Mazda Miata Problems and Solutions
                    Talk about Miata problems and share solutions with other owners here.
I just bought a 2001 MX-5 AND I love it. However my roof top latch on the right side will not lock into place. I took it to the dealer but they said it would cost me $200 dollars and that it is not covered under the extended warranty. Should have guessed that, I was wondering if I order the part myself would a person with no car expereince be able to install it. Unless someone has some other trouble shooting ideas. Thanks.
Manual indicates an fan belt alternator issue.
What else should I be looking for?
I just bought a 1994-Miata with 92k miles.
I am thinking to have Timing Belt and Water Pump replaced
eventhough the user's manual recommends to change Timing Belt at 105k miles, is it too early to replace timing belt at 92k miles ?
My second question: when timing belt is replaced, is it a good idea to also replace the tensioners (tensioners really exist around some belts ?) ?
I am not sure if the Miata has any drive-belt tensioners or any timing belt tensioners ?
One last question please: what can go wrong or get damaged if any of the tensioners fail to work during driving ?
Thanks so much.
Miata Lover
Tensioners should be fine. My advice is to putt along, until either the water pump leaks, or the belt breaks. Too often, preventive maintenance is used by mechanics, and especially dealers, to screw the owners. Last year, the A/C failed on the Lexus. I was told by a mechanic that I needed a new evaporator and stuff, and the cost was $1,200. I knew that the only obvious problem was a small plastic part that fell into the passenger side, so I asked him to reinstall that part, and that I'd think about that big repair. Cost me $200. The A/C is working perfectly now. If I wasn't such a dummy, it should have cost me nothing. Watch out for the crooks......
Chuck
("What Tensioners replaced at 92k miles ?").
I'd like to have another question:
- if the timing belt breaks when driving on the Miata/94, what can go wrong to the car or the engine (consequences, etc.) ?
or please advise me of some pointers (website, books, etc.) from where I can find out the reliable answer.
I've learned from somepeople that certain car models/engines do not get damaged at all even when timing belt breaks.
Thanks again.
It's easy if you have four arms. Seriously convertible top installation is a complex task involving extensive fitting, gluing, measuring and stretching.
http://www.gates.com/downloads/download_common.cfm?file=GatesTBR.pdf&folder=brochure
I bought my Miata with 124,000 miles on it and I have no idea when the timing belt was last replaced (if ever). Someday, maybe I'll get in there and inspect it, but it's not something I'm freaking out about. Now if it was a Honda....I'dve had it replaced months ago, just to be sure.
I have a 94-miata and it is running fine now.
It's about time to replace its timing belt and water-pump.
I already bought the parts from Mazda dealership, I am debating whether to pay some mechanic to do this job (labor cost of $195) or do it myself.
I am not an auto-mechanic but I could be very handy when fixing things around the house and minor things on the car. I bought a Miata workshop book which has all the detail instructions to replace timing belt and water-pump.
My question is:
- is it worth (time, effort, and any risk of damaging the car ?)
to do this job myself instead of giving it to a mechanic ?
- if you had experience of doing such a job please share what you
learned from it (what to watch out for ?, what to not overlooking ? ).
- I expect that this job will take at least 5 hours (for me-), it is about right?
Thanks much in advance!
Miata lover.
I am also looking for a bargain deal on the Robbins top with glass window.
If you are really considering doing it yourself, let me recommend to you Keith Tanner's Miata projects book. In it he has details / photos on how to do the job. Buy it and read it and decide if its still something you want to mess with.
BTW, it'll help to lube up the new boot with some motor oil (or whatever you're using for turret oil) before trying to slip it on.
I don't remember the website now, but I found one that said the Miata has a 'non-interference' engine. In other words, it has enough clearance so the valves don't pound holes in the pistons when you do what I did.
It took me a while to figure out the belt was the problem. It didn't really break. It just lost a bunch of the notches on it. When I took the cover off the cam-sprockets and turned the ignition and they didn't move, I knew what was up.
