power of your car, unless you are talking about F1 or something that cost $1.3M to make. I bet even those can be modified even more but the rules don't allow it.
My friend had his '04 S2000 ECU reprogrammed and got 13hp out of it. He also installed the same 2.5" exhaust I have on my Integra (but made for his car), and got 11.8hp at the wheels with it. Subaru WRX and STI easily get 30whp with an intake, header & exhaust (or I/H/E as we call them).
Aftermarket parts companies make hundreds of millions $$ year after year. Do you think it's all because none of their parts improve performance?
'06 Civic LX coupe
Chintan Talati
also, some stock parts are made for luxury and noise reduction. meaning you can eliminate some things and add others because they wanted to please everyone with their car.
But often these are project cars, bought used or inherited, and much can be learned from a little tinkering.
I wouldn't go overboard, but it can be a positive/learning experience for those mechanically inclined and interested.
People only get into accidents because they are accidents. Sure there are quite a lot that would involve modified cars, but that shouldn't be a reason to stop you from modifying your car as you see fit.
What ever happened to personalization, customization, and making it truly your own? Is it wrong to be different?
It's the quality of some of these aftermarket parts that just isn't up to par. Quite often you'll see "For Show/Off Road Use Only" right on the package, yet you just know these people aren't taking those items off the car when they drive on public roads.
Things like poor taillights could be a safety hazard. In fact I believe many of them were recalled for that reason. Too-dark tint means you can't see when you're parking. Or oversized wheels with a weight the suspension isn't meant to handle.
Those things are wrong, yet they're common.
What is the point in raising a fuss and a complaint over something as trivial as human will to do as they please?
I'm not tryin' to oust you or anything, I'm just saying that those individuals know the consequences for their actions yet still have the impulse to have a fast affordable car.
-mike
To make blanket statements about modifying cars is a misnomer and exhibits an equal level of ignorance. Many parts are labeled "for off-road use only" because the company doesn't employ a fleet of lawyers to flock to their rescue when some [non-permissible content removed] wrecks himself on the road and tries to blame the aftermarket parts. That, or they are "illegal" in states such as California where pretty much nothing short of changing your oil is permitted. This label certainly doesn't indicate that the parts are unfit for daily use. Think about it, performance parts are meant to stand up to hours of track driving, hundreds of 1/4 mile passes, etc. Do you really think the daily commute is too much for them to handle?
Many people are disillusioned about what they buy. The author of this article hit it dead on the nose... if you spend a few grand on something, of course you're going to think it helped the car. Anybody with half a brain knows the proof is in the pudding though. Run laps with an electronic timer before and after a suspension upgrade to evaluate its worth. Run some 1/4 mile passes before and after an engine upgrade to determine how much faster you are. **gasp** Fork over a few bills and get some dyno time. There is always room for improvement. You just have to distinguish improvement from change.
and my blog on a current performance up date on a gm product that has no effect on mpg or warranty.
