Visitor Agreement.
John
Timothy is great for his many personalities depending on who he is posting too. Must be associated with a lack of proper upbringing. He was born a poor dumb child.
one, no one has a problem with ford/dodge/toyota fans posting here (here being the chevy silverado thread) as long as it contributes to the thread. bashing and personal attacks do not do this.
two, the only ford/dodge/toyota threads you'll find me in are the ones that request an opinion on the big 3 and tundra. if it has to do with chevy, i tend to take interest.
there's a huge difference.
tim - please do us all a favor and stop baiting f150 into personal attacks on this thread. it works both ways, man...let's keep the bashing and personal attacks where they belong...
bco
Can you give us some details on this F150 that you have (year, options, upgrades, etc)? I'm just a little curious is all.
On another note.
Has anyone else noticed this, but when I'm facing a new Silverado head on and they have their turn signal on, it is awful hard to see the orange turn signal blinking when the bright yellow daytime running lights are on. They are right next to each other and it's hard to make out the turn signal. Has anyone tinkered with their daytime running lights? Lowered the wattage, used a different color, etc?
-David
like a fly that ya can't get rid of I guess?
LOL
as much as I love this stuff...I'll wait until it comes over...
- Tim
Tim - i was thinking more on the lines of vaseline or KY jelly for the lube hahaha not crisco. But thanks for the suggestion
John
John
Jaumen: Heres my scenerio with my 1500. Order accepted 3-14
TPW: 4-10-00
Called 4-3-00 GM didnt know the TPW
Called 4-10-00 to verify dealers TPW.
GM said truck was built
4-10-00 Truck was delivered to the dealership. Truck was built 4-6-00.
I picked it up 4-29-00
Hope this helps a little
Ryan
Hey Dean you should use this purple M-1 chassie lube, it will match your oil color. LOL
pat
Red grease from checkers
Blue oil filter (pf59) from K Mart.
Boy, that's a lot of driving for a lube and change oil job. Maybe I should buy more than one of each....LOL
Dean
You can get the extension hoses at AutoZone or anywhere grease guns are sold and get a connector nipple at any hardware store (take one of the hoses with you to the hardware store and get the size that fits). Sure makes it easier to have the additional reach of the extension. Get your wife or "significant other" to hold the gun while you handle the cleaning and greasing - it'll be a lot easier on ya.
John
link you posted. i thought they also had the
purple stuff in grease form. if not i'll stick
with M1. obyone, i'm curious, are you using the
purple stuff in the rear as well? i've talked to
a few weekend racers that run the local roundy
rounder type tracks with super modifieds and they
all swear by this stuff.
...red
AutoZone here in Edmond,OK had at least 15 difference brands and kinds of chasis grease. Much larger selection than any other store I've seen. AutoZone was even competitive with WalMart on the M1 oil - I was surprised by that. AutoZone also had the M1 syn 75W90 gear lub for $6.99 a quart - beats the ~$25.00/quart for Mr. Goodwrench.
John
I do (11) zerks. On most, I hold the back side of the grease barrel in one hand, use the other to hold the hose on the fitting, and then smash the lever against the frame with the hand holding the barrel.
- Tim
over sharp bumps at slow speeds. my dealer was
gonna swap parts from another new truck that was
tight, but gm put the red light on the repairs
stating that it would end up doing the same
thing. after going through the BBB they promised
to have a fix developed within 60 days and would
then do the parts replacement needed to eliminate
this annoying problem once and for all. it's been
about 2 months now so i should be getting a call
soon.
pat
pat
John
John
pat
How do we find out which Assembly Plant unit will get built at?????
I heard you could specify which Plant you wanted to build - Doubt It!!???
Planing to try to take Assembly Plant Tour at either Pontiac or Ft. Wayne mid-Oct.
75v
75V you cant specify the plant.
Ryan
Stan
Ryan
Mark
Dean
Is it a nice place?
Ryan
John
haha
Ryan
Dean
Product Number 53201-0
NLGI Grade 2
Soap Type Lithium Complex
Structure Smooth; Slight Tack
Color Red
ITS RED not purple just to let you know the correct answer.
Ryan
red
Ryan
Grease-red
Oil-purple
oil filter- blue
OK?
Dean...LOL
where's f150 BTW? I'd hope the lurd be lurking...
sometimes I just crack myself up...LMFAO!!!
Also anyone ever pull out a small tree stump with their truck??? (tow hooks and chain?) I have a small stump that needs removal i figure the truck would be the best way to remove it.
Ryan
Grease gun. Get one with a trigger handle and carries a full cartridge. Best investment I made. Most grease guns have a long lever making hold the hose onto the zerk with one hand and pumping the long handle with the other very difficult. I've have the same type of grease gun but comes with a 3" trigger making it soooo much easier to pump the grease. that way, the wife stays clean and in a better mood.
Dean
I have my dads S-10 but no tow hooks. OOO just got an idea. Ill use my moms blazer haha it has tow hooks she will never know. Its not a big stump i am just lazy to dig it out. I will use a tow strap and my tow hooks. Hopefully no recoil. Might have a smashed windshield or headlight and grill when im done but that damn stump will be gone haha. Ill post pics after i remove it.
Thanks dean ill probably go out looking for a grease gun tonight.
Ryan
Good Luck
- Tim