I read all sorts of horror stories about how hard it was to line the cam sprockets, the crank gear, and the belt. Every site said to be sure and mark all these or even split the old belt in half down the middle before taking it off to maintain this alignment while putting on the new belt, but my alignment was already toast. The instructions I got in the little nothing pamphlet that came with the belt (I think I got the Gates kit with new tensioners from O'Reily Auto Parts - part # TCK179) helped the most. They said exactly how to line everything up with the marks on the engine.
My Miata runs great now.
Jimmie
I am in the process of replacing my Miata (94')'s timing belt. I am having trouble to remove the CrankShaft pulley bolt (the big 21mm bolt). I cannot unscew this bolt by turning it, a couple questions:
- I am not positive about turning this bolt counter-clockwise or clockwise for unscrewing it - which direction is correct ? It's already very tight.
- when this bolt is turned, the crankshaft turns with it together, how do I lock the crankshaft from turning ?
My workshop's book tells me this but I don't quite understand:
" Manual transmission cars (which is my car) can be put in first gear and have their roadwheels chocked to lock the crankshaft".
What is the roadwheels and how (easy/hard?) to chock them in order to lock the crankshaft ?
- I also accidently turned the left cam-sprocket (without turning the second cam-sprocket and the crankshaft grear), what is the correct procedure for lining it up with the right cam-sprocket and the crankshaft ?
( using some the marks on the engine ?)
I remember the original orientation of the left cam-sprocket before I turned it (the angle-degree relative of clock's position of letter E on left cam-sprocket), if I turn it forward (clockwise) back to the original orientation, would that be correct ?
Any tips or pointers to the recommended procedures (website, etc.) would be very very appreciated- I am stuck in this process of replacing timing belt (my first time) !
Thanks in advance!
-Miata lover-
Try http://www.gomiata.com/robsoftop.html for soft tops and watch for their discount sales. I am also in the market for a new soft-top.
by-the-way, the website http://www.miata.net/garage/timingbelt.html gives excellent instructions with clear pictures of how to replace timing belt and water-pump, I finished this job and my car is back running.
-Miata lover-
So I decided to order a new double-core radiator from PBC. I'll probably take out the old radiator tomorrow and put the new one in whenever it comes in...it should be pretty easy form everything I've read but we'll see.
see http://www.gomiata.com/newrobnozgla.html .
Anyone has experience or has knowledge about the quality/price of this top, and how it looks in the color Tan (dark, moderate Tan, etc. ?) ?
Basically I am looking for a new top with glass window, no-zipper,
and the color Tan.
-MiataLover-
thanks for the tip. It's a brilliant idea and takes no physical labor.
I have a 1994 Miata that seems to miss or hesitate (looses power)once it warms up.I am planning on rpl plugs,wires and fuel filter.The car has 80,000 miles on it.any ideas?.Thanks
If my is an unusual low gas mileage then what can I do to improve my gas mileage ? I already replaced sparkplugs, sparkplug wires, air filter, and fuel filter.
Thanks in advance!
Miata lover.
If you're only getting 20 mpg, something is wrong.
I LOVE MY MAZDA MIATA.
NOW, I WENT TO THE MAZDA AUTO BODY PARTS DEPARTMENTS AT A MAZDA DEALER.
THEY HAVE ALL PARTS ON THE COMPUTER THERE.
I HAD AN ACCIDENT IN MY FRONT LEFT BUMPER , DRIVERS SIDE.
I HAD TO TAKE OFF MY BUMPER AND EVERY THING BEHIND THE BUMPER AND TO BUY SOME OF THOSE PARTS.
THEY GAVE ME PRINT OUT SHEETS WITH PHOTO PARTS AND PARTS #S AND THEN I GOT PRICES FOR THE PARTS THAT I NEEDED.
THERE ARE AFTER MARKET PRICE ON TH INTERNET BUT NO PHOTOS.
I WRITE IN CAPITAL LETTERS, SO I CAN SEE THEM BETTER
I AM A 63 OLD FEMALE AND THIS IS THE FIRST CAR PROJECT THAT I HAVE TAKEN ON.
PRECIOUSE
